  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 76.6k Views 11 Watching
  • R Ralf H
    hey,
    I really like your plugin now that I finally managed to get everything working. :)
    But I would also like to use a BH1750 Light sensor with your plugin. I made a sensorbox with PIR to switch on lights for a minute when movement is detected, but I only want to switch on light when it's dark enough. Is it planned to add support for this?
    Dheeraj
    @Ralf-H sure will add support for light sensor
    • Vladut GrecuV
      Vladut GrecuV
      Vladut Grecu
      wrote on last edited by Vladut Grecu
      #24
      I would like to help you make a color picker for rgb leds and a slider for random pwm outputs :D
      -edit-
      deviceClasses = [
              MySensorsDHT
              MySensorsBMP
              MySensorsPIR
              MySensorsSwitch
              MySensorsPulseMeter
              MySensorsButton
              MySensorBattery
              MySensorsDevDimmer
      and
       class MySensorsDevDimmer extends env.devices.DimmerActuator
          constructor: (@config,lastState, @board) ->
            @id = config.id
            @name = config.name
            @_state = lastState?.state?.value
            env.logger.info "MySensorsDevDimmer" , @id , @name, @_state
            @board.on('rfValue', (result) =>
              if result.sender is @config.nodeid and result.type is
              V_LIGHT and result.sensor is @config.sensorid
                state = (if parseInt(result.value) is 1 then on else off)
                env.logger.info "<- MySensorDevDimmer " , result
                @_setState(state)
            super()
          changeStateTo: (state) ->
            assert state is on or state is off
            if state is true then _state = 1  else _state = 0
            datas = {}
            datas =
              "destination": @config.nodeid,
              "sensor": @config.sensorid,
              "type"  : V_LIGHT,
              "value" : _state,
              "ack"   : 1
            @board._rfWrite(datas).then ( () =>
              @_setState(state)
      But i get :
      Could not initialize the plugin "mysensors": MySensorsDevDimmer is not defined
      I know that this won`t actually work because of the :
      and the :
      What I don't get is why does it throw me that error. (Don't go hard on me, I just learned the basics of coffee script only for this)
      D 1 Reply Last reply
      • Vladut GrecuV Vladut Grecu
        -edit-
        deviceClasses = [
                MySensorsDHT
                MySensorsBMP
                MySensorsPIR
                MySensorsSwitch
                MySensorsPulseMeter
                MySensorsButton
                MySensorBattery
                MySensorsDevDimmer
        and
              @id = config.id
              @name = config.name
                  @_setState(state)
              super()
              datas = {}
              datas =
                "type"  : V_LIGHT,
                "value" : _state,
                "ack"   : 1
                @_setState(state)
        But i get :
        and the :
        Dheeraj
        check the pimatic-daemon.log file and what kind of error exception your are getting . not sure if you have enable the "logLevel": "debug", in config.json for pimatic.
        Also, you need to add entry in device-config-schema.coffee schema file.
        if nothing works share the log file with me..
        I'm also new to coffee or nodejs and struggled a lot understanding the coffee script , basically, still in learning phase..
        • D Dheeraj
          @gogomartin
          Currently mysensors plugin only support static node id. Try configuring static node id in sensor code. Hint.. Gw. Begin (null, node id)
          Let me know if it's works
          Sebastien Vayrette-GavardS
          @Dheeraj, I have been looking all day for how to configure static node id , meanwhile I heard of mysensors last night so pardon me if I didn't find the doc that explain it. Can you point me in the right direction?
          • Sebastien Vayrette-GavardS
            I didn't search enough, http://forum.mysensors.org/topic/753/static-node-id-and-other-unanswered-questions
            • Sebastien Vayrette-GavardS Sebastien Vayrette-Gavard
              Dheeraj
              follow the below instruction
              for pimatic installation:
              http://www.pimatic.org/guide/getting-started/installation/
              plugin instruction:
              https://github.com/DheerajKhajuria/pimatic-mysensors
              • J
                J
                jurasek
                Hello, I am new with controler. I already have some temperature sensors and other controls, but until now I did not use any controller,
                I am not familiar with linux, and I need help with instalation of controler on raspbery 2.
                I am done with OS instalation, I am using image NOOBS.
