  3. Humidity/Temp Sensor Issues
dht22nrf24l01mini pro
12 Posts 8 Posters 7.4k Views 3 Watching
  • F Offline
    F Offline
    FUZNUTS
    wrote on last edited by FUZNUTS
    This is my second humidity sensor.
    I keep getting the same error.
    Failed reading temperature from DHT
    Failed reading humidity from DHT
    1. I have tried 4 different DHT22 and even the one off my working Humidity sensor
    2. I have tried 5 different mini pros with only my original working..
    3. My original has a blue LED but the others were ordered in a ten pack and have red LED.
    4. Some of the red LED mini pro will only connect @ 57600 while others and blue LED connect @ 115200
    5. Changing the input pin for the DHT22 makes no difference.
    Do I just have a bunch of bad Mini Pros or am I missing something?
    • D Offline
      Dean
      Mine was doing the same thing when I had it plugged into my laptop while viewing the serial monitor. Once I connected it to my Gateway and into Vera, all is working. I got really frustrated at this, but it just seemed like it wanted to be connected to something first.
      Sorry, probably not much help, but thought I would share my experience.
      • J Offline
        J Offline
        Jan Gatzke
        Perhaps your minis are 3.3v 8 Mhz and you selected 5v 16 Mhz in the IDE?
        • F Offline
          F Offline
          FUZNUTS
          these are all 5.5v 16mhz or at least that's what they say..lol
          ill try leaving it set up on the gateway and see what happens with fingers crossed
          • S Offline
            Salmoides
            When you apply voltage to the RAW pin, do you get 5v out of Vcc?
            Sal
            F 1 Reply Last reply
            • S Salmoides
              F Offline
              F Offline
              FUZNUTS
              @Salmoides 5v regulated into raw comes out 4.52v on vcc
              B 1 Reply Last reply
              • F FUZNUTS
                B Offline
                B Offline
                BulldogLowell
                @FUZNUTS
                have you tried to put a cap on the DHT's Vcc and ground??
                • B BulldogLowell
                  @FUZNUTS
                  F Offline
                  F Offline
                  FUZNUTS
                  @BulldogLowell Yes. I put one 4.7uf for the radio and one for the DHT22 with no change. Over two days I did get it to read the DHT22 once out of 1000 or so reads and that was with out any capacitors.. Reading every 5 seconds
                  • L Offline
                    L Offline
                    ludoarchi
                    I have a similar problem with a pack of 10 pro mini 3,3v bought at the ebay link from mysensor ?
                    But every think is ok with pro mini 5.5v ...
                    I tried many things but it still do not work ?
                    Other people with same problem ?
                    Ideas ?
                    Thinks
                    hekH 1 Reply Last reply
                    • L ludoarchi
                      Ideas ?
                      Thinks
                      hekH Offline
                      hekH Offline
                      Only problem with humidiy sensor or a more general problem?
                      Googling 3.3v dht22 giver a lot of results. E.g.
                      http://forum.arduino.cc/index.php?topic=269216.0
                      • L Offline
                        L Offline
                        ludoarchi
                        Problem with dht22 and ds18b20.
                        It looks likes a programmation beceause i just switch from arduino pro 3.3 to a 5.5 on my mys1.1 board and it works fine.
                        Or it s really a problem of manufacturing ...
                        • T Offline
                          T Offline
                          TimO
                          I've a sensor running with naked 328p, 3.3V, 8 MHz internal Osz and DHT22. Maybe I'm lucky?!
