  3. Getting system time from the controller
13 Posts 4 Posters 2.2k Views 3 Watching
  • dpconsD
    dpconsD
    dpcons
    Just starting on a scene controller, which I intend to use to display temperatures from a mysensors sensor unit connected to my fridge. Right now I just trying to get the system time using "requestTime()" function.
    The system is communicating OK, I think. When I send the command, the "receiveTime() function never gets executed. Should I see this time request in the log??
    Here's the serial debug info: I don't get any error executing the requestTime() function
    requesting time
    450046 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    450375 TSF:MSG:READ,0-0-6,s=255,c=3,t=1,pt=0,l=10,sg=0:1740594416 ****What's this?
    The code follows: Anybody see any issues? Thanks for looking.
    Scene Controller Will be used to receive my Fridge and Freezer Temps and display on a MAX7917 7-Seg
    8 Character display.
    #define MY_RADIO_RF24
    #include <TimeLib.h>
    #include <stdarg.h>
    #define CHILD_ID 1
    MyMessage on(CHILD_ID, V_SCENE_ON);
    MyMessage off(CHILD_ID, V_SCENE_OFF);
    bool timeReceived = false;
    unsigned long lastTimeUpdate=0, lastRequest=0;
    char timeBuf[20];
    // Request time from controller.
    requestTime();
    void presentation() {
    sendSketchInfo("Fridge Temp Displays", "1.0");
    present(CHILD_ID, S_SCENE_CONTROLLER);
    unsigned long now = millis();
    // If no time has been received yet, request it every 10 second from controller
    // When time has been received, request update every hour
    if ((!timeReceived && now-lastRequest > (unsigned long)101000)
    || (timeReceived && now-lastRequest > (unsigned long)60
    1000*60)) {
    Serial.println("requesting time");
    bool status = requestTime();
    if(!status) Serial.println("time request failed");
    lastRequest = now;
    // Update time every second
    if (timeReceived && now-lastTimeUpdate > 1000) {
    printTime();
    lastTimeUpdate = now;
    // This is called when a new time value was received
    void receiveTime(unsigned long time) {
    // Ok, set incoming time
    setTime(time);
    timeReceived = true;
    void printTime() {
    sprintf(timeBuf, "%02d:%02d:%02d", hour(), minute(), second());
    Serial.println(timeBuf);
      The received message looks like this:
      Received Message
      Sender: 0
      Last Node: 0
      Destination: 6
      Sensor Id: 255
      Command: INTERNAL
      Message Type: I_TIME
      Payload Type: P_STRING
      Payload Length: 10
      Signing: 0
      Payload: 1740594416
      https://www.mysensors.org/build/parser?log=450375 TSF%3AMSG%3AREAD%2C0-0-6%2Cs%3D255%2Cc%3D3%2Ct%3D1%2Cpt%3D0%2Cl%3D10%2Csg%3D0%3A1740594416
      1740594416 is Thu, 27 Feb 2025 11:56:37 GMT which looks reasonable.
      So question is, why doesn’t the node print the received time?
      dpconsD 1 Reply Last reply
      • skywatchS
        skywatchS
        skywatch
        This post is deleted!
          Received Message
          Sender: 0
          Last Node: 0
          Destination: 6
          Sensor Id: 255
          Command: INTERNAL
          Payload Length: 10
          Signing: 0
          Payload: 1740594416
          dpconsD
          dpconsD
          dpcons
          @mfalkvidd
          Thanks for your response. Yes, that's the question. Did I neglect something in my code? Do I have to register the "receiveTime" routine? Is there any workaround to use the response data? This node is an ESP32 D1 mini...if that makes a difference. Does the operation depend on an interrupt?
          Again, thanks
          dpconsD mfalkviddM 2 Replies Last reply
          • dpconsD dpcons
            @mfalkvidd
            Again, thanks
            dpconsD
            dpconsD
            dpcons
            @dpcons sorry...esp8266 wemos mini is the actual device.
            • dpconsD dpcons
              @mfalkvidd
              Again, thanks
              @dpcons it could be that the gateway code for receiving time is (unintentionally) broken. I noticed that the other thread you found also was about a gateway.
              I have never used receivetime myself but I am pretty sure I have seen it working for other people on regular nodes.
              • nagelcN
                nagelcN
                nagelc
                I have found that controllers can be very slow to respond to time requests. Same experience for Domoticz and for Homeassistant. Try a wait(1500) after the time request.
                • nagelcN nagelc
                  dpconsD
                  dpconsD
                  dpcons
                  @nagelc Thanks for responding. The response from the controller seems to be very quick. The problem is the 'receiveTime' routine never gets executed. mfalkvidd stated that the response in the serial output looked reasonable so I'm assuming the controller is responding OK. I tried adding the delay(1500) but same issue.
                  Again, thanks for your response.
                    dpconsD
                    dpconsD
                    dpcons
                    @mfalkvidd Thanks for the response. I once built the 'Display and Time' sensor and I remember it working...but that was about 3-4 years ago and I no longer have the device. Maybe I build it back up again and give it a shot!
                    • dpconsD dpcons
                      dpconsD
                      dpconsD
                      dpcons
                      @dpcons I built the Time Display example and after a little futzing, I got it to talk to my NRF24L01 system but the receiveTimez() function looks broken. It appears to respond with data that's read, but function never executes.
                      Looks like I'll punt for now.
                        I think the relevant code is here:
                        https://github.com/mysensors/MySensors/blob/e298769eb73ba2da781a34d66cae345c6840b7c0/core/MySensorsCore.cpp#L473
                        but I can’t see anything that looks broken.
                        • dpconsD dpcons
                          @dpcons try changing unsigned long in your sketch to uint32_t
                          Could be that the override needs to have an exact match.
                            dpconsD
                            dpconsD
                            dpcons
                            @mfalkvidd Thanks, I'll try that.
