  3. IR sender & Repeater combined help
9 Posts 2 Posters 5.2k Views 2 Watching
  • A Offline
    A Offline
    alexeinz
    Hi , I am trying to combine IR sender with Repeater node ( usb powered ) on a Nano
    but anytime I add gw.begin it will not start at all
    gw.begin(incomingMessage,30, true);
    when i change to NULL
    gw.begin(NULL,30, true);
    it will start, but then it will not respond to the gw commands ( I can see it receives the command )
    // Example sketch showing how to create a node thay repeates messages
    // from nodes far from gateway back to gateway.
    // It is important that nodes that has enabled repeater mode calls
    // gw.preocess() frequently. This node should never sleep.
    #include <IRremote.h>
    IRsend irsend;
    unsigned int Signal_0_0[] = {4372,4416,528,1636,528,1640,524,1640,528,1640,524,560,524,556,524,1640,528,556,524,556,524,560,524,556,524,556,528,1636,528,}; //AnalysIR Batch Export (IRremote) - RAW
    unsigned int Signal_1_1[] = {4372,4416,524,1640,528,1640,528,1636,528,1640,528,556,524,556,524,1640,528,556,528,552,528,556,524,556,524,556,528}; //AnalysIR Batch Export (IRremote) - RAW
    int khz=38;
    #define CHILD_1 3 // childId
    MyMessage msg(CHILD_1, V_VAR1);
    // The third argument enables repeater mode.
    //Send the sensor node sketch version information to the gateway
    gw.sendSketchInfo("Repeater Node& IR", "1.0");
    gw.present(CHILD_1, S_LIGHT);
    // By calling process() you route messages in the background
    if (message.type==V_LIGHT) {
    int incomingRelayStatus = message.getInt();
    if (incomingRelayStatus == 1) {
      irsend.sendRaw(Signal_1_1, sizeof(Signal_1_1)/sizeof(int), khz); // Vol up yamaha ysp-900
      irsend.sendRaw(Signal_0_0, sizeof(Signal_0_0)/sizeof(int), khz);// Vol down yamaha ysp-900
    mqtt gw 1.4 /openhab / zwave
    • M Offline
      M Offline
      marceloaqno
      Code Contributor
      What are you using to send messages to the node? Could you post the serial output?
      A 1 Reply Last reply
      • M marceloaqno
        A Offline
        A Offline
        alexeinz
        @celonunes
        if this is specified, then there is no output for some reason
        if I specify NULL then i get this
        repeater started, id 30
        send: 30-30-128-0 s=255,c=0,t=18,pt=0,l=5,st=fail:1.4.1
        send: 30-30-128-0 s=255,c=3,t=6,pt=1,l=1,st=fail:128
        send: 30-30-128-0 s=255,c=3,t=11,pt=0,l=13,st=fail:Repeater Node
        send: 30-30-128-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
        send: 30-30-128-0 s=3,c=0,t=3,pt=0,l=5,st=fail:1.4.1
        It does seem to receive ( I send using mqtt )
        command on mosquitto :
        mosquitto_pub -t sensor/30/3/V_LIGHT -m 0 -d
        I can see its received on serial
        read: 0-0-30 s=3,c=1,t=2,pt=0,l=1:0
        ..... any help appreciated
        • A Offline
          A Offline
          alexeinz
          reflash eprom and i can verify
          gw.begin(incommingmessage,AUTO, true); will always result in sensor not starting at all( no serial out)
          but
          gw.begin(NULL,AUTO, true); will work and will receive messages
          repeater started, id 24
          send: 24-24-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
          send: 24-24-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
          read: 0-0-24 s=255,c=3,t=6,pt=0,l=1:M
          send: 24-24-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:Repeater Node
          send: 24-24-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
          send: 24-24-0-0 s=3,c=0,t=3,pt=0,l=5,st=ok:1.4.1
          read: 22-22-255 s=255,c=3,t=7,pt=0,l=0:
          send: 24-24-22-22 s=255,c=3,t=8,pt=1,l=1,st=ok:1
          read: 22-22-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
          send: 22-24-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
          read: 22-22-0 s=255,c=3,t=6,pt=1,l=1:24
          • M Offline
            M Offline
            marceloaqno
            Code Contributor
            Strange. Did you tried to remove everything that is not related to mysensors from the sketch? Keep only the essentials, just to see if it works.
