1.1k Posts 105 Posters 786.9k Views 98 Watching
  • N
    N
    ncollins
    Compact, simple NRF52 motion sensor
    Ebyte E104-BT5032A NRF52832 module
    MH-SR602 Motion Sensor
    LiFePO4 AA Battery
    • T
      tssk
      MYS PoE MQTT Gateway with 868Mhz LoRa radio in IP55 85mm x 85mm box
      • arduino pro mini 3.3V clone
      • SX1276 with spring antenna
      • W5500 lite
      • 5V 802.3at power over ethernet splitter (gutted)
      • SPELSBERG IP55 box
      • berkseoB
        berkseoB
        berkseo
        My new arduino project wireless weather mini station with electronic ink display 2.9 inches (GDEH029A1), very low power consumption,compact size, housing with magnets. The device can use si7020 / 21, sht20 / 21, HTU20/21D or BME280 sensors. Use the MINEW MS50SFA RF module with nRF5210, nRF52811, nRF52832 chips, or the EBYTE E73 module with nRF52840 and nRF52833 chips. Soon to be available on openhardware.io
        Video: DIY Mini Weather station with an electronic ink display 2.9 Inch ( GDEH029A1 )
        • T
          tssk
          wrote on last edited by tssk
          #999
          Prototype of room sensor for stardard electric box
          • sx1276 radio
          • bme680
          • 2x1.5V AA battery holder
          • battery measuring circuit according to https://www.mysensors.org/build/battery
          • ABB Tango cover (drilled)
          IMG_20201025_141753.jpg IMG_20201025_141837.jpg IMG_20201025_141848.jpg IMG_20201025_141942.jpg IMG_20201025_142159.jpg
          Cover is not fully closed to allow air circulation. But I would preffer some method to drill holes/grill into it - any tips to get decent looking result?
          NeverDieN sundberg84S 2 Replies Last reply
          • T tssk
            • sx1276 radio
            • bme680
            #1000
            @tssk said in What did you build today (Pictures) ?:
            1. Drill at low RPM so you don't melt the plastic.
            2. If you're going to drill a bunch of holes to make a kind of grill, then preferably use a CNC (even a cheap one!) to drill them so that they don't look hodgepodge.
            • T tssk
              • sx1276 radio
              • bme680
              sundberg84S
              sundberg84S
              @tssk - really like your design! Well done.
              • sundberg84S sundberg84
                @sundberg84 thanks for creating this thread btw. You got the 1st and 1001st post :)
                • sundberg84S
                  sundberg84S
                  Today im testing and outdoor node in a new PCB, but I had mixed csk and ce on the radio (it's a dual radio PCB).
                  • N ncollins
                    A bed occupancy sensor. 4 50kg load cells, an HX711, and a Wemos D1 to make a wifi scale that rests on a bed slat under the boxspring.
                    Given the placement and weight distribution it doesn't turn the bed into a huge bath scale, but definitely accurate enough to use the deltas to estimate if there is someone in the bed. I can also tell when our 12lb (5.5kg) dog is on the bed.
                    I have rules in openhab to turn the overhead fan on and off. Also disables some TTS notifications if somebody is in bed.
                    IMG_1154.jpg IMG_1155.jpg IMG_1156.jpg IMG_1157.jpg IMG_1158.jpg Screen Shot 2020-09-15 at 8.26.22 PM.png
                    @ncollins Just wondering: why 4 load cells per sensor instead of only one?
                    N 1 Reply Last reply
                      N
                      N
                      ncollins
                      • At 50kg per cell, 4 would allow me to actually turn the bed into a huge scale if I decided to go down that route
                      • I don't believe these are intended to support a significant load for extended periods of time, they can permanently deflect. Given they always have the weight of a king size mattress + boxspring, I wanted to distribute that as much as possible
                      • sundberg84S
                        sundberg84S
                        Current issue: outdoor nodes random stops/disappears - maybe during the time when its high humidity, so trying to try some different approaches i read - this multisensor is getting painted with clear nail polish. Also this PCB is a new board im testing, that Im hoping to be the base for my "final" home automation nodes. Still in dev. but great possibilities!
                          @sundberg84 Gaskets that are held under tight compression seem to work well at holding out moisture. I've seen a number of commercial products that rely on that and only that for in-ground radio sensors.
                            Here's an example from the new Flume (version 2) water meter monitor:
                            It gets strapped to your water meter, typically in the ground. All it has is one gasket to seal out everything. This particular box just snaps closed. No screws! Quite a difference from Version 1, which also used a gasket, but had 12 screws holding it snug.
                              tssk
                              #1009
                              @sundberg84 Really like the shape and look of the PCB! I hope I can achieve similar result for my room sensor.
                              • berkseoB
                                berkseoB
                                berkseo
                                #1010
                                And another of my completed projects is a mini weather station running on nRF52832 and nRF52840, you can install bme280 or si7021, htu21d. Powered by a single cr2450 battery. As always soon to be on openhardware.io
                                Video: https://youtu.be/HNjYtKyh8zo
                                • berkseoB berkseo
                                  @berkseo By calling it a mini weather station now you'll need to add an anemometer and rain gauge... :-)
                                  berkseoB 1 Reply Last reply
                                    berkseoB
                                    berkseoB
                                    berkseo
                                    #1012
                                    @NeverDie Sorry, I didn't know there were rules like that now :), then it would just be a temperature, humidity and pressure gauge with weather forecasting, okay?
                                    • franz-unixF
                                      franz-unixF
                                      franz-unix
                                      Hi guys,
                                      this is my last node. A 3d printable smart USB power hub.
                                      20201107_112237_HDR.jpg 20201107_112249_HDR.jpg 20201107_112323.jpg 20201107_113033.jpg 20201107_113043.jpg 20201107_113053.jpg 20201107_140802.jpg 20201107_140813.jpg 20201107_141854.jpg 20201107_141907.jpg 20201107_143615.jpg 20201107_143645.jpg 20201107_144222.jpg
                                      If someone is interested, here all the details.
                                      • nagelcN
                                        nagelcN
                                        nagelc
                                        I am testing a node with a DigiPyro, PYD 1598 motion detector. It is advertised to be low power and runs from 1.8 to 3.6 volts, so should run well with a coin cell. They have to be programmed with several options and I have not found a lot of documentation. I went with what seemed like the most sensitive choices and it seems to work so far. More research needed . ...
                                        https://www.excelitas.com/product/pyd-1588-pyd-1598-low-power-digipyros
                                        I bought a couple of these from DigiKey for around $4 each. Now they are more than $12 each and there is no stock. So, these may not be as good a choice as they seemed at first. We'll see . ...
                                        nagelcN 1 Reply Last reply
                                        • JoeridemanJ
                                          JoeridemanJ
                                          Joerideman
                                          The milling topic got my interest and I have been working on getting a machine for myself.
                                          So far I have just assembled the machine and realised milling is a bit more difficult to start then 3d printing.
                                          anyway, I would like to share my progress. I am building video's now :)
                                          No circuitsboards yet, but here is a introduction of my way to victory.
                                          https://www.youtube.com/watch?v=45tTuHpgH1c&feature=youtu.be
