  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 76.6k Views 11 Watching
  • G gogomartin
    @Dheeraj
    This is my first try at getting MySensors to work.
    I've connected a SerialGateway to the Pi, and configured a DHT22 sensor. But no values are recorded.
    Logs from the pi:
    <- I_LOG_MESSAGE 0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
    <- I_ID_REQUEST 255;255;3;0;3;
    Serial output from the sensor:
    req node id
    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
    T: 22.70
    req node id
    H: 31.10
    req node id
    H: 31.00
    What can I be doing wrong? Seems like the sensor is requesting a node ID but not getting any?
    Thank you for any kind of response!
    Regards, Martin
    Dheeraj
    @gogomartin
    Currently mysensors plugin only support static node id. Try configuring static node id in sensor code. Hint.. Gw. Begin (null, node id)
    Let me know if it's works
    Sebastien Vayrette-GavardS 1 Reply Last reply
    • R
      R
      ricardot
      Dheeraj,
      Good work!
      Is possible to send sensor battery level info?
      D 2 Replies Last reply
      • R ricardot
        Dheeraj,
        Good work!
        Dheeraj
        @ricardot
        battery sensor visualization is WIP..
        • R
          R
          Ralf H
          hey,
          I really like your plugin now that I finally managed to get everything working. :)
          But I would also like to use a BH1750 Light sensor with your plugin. I made a sensorbox with PIR to switch on lights for a minute when movement is detected, but I only want to switch on light when it's dark enough. Is it planned to add support for this?
          D 1 Reply Last reply
          • D
            Dheeraj
            • R ricardot
              Dheeraj,
              Good work!
              Dheeraj
              @ricardot added support for battery level stats 0.8.9
              • R Ralf H
                hey,
                Dheeraj
                @Ralf-H sure will add support for light sensor
                • Vladut GrecuV
                  Vladut GrecuV
                  Vladut Grecu
                  wrote on last edited by Vladut Grecu
                  #24
                  I would like to help you make a color picker for rgb leds and a slider for random pwm outputs :D
                  -edit-
                  deviceClasses = [
                          MySensorsDHT
                          MySensorsBMP
                          MySensorsPIR
                          MySensorsSwitch
                          MySensorsPulseMeter
                          MySensorsButton
                          MySensorBattery
                          MySensorsDevDimmer
                  and
                   class MySensorsDevDimmer extends env.devices.DimmerActuator
                      constructor: (@config,lastState, @board) ->
                        @id = config.id
                        @name = config.name
                        @_state = lastState?.state?.value
                        env.logger.info "MySensorsDevDimmer" , @id , @name, @_state
                        @board.on('rfValue', (result) =>
                          if result.sender is @config.nodeid and result.type is
                          V_LIGHT and result.sensor is @config.sensorid
                            state = (if parseInt(result.value) is 1 then on else off)
                            env.logger.info "<- MySensorDevDimmer " , result
                            @_setState(state)
                        super()
                      changeStateTo: (state) ->
                        assert state is on or state is off
                        if state is true then _state = 1  else _state = 0
                        datas = {}
                        datas =
                          "destination": @config.nodeid,
                          "sensor": @config.sensorid,
                          "type"  : V_LIGHT,
                          "value" : _state,
                          "ack"   : 1
                        @board._rfWrite(datas).then ( () =>
                          @_setState(state)
                  But i get :
                  Could not initialize the plugin "mysensors": MySensorsDevDimmer is not defined
                  I know that this won`t actually work because of the :
                  and the :
                  What I don't get is why does it throw me that error. (Don't go hard on me, I just learned the basics of coffee script only for this)
                  • Vladut GrecuV Vladut Grecu
                    -edit-
                    deviceClasses = [
                            MySensorsDHT
                            MySensorsBMP
                            MySensorsPIR
                            MySensorsSwitch
                            MySensorsPulseMeter
                            MySensorsButton
                            MySensorBattery
                            MySensorsDevDimmer
                    and
                          @id = config.id
                          @name = config.name
                              @_setState(state)
                          super()
                          datas = {}
                          datas =
                            "type"  : V_LIGHT,
                            "value" : _state,
                            "ack"   : 1
                            @_setState(state)
                    But i get :
                    and the :
                    Dheeraj
                    check the pimatic-daemon.log file and what kind of error exception your are getting . not sure if you have enable the "logLevel": "debug", in config.json for pimatic.
