1.1k Posts 105 Posters 792.9k Views 98 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    Finally I am starting to do a little electronics again.. First thing is a prototype assembly of RASLE (Rpi Arcade Sound and Light Extension). It's a custom made arduino "coprocessor" for a raspberry pi, built into retropie arcade cabinets. It's a joint project with a couple of friends that are building arcade cabinets (I built mine a couple of years ago, I think that there is pictures earlier in this thread).
    Features:
    • stereo 3W class-d amplifier
    • atmega328p
      • 3 pwm channels for LED strips
      • a port for WS2812 type led strips
      • pwm channel for fan
      • output for a relay to control mains input for the box (let the rpi shutdown cleanly, before disconnecting power)
      • 5 button inputs (shared between rpi and atmega)
    • franz-unixF
      franz-unixF
      franz-unix
      Hi, finished two nodes based on the same multi-purpose battery powered pcb (all the documentation here)
      One is a door / window sensor based on a Reed switch.
      If someone is interested, the dedicated wiki page contains the detailed build instructions.
      The other is a soil moisture sensor.
      For this one, the wiki page is here.
      Happy Easter, even if at home!
        Anyone know or have experience with how well the underlying capacitive soil moisture sensors hold up over the long term? Clearly they're better than the cheap conductive electrode kind, which for most people don't last very long at all, but I recollect reading that water ultimately invades the PCB enough on even the capacitive designs that it goes kaput. Maybe they've been improved since then or maybe there are now known tricks for how to fortify them against that happening?
        franz-unixF BearWithBeardB berkseoB A 4 Replies Last reply
          franz-unixF
          franz-unixF
          franz-unix
          wrote on last edited by franz-unix
          #933
          @NeverDie Good question. My is too young (2 days) to say something.
          Here a possible solution. See at about 9:50
            BearWithBeardB
            BearWithBeardB
            BearWithBeard
            wrote on last edited by BearWithBeard
            #934
            @NeverDie The guy with the swiss accent once said that you can coat the capacitive soil moisture sensors with a water resistant varnish or put it inside a waterproof shell.
            https://www.youtube.com/watch?v=udmJyncDvw0
            starting at ~7 mins.
            @franz-unix Ha, Great minds think alike. :D
            franz-unixF YveauxY 2 Replies Last reply
            • BearWithBeardB BearWithBeard
              franz-unixF
              franz-unixF
              franz-unix
              @BearWithBeard :+1: :grin: I love the video of the swiss guy!
                @BearWithBeard ah, now I know who 'the guy with the Swiss accent' is :)
                • sundberg84S
                  sundberg84S
                  Today I have a very strange problem. I have created a new outdoor sensor which is powered by a 240v-5v HLK module. Its working VERY intermittent and should send data every 5 minutes (no exceptions).
                  Whats even more strange is that, when my outside node (called multi) is working, I have a battery powered node (sleep 15 min - send - sleep) that seems to go down, and the other way around (not always, but quite frequent - could be very unrelated but I have notised it a couple of times now).
                  Anyhow, Im very glad i build my logger node - works great once more. I use this so often and really recommend all with a bigger network to have some sort of mobile debugger. Most of the times I use the bluetooth module (2xAA powered) but at this point I have my node on my workbench powered by a USB adapter (orange wires). I then parasite power from the node to run the debugger and is now logging everything to a sd-card.
                  • mfalkviddM
                    In case anyone hasn't seen the logger before, it is available at https://www.openhardware.io/view/532/The-Logger-Machine-Short-and-long-term-serial-logging
                    • sundberg84S
                      sundberg84S
                      #939
                      Another picture from today:
                      Just started working with coincells - CR2032 to be exact. Anyone knows why the battery % varies with the given temperature? Are those coincells very temp. dependent or I have made a misstake somewhere... ???
                      Nca78N YveauxY 2 Replies Last reply
                      • sundberg84S sundberg84
                        They don't like it when it's too cold. Check page 4 :
                        https://data.energizer.com/pdfs/lithiumcoin_appman.pdf
                          @sundberg84 looks like you can ditch the temperarure sensor and just use the battery voltage to measure the temperature :muscle:
                          • C
                            C
                            cloolalang
                            433 MHz ESP 32 MQTT Gateway with proper antenna
                            • YveauxY Yveaux
                              sundberg84S
                              sundberg84S
                              @Nca78 - Well, its been around 14-17dgr C today, so almost room temp. Strange
                              @Yveaux - hahaha, best answer! Saving uA!
                                Yesterday received the PCB. Today assembled for testing this battery-powered nRF52-based passive infrared motion detector:
                                I
                                I
                                idanronen
                                @NeverDie sorry if it's a bit off topic, but I see that 10 pin ARM box connector you use in several of your designs, and I was wondering if it offers anything extra in addition to the regular 6 pin programming pins. I'm asking specifically because I want to try some of your nrf52832 designs, but would like to avoid spending extra money on special connectors and cables. Thanks!
                                • I idanronen
                                  #945
                                  @idanronen No, nothing extra. It just conveniently and transparently interfaces to the ribbon adapter cable used by the Nordic nrf52 dev kits for programming external nRF52 MCU's. If you want to roll-your-own, you can do away with most of the pins. I myself migrated to a smaller connector in later designs.
                                  I 1 Reply Last reply
                                    I
                                    I
                                    idanronen
                                    wrote on last edited by idanronen
                                    #946
                                    @NeverDie thanks for clarifying!
                                    So for example in the mini breakout board (https://www.openhardware.io/view/471/Ebyte-nRF52832-Small-Breakout-Board) I could just align the 6 pads and use a standard 6 pin pogo programmer right?
                                    • I idanronen
                                      #947
                                      @idanronen Yup. If you have more questions, you should probably ask them on a different thread than this one, as it's off topic here.
                                      • monteM
                                        monteM
                                        monte
                                        Offtopic in terms of mysensors platform, but somehow tangent to a home automation. I've made a batch of concrete switches/push buttons which are in this case simple buttons with led backlight and all the logic is located centrally in distribution box, based on KNX ABB module. But I am planning on making smarter and more complex version which could use Mysensors as its transport.
                                        and a photo of insides of one of the prototypes at first stages of development
                                        MatiasVM NeverDieN 2 Replies Last reply
                                        • monteM monte
                                          MatiasVM
                                          MatiasVM
                                          MatiasV
                                          @monte Nice work! I love the looks of the concrete switches, do you have some links or useful information on how you did it.
                                          I have a project of a doorbell that could use such a switch.
                                          HomeAssistant
                                          MyController.org
                                          MQTT GW WIFI
                                          FOTA/MYSBootloader
