1.1k Posts 105 Posters 792.8k Views 98 Watching
  • K KooLru
    I2S/IIC to MYSX converter
    Configurable via jumper matrix
    sundberg84S
    sundberg84S
    @KooLru - very clever sollution for the lines.
    • berkseoB berkseo
      My new project of a temperature and humidity sensor with an electronic ink display 1.02 Inch ( GDEW0102T4 ), very low power consumption, very small device.
      https://youtu.be/2zTEHTAr7lk
      nagelcN
      nagelcN
      nagelc
      wrote on last edited by nagelc
      #1046
      @berkseo
      Hey. Our own berkseo is on Hackaday. Congrats!
      https://hackaday.com/2021/03/11/nrf52-weather-station-gives-forecast-with-style/
      berkseoB 2 Replies Last reply
      • nagelcN nagelc
        @berkseo
        berkseoB
        berkseoB
        berkseo
        @nagelc
        Wow, this is unexpected.
        • nagelcN
          nagelcN
          nagelc
          I made a simple board to use as a CR2032 battery simulator. It is actually two identical pcb's back to back. I added pins for applying power and another set for measuring current. Now I need a better ammeter. The uA scale works well when sleeping, but the mA scale doesn't seem to pick up the awake current.
          electrikE 1 Reply Last reply
          • nagelcN nagelc
            electrikE
            electrikE
            electrik
            @nagelc Nice!
            What is the PCB you are measuring on? I'm actually looking for a NRF5 board to use with a coin cell.
            • nagelcN nagelc
              I am testing a node with a DigiPyro, PYD 1598 motion detector. It is advertised to be low power and runs from 1.8 to 3.6 volts, so should run well with a coin cell. They have to be programmed with several options and I have not found a lot of documentation. I went with what seemed like the most sensitive choices and it seems to work so far. More research needed . ...
              https://www.excelitas.com/product/pyd-1588-pyd-1598-low-power-digipyros
              I bought a couple of these from DigiKey for around $4 each. Now they are more than $12 each and there is no stock. So, these may not be as good a choice as they seemed at first. We'll see . ...
              nagelcN
              nagelcN
              nagelc
              @electrik
              It's actually at this link posted earlier in the thread: What did you build today (Pictures) ?:
              I mostly use it with BME280 modules for temperature and humidity, but I have tried some other I2C modules in it.
              I'm still experimenting with the motion detector. That will probably get it's own board at some point. It doesn't really fit the enclosure I designed this board for.
              • berkseoB
                berkseoB
                berkseo
                #1051
                I think this open source project is finished. This is a small air quality sensor. Quite a useful thing turned out for our not simple time.
                https://github.com/smartboxchannel/EFEKTA-EINK213-AIR-QUALITY-SENSOR-NRF52840-V2-ED3
                • K
                  K
                  KevinT
                  Finished my Garage Door Node.
                  It has open/close magnetic reed switch sensors, a DS18B20 temperature sensor, a PIR motion sensor and a bjt to trigger the door to open/close/stop.
                  K 1 Reply Last reply
                  • K KevinT
                    K
                    K
                    KevinT
                    nagelcN 1 Reply Last reply
                    • K KevinT
                      nagelcN
                      nagelcN
                      nagelc
                      @KevinT Very cool.
                      How does it respond to the PIR. Does it stop the door if it sees motion?
                      • K
                        K
                        KevinT
                        The motion sensor is used to turn on the lights in the garage via a Sonoff mini.
                        Also, I've had the garage door randomly open by itself (power glitches?) a few times over the years. So I'm adding an automation to close the door if no motion is present and it is after midnight.
                        • F
                          F
                          fsgraz
                          A collection of the sensors and actuators I buit for my camper in the past year
                          the power supply system under the dinette seat
                          the battery management system (purchased) data are read via wifi by an ESP32, which reports the info to the GW via nRF24L01+.
                          a closed look at 2 sensors.
                          the one on the left reads voltage and current from the solar PV panel and to the battery management system
                          the one on the right reads voltage and current from/to the start and service batteriers
                          both sensors report instant power and energy.
                          Fresh water sensor reads the water level, flow and temperature.
                          has 4 optcoupled outputs to send the information to the 4 LEDs of the original control panel of the camper
                          gray water tank sensor reports water level with an ultrasound sensor. has an optocoupled output to the "full" LED of the original control panel
                          bettry supplied temperature and humidity sensor.
