  3. Domoticz
  4. Domoticz Beta for MySensors official support?
18 Posts 7 Posters 10.4k Views 5 Watching
  • jeylitesJ jeylites
    @blacey I didn't know you into Domoticz.
    What's up @kunall....I will like to see where this project goes from a user perspective.
    K
    K
    kunall
    @jeylites After success with OpenHab, I wanted to give a try to Domoticz. Lets see how it goes. I will keep you updated!
    • raditvR
      raditvR
      raditv
      @kunall which sketch did you use for relay with button? did you modify the sketch?
      K 1 Reply Last reply
      • raditvR raditv
        K
        K
        kunall
        wrote on last edited by kunall
        @raditv I used the default sketch given in examples for Relay actuator on mysensors. I checked my ethernet gateways debug log, it seems that its not receiving any command from Domoticz at all.
        • raditvR
          raditvR
          raditv
          wrote on last edited by raditv
          I see, I never check ethernet script for domoticz, maybe there's a bugs there. I'll check it anyway. but if you try serial gateway, it will run
          K 2 Replies Last reply
          • raditvR raditv
            K
            K
            kunall
            @raditv Yeah, let me know if you face any issues with ethernet gateway. I will give a try to serial gateway, right now!
            • H hawk_2050
              @blacey, I also built and installed from the head of the Domoticz trunk a few days ago on my Raspberry Pi 2. Although it runs initially after a few minutes the web server side of the application crashes and burns. Have you experienced anything like that when running it on your Pi 2?
              Richard
              K
              K
              kunall
              @hawk_2050 I had few crashing issues today when I installed from source code. It ran fine for a while, got me excited and then started crashing. So I went ahead and installed from stable binary. So far no issues except I can not turn on/off light from the UI. Not sure if its the ethernet gateway issue or domoticz'.
              • raditvR raditv
                K
                K
                kunall
                @raditv @hek I can confirm that the Light turns on/off with Serial gateway. Just tried it and it works. However it does not work with ethernet gateway sketch. Any solution to make it work with ethernet?
                • blaceyB blacey
                  @kunall Probably. I built Domoticz on an RPI2 recently and it included MySensors hardware/device support out of the box so to speak. I followed the "Installing from Source" instructions here. which means that my install included the latest and greatest from the Domoticz development team.
                  K
                  K
                  kunall
                  @blacey Are you running Serial or Ethernet gateway for Domoticz?
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    I've installed monit, to keep an eye on my domoticz install, It restarts it automaticly if it crashes.
                    I'm using serial GW for mine, and only have 2 Sensors (mysensors micro type) connected at the moment. (and some virtual presence detection "sensors" running on my router.
                    • raditvR
                      raditvR
                      raditv
                      if you dont want to install anything to restart domoticz when it's crash. you can put crontab to check it with bash script like this
                      put this on your cront :
                      */1 * * * * sudo /opt/Domoticz/scripts/online_check.sh 2>&1 >> /dev/null
                      and this is online_check.sh
                      #!/bin/bash
                      #Title check_domoticz_online.sh
                      # check domoticz
                      sudo service domoticz.sh status
                      # if not found - equals to 1, start it
                      if [ $? -eq 1 ]
                      then
                      sudo service domoticz.sh restart
                      echo "Domoticz running - do nothing"
                      fi
