  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
    @nagelc If you do manage to get it working, I'd be curious as to what kind of range you get out of it a compared to other modules. The antenna pattern looks a bit different.
    nagelcN
    nagelcN
    nagelc
    It isn't very scientific, but I think the range is roughly equivalent to a BT832. I can reach my gateway from everywhere in my house except the far corner of the basement, same as the BT. That corner is behind a chimney an lots of plumbing -- RFM69 territory. Maybe the BT832F would work there. Haven't tried those.
    After fixing a missing trace on my dev board (my fault, not Oshpark's), and updating my J-link and bmp software. I am able to program these.
    I popped the shield off of one just to confirm I ordered the right version. The part numbering vs processor is not very clear on Aliexpress. No surprises there.
      #1846
      A Version 2 of the micro:bit is due to be released this month: https://www.electronicsweekly.com/news/products/bus-systems-sbcs/microbit-version-2-educational-computer-now-runs-ai-gets-loudspeaker-2020-10/
      It's based around the 64Mhz, 128Kbyte RAM nRF52833: https://www.nordicsemi.com/Products/Low-power-short-range-wireless/nRF52833
      Version 2 will include a speaker and a microphone and will apparently make use of bluetooth for wireless communication. The EW article also says it will support a "microbit-radio protocol". Also, the EW article says that Javascript will run on it.
      By itself it's not that interesting, but for someone looking to get started, it's another way in.
      Nca78N 1 Reply Last reply
        wrote on last edited by Nca78
        #1847
        @NeverDie said in nRF5 action!:
        No revolution on the radio sidde, bluetooth and microbit-radio were already here in first version of micro:bit. But use of speaker and microphone in addition to much larger memory is quite nice for students learning with it, it will open a lot of possibilities. Open source schematic and programs can also be a great base to make open source sound-related sensors and actuators compatible with MySensors.
        • N
          N
          ncollins
          Before exploring compatibility, I ordered a few nRF52805 modules from Ebyte, but I'm still waiting on delivery https://www.aliexpress.com/item/1005001709688444.html
          Any way to know if NRF52805s are compatible with the current core, sandeepmistry/arduino-nrf5? With MySensors?
          https://infocenter.nordicsemi.com/topic/struct_nrf52/struct/nrf52.html?cp=4l
          What is the hypothetical process of adding a new NRF52 variant? Where would I start?
          • N ncollins
            #1849
            @ncollins The sandeepmitry library has incomplete coverage, but what it does provide is access to the nRF5 registers. From there you can do whatever it is that you want to do by manipulating the registers directly. That makes it closer to assembly language, at least in thought process, than the confortable arduino library support you may be accustomed to.
            I haven't tracked the arduino or adafruit implementations. Maybe by now they have better library support? Alternatively, mbed and sager and probably others have their own library support for it, so there's always that which you can look into. Come to think of it, IIRC, Arduino simply adopted the mbed platform for the nRF52 rather than roll their own, which was a rather unusual move. That may mean it may never be completely "arduino" in the same way other arduino platforms are.
              N
              N
              ncollins
              @NeverDie I see.
              Say the Arduino mbed route supports my nRF module, would MySensors library need to be rewritten? Any idea how coupled it is to the sandeepmistry core?
              monteM 1 Reply Last reply
              • N ncollins
                @NeverDie I see.
                monteM
                monteM
                monte
                wrote on last edited by monte
                #1851
                @ncollins said in nRF5 action!:
                Yes.
                mbed is RTOS, sandeepmistry's core runs on bare metal instead.
                • N
                  N
                  ncollins
                  @monte thanks
                  I'm struggling with choosing the direction of the next steps in my diy sensor journey.
                  My focus has moved exclusively to nRF5 boards given the compact size, performance, and cost. I don't have range, penetration, or interference concerns, so I don't utilize any of the LoRa support in MySensors.
                  Given the ubiquitous support of BLE, recent advancements in mesh and long range capabilities, continued investment, widespread adoption...it might make more sense for someone with my use case to explore moving to a BLE based network.
                  I'm assuming there isn't much to gain by layering MySensors on top of BLE. And I'm not sure it makes sense for the MySensors community to expand and maintain support for boards capable of MySensors use, but primarily intended for BLE use. Especially, considering a significant majority of the community is completely satisfied with ATMEGA + (NRF24 / LoRa).
                  • N ncollins
                    @monte thanks
                    @ncollins If you have the gumption to do it, it might open up some interesting new possibilities. In the past programming bluetooth was a bit daunting, but it seems like some of the newer tools may be easier to learn: e.g. https://learn.adafruit.com/introducing-the-adafruit-nrf52840-feather/bluefruit-nrf52-api
                    N 2 Replies Last reply
                      N
                      N
                      ncollins
                      Ha, I ordered one yesterday. I'll mess around and report back.
                      • CharallC
                        CharallC
                        Charall
                        Where to start?
                        nagelcN 1 Reply Last reply
                        • CharallC Charall
                          Where to start?
                          nagelcN
                          nagelcN
                          nagelc
                          @Charall For MySensors NRF5, start with these:
                          https://forum.mysensors.org/topic/6705/mysensors-nrf5-platform
                          https://forum.mysensors.org/topic/9266/guide-nrf5-nrf51-nrf52-for-beginners
                          • N
                            N
                            ncollins
                            Just started testing my new NRF52805 breakout board. I added a new generic variant to sandeepmistry/arduino-nRF5, added a new board to mysensors nRF5, now I'm testing compatibility.
