  3. nRF24L01+PA+LNA
nRF24L01+PA+LNA
35 Posts 9 Posters 46.7k Views 4 Watching
  • D doblanch
    I use 2" nRF24L01+ with PA + LNA " bought on ebay.
    I connected the arduino directly to the nRF including 3.3V.
    I feel the distance very very short. Maybe 4 meters with a Wall... Should I define RF24_PA_LEVEL_GW to max" ?:
    #define RF24_PA_LEVEL_GW RF24_PA_MAX ???
    Can I expect something better ?
    Or should I use a specific 3.3V power supply which is not very convenient ?
    rgds
    thanks
    korttomaK
    korttomaK
    korttoma
    @doblanch the 3.3V output from an arduino can not provide the current needed for the PA-LNA module.
    Add a seperate power source and/or use a lower setting for your sensor PA level (RF24_PA_LEVEL)" in the MyConfig.h
    • Tomas
    D 2 Replies Last reply
    • korttomaK korttoma
      doblanch
      @korttoma OK. Thank you. Should I use an external power source for both GW + node ? If ext power use, I can keep the level set to max ? In fact, what is the best way to get a maximum range ? Also, should I connect a capacitor ? thank you by advance. rgds
        doblanch
        @korttoma In the arduino doc, it's 40ma for 3.3V pin
        http://arduino.cc/en/main/arduinoBoardUno
        I read in the nrf24L01 doc 11.3ma;
        Transmitter
        x00 Programmable output power: 0, -6, -12 or -18dBm x00 11.3mA at 0dBm output power
        • Receiver
        x00 Fast AGC for improved dynamic range x00 Integrated channel filters
        x00 13.5mA at 2Mbps
        So it should be enough no ? Did I miss something ?
        • korttomaK
          korttomaK
          korttoma
          Thos figures are for the module without the PA LNA. The PA LNA version draws over 100mA
          • Tomas
          D 1 Reply Last reply
            doblanch
            wrote on last edited by doblanch
            @korttoma mmm... that's pretty much clear from now. we are then close to the limit then...which kind of power module is recommended ?
            This one sounds good ? :: http://www.ebay.com/itm/1Pcs-New-3-3V-5V-MB102-Breadboard-Power-Supply-Module-For-Arduino-Breadboard/281372556250?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D29266%26meid%3D1f59438fd24b4f9eb809f216f307ad1a%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D181718046489&rt=nc&autorefresh=true
            it allows to use with one 5V input, and Two output, one is 3.3V and the second one 5V.... do you have a better idea ? thanks in advance rgds.
            AWIA 1 Reply Last reply
            • D doblanch
              AWIA
              AWIA
              AWI
              @doblanch Take a look at MySensors store. The adapter board works good with the amplified radio.
              upload-9050360c-eaf2-403f-bb52-2b104e42622d
              • AWIA AWI
                doblanch
                @AWI I confused from now. This adapter allow to convert 5V to 3.3V. HOwever my problem right now is a problem of consumption. It seems that NRF+PA consummes 100+Ma... each I/O pin on arduino is max 50Ma... I wil not solve my problem to put a 5V to 3.3V ? I need to add a new power source able to provide more than 100ma or more ? correct ?
                AWIA D 2 Replies Last reply
                • D doblanch
                  AWIA
                  AWIA
                  AWI
                  @doblanch Sorry for confusing you. If you are using the Uno the 5V pin can deliver about 450mA if powered from USB and 650mA if powered from power jack. This is more than enough to supply the "Socket Adapter Board" which has a powerfull regulator. The 3.3V pin on the Uno can only supply 40mA.
                  There is nothing wrong with the supply you mentioned either. The converter board is more convenient to connect and includes the capacitors (ceramic & tantalum) needed for a stable supply . Schematic below:
                  upload-484c79ac-6b0d-4723-9674-ccff475064ae
                  • D doblanch
                    dzairo
                    @doblanch ehm.. ATmega chip can get around 25mA maximum from one pin .. but nRF24L01 + PA + LNA is not powered from arduino pin .. is powered from converter.. and this converter must give more then 800mA then .. not problem power .. and if you power Arduino from 5V then OK .. nRF24L01+ have pin 5V tolerant inputs ..
                    • D dzairo
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      @dzairo The "tolerance" you mention is only for in/outputs not for the power supply. It will most likely burn when you supply it with 5V
                      • AWIA AWI
                        dzairo
                        @AWI of course .. he ask for voltage converter.. from 5V to 3.3V ..
                        • D dzairo
                          AWIA
                          AWIA
                          AWI
                          @dzairo Better to be safe ;-)
                          • AWIA AWI
                            doblanch
                            #22
                            @AWI That's clear then.... I didn't know that 5V on uno can draw 450ma... ON their website, they precise only I/O and 3.3V... From now it's very clear. I will use the 5V pin, with "something" to reduce it to 3.3V...
                            I have this in stock : http://www.ebay.com/itm/Mini-3A-DC-DC-Converter-Adjustable-Step-down-Power-Supply-Module-replace-LM2596s-/261328784505?ssPageName=ADME:L:OU:FR:3160
                            a power down module, IN="5V" OUT-"adjustable (including 3.3V)"
                            Do you know for the nano the +5V max draw ?
                            Thank for your help, grandly appreciated.
                            • D doblanch
                              AWIA
                              AWIA
                              AWI
                              @doblanch The Nano has an 78M05 regulator, should be able to supply 500mA (including the power for the MCU and FTDI chip, So more than enough power to power your step-down. Let us know if your problem is solved.
                              • AWIA AWI
                                doblanch
                                #24
                                @AWI Hello, I put a stepdown module on the both end, added a capacitor. I change the myconfig.h file to put RF24_PA_MAX on RF24_PA_LEVEL and RF24_PA_LEVEL_GW . The result was a little bit better, I'm not even sure :-( . But from now, result are good, I switch back my current antenna by the original one delivered with the module NRF24+.
                                in fact, I installed some big antenna (I have some spare with my routed wifi network), but I think it was a mistake. With the NRF24 bulk antenna, it works really better, I have some others tests to do...I will keep you informed in the coming days. thanks again for you help
                                • W
                                  W
                                  wico2002
                                  Hi, i have the same problem. Bought a pa+lna radio with black antenna and only work if i touch the antenna or the radio's pcb, else the data if not sent at all. i added only a 200uf capacitor. Even with the breadboard power supply, to have a separate 3.3v it dont work. My basic nrf24l01+ is working well (except the range) but not the pre amplified one.
                                  Any one have ideas ?
                                  OitzuO 1 Reply Last reply
                                  • W wico2002
                                    OitzuO
                                    OitzuO
                                    Oitzu
                                    @wico2002 try adding a layer of plastic wrap followed by a layer of tin foil around the pcb.
                                    In this process don't let the tinfoil touch the pcb or any connection. This will basically create a farraday cage around your pcb.
                                    I've learned the hard way that the boosted modules can sometimes, at high power levels, interfere with itself.
                                    • W
                                      W
                                      wico2002
                                      @Oitzu I try running it at a lower PA level, set in the code, don't know if it helped or not. I also found if I keep the antenna straight (my antenna plug is pointing on the side, so let say 0 degrees) or at 90 degrees no data is sent but if it is fold at 45 degree the data seems to be sent good even if I don't touch the radio (but still don't know if I got a good range or not). seems to work better without the antenna plugged in ...
                                      i'll try your trick
                                      • OitzuO
                                        OitzuO
                                        Oitzu
                                        @wico2002 that's all really the typical behaviour i observed, too.
                                        In reality the module sends the data but will never receive the "ack" because the signal overloads, due to interferences, the nrf24l01+ on the board.
                                        Holding your hand arround the pcb or antenna or unplugging the antenna weakens the signal and stops this behaviour.
                                        See also: http://forum.mysensors.org/topic/1877/2-x-nrf24l01-pa-lna-with-rf24_pa_max/12
                                        • W
                                          W
                                          wico2002
                                          Thank you for this link.
                                          I will reply in that topic to continue the same subject.
