  3. Newbie Problem! Get Started with NRF24L01+
55 Posts 9 Posters 28.0k Views 2 Watching
    The serial gateway does not hand out ids by itself.
    If you want to create something standalone I suggest you set static id:s on your nodes and don't rely on any configuration (metric/imperial) received from controller.
    F 1 Reply Last reply
      F
      F
      fakeJake
      @hek How can I set static IDs?
        http://www.mysensors.org/download/sensor_api_14#the-full-api
        Second argument to gw.begin(NULL, xxx);
        • C Chester
          Just to check, did you upload the DallasTemperatureSensor.ino, or did you upload the Temperature sketch inside the MySensors subfolder?
          I'm at work currently so I can't give exact details, but I noticed that if you unpack the MySensors package into the Arduino libraries, you get a heap of example sketches for various items, but then inside the MySensors subfolder are the sketches set up for the MySensors stuff.
          So check which one you have used for the remote module with the dallas sensor.
          Also on the serial gateway, check the serial output on that (at 115,200 board speed), and check, it should say "Gateway setup complete" or something close to that.
          F
          F
          fakeJake
          wrote on last edited by fakeJake
          @Chester : After checking the wire and the supply I know my connection isn't the problem so I replaced my Arduino.
          This is the output:
          send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
          req node id
          send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
          sensor started, id 255
          req node id
          req node id
          req node id
          req node id
          @hek : After using gw.begin(NULL, 0);
          Thi is the output:
          send: 0-0-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
          sensor started, id 0
          send: 0-0-255-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
          send: 0-0-255-0 s=255,c=3,t=6,pt=1,l=1,st=fail:255
          send: 0-0-255-0 s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor
          send: 0-0-255-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
          send: 0-0-255-0 s=0,c=0,t=6,pt=0,l=5,st=fail:1.4.1
          send: 0-0-255-0 s=0,c=1,t=0,pt=7,l=5,st=fail:29.9
          What are the s,c,t,pt
          • korttomaK
            korttomaK
            korttoma
            Don't use 0 for your node ID! (gw.begin(NULL, 0);) Choose a value beween 1 and 254.
            nodeId - The unique id (1-254) for this sensor.
            Do not confuse this with child sensor ID
            childSensorId - The unique child id you want to choose for the sensor connected to this Arduino. Range 0-254.
            • Tomas
            • korttomaK korttoma
              F
              F
              fakeJake
              @korttoma : Ok. Thank you! Could you kindly explain what are the send, s, c, t, pt, l and st?
              tekkaT 1 Reply Last reply
              • rvendrameR
                rvendrameR
                rvendrame
                Maybe this may cover it http://www.mysensors.org/download/serial_api_14
                ESP8266 GW + mySensors 2.3.2
                Alexa / Google Home
                • F fakeJake
                  tekkaT
                  tekkaT
                  tekka
                  @fakeJake you could also use the latest release of MYSController (0.1.2.278) to have the debug messages parsed.
                  • F
                    F
                    fakeJake
                    Can I use the inclusion button on the serialGateway?
                    korttomaK 1 Reply Last reply
                    • F fakeJake
                      korttomaK
                      korttomaK
                      korttoma
                      yes
                      • Tomas
                      • F
                        F
                        fakeJake
                        The inclusion button is used to detect the connecting modules, yes?
                        This is the output I get when I press the inclusion button on the serial gateway
                        0;0;3;0;9;Inclusion started by button.
                        0;0;3;0;5;1
                        0;0;3;0;5;0
                        I have another NRF module with ds18b20 connected. Can you help me on how I can get the temp sensor to connect to the serial gateway? I c
                        I used the code here and changed the gw.begin() to gw.begin(NULL, 1)
                        sensor started, id 1
                        send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
                        send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                        send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor
                        send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
                        send: 1-1-0-0 s=0,c=0,t=6,pt=0,l=5,st=fail:1.4.1
                        send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:29.6
                        send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:29.7
                        send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
                        send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:29.8
                        • A
                          andriej
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            How are you powering your node? Your node's radio is constantly fail to transmit (st=fail).
                            Alexa / Google Home
                            hekH 1 Reply Last reply
                            • rvendrameR rvendrame
                              It's actually the gateway having problems transmitting acks back to node.
                                F
                                F
                                fakeJake
                                I'm powering the nrf modules from same 3.3V supply since I haven't bought a regulator yet. I'll test it again later. I'll be going out to buy them now.
                                Just to give me a heads up. What should the serial gateway get after i press the inclusion button?
                                • F
                                  F
                                  fakeJake
                                  #23
                                  Sorry for the late reply
                                  Each modules are now supplied with 5V and 3.3V.
                                  This is the serial gateway output:
                                  0;0;3;0;9;read: 1-1-0 s=0,c=1,t=0,pt=7,l=5:30.2
                                  1;0;1;0;0;30.2
                                  0;0;3;0;5;1
                                  0;0;3;0;5;0
                                  This is the temp output:
                                  send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:30.2
                                  st keeps on failing. I checked the nrf supply and it ranges from 3.1v to 3.3 v. Is this bad? I'm using spx2815 since it's the only thing available to me. I placed 10uF capacitor in the 5v input and 3.3v output to ground
                                    F
                                    F
                                    fakeJake
                                    It only explains the "0;0;3;0;14;" but not the "s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor" that it sends or reads
                                    • rvendrameR
                                      rvendrameR
                                      rvendrame
                                      @fakeJake , are the node far from gateway, or any obstacle (such as a wall) in between? Another source of interference is for example a microwave.
                                      Alexa / Google Home
                                        F
                                        F
                                        fakeJake
                                        They are just 6 inches apart :worried:
                                        • rvendrameR
                                          rvendrameR
                                          rvendrame
                                          Some people reported trouble with cheap fake radios. If you have spares nRF try replacing one of them or both.
                                          You mentioned a flotation (3.1 to 3.3) in radio VCC, this can also be a reason, as these nRF are very sensible to power variations.
                                          Post your sketches too, just incase...
                                          Alexa / Google Home
