  3. How to pass #define value to library
10 Posts 2 Posters 1.9k Views 2 Watching
  • R Offline
    R Offline
    Rbonat
    Re: How to pass the #define for MySensors
    I found that old topic answering my question, but the answer:
    "The "trick" we use in the mysensors library is to include code files (cpp) in the MySensors.h header file"
    is really not clear to me.
    If I have mylib.h and mylib.cpp, what exactly should I do to have #define values available in library?
    R 1 Reply Last reply
    • R Rbonat
      R Offline
      R Offline
      Rbonat
      Maybe more details will interest someone to help and share this "tricky" solution.
      I've written a lightweight code for passive node sending messages to MySensors gateway.
      The goal was to utilize dozens of Attiny's and Atmega's low resources AVR's laying in my drawer for simple motion/door/switch/light/temp remote sensors.
      Code compiles and works stable even on smallest Attinys, the goal was achieved.
      Now I'm trying to create an library based on that code, with "MySensors like" API, to share it.
      For that task the only thing I'm not able to do is to pass #define values from main sketch to the library, which seems to be a standard in MySensors API.
      Whatever i try I always get " NAME was not declared in this scope".
      I've already try to include cpp in header, no progress.
      While I do not understand the "trick", i don't know what I'm doing wrong, and I see it working in MySensors library, so frustrating.
      What do I have to do, to have this example definitions from main code:
      #define MY_NODE_ID 3
      #define MY_CE_PIN 4
      #include <MyTinySensors.h>
      accesible in level of cpp library scope, to use like this?
      bool sendRaw( MyMessage* data)
        #if defined MY_CE_PIN
          digitalWrite(MY_CE_PIN, LOW);
          delay(40);
      • electrikE Offline
        electrikE Offline
        electrik
        I think you have to include the source.cpp in the file MyTinySensors.h
        So
        #include "source.cpp"
        • R Offline
          R Offline
          Rbonat
          Thank you for your response, but still not working :(
          MyTinySensors.h:
          #ifndef MyTinySensors_h
          #define MyTinySensors_h
          #include "MyMessage.h"
          #include "MyTinySensors.cpp"  // ----- source cpp included
          bool myTinySensorInit(MyMessage &msg);
          bool sendSketchInfo(const char *name, const char *version, MyMessage &msg, const bool requestEcho=false);
          bool present(const uint8_t childSensorId, const mysensors_sensor_t sensorType, const char *description, MyMessage &msg, const bool requestEcho =false);
          bool send( MyMessage &msg);
          bool sendRaw( MyMessage* data);
          begining of MyTinySensors.cpp:
          //#include "MyTinySensors.h"  // ------ when not commented, duplicate definition error
            msg.setCommand(C_SET);
            return sendRaw(&msg);
          And still:
          ...platformio\lib\MyTinySensors\MyTinySensors.cpp: In function 'bool sendRaw(MyMessage*)':
          ...platformio\lib\MyTinySensors\MyTinySensors.cpp:39:16: error: 'MY_NODE_ID' was not declared in this scope
          Any other ideas what can I try?
          • electrikE Offline
            electrikE Offline
            electrik
            I've compared your approach to what is done in MySensors.h. In MySensors.h, the cpp file is included instead of the header file.
            #include "core/MyMessage.cpp"
            If you follow the same steps like in MySensors.h, it should give the same result.
            • R Offline
              R Offline
              Rbonat
              Thank you for your assistance, I think we are close, but not there yet.
              MyMessage is not an issue, it doesn't use global definitions and compiles without errors.
              The "magic" is in MySensorsCore and others libraries, using global definitions.
              In MySensors, include sequence is: Sketch -> include MySensors.h -> include both MysensorsCore.h (line 47) and MysensorsCore.cpp (line 433).
              In my project I try to do (almost) the same: Sketch -> include MyTinySensors.h -> include MyTinySensors.cpp.
              Does not work.
              So let's do exactly same sequence. I've added MyTinyWrapper.h (replacement of MySensors.h), including both MyTinySensors.h and MyTinySensors.cpp, and included MyTinyWrapper.h in main sketch.
              MyTinyWrapper.h:
              #ifndef MyTinyWrapper_h
              #define MyTinyWrapper_h
              MyTinySensors.h:
              bool sendSketchInfo(const char *name, const char *version, MyMessage &msg);
              bool present(const uint8_t childSensorId, const mysensors_sensor_t sensorType, const char *description, MyMessage &msg);
              MyTinySensors.cpp:
              #define SOH 1
              #define STX 2
              #define ETX 3
              #define EOT 4
              #define ICSC_SYS_PACK 0x58
              #define GATEWAY_ADDRESS 0
              #define NODE_SENSOR_ID 0xFF
                  delay(40);
              Result? Still same error 'MY_NODE_ID' was not declared in this scope' in MyTinySensors.cpp
              Can you analyze this if there are any differences with MySensors approach ?
              • electrikE Offline
                electrikE Offline
                electrik
                @Rbonat said in How to pass #define value to library:
                MY_NODE_ID
                Where have you defined this value exactly?
                • R Offline
                  R Offline
                  Rbonat
                  In the begging of main sketch of course :)
                  #define MY_CE_PIN 4
                  #define SENSOR_ID 1
                  #define sensorPin 2
                  #include "MyTinyWrapper.h"
                  //attiny13 osc cal
                  #include <EEPROM.h>
                  bool lastTripped=false;
                  MyMessage myMSG;
                    // Attiny13 softserial oscillator callibration
                    // Check if there exist any OSCCAL value in EEPROM addr. 0
                    // If not, run the oscillator tuner sketch first
                    uint8_t cal = EEPROM.read(0);
                    if(cal < 0x7F)
                    OSCCAL = cal;
                    //Init MyTinySensors library and presentation of node and sensors
                    myTinySensorInit(myMSG);
                    sendSketchInfo("Test3", "2.1", myMSG);
                    present(SENSOR_ID, S_MOTION, "My Motion", myMSG);
                    //send initial values - mandatory for Home Assistant integration
                    myMSG.setSensor(SENSOR_ID);
                    myMSG.setType(V_TRIPPED);
                    myMSG.set(false);
                    send(myMSG);
                    pinMode(sensorPin, INPUT_PULLUP);      // sets the motion sensor digital pin as input
                   bool tripped = digitalRead(sensorPin);
                   if (tripped != lastTripped)
                     myMSG.set(tripped);
                     send(myMSG);
                     lastTripped=tripped;
                  • electrikE Offline
                    electrikE Offline
                    electrik
                    The only difference I see, is that MY_NODE_ID is not used in MysensorsCore, but only in MyTransport.
                    It looks like you are close indeed, but I don't get this neither.
                    I hope someone else can help and let us know if you succeeded...
                    • electrikE Offline
                      electrikE Offline
                      electrik
                      I think I understand what is happening.
                      The compiler compiles all source files it finds in the folder. So when compiling the sketch itself everything goes fine I think. When the compiler comes across the MyTinySensors.cpp, it tries to compile that file also but can't find the define MY_NODE_ID.
                      So I think you should move these files to subfolders (like done in the MySensors structure), so they won't be compiled individually anymore. Sounds plausible right?