                    Also, you need to add entry in device-config-schema.coffee schema file.
                    if nothing works share the log file with me..
                    I'm also new to coffee or nodejs and struggled a lot understanding the coffee script , basically, still in learning phase..
                    • D Dheeraj
                      @gogomartin
                      @Dheeraj, I have been looking all day for how to configure static node id , meanwhile I heard of mysensors last night so pardon me if I didn't find the doc that explain it. Can you point me in the right direction?
                      • Sebastien Vayrette-GavardS
                        I didn't search enough, http://forum.mysensors.org/topic/753/static-node-id-and-other-unanswered-questions
                        • Sebastien Vayrette-GavardS Sebastien Vayrette-Gavard
                          Dheeraj
                          follow the below instruction
                          for pimatic installation:
                          http://www.pimatic.org/guide/getting-started/installation/
                          plugin instruction:
                          https://github.com/DheerajKhajuria/pimatic-mysensors
                          • J
                            J
                            jurasek
                            Hello, I am new with controler. I already have some temperature sensors and other controls, but until now I did not use any controller,
                            I am not familiar with linux, and I need help with instalation of controler on raspbery 2.
                            I am done with OS instalation, I am using image NOOBS.
                            I try to install Pimatic acording this procedure, http://pimatic.org/guide/getting-started/installation/
                            And now I am not sure what next.
                            Please can anybody help me?
                            funky81F 1 Reply Last reply
                            • J jurasek
                              funky81F
                              funky81F
                              funky81
                              @jurasek I found out that pimatic installation in the website quite general.
                              for more details, you can use following link for the forum.
                              it gives me clear idea and more details step by step
                              • J
                                J
                                jurasek
                                Thanks, I have a pimatic runing now. I would like connect NRF24 directly to the RPI is this possible? How can I setup mysensors plugin for this?
                                • J jurasek
                                  Dheeraj
                                  @jurasek connecting NRF24L01 to RPi directly is possible you will find good amount of references if you search this form.
                                  • F
                                    F
                                    Fredrik Carlsson
                                    Hello @Dheeraj
                                    Any info about how to setup a pulsecount sensor?
                                    D funky81F 2 Replies Last reply
                                      wrote on last edited by Sebastien Vayrette-Gavard
                                      #34
                                      @Dheeraj is the light sensor supported? I am getting
                                      20:32:05.069 [pimatic] warn: no plugin found for device "Light1" of class "MySensorLight"!
                                      when starting pimatic with
                                            "id": "Light1",
                                            "name": "Lighti1",
                                            "class": "MySensorLight",
                                            "nodeid": 11,
                                            "sensorid": 0
                                      yet I am able to see the sensor in pimatic's logs
                                      <- I_LOG_MESSAGE 0;0;3;0;9;read: 11-11-0 s=0,c=1,t=23,pt=2,l=2:39
                                              "id": "Light1",
                                              "name": "Lighti1",
                                              "nodeid": 11,
                                              "sensorid": 0
                                        Dheeraj
                                        yet I am able
                                        kindly change the "class" name as "MySensorsLight" . please note it has a 's' in between.
                                        • F Fredrik Carlsson
                                          Hello @Dheeraj
                                          Dheeraj
                                          @Fredrik-Carlsson
                                          frankly, i couldn't check pulsecount using actual power meter. although i can simulate it :) . It's custom made according to my need. I can modify it as per http://www.mysensors.org/build/pulse_power build easily.
                                          currently it only supports "V_WATT" message.
