  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 76.6k Views 11 Watching
  • J
    J
    jurasek
    Hello, I am new with controler. I already have some temperature sensors and other controls, but until now I did not use any controller,
    I am not familiar with linux, and I need help with instalation of controler on raspbery 2.
    I am done with OS instalation, I am using image NOOBS.
    I try to install Pimatic acording this procedure, http://pimatic.org/guide/getting-started/installation/
    And now I am not sure what next.
    Please can anybody help me?
    funky81F 1 Reply Last reply
    • J jurasek
      funky81F
      funky81F
      funky81
      @jurasek I found out that pimatic installation in the website quite general.
      for more details, you can use following link for the forum.
      it gives me clear idea and more details step by step
      • J
        J
        jurasek
        Thanks, I have a pimatic runing now. I would like connect NRF24 directly to the RPI is this possible? How can I setup mysensors plugin for this?
        D 1 Reply Last reply
        • J jurasek
          Dheeraj
          @jurasek connecting NRF24L01 to RPi directly is possible you will find good amount of references if you search this form.
          • F
            F
            Fredrik Carlsson
            Hello @Dheeraj
            Any info about how to setup a pulsecount sensor?
            D funky81F 2 Replies Last reply
            • Sebastien Vayrette-GavardS
              wrote on last edited by Sebastien Vayrette-Gavard
              #34
              @Dheeraj is the light sensor supported? I am getting
              20:32:05.069 [pimatic] warn: no plugin found for device "Light1" of class "MySensorLight"!
              when starting pimatic with
                    "id": "Light1",
                    "name": "Lighti1",
                    "class": "MySensorLight",
                    "nodeid": 11,
                    "sensorid": 0
              yet I am able to see the sensor in pimatic's logs
              <- I_LOG_MESSAGE 0;0;3;0;9;read: 11-11-0 s=0,c=1,t=23,pt=2,l=2:39
              • Sebastien Vayrette-GavardS Sebastien Vayrette-Gavard
                      "id": "Light1",
                      "name": "Lighti1",
                      "nodeid": 11,
                      "sensorid": 0
                Dheeraj
                @Sebastien-Vayrette-Gavard said:
                yet I am able
                kindly change the "class" name as "MySensorsLight" . please note it has a 's' in between.
                • F Fredrik Carlsson
                  Hello @Dheeraj
                  Dheeraj
                  @Fredrik-Carlsson
                  frankly, i couldn't check pulsecount using actual power meter. although i can simulate it :) . It's custom made according to my need. I can modify it as per http://www.mysensors.org/build/pulse_power build easily.
                  currently it only supports "V_WATT" message.
                  • F
                    F
                    Fredrik Carlsson
                    wrote on last edited by Fredrik Carlsson
                    #37
                    Good morning @Dheeraj
                    Do you have any example for how you are configuring it? I have made a node with the "original" sketch and configured it with sensor array [0,1,2] in pimatic. I see the device, with parameters w/kw/kWh but no info comes in. Are you using a custom sketch then or how is your setup working?
                    I think one of the nicest things about pimatic is the graphing functionality. I want to log and and check how the heating is distributed throughout my house and at which consumption depending on heatpump / woodstove settings
                      @Dheeraj maybe you can fix the example here for lazy eyes/asses like me. I just copied and paste and didn't notice the missing "s" Thank you so much for the quick support and the great plugin.
                        Dheeraj
                        since i don't have home laptop with me. otherwise , i could have shared the custom sketch with you. but what i remember is that it sends V_WATT message with wattage usage and calculate KW and KWh ( still broken ) at controller end ( pimatic ).
                        meanwhile, i'm fixing the pulsemeter code which will be compatible with actual sketch, wait for 1 or 2 days. Also, we will be able to see battery status (optional) with sensor devices.
                        one thing you missed here is that pimatic is browser based also have the "automation by rules" functionality which is awesome. also you can try various plugins available with pimatic. http://www.pimatic.org/pages/plugins/
                        • F
                          F
                          Fredrik Carlsson
                          @Dheeraj I wait patiently then :)
                          Yes the more im digging in to pimatic the more i like it and feel that it fits my needs perfectly
                          • Mad MooM
                            Mad MooM
                            Mad Moo
                            wrote on last edited by Mad Moo
                            #41
                            Yesterday was great update (0.8.14). Now battery level is connected with device as regular attribute. Great job, @Dheeraj! Thanks a lot!
                            • Mad MooM Mad Moo
                              Dheeraj
                              newer version (0.8.15 ) of plugin release . support Acronym for devices . improves user experience.
                              Mad MooM 1 Reply Last reply
                                Hello @Dheeraj
                                funky81F
                                funky81F
                                funky81
                                @Fredrik-Carlsson info you havent got one, please check my development git
                                • Pulse sensor ( Watt, KWh and Ampere )
                                  "id": "EnergySensor,
                                  "name": "Energy Sensor",
                                  "class": "MySensorsPulseMeter",
                                  "nodeid": 3,
                                  "batterySensor": true,
                                  "sensorid": 1,
                                  "appliedVoltage" : 220
                                • F
                                  F
                                  Fredrik Carlsson
                                  Yes saw it on github, very interesting. Will try as soon as I am home again
                                    funky81F
                                    funky81F
                                    funky81
                                    @Fredrik-Carlsson please try it, please notice me if you find any bugs.
                                    I'm in the middle of pull request to @Dheeraj
                                    • F
                                      F
                                      Fredrik Carlsson
                                      Hello
                                      haven't had the opportunity to test yet.
                                      will try to find time tomorrow
                                      • D Dheeraj
                                        Mad MooM
                                        Mad MooM
                                        Mad Moo
                                        #47
                                        Hello @Dheeraj,
                                        Could you tell me which commit was connected with 0.8.15? I am little bit confused because your github is still contains 0.8.14 but it looks newer when 0.8.15.
                                        • Mad MooM Mad Moo
                                          Hello @Dheeraj,
                                          Dheeraj
                                          @Mad-Moo latest code 0.8.17 is pushed to github. now everything is sync.