                I try to install Pimatic acording this procedure, http://pimatic.org/guide/getting-started/installation/
                And now I am not sure what next.
                Please can anybody help me?
                funky81F 1 Reply Last reply
                • J jurasek
                  funky81F
                  funky81F
                  funky81
                  @jurasek I found out that pimatic installation in the website quite general.
                  for more details, you can use following link for the forum.
                  it gives me clear idea and more details step by step
                  • J
                    J
                    jurasek
                    Thanks, I have a pimatic runing now. I would like connect NRF24 directly to the RPI is this possible? How can I setup mysensors plugin for this?
                    • J jurasek
                      Dheeraj
                      @jurasek connecting NRF24L01 to RPi directly is possible you will find good amount of references if you search this form.
                      • F
                        F
                        Fredrik Carlsson
                        Hello @Dheeraj
                        Any info about how to setup a pulsecount sensor?
                        D funky81F 2 Replies Last reply
                          wrote on last edited by Sebastien Vayrette-Gavard
                          #34
                          @Dheeraj is the light sensor supported? I am getting
                          20:32:05.069 [pimatic] warn: no plugin found for device "Light1" of class "MySensorLight"!
                          when starting pimatic with
                                "id": "Light1",
                                "name": "Lighti1",
                                "class": "MySensorLight",
                                "nodeid": 11,
                                "sensorid": 0
                          yet I am able to see the sensor in pimatic's logs
                          <- I_LOG_MESSAGE 0;0;3;0;9;read: 11-11-0 s=0,c=1,t=23,pt=2,l=2:39
                                  "id": "Light1",
                                  "name": "Lighti1",
                                  "nodeid": 11,
                                  "sensorid": 0
                            Dheeraj
                            yet I am able
                            kindly change the "class" name as "MySensorsLight" . please note it has a 's' in between.
                            • F Fredrik Carlsson
                              Hello @Dheeraj
                              Dheeraj
                              @Fredrik-Carlsson
                              frankly, i couldn't check pulsecount using actual power meter. although i can simulate it :) . It's custom made according to my need. I can modify it as per http://www.mysensors.org/build/pulse_power build easily.
                              currently it only supports "V_WATT" message.
                              • F
                                F
                                Fredrik Carlsson
                                wrote on last edited by Fredrik Carlsson
                                #37
                                Good morning @Dheeraj
                                Do you have any example for how you are configuring it? I have made a node with the "original" sketch and configured it with sensor array [0,1,2] in pimatic. I see the device, with parameters w/kw/kWh but no info comes in. Are you using a custom sketch then or how is your setup working?
                                I think one of the nicest things about pimatic is the graphing functionality. I want to log and and check how the heating is distributed throughout my house and at which consumption depending on heatpump / woodstove settings
                                  @Dheeraj maybe you can fix the example here for lazy eyes/asses like me. I just copied and paste and didn't notice the missing "s" Thank you so much for the quick support and the great plugin.
                                    Dheeraj
                                    since i don't have home laptop with me. otherwise , i could have shared the custom sketch with you. but what i remember is that it sends V_WATT message with wattage usage and calculate KW and KWh ( still broken ) at controller end ( pimatic ).
                                    meanwhile, i'm fixing the pulsemeter code which will be compatible with actual sketch, wait for 1 or 2 days. Also, we will be able to see battery status (optional) with sensor devices.
                                    one thing you missed here is that pimatic is browser based also have the "automation by rules" functionality which is awesome. also you can try various plugins available with pimatic. http://www.pimatic.org/pages/plugins/
                                    • F
                                      F
                                      Fredrik Carlsson
                                      @Dheeraj I wait patiently then :)
                                      Yes the more im digging in to pimatic the more i like it and feel that it fits my needs perfectly
                                      • Mad MooM
                                        Mad MooM
                                        Mad Moo
                                        wrote on last edited by Mad Moo
                                        #41
                                        Yesterday was great update (0.8.14). Now battery level is connected with device as regular attribute. Great job, @Dheeraj! Thanks a lot!
                                        • Mad MooM Mad Moo
                                          Dheeraj
                                          newer version (0.8.15 ) of plugin release . support Acronym for devices . improves user experience.
                                          Mad MooM 1 Reply Last reply