                            This new NRF52805 chip is interesting. Way stripped down compared to the rest of the NRF5 line. No PWM, no LPCOMP, only 10 GPIO (maybe 8 usable).
                            But, it's cheap, ~$2.50 for the EBYTE BT104-BT5005 module, compact, and appropriate for most low-power use cases.
                            Interestingly, the chip does not support the current MySensors default, but deprecated, data rate of 250Kbps. Today I also learned that modules can only communicate on the same data rate. So I created a ESP8266 + NRF24L01+ gateway at MY_RF24_DATARATE RF24_1MBPS, and it worked!
                            Still need to test a few things:
                            • I2C
                            • SPI
                            • Power consumption
                            If all goes well, I'll submit the merge requests and publish this board schematic on openhardware sometime in the next week.
                              N
                              N
                              ncollins
                              wrote on last edited by ncollins
                              #1858
                              @NeverDie I spent the last week really deep diving into NRF BLE & NRF networking capabilities.
                              Some things I learned:
                              • BLE is a great way for low power communication with a dedicated, physically close parent node
                              • BLE alone does not establish a network, just a link to a central/gateway node. Giving the limited range, that means having multiple gateways, and dedicated links (painful, inflexible)
                              • That led to the creation of BLE Mesh. I found this article from Integra Sources to be really helpful as they talk through the real world limitations they experienced trying to go to production with it. In summary, BLE Mesh is a "managed flood" which quickly leads to network storms if not optimized
                              • Then I found OpenThread
                              • After messing around for few days, I found this guide https://github.com/kyberpunk/openthread which really simplifies getting started. Two docker containers: OpenThread Border Router (sensor network gateway) and MQTT-SN (UDP6 MQTT bridge to MQTT Broker). I was able to setup a network with two NRF52840 dongles + NRF52840 DK, and post messages to my MQTT instance within a couple of hours.
                              OpenThread is supported on the the NRF52840, NRF52811, NRF52833, as well as 10-15 chips from other vendors.
                              I really like the ability to route via IP and the fact that all of the nodes communicate with common, well known protocols. I like the secure-by-default approach, and the built in tools for administering networks (commissioning new nodes).
                              I'm going to keep exploring this route, seems promising....
                              NeverDieN A 2 Replies Last reply
                              • N
                                N
                                ncollins
                                #1859
                                Update on my NRF52805 Breakout:
                                • I2C is now working, just a few small changes to select the right interface
                                • Power consumption looks good, around 1.8uA. The Si7021 module is reading 2.5uA in isolation.
                                Just need to test SPI and figure out a clever name for the board, and should be good to go.
                                J 1 Reply Last reply
                                • N ncollins
                                  • I2C
                                  • SPI
                                  • Power consumption
                                  • I2C
                                  • SPI
                                  • Power consumption
                                  Great work! For the gateway you might want to look into Ebyte E01-2G4M27D (https://www.aliexpress.com/item/4000536940861.html?spm=a2g0s.9042311.0.0.60da4c4dGywFPS), which should have better receive sensitivity than the usual nrf24L01 because it includes an LNA.
                                  • N ncollins
                                    Very inspiring! I've had high hopes for Thread, and from your report it sounds like maybe now is a good time to jump in.
                                      • I2C
                                      • SPI
                                      • Power consumption
                                      N
                                      N
                                      ncollins
                                      @NeverDie Thanks, and good call on the Ebyte NRF24 with LNA. I have a few laying around that I've been meaning to incorporate into a generic multi-sensor gateway/repeater node. If they're always connected, might as well collect environment data and maybe motion too.
                                      • N ncollins
                                        Avamander
                                        wrote on last edited by Avamander
                                        #1863
                                        @ncollins
                                        There's this nice HAT for the Raspberry Pi you might find interesting :) : https://gitlab.com/electronutlabs-public/indrium-pi-hat
                                        On another topic, I would honestly like to see MySensors using OpenThread or BLE Mesh transport...
                                        • A Avamander
                                          @ncollins
                                          N
                                          N
                                          ncollins
                                          @Avamander That would make a great gateway. I believe I read a getting started guide by the creator of that Pi Hat, Playing with Thread and MQTT-SN on Nordic nRF52840. The tutorial is a little outdated now, but it's a good overview of the process of setting up a Thread network. There is a lot of good content on that blog.
                                          I agree, but it is still not clear to me what the appropriate relationship between MySensors and OT / BLE Mesh is. It seems there is a lot of overlap in functionality. While I prefer to focus on the NRF5 series, a majority of the community is using ATMEGA328 and NRF24, or LoRa modules, which wouldn't support OT / BLE.
                                          At the very least, I'd like to see MySensors tap into some more of the advanced NRF5 capabilities: OTA, NFC.
                                          There are also a few examples of NRF5 modules running in dual mode: BLE + OT. If it's possible to run 2.4GHz + BLE in parallel, then there is potential to create a MySensors bridge device.
                                          Or maybe leveraging BLE to configure MySensor nodes at runtime: modifying sleep duration, send frequency.
                                          Given the abundance of storage and memory on the NRF5 devices, it is also feasible to create something like Tasmota / ESPeasy for MySensors. Use the same firmware on every node, have the MySensors gateway/controller manage and push configuration templates. Given the great work on MySensors NodeManager and the SmartSleep functionality, it seems like the foundation is already in place.
                                          12.5k
