  3. MySensors gateway and network reliability
20 Posts 7 Posters 2.8k Views 7 Watching
  • alowhumA
    alowhumA
    alowhum
    This is actually a good reminder to implement a watchdog on the gateway :-)
    // Update:
    Here's my new code:
    * The Candle receiver acts as the bridge between the Candle devices and the Candle Controller.
    * It only allows communication with other Candle devices that use the same encryption password as it uses itself.
    * When you install the Candle Manager, a random password is generated for you. If you ever want to change the encryption password used by your network, this can be done in the Candle Manager settings.
    * Be warned that you will have to re-create this receiver as well as all your devices, since they will all need to have new code with the new password in it.
    * If you have already installed the MySensors add-on, please temporarily disable it before creating this receiver. Otherwise the MySensors add-on may try to connect to it during the creation process, and thus disrupt it.
    * SETTINGS */
    // You can enable and disable the settings below by adding or removing double slashes ( // ) in front of a line.
    #define RF_NANO                                     // RF-Nano. Enable this if you are using the RF-Nano Arduino, which has a built in radio. The Candle project uses the RF-Nano.
    /* END OF SETTINGS
    // Enable MySensors debug output to the serial monitor, so you can check if the radio is working ok.
    #ifdef RF_NANO
    // If you are using an RF-Nano, you have to switch CE and CS pins.
    #define MY_RF24_CS_PIN 9                            // Used by the MySensors library.
    #define MY_RF24_CE_PIN 10                           // Used by the MySensors library.
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    //#define MY_RF24_PA_LEVEL RF24_PA_MIN
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Mysensors advanced security
    #define MY_ENCRYPTION_SIMPLE_PASSWD "changeme"      // The Candle Manager add-on will change this into the actual password your network uses.
    //#define MY_SECURITY_SIMPLE_PASSWD "changeme"      // Be aware, the length of the password has an effect on memory use.
    //#define MY_SIGNING_SOFT_RANDOMSEED_PIN A7         // Setting a pin to pickup random electromagnetic noise helps make encryption more secure.
    // Mysensors advanced settings
    //#define MY_RF24_CHANNEL 100                       // In EU the default channel 76 overlaps with wifi, so you could try using channel 100. But you will have to set this up on every device, and also on the controller. You can even try 115.
    //#define MY_RF24_DATARATE RF24_250KBPS             // Slower datarate increases the range, but the RF-Nano does not support this slow speed.
    #define MY_RF24_DATARATE RF24_1MBPS                 // This datarate is supported by pretty much all NRF24 radios, including the RF-Nano.
    #define MY_SPLASH_SCREEN_DISABLED                   // Saves a little memory.
    #include <MySensors.h>                              // The MySensors library, which takes care of creating the wireless network.
    #include <avr/wdt.h>                                // The watchdog timer - if the device becomes unresponsive and doesn't periodically reset the timer, then it will automatically reset once the timer reaches 0.
    // Clock for the watchdog
    #define INTERVAL 1000                               // Every second we reset the watchdog timer. If the device freezes, the watchdog will not re reset, and the device will reboot.
    unsigned long previousMillis = 0;                   // Used to run the internal clock
      wdt_enable(WDTO_2S);                              // Starts the watchdog timer. If it is not reset once every 2 seconds, then the entire device will automatically restart.
    	// The receiver does not have any extra children itself.
      if(millis() - previousMillis >= INTERVAL){        // Main loop, runs every second.
        previousMillis = millis();                      // Store the current time as the previous measurement start time.
        wdt_reset();                                    // Reset the watchdog timer
    * Copyright (C) 2013-2018 Sensnology AB
    * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
    • alowhumA alowhum
      // Update:
      Here's my new code:
      * SETTINGS */
      /* END OF SETTINGS
      #ifdef RF_NANO
      @alowhum MySensors resets the watchdog every time loop() is exited, so there is no need to call wdt_reset() unless you do something that takes a long time. If you do stuff that takes a long time you should call wait() instead, so messages can be processed.
      alowhumA 1 Reply Last reply
      • Nick WillisN
        Nick WillisN
        Nick Willis
        So I should be able to solve my gateway crashes easily by just doing the following in my gateway code:
        And that's it?
        NeverDieN skywatchS 2 Replies Last reply
        • Nick WillisN Nick Willis
          And that's it?
          @nick-willis Sounds like it.
          My gateway runs on an ESP8266, which has its own watchdog enabled by the default ESP8266 Arduino code. i.e. on an ESP8266, even the blink demo program has watchdog enabled without having to do so explicitly. But on an AVR platform, you need to explicitly enable the watchdog or it won't be active.
          Maybe the mysensors code should enable watchdog by default? I bet a lot of people are running without a watchdog and don't even know it.
            alowhumA
            alowhumA
            alowhum
            @mfalkvidd said in MySensors gateway and network reliability:
            Very interesting! If I don't call wait() manually, when does the library process messages? Also at the end of the loop?
            Sounds good to me! What is the code/memory overhead of doing this?
            If the wdt_reset function is already being called in every loop, doesn't that imply that Arduino also already loads the entire watchdog code? Otherwise, wouldn't that cause a "function not found" error?
            • zboblamontZ zboblamont
              @neverdie No offence intended, but I gathered watchdog was tried and failed on at least one installation, it appears to be the NRF comms medium itself which is common to both complainants, neither of which your setup uses.
              Or were you suggesting an external watchdog (if not already trialled) might shed some light on their issues?
              @zboblamont What is it that you recommend instead? Maybe (?) there are other issues, but my take is that, at the very least, his watchdog isn't working. So, why not start with that? At least then maybe he wouldn't be locked out of his system while he's on vacation.
              But if you think he should put his effort elsewhere, then where exactly, and why?
              • alowhumA alowhum
                @alowhum said in MySensors gateway and network reliability:
                Correct
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @neverdie My query was that having read @skywatch previously failure with WDT, whether an external device offered a different methodology which the soft version did not address.
                  Never experienced the problems these lads are trying to resolve as use different comms hardware which are 100% reliable, so no need to learn about WDTs. As I understood it the WDT initiates a reset, which if it clears the problem through re-initialisation implies a lockup on the comms to the NRF or within the NRF itself, since the processor and sketch should be fairly standard.
                  Why SOME have problems but not others is a curiosity.
                    And that's it?
                    skywatchS
                    skywatchS
                    skywatch
                    @nick-willis
                    I also have " wdt_reset(); " in the loop part. I thought that would be needed to reset the WDT, but maybe I misunderstood?
                    • skywatchS
                      skywatchS
                      skywatch
                      I just thought I'd share this with you all in case someone has an idea about it.
                      This morning I got no response from the pi via http or ssh. Usual situation when it 'crashes'. But this time I noticed that whilst everything was still powered on the network socket leds on the pi3 were out. Both of them completely unlit.
                      So maybe the issue is with the networking on the pi? It would explain why both http and ssh always die at the same time. Maybe if someone else gets another outage they could check to see if the same condition applies?
                      Another thing was that the 'act' led was flashing 7 times repeatedly. Apparently this happens if 'kernel.img' cannot be found. Anyone have an idea on why kernel.img might suddenly not be found on a pi running from ssd?
                      • N
                        N
                        NielBierman
                        If you really enjoy fiddling with connection problems and gateways freezing you should try using the gsm gateway. At first it froze up every day or two. I now run a second mcu just to check connectivity to mycontroller and resetting the gateway when it fails. This sometimes happen a couple of times a day.
