  3. NRF24l01+ directly on Raspberry Pi ?
8 Posts 4 Posters 5.4k Views 2 Watching
  • A
    ahhk
    wrote on last edited by ahhk
    Hi all,
    i searched and read a lot topics, but i am still not sure: Is it possible to run a NRF24L01+ directly connected to a Raspi and run a kind of "gateway" in software instead connecting an arduino to the Raspi? I would be happy to get rid of the arduino-ethernet-mqtt gateway...
    I think i found a link to sourcecode where someone ported the libs to pi, but no manual about it (howto install,....)..
    Maybe someone can give me a helping hand?
    Greetings
    Andreas
      sharath krishna
      @ahhk install the raspberry pi mysensor port on ur raspberry and run the make command. then u shd see get executable file generated which u can then open and this would work as a /dev/tty* serial port .
      • A
        ahhk
        Ah, ok. Thx. i will try this.
        Is there a serial2mqtt-interface on the pi too?
          sharath krishna
          @ahhk mostly no i did not see mqtt der
          • H
            H
            HenkeP
            I just got hocked on the mysensors project and I started of now connecting a radio directly to the raspberry and using the EasyIoT (http://www.mysensors.org/controller/easyiot). A guide on how to connect the radio is found on that controllers webpage: http://iot-playground.com/3-easyiot-server-installation
            Perhaps you only wanted it as a gateway and not a controller at the same time? That project could maybe help anyhow?
            //Henrik
            • A
              ahhk
              i have Openhab runnning, so i dont want to install EasyIoT too.
              Greetings
              • A
                andriej
                Will it work with OrangePi also?
                It's supposed to have RPi GPIO fully compatible, so it's mostly the software I'm asking about.
                • A
                  andriej
                  Well, it don't want to compile.
                  $ make
                  g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv6zk -D BCM2835_PERI_BASE=0x -c RF24.cpp
                  In file included from /usr/include/stdio.h:927:0,
                                   from ./RF24_config.h:24,
                                   from RF24.cpp:17:
                  /usr/include/arm-linux-gnueabihf/bits/stdio.h: In function ‘int vprintf(const char*, __gnuc_va_list)’:
                  /usr/include/arm-linux-gnueabihf/bits/stdio.h:37:58: sorry, unimplemented: Thumb-1 hard-float VFP ABI