                          I use it in the fridge but also at home, where I have also one with BME280.
                          A fan controller to help the fridge to work better, controlling the condenser temperature using an optical thermometer sensor.
                          I have 3 other units, one in the power supply system, one in the closet and one on the roof.
                          They are all with a PID controller.
                          IMG_20210503_095913.jpg IMG_20210313_153635 (2).jpg IMG_20210313_153612 (2).jpg
                          • F
                            F
                            fsgraz
                            the display node for my camper, based on a Arduino Mega clone
                            F 1 Reply Last reply
                            • siddarth sidS
                              siddarth sidS
                              siddarth sid
                              This thread is really good, kind of addicting to scroll all time.
                              Only problem though is the way it is structured. Its really hard to find the same post twice.
                              Maybe the admins should consider having a separate section for this !!>?
                              • N ncollins
                                The latest addition to my coin cell nodes, a PIR motion sensor based on the Ebyte NRF52805 module.
                                The PIR sensor is a Senba S16-L221D-2. I'm measuring around 24uA, which is higher than advertised, but with the 6-7uA from the NRF52805, should still get me 3-4 years on a single 2477.
                                Amit BTA
                                Amit BTA
                                Amit BT
                                @ncollins said in What did you build today (Pictures) ?:
                                Hi, I see you integrated the E104-BT5005A BLE chip in this project.
                                I’m trying to use it in a simple robot project and having difficulties to make the RX/TX connection with “RF Connect” IOS app.
                                I already wired the chip to the Seeeduino board and I can find and connect the bluetooth on the RF scan list. But I just don’t know the Arduino code to make it send and receive simple massages on the Arduino serial monitor.
                                Your help is very much appreciated.
                                Amit
                                • F fsgraz
                                  F
                                  F
                                  fsgraz
                                  Some updates in almost one year.
                                  I moved all the gateways and controller part in a most suitable locationIMG_20220305_110252.jpg
                                  I've created a dual current sensor for the fuse box and the inverter. Each Current sensors can withstand 90A max, so I used both channels in parallel. The sensors are defined for both Channel 1, 2 and Sum(Ch1+Ch2) to handle this case easily
                                  Recently I made an updated version of my Photovoltaic monitor since the 20A that the old one could withstand are not enough now, so the new version is capable of 50A max. Still waiting the Hall sensors though...
                                  Finally, I cleaned up a bit the deployment under the bench
                                  IMG_20220527_161849.jpg but I am not done yet
                                    #1061
                                    I made this CR2032 coincell powered locator beacon using an nRF52805:
                                    It was my first experience using a TAG-CONNECT to make the programming connections. It's for that reason that I haven't yet attached the battery holder. The TAG-CONNEC provides power during programming (and debugging as well if so desired).
                                    I have the antenna hanging out over the edge, as per Nordic Semiconductor recommendations, so that it doesn't hover over the ground plane. However, that makes the overall footprint a bit larger, somewhat defeating the point of powering it with a CR2032. I may try making a smaller version where the antenna doesn't overhang just to see how much difference it does or doesn't make. For a device like this, I mostly care about reception rather than transmitting, so maybe for receiving such a change won't make much of a difference.
                                    Who makes the world's smallest nRF5x module?
                                    OldSurferDudeO 1 Reply Last reply
                                    • F fsgraz
                                      F
                                      F
                                      fsgraz
                                      Finally I had the time to refine it:
                                        OldSurferDudeO
                                        OldSurferDudeO
                                        OldSurferDude
                                        @NeverDie It is my understanding, though I can't wrap my head around it, that it is the length of the conductor that makes the antenna tuned to a certain frequency. If this is the case, you could run your antenna around the edge of your circular pcb which would make the effective radius only slightly bigger.
                                          #1064
                                          @OldSurferDude said in What did you build today (Pictures) ?:
                                          You mean like this?
                                          I get the impression that somehow the antenna positioning relative to the ground plane might figure into it as well:
                                          Perhaps that stands in the way of wrapping the antenna completely around the circumference? I can't claim to have any deep understanding of how antennas are supposed to be designed. In the past I noticed that TI sold a sample set of canonical antenna designs, so then you could try them all out and see what suits you: https://www.ti.com/lit/an/swra161b/swra161b.pdf?ts=1661617962454&ref_url=https%253A%252F%252Fwww.google.com%252F