            • A Offline
              A Offline
              alexeinz
              yea.. as long as this is there it will totally fail
              i will try with the dev branch and let know result
              • A Offline
                A Offline
                alexeinz
                hmmm
                any sketch in dev gets me these
                /Volumes/1TB Audio/Users/audio/Documents/Arduino/libraries/MySensors/MySensor.cpp:81: error: 'eeprom_update_byte' was not declared in this scope
                /Volumes/1TB Audio/Users/audio/Documents/Arduino/libraries/MySensors/MySensor.cpp:94: error: 'eeprom_update_byte' was not declared in this scope
                /Volumes/1TB Audio/Users/audio/Documents/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::process()':
                • M Offline
                  M Offline
                  marceloaqno
                  Code Contributor
                  wrote on last edited by marceloaqno
                  Are you using the latest version of Arduino IDE? (1.6.0)
                  • A Offline
                    A Offline
                    alexeinz
                    yes I am
                    I also replaced libs to Iremote and have same problem
                    basically as long as there is sendRaw command and incomingMessage in the same sketch, it will not work....
                    this seems like something wrong with incommingMessage, because send raw on itself works and I have tried both IRlibraries
                    any suggestion?
                    // Example sketch showing how to control physical relays.
                    // This example will remember relay state even after power failure.
                    #include <IRLib.h>
                    #define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                    unsigned int Signal_0_0[] = {4372,4416,528,1636,528,1640,524,1640,528,1640,524,560,524,556,524,1640,528,556,524,556,524,560,524,556,524,556,528,1636,528,1640,528,556,524,1640,528,556,524,556,524,556,528,556,524,556,528,552,528,1636,528,1640,528,1636,528,1640,528,1640,524,1640,528,1640,524,1640,528,556,524,556,528,556,524,556,524,560,524,556,528,552,528,552,528,556,524,1640,528,1636,528,1644,524,556,524,556,528,556,524,556,524,556,528,556,524,556,524,560,524,556,524,556,528,556,524,1640,524,1640,528,1640,528,556,524,556,524,560,524,556,524,556,528,556,524,556,524,556,528,1636,528,1640,528,556,524,556,528,552,528,1640,524,1640,528,556,524,5288,4376,4412,528,1640,524,1640,528,1640,524,1640,528,556,524,556,528,1636,528,556,524,560,524,556,524,556,528,556,524,1636,528,1640,528,556,524,1640,528,556,524,556,528,556,524,556,524,556,528,556,524,1640,528,1636,528,1640,528,1640,524,1640,528,1636,528,1640,528,1640,524,556,528,556,524,556,524,556,528,556,524,556,528,552,528,556,524,556,528,1636,528,1640,528,1636,528,556,528,556,524,556,524,556,528,556,524,556,528,556,524,556,524,556,528,556,524,556,528,1636,528,1640,528,1636,528,556,524,556,528,556,524,556,528,552,528,556,524,556,528,556,524,1640,528,1636,532,552,528,556,524,556,524,1640,528,1640,524,556,528}; //AnalysIR Batch Export (IRremote) - RAW
                    unsigned int Signal_1_1[] = {4372,4416,524,1640,528,1640,528,1636,528,1640,528,556,524,556,524,1640,528,556,528,552,528,556,524,556,524,556,528,1636,528,1640,528,560,520,1640,528,556,524,556,524,556,528,556,524,556,524,560,524,1640,524,1640,528,1636,528,1640,528,1640,524,1640,528,1640,524,1640,528,556,524,556,532,552,524,556,524,556,528,556,524,556,528,552,528,556,524,1640,528,1640,524,1640,528,556,524,556,528,556,524,556,528,552,528,556,524,556,528,556,524,556,524,556,528,556,524,556,528,1636,528,1640,528,556,524,556,524,556,528,556,524,556,528,552,528,556,524,556,528,1636,528,1640,528,556,524,556,524,556,528,556,524,1640,528,556,524,5404,4372,4412,528,1640,528,1636,528,1640,528,1636,528,556,528,556,524,1640,524,556,528,556,524,556,528,556,524,556,524,1640,528,1636,528,556,528,1636,528,556,528,556,524,556,524,556,528,556,524,556,528,1636,528,1640,528,1636,528,1640,528,1636,528,1640,528,1636,528,1640,528,556,524,556,524,556,528,556,524,556,528,552,528,556,524,556,528,556,524,1640,528,1636,528,1640,528,552,528,556,524,556,528,556,524,556,528,556,524,556,524,556,528,556,524,556,528,552,528,556,524,1640,528,1636,528,556,528,552,528,556,524,556,528,556,524,556,528,552,528,556,524,1640,528,1640,524,556,528,556,524,556,528,552,528,1636,528,556,528}; //AnalysIR Batch Export (IRremote) - RAW
                    int khz=38;
                    int longs=295;
                    IRsend irsend;
                    gw.begin( incomingMessage , 30, true);
                    gw.sendSketchInfo("IR Sensor", "1.0");
                    gw.present(RELAY_1, S_LIGHT);
                    if (message.type==V_LIGHT && message.sensor == 3) {
                    irsend.IRsendRaw::send(Signal_1_1, longs, khz); // Vol up yamaha ysp-900
                    irsend.IRsendRaw::send(Signal_0_0, longs, khz); // Vol down yamaha ysp-900
