1.1k Posts 105 Posters 792.8k Views 98 Watching
  • franz-unixF
    franz-unixF
    franz-unix
    Hi guys,
    my last creation: the d-diot hub v.3.0
    20210123_205004.jpg 20210124_120658.jpg 20210124_120759.jpg 20210124_120909.jpg 20210214_100204.jpg 20210214_100225.jpg 20210214_100243.jpg 20210123_204437_HDR.jpg 20210123_204535.jpg
    The hub A (wood) is a dual MySensors gateway (RFM69 and NRF24) based on two ESP8266 modules and a BLE gateway + RGB controller thanks to an ESP32 module and ESPHome firmware.
    The hub B (grey and red) is an IR gateway and RC 433 Mhz gateway based on ESP32 modules with an ESPHome firmware. The hub B has also an integrated step-up and step-down voltage regulator based on Arduino Nano.
    To allow the maximum flexibility in placement inside the house, each module can be build as a stand-alone piece of hardware or combined in a single device (see pictures).
    The hub is meant to be used with Home Assistant, the case is 3d printable and as usual, if someone is interested, there is a dedicated wiki page with all the details and the build instructions.
    • K
      K
      KooLru
      I2S/IIC to MYSX converter
      Configurable via jumper matrix
      • K KooLru
        sundberg84S
        sundberg84S
        @KooLru - very clever sollution for the lines.
        • berkseoB berkseo
          My new project of a temperature and humidity sensor with an electronic ink display 1.02 Inch ( GDEW0102T4 ), very low power consumption, very small device.
          https://youtu.be/2zTEHTAr7lk
          nagelcN
          nagelcN
          nagelc
          wrote on last edited by nagelc
          #1046
          @berkseo
          Hey. Our own berkseo is on Hackaday. Congrats!
          https://hackaday.com/2021/03/11/nrf52-weather-station-gives-forecast-with-style/
          berkseoB 2 Replies Last reply
          • nagelcN nagelc
            @berkseo
            berkseoB
            berkseoB
            berkseo
            @nagelc
            Wow, this is unexpected.
            • nagelcN
              nagelcN
              nagelc
              I made a simple board to use as a CR2032 battery simulator. It is actually two identical pcb's back to back. I added pins for applying power and another set for measuring current. Now I need a better ammeter. The uA scale works well when sleeping, but the mA scale doesn't seem to pick up the awake current.
              electrikE 1 Reply Last reply
              • nagelcN nagelc
                electrikE
                electrikE
                electrik
                @nagelc Nice!
                What is the PCB you are measuring on? I'm actually looking for a NRF5 board to use with a coin cell.
                • nagelcN nagelc
                  I am testing a node with a DigiPyro, PYD 1598 motion detector. It is advertised to be low power and runs from 1.8 to 3.6 volts, so should run well with a coin cell. They have to be programmed with several options and I have not found a lot of documentation. I went with what seemed like the most sensitive choices and it seems to work so far. More research needed . ...
                  https://www.excelitas.com/product/pyd-1588-pyd-1598-low-power-digipyros
                  I bought a couple of these from DigiKey for around $4 each. Now they are more than $12 each and there is no stock. So, these may not be as good a choice as they seemed at first. We'll see . ...
                  nagelcN
                  nagelcN
                  nagelc
                  @electrik
                  It's actually at this link posted earlier in the thread: What did you build today (Pictures) ?:
                  I mostly use it with BME280 modules for temperature and humidity, but I have tried some other I2C modules in it.
                  I'm still experimenting with the motion detector. That will probably get it's own board at some point. It doesn't really fit the enclosure I designed this board for.
                  • berkseoB
                    berkseoB
                    berkseo
                    #1051
                    I think this open source project is finished. This is a small air quality sensor. Quite a useful thing turned out for our not simple time.
                    https://github.com/smartboxchannel/EFEKTA-EINK213-AIR-QUALITY-SENSOR-NRF52840-V2-ED3
                    • K
                      K
                      KevinT
                      Finished my Garage Door Node.
                      It has open/close magnetic reed switch sensors, a DS18B20 temperature sensor, a PIR motion sensor and a bjt to trigger the door to open/close/stop.
                      K 1 Reply Last reply
                      • K KevinT
                        K
                        K
                        KevinT
                        nagelcN 1 Reply Last reply
                        • K KevinT
                          nagelcN
                          nagelcN
                          nagelc
                          @KevinT Very cool.
                          How does it respond to the PIR. Does it stop the door if it sees motion?
