  3. STM32F411 BlackpillV2 ST core - problem with reading data from RS485 (HW serial 2)
2 Posts 1 Posters 1.1k Views 1 Watching
  • T
    thom4s
    for years Im using MySensors 2.3.1 lib running on Bluepill (STM32F103C8T6 Roger`s STM32 core) with RS485 transport as a node without any problems. Now I need to add new node so I decided to use BlackPill 2 (STM32F411) with STM32 ST core and Whisky Delta fork . (https://github.com/WhiskyDelta/MySensors/tree/stm32_cores) I have no problem with code compilation of simple test node sketch but node is not receiving data from gateway through RS485.
    As you can see from debug log, node send a message and GW replied but node does not received anything. Strange thing is that some chars appeared in debug console "�vXvv���" before 2215 ?TSF:MSG:SEND,.....
    For testing purpose Iv got on desk Ardu Nano as GW with MAX485 converters and as a node I tested with Whisky Delta lib one by one Arduino Mega2560 , Bluepill STM32F103c8t6 , Blackpill2 STM32F411 and F4VE (STM32F407VET). As a node is working only Mega2560. Bluepill were frozen after first attempt to pair with GW. Blackpill 2 and F4VE are repeating sending request for pair to GW with this strange chars in serial debug. ("�vXvv���")
    Im sure that HW is ok. (wiring,DE+RE,termination resistors,5V supply of MAX485, etc)
    Does anybody else has a problem like this ? Do you have any idea where should be a problem ?
    Gateway received data from node and responded
    0;255;3;0;9;8233171 TSF:MSG:READ,118-118-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;8233177 TSF:MSG:BC
    0;255;3;0;9;8233180 TSF:MSG:FPAR REQ,ID=118
    0;255;3;0;9;8233184 TSF:PNG:SEND,TO=0
    0;255;3;0;9;8233187 TSF:CKU:OK
    0;255;3;0;9;8233190 TSF:MSG:GWL OK
    0;255;3;0;9;8233447 TSF:MSG:SEND,0-0-118-118,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    Node trying to pair but does not receive data from gateway. What are chars �vXvv��� ?
    2050 MCO:BGN:INIT OK,TSP=0
    2211 !TSM:FPAR:NO REPLY
    2213 TSM:FPAR
    �vXvv���2215 ?TSF:MSG:SEND,118-118-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0
    Simple node sketch. Debug is using Serial1 and MAX485 is using Serial2
    #define MY_TRANSPORT_WAIT_READY_MS 2000
    //#define MY_TRANSPORT_SANITY_CHECK_INTERVAL 2000
    //#define MY_RS485_SOH_COUNT 2
    #define MY_NODE_ID 118
    #define MY_RS485
    #define MY_RS485_DE_PIN PB3
    #define MY_RS485_HWSERIAL Serial2
    #define CHILD_ID_SudyNode 0
    MyMessage msgStatus(CHILD_ID_SudyNode, V_VAR1); //Status
    MyMessage msgErrorEvent(CHILD_ID_SudyNode, V_VAR2); //Err event
    MyMessage msgDebug(CHILD_ID_SudyNode, V_VAR3); //DEBUG
    void presentation() {  sendSketchInfo("TestNODE", "Ver. 1");present(CHILD_ID_SudyNode, S_CUSTOM);}
         Serial.setRx(PA10);
         Serial.setTx(PA9);
    String SendBuffer = "TEST Message";
    unsigned long CasovacMillis = millis();
    if ((millis() - CasovacMillis) >= 3000) {
     Serial.println("NODE ALIVE");
     send(msgStatus.set(SendBuffer.c_str()));
      if (message.sensor == 123 ) {
          String BufferString = message.getString();
          char CommandBuffer[BufferString.length()];
          BufferString.toCharArray(CommandBuffer, BufferString.length()+1);
          Serial.print("RECEIVED DATA: "); Serial.println(CommandBuffer);
    • T
      thom4s
      OK problem found. Found out that when I selected "Blackpill F411CE" board before code compilation everything were ok.
      Usually I am choosing generic types so I used "F411CEUx" in case of blackpill 2 and I found out that generic types has different default "Serial" pins in ST core. Now I can confirm that Bluepill , Blackpill and F4VE board are working with MAX485.
      ST core v 2.4.0.
      ../.arduino15/packages/STMicroelectronics/hardware/stm32/2.4.0/variants/STM32F4xx/F411C(C-E)(U-Y)/variant_generic.h
      // UART Definitions
      #ifndef SERIAL_UART_INSTANCE
        #define SERIAL_UART_INSTANCE  2
      // Default pin used for generic 'Serial' instance
      // Mandatory for Firmata
      #ifndef PIN_SERIAL_RX
        #define PIN_SERIAL_RX         PA3
      #ifndef PIN_SERIAL_TX
        #define PIN_SERIAL_TX         PA2
      ../.arduino15/packages/STMicroelectronics/hardware/stm32/2.4.0/variants/STM32F4xx/F411C(C-E)(U-Y)/variant_BLACKPILL_F411CE.h
      // UART Definitions
        #define SERIAL_UART_INSTANCE  1
        #define PIN_SERIAL_RX         PA10
        #define PIN_SERIAL_TX         PA9
      So be carefull while using ST core and generic type of STM32.
