  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 76.6k Views 11 Watching
  • D Dheeraj
    @gogomartin
    Currently mysensors plugin only support static node id. Try configuring static node id in sensor code. Hint.. Gw. Begin (null, node id)
    Let me know if it's works
    Sebastien Vayrette-GavardS
    @Dheeraj, I have been looking all day for how to configure static node id , meanwhile I heard of mysensors last night so pardon me if I didn't find the doc that explain it. Can you point me in the right direction?
    D 1 Reply Last reply
    • Sebastien Vayrette-GavardS
      I didn't search enough, http://forum.mysensors.org/topic/753/static-node-id-and-other-unanswered-questions
      • Sebastien Vayrette-GavardS Sebastien Vayrette-Gavard
        Dheeraj
        follow the below instruction
        for pimatic installation:
        http://www.pimatic.org/guide/getting-started/installation/
        plugin instruction:
        https://github.com/DheerajKhajuria/pimatic-mysensors
        • J
          J
          jurasek
          Hello, I am new with controler. I already have some temperature sensors and other controls, but until now I did not use any controller,
          I am not familiar with linux, and I need help with instalation of controler on raspbery 2.
          I am done with OS instalation, I am using image NOOBS.
          I try to install Pimatic acording this procedure, http://pimatic.org/guide/getting-started/installation/
          And now I am not sure what next.
          Please can anybody help me?
          funky81F 1 Reply Last reply
          • J jurasek
            funky81F
            funky81F
            funky81
            @jurasek I found out that pimatic installation in the website quite general.
            for more details, you can use following link for the forum.
            it gives me clear idea and more details step by step
            • J
              J
              jurasek
              Thanks, I have a pimatic runing now. I would like connect NRF24 directly to the RPI is this possible? How can I setup mysensors plugin for this?
              • J jurasek
                Dheeraj
                @jurasek connecting NRF24L01 to RPi directly is possible you will find good amount of references if you search this form.
                • F
                  F
                  Fredrik Carlsson
                  Hello @Dheeraj
                  Any info about how to setup a pulsecount sensor?
                  D funky81F 2 Replies Last reply
                    wrote on last edited by Sebastien Vayrette-Gavard
                    #34
                    @Dheeraj is the light sensor supported? I am getting
                    20:32:05.069 [pimatic] warn: no plugin found for device "Light1" of class "MySensorLight"!
                    when starting pimatic with
                          "id": "Light1",
                          "name": "Lighti1",
                          "class": "MySensorLight",
                          "nodeid": 11,
                          "sensorid": 0
                    yet I am able to see the sensor in pimatic's logs
                    <- I_LOG_MESSAGE 0;0;3;0;9;read: 11-11-0 s=0,c=1,t=23,pt=2,l=2:39
                            "id": "Light1",
                            "name": "Lighti1",
                            "nodeid": 11,
                            "sensorid": 0
                      Dheeraj
                      yet I am able
                      kindly change the "class" name as "MySensorsLight" . please note it has a 's' in between.
                      • F Fredrik Carlsson
                        Hello @Dheeraj
                        Dheeraj
                        @Fredrik-Carlsson
                        frankly, i couldn't check pulsecount using actual power meter. although i can simulate it :) . It's custom made according to my need. I can modify it as per http://www.mysensors.org/build/pulse_power build easily.
                        currently it only supports "V_WATT" message.
                        • F
                          F
                          Fredrik Carlsson
                          wrote on last edited by Fredrik Carlsson
                          #37
                          Good morning @Dheeraj
                          Do you have any example for how you are configuring it? I have made a node with the "original" sketch and configured it with sensor array [0,1,2] in pimatic. I see the device, with parameters w/kw/kWh but no info comes in. Are you using a custom sketch then or how is your setup working?
                          I think one of the nicest things about pimatic is the graphing functionality. I want to log and and check how the heating is distributed throughout my house and at which consumption depending on heatpump / woodstove settings
                            @Dheeraj maybe you can fix the example here for lazy eyes/asses like me. I just copied and paste and didn't notice the missing "s" Thank you so much for the quick support and the great plugin.
                              Dheeraj
                              since i don't have home laptop with me. otherwise , i could have shared the custom sketch with you. but what i remember is that it sends V_WATT message with wattage usage and calculate KW and KWh ( still broken ) at controller end ( pimatic ).
                              meanwhile, i'm fixing the pulsemeter code which will be compatible with actual sketch, wait for 1 or 2 days. Also, we will be able to see battery status (optional) with sensor devices.
                              one thing you missed here is that pimatic is browser based also have the "automation by rules" functionality which is awesome. also you can try various plugins available with pimatic. http://www.pimatic.org/pages/plugins/
                              • F
                                F
                                Fredrik Carlsson
                                @Dheeraj I wait patiently then :)
                                Yes the more im digging in to pimatic the more i like it and feel that it fits my needs perfectly
                                • Mad MooM
                                  Mad MooM
                                  Mad Moo
                                  wrote on last edited by Mad Moo
                                  #41
                                  Yesterday was great update (0.8.14). Now battery level is connected with device as regular attribute. Great job, @Dheeraj! Thanks a lot!
                                  • Mad MooM Mad Moo
                                    Dheeraj
                                    newer version (0.8.15 ) of plugin release . support Acronym for devices . improves user experience.
                                    Mad MooM 1 Reply Last reply
                                      Hello @Dheeraj
                                      funky81F
                                      funky81F
                                      funky81
                                      @Fredrik-Carlsson info you havent got one, please check my development git
                                      • Pulse sensor ( Watt, KWh and Ampere )
                                        "id": "EnergySensor,
                                        "name": "Energy Sensor",
                                        "class": "MySensorsPulseMeter",
                                        "nodeid": 3,
                                        "batterySensor": true,
                                        "sensorid": 1,
                                        "appliedVoltage" : 220
                                      • F
                                        F
                                        Fredrik Carlsson
                                        Yes saw it on github, very interesting. Will try as soon as I am home again
                                          funky81F
                                          funky81F
                                          funky81
                                          @Fredrik-Carlsson please try it, please notice me if you find any bugs.
                                          I'm in the middle of pull request to @Dheeraj