                          • K
                            K
                            KevinT
                            The motion sensor is used to turn on the lights in the garage via a Sonoff mini.
                            Also, I've had the garage door randomly open by itself (power glitches?) a few times over the years. So I'm adding an automation to close the door if no motion is present and it is after midnight.
                            • F
                              F
                              fsgraz
                              A collection of the sensors and actuators I buit for my camper in the past year
                              the power supply system under the dinette seat
                              the battery management system (purchased) data are read via wifi by an ESP32, which reports the info to the GW via nRF24L01+.
                              a closed look at 2 sensors.
                              the one on the left reads voltage and current from the solar PV panel and to the battery management system
                              the one on the right reads voltage and current from/to the start and service batteriers
                              both sensors report instant power and energy.
                              Fresh water sensor reads the water level, flow and temperature.
                              has 4 optcoupled outputs to send the information to the 4 LEDs of the original control panel of the camper
                              gray water tank sensor reports water level with an ultrasound sensor. has an optocoupled output to the "full" LED of the original control panel
                              bettry supplied temperature and humidity sensor.
                              I use it in the fridge but also at home, where I have also one with BME280.
                              A fan controller to help the fridge to work better, controlling the condenser temperature using an optical thermometer sensor.
                              I have 3 other units, one in the power supply system, one in the closet and one on the roof.
                              They are all with a PID controller.
                              IMG_20210503_095913.jpg IMG_20210313_153635 (2).jpg IMG_20210313_153612 (2).jpg
                              • F
                                F
                                fsgraz
                                the display node for my camper, based on a Arduino Mega clone
                                F 1 Reply Last reply
                                • siddarth sidS
                                  siddarth sidS
                                  siddarth sid
                                  This thread is really good, kind of addicting to scroll all time.
                                  Only problem though is the way it is structured. Its really hard to find the same post twice.
                                  Maybe the admins should consider having a separate section for this !!>?
                                  • N ncollins
                                    The latest addition to my coin cell nodes, a PIR motion sensor based on the Ebyte NRF52805 module.
                                    The PIR sensor is a Senba S16-L221D-2. I'm measuring around 24uA, which is higher than advertised, but with the 6-7uA from the NRF52805, should still get me 3-4 years on a single 2477.
                                    Amit BTA
                                    Amit BTA
                                    Amit BT
                                    @ncollins said in What did you build today (Pictures) ?:
                                    Hi, I see you integrated the E104-BT5005A BLE chip in this project.
                                    I’m trying to use it in a simple robot project and having difficulties to make the RX/TX connection with “RF Connect” IOS app.
                                    I already wired the chip to the Seeeduino board and I can find and connect the bluetooth on the RF scan list. But I just don’t know the Arduino code to make it send and receive simple massages on the Arduino serial monitor.
                                    Your help is very much appreciated.
                                    Amit
                                    • F fsgraz
                                      F
                                      F
                                      fsgraz
                                      Some updates in almost one year.
                                      I moved all the gateways and controller part in a most suitable locationIMG_20220305_110252.jpg
                                      I've created a dual current sensor for the fuse box and the inverter. Each Current sensors can withstand 90A max, so I used both channels in parallel. The sensors are defined for both Channel 1, 2 and Sum(Ch1+Ch2) to handle this case easily
                                      Recently I made an updated version of my Photovoltaic monitor since the 20A that the old one could withstand are not enough now, so the new version is capable of 50A max. Still waiting the Hall sensors though...
                                      Finally, I cleaned up a bit the deployment under the bench
                                      IMG_20220527_161849.jpg but I am not done yet
                                        #1061
                                        I made this CR2032 coincell powered locator beacon using an nRF52805:
                                        It was my first experience using a TAG-CONNECT to make the programming connections. It's for that reason that I haven't yet attached the battery holder. The TAG-CONNEC provides power during programming (and debugging as well if so desired).
                                        I have the antenna hanging out over the edge, as per Nordic Semiconductor recommendations, so that it doesn't hover over the ground plane. However, that makes the overall footprint a bit larger, somewhat defeating the point of powering it with a CR2032. I may try making a smaller version where the antenna doesn't overhang just to see how much difference it does or doesn't make. For a device like this, I mostly care about reception rather than transmitting, so maybe for receiving such a change won't make much of a difference.
                                        Who makes the world's smallest nRF5x module?
                                        OldSurferDudeO 1 Reply Last reply
                                        • F fsgraz
                                          F
                                          F
                                          fsgraz
                                          Finally I had the time to refine it:
