  3. Backlit Dimmable LED Mirror with Motion Sensor
43 Posts 12 Posters 39.7k Views 14 Watching
  • FrancoisF
    FrancoisF
    Francois
    @hek Yes I am using 1.4.1 on both the sensor. This the error I am getting on the sensor node: The sensor was working on a different node it also has cap on VCC and GRD.
    sensor started, id=25, parent=0, distance=2
    send: 25-25-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
    send: 25-25-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
    read: 0-0-25 s=255,c=3,t=6,pt=0,l=1:M
    send: 25-25-0-0 s=0,c=0,t=4,pt=0,l=5,st=fail:1.4.1
    send: 25-25-0-0 s=1,c=0,t=1,pt=0,l=5,st=fail:1.4.1
    send: 25-25-0-0 s=255,c=3,t=11,pt=0,l=10,st=fail:Mirror LED
    lost parent
    find parent
    send: 25-25-255-255 s=255,c=3,t=7,pt=0,l=0,st=bc:
    read: 0-0-25 s=255,c=3,t=8,pt=1,l=1:1
    new parent=0, d=2
      Strange. Looks like distance to gw is 2 but you're actually communicating to it directly.
      • FrancoisF
        FrancoisF
        Francois
        wrote on last edited by Francois
        @hek this is the sketch from about that that copy and recompile on 1.4.1. I did not used the codebender to compile the sketch.
        This is the serial info on the MQTT Gateway:
        0;0;3;0;9;read: 25-25-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
        0;0;3;0;9;read: 25-25-0 s=255,c=3,t=6,pt=1,l=1:0
        0;0;3;0;9;send: 0-0-25-25 s=255,c=3,t=6,pt=0,l=1,st=ok:M
        0;0;3;0;9;read: 25-25-0 s=0,c=0,t=4,pt=0,l=5:1.4.1
        0;0;3;0;9;read: 25-25-0 s=1,c=0,t=1,pt=0,l=5:1.4.1
        0;0;3;0;9;read: 25-25-0 s=255,c=3,t=11,pt=0,l=10:Mirror LED
        MyMQTT/25/255/V_SKETCH_NAME
        30 27 00 1B 4D 79 4D 51 54 54 2F 32 35 2F 32 35 35 2F 56 5F 53 4B 45 54 43 48 5F 4E 41 4D 45 4D 69 72 72 6F 72 20 4C 45 44
        0;0;3;0;9;read: 25-25-255 s=255,c=3,t=7,pt=0,l=0:
        0;0;3;0;9;send: 0-0-25-25 s=255,c=3,t=8,pt=1,l=1,st=ok:1
        0;0;3;0;9;read: 0-25-25 s=255,c=3,t=8,pt=1,l=1:1
        • FrancoisF
          FrancoisF
          Francois
          Hi I got this sketch to work. There must have being something wrong with MySensor library 1.4.1 once I re-install it and recompile the sketch it is working.
          petewillP 1 Reply Last reply
          • FrancoisF Francois
            petewillP
            petewillP
            petewill
            @Francois Great to hear and thanks for letting us know!
            • FrancoisF
              FrancoisF
              Francois
              @petewill I add a light sensor to your sketch and this now slow everything down what will the reason for this be? The motion sensor will not always pickup motion. I have another node with light and motion sensor and that is working right.
              Here is the code:
               * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
               * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
               * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
               * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
               * The MOSFET Gate pin is connected to Arduino pin 3 (MIRROR_LED_PIN), the MOSFET Drain pin is connected
               * to the LED negative terminal and the MOSFET Source pin is connected to ground.
               * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
               * Version 1.0 - February 15, 2014 - Bruce Lacey
               * Version 1.1 - February 4, 2014 - Pete B - added buttons to control on/off and dim level and a motion sensor
              #define SN "Mirror LED with PIR and LDR"
              #define SV "1.2"
              #define NODE_ID 50  //change to a number to assign a specific ID
              #include <MySigningNone.h>
              #include <MyTransportNRF24.h>
              #include <MyHwATMega328.h>
              #define MIRROR_LED_CHILD 0    //ID of the LED child
              #define MOTION_CHILD 1  //ID of the motion sensor child
              #define CHILD_ID_LIGHT 2 //ID for LDR sensor
              MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
              #define MIRROR_LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
              #define UP_BUTTON_PIN 8  // Arduino Digital I/O pin number for the fade up button
              #define DOWN_BUTTON_PIN 7  // Arduino Digital I/O pin number for the fade down button
              #define POWER_BUTTON_PIN 4  // Arduino Digital I/O pin number for the power button
              #define MOTION_PIN  6  // Arduino pin tied to trigger pin on the motion sensor.
              #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
              #define FADE_PERCENTAGE 10 //The percentage the fade level will be changed when a button is pressed
              MyHwATMega328 hw;
              MySensor gw(radio, hw);
              //MySensor gw; //Don't need to define pins unless they are changing from the default
              static int currentLevel = 0;  // Current dim level...
              uint8_t fadeLevel = 0; //used to store the fade level when using the buttons
              uint8_t upPreviousValue;
              uint8_t downPreviousValue;
              uint8_t powerPreviousValue;
              Bounce upDebouncer = Bounce();
              Bounce downDebouncer = Bounce();
              Bounce powerDebouncer = Bounce();
              //motion sensor
              uint8_t lastMotion = 0;
              unsigned long previousMillis = 0; // last time update //see http://stackoverflow.com/questions/10773425/performing-a-function-after-x-time for more details on this
              unsigned long motionDelay = 10000; // interval at which to keep motion sensor trippped (milliseconds).  Used to prevent too frequent updates to Vera.
              unsigned long upPreviousMillis = 0;
              unsigned long downPreviousMillis = 0;
              unsigned long buttonFadeDelay = 200;
              int lastLightLevel;
              boolean metric = true;
              MyMessage motionMsg(MOTION_CHILD, V_TRIPPED);
              MyMessage dimmerMsg(MIRROR_LED_CHILD, V_DIMMER);
              //MyMessage lightMsg(LED_CHILD, V_LIGHT);  removed, updating with dimmer values only
               * Dimmable LED initialization method
                Serial.println( SN );
                gw.begin( incomingMessage,  NODE_ID);
                // Register the LED Dimmable Light with the gateway
                gw.present(MIRROR_LED_CHILD, S_DIMMER );
                gw.present(MOTION_CHILD, S_MOTION);
                gw.sendSketchInfo(SN, SV);
                 // Setup the button
                pinMode(UP_BUTTON_PIN,INPUT);
                pinMode(DOWN_BUTTON_PIN,INPUT);
                pinMode(POWER_BUTTON_PIN,INPUT);
                // Activate internal pull-up
                digitalWrite(UP_BUTTON_PIN,HIGH);
                digitalWrite(DOWN_BUTTON_PIN,HIGH);
                digitalWrite(POWER_BUTTON_PIN,HIGH);
                upDebouncer.attach(UP_BUTTON_PIN);
                downDebouncer.attach(DOWN_BUTTON_PIN);
                powerDebouncer.attach(POWER_BUTTON_PIN);
                upDebouncer.interval(5);
                downDebouncer.interval(5);
                powerDebouncer.interval(5);
               *  Dimmable LED main processing loop
                //process the LED commands from gateway
               int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
               // Serial.println(lightLevel);
                    gw.send(msg.set(lightLevel));
                    lastLightLevel = lightLevel;
                //motion sensor code
                   if(currentMillis - previousMillis > motionDelay){
                    uint8_t motionDetect = digitalRead(MOTION_PIN);
                    if(motionDetect != lastMotion){
              //        Serial.print("motionDetect Value: ");
              //        Serial.println(motionDetect);
                      gw.send(motionMsg.set(motionDetect));  // Send tripped value to gw
                      if(motionDetect == 1){
                        previousMillis = currentMillis;  //"Tripped" delay
                      else{
                        previousMillis = currentMillis - motionDelay + 1000; //"Not tripped" delay for 1 second to stop rapid "not tripped" and "tripped" updates to Vera
                       lastMotion = motionDetect;
              There are 3 buttons attached to the mirror.  One is an on/off button and the other two will fade up/fade down.
              The sensor will remember the last fade state and fade the lights to that level next time they are turned on.
              If fade up or fade down button is pressed it should store that value into a variable and when the ON button is pressed
              it will fade to that previous value.
                  upDebouncer.update();
                  // Get the update value
                  uint8_t upValue = upDebouncer.read();
                  unsigned long upCurrentMillis = millis();
                  if(upCurrentMillis - upPreviousMillis > buttonFadeDelay){
                    if ((upValue == LOW) && (fadeLevel<100)) { //Because of the internal pullup resistors LOW = button is presssed
                      fadeLevel += FADE_PERCENTAGE;
                      fadeLevel = fadeLevel > 100 ? 100 : fadeLevel;
                      fadeToLevel( fadeLevel );
                    upPreviousMillis = upCurrentMillis;
                  downDebouncer.update();
                  uint8_t downValue = downDebouncer.read();
                  unsigned long downCurrentMillis = millis();
                  if(downCurrentMillis - downPreviousMillis > buttonFadeDelay){
                    if ((downValue == LOW) && (fadeLevel>0)) {
                      fadeLevel -= FADE_PERCENTAGE;
                      fadeLevel = fadeLevel < 0 ? 0 : fadeLevel;
                      //powerState = fadeLevel; //Remember fade level for when power button is pressed
                    downPreviousMillis = downCurrentMillis;
                  powerDebouncer.update();
                  uint8_t powerValue = powerDebouncer.read();
                  if(powerValue != powerPreviousValue){
                    if (powerValue == LOW) {
                    Serial.print("Power Button Pressed. fadeLevel is ");
                    Serial.println(fadeLevel);
                      if (currentLevel > 0) {
                        fadeToLevel( 0 );
                      else{
                        if (fadeLevel == 0) {
                          fadeToLevel(50);
                          fadeLevel = 50;
                        else{
                          fadeToLevel(fadeLevel);
                    powerPreviousValue = powerValue;
                if (message.type == V_LIGHT || message.type == V_DIMMER) {
              //    Serial.print( "Changing level to " );
              //    Serial.print( requestedLevel );
              //    Serial.print( ", from " );
              //    Serial.println( currentLevel );
                  fadeToLevel( requestedLevel );
               *  This method provides a graceful fade up/down effect
              void fadeToLevel( int toLevel ) {
              //  Serial.print("toLevel Value: ");
              //  Serial.println(toLevel);
              //  Serial.print("currentLevel Value: ");
              //  Serial.println(currentLevel);
                int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
                while ( currentLevel != toLevel ) {
                  currentLevel += delta;
                  analogWrite( MIRROR_LED_PIN, (int)(currentLevel / 100. * 255) );
                  delay( FADE_DELAY );
                //gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));  //used to send status of light (on/off) to Vera
                gw.send( dimmerMsg.set(currentLevel) );
                Here is the code:
                #define SV "1.2"
                MyHwATMega328 hw;
                //motion sensor
                int lastLightLevel;
                   // Setup the button
                        else{
                          fadeToLevel( 0 );
                        else{
                            fadeToLevel(50);
                            fadeLevel = 50;
                          else{
                petewillP
                petewillP
                petewill
                @Francois I usually put a "millis" delay for all of my sensors that don't need instant updates (temperature, humidity, light, etc). I have had some of my sensors updating too frequently and causing communication issues for the rest of my sensors. Maybe that's what's happening to you? Try adding some code so the light sensor only updates once per 10 seconds or what ever interval you feel is good. You can use my motion sensor code as an example for adding a delay with millis.
                • petewillP petewill
                  Hi Everyone,
                  I have created backlit mirror based on Bruce Lacey's dimmable LED sketch. I have added a motion sensor and some on/off and fade up/down buttons. There is some logic in the code to save the dim level when the buttons are pressed. I have all my motion turn on/off logic in my Vera controller using PLEG. It could be easily adapted to control the on/off functionality in the Arduino code but I like to have my automation logic in one place (my Vera).
                  This was a fun project to work on and although it looks pretty ugly from the back my wife loves the way it looks in our master bathroom. I tried to document as best I could but please let me know if you have any questions.
                  Here is a list of the parts I used
                  • Items from MySensors Store http://www.mysensors.org/store/
                    • Female Pin Header Connector Strip
                    • Prototype Universal Printed Circuit Boards (PCB)
                    • NRF24L01 Radio
                    • Arduino Pro Mini
                    • FTDI USB to TTL Serial Adapter
                    • Capacitors (10uf and .1uf)
                    • 3.3v voltage regulator
                    • 5v voltage regulator
                    • IRLZ44N Logic Level Transistor MOSFET
                    • 12v Transformer (power supply)
                    • 5 Meter LED Strip (I used 3528)
                    • HC-SR501 PIR Motion Sensor Module
                  • 22-24 gauge wire or similar (I used Cat5/Cat6 cable)
                  • 2 Pole 5mm Pitch PCB Mount Screw Terminal Block
                  Here is a video explaining how to build it yourself.
                  http://youtu.be/jblaMddRDpc
                  Here is the Fritzing (http://fritzing.org/) wiring diagram file if you want to view in more detail: Mirror LED Wiring Diagram.fzz
                  https://codebender.cc/sketch:81486
                  H
                  H
                  henno
                  @petewill Just wanted to let you know that I've built two of these for my daughters but instead of putting them behind a mirror I put it under their bed. Works really good, thanks for sharing!
                  petewillP hekH DrJeffD 3 Replies Last reply
                  • H henno
                    petewillP
                    petewillP
                    petewill
                    @henno Cool idea!
                    • H henno
                      Scares away all the monsters? :trollface:
                      • H henno
                        DrJeffD
                        DrJeffD
                        DrJeff
                        @henno That is too funny I was at a hotel and they had LEDs under the cabinets with motion sensors to light the floor. So when I came home I knew I saw some guy doing something similar to a mirror that I'm gonna steal for under my bed to walk at night without bumping my toes! Thanks Pete!
                        • C
                          C
                          csa02221862
                          For those of us without a central 12v system do you know what the current draw is?
                          What is your system setup? Thinking of doing the same.
                          • C csa02221862
                            petewillP
                            petewillP
                            petewill
                            @csa02221862 Sorry for the delayed reply. Unfortunately I don't remember what the power draw is. I believe it is around 1.5A but can't say for sure.
                            • C
                              C
                              csa02221862
                              Thanks. I'm hopeing to do a "ehole house" 12v system also. What is your power source. I've been looking at
                              http://www.banggood.com/AC110V-220V-To-DC12V-12_5A-150W-Voltage-Transformer-Switch-Power-Supply-For-LED-Strip-p-984967.html?currency=USD&createTmp=1&utm_source=google&utm_medium=shopping&utm_content=saul&utm_campaign=led-gadget-US&gclid=Cj0KEQjw44exBRCu8vfS_bPEtNoBEiQACrt002cdBU-mBxB0Z5PGsGCkTgwp37OcWYL28zNGmJNjTu8aAitZ8P8HAQ
                              Thoughts?
                              • C csa02221862
                                Thoughts?
                                petewillP
                                petewillP
                                petewill
                                @csa02221862 Depending on what you want to run it may be a little under powered. For the last year and a half I have been using a hacked 300 watt PC power supply. I originally just set it up as a temporary measure but it has been working great. I have even made some stupid wiring mistakes and shorted it out a few times. Each time I just fix the mistake and it powers right back on. I need to make a video of how I set everything up but I have had so little time lately...
                                • C
                                  C
                                  csa02221862
                                  Thanks for the info. I may get this for use in the "lab" and see what you are doing with the computer power supply when you do the video. I believe many of us would like to have a 12v/5v power distribution system in the house.
                                  Your videos are OUTSTANDING!
                                  • C
                                    C
                                    csa02221862
                                    Looking forward to the "whole house power" video.
                                    I'm building this for two mirrors as well as kitchen under counter and bookcase down lighting.
                                    Your Vera videos have been MOST helpful. You do great "practical" work.
                                    THANKS AGAIN!
                                    • C csa02221862
                                      THANKS AGAIN!
                                      petewillP
                                      petewillP
                                      petewill
                                      @csa02221862 Great! I have these all around my house in various places and I love them. All credit goes to @blacey.
                                      I do need to work on the power video. There are so many things I want to work on I have been focusing on making videos as I work on new sensors. It's so hard to find time these days...
                                      • Dave DanD
                                        Dave DanD
                                        Dave Dan
                                        @petewill ,
                                        I have a question on this project.
                                        I'm replicating it for a wider mirror and I was thinking about having two separate dimming zones ( left and right ). based on the sketch and the design: Do you think One arduino can control both sides or do I need 2 different arduinos (+ electronics) and one won't be enough.
                                        Happy to details more if needed.
                                        thanks in advance!
                                        • Dave DanD Dave Dan
                                          @petewill ,
                                          thanks in advance!
                                          petewillP
                                          petewillP
                                          petewill
                                          Definitely. I have one pro mini controlling 3 different dimmers. You just need to make sure you use PWM pins for the outputs.
