  3. Newbie Problem! Get Started with NRF24L01+
55 Posts 9 Posters 28.0k Views 2 Watching
  • korttomaK
    korttomaK
    korttoma
    Don't use 0 for your node ID! (gw.begin(NULL, 0);) Choose a value beween 1 and 254.
    nodeId - The unique id (1-254) for this sensor.
    Do not confuse this with child sensor ID
    childSensorId - The unique child id you want to choose for the sensor connected to this Arduino. Range 0-254.
    • Tomas
    F 1 Reply Last reply
    • korttomaK korttoma
      F
      F
      fakeJake
      @korttoma : Ok. Thank you! Could you kindly explain what are the send, s, c, t, pt, l and st?
      tekkaT 1 Reply Last reply
      • rvendrameR
        rvendrameR
        rvendrame
        Maybe this may cover it http://www.mysensors.org/download/serial_api_14
        ESP8266 GW + mySensors 2.3.2
        Alexa / Google Home
        • F fakeJake
          tekkaT
          tekkaT
          tekka
          @fakeJake you could also use the latest release of MYSController (0.1.2.278) to have the debug messages parsed.
          • F
            F
            fakeJake
            Can I use the inclusion button on the serialGateway?
            korttomaK 1 Reply Last reply
            • F fakeJake
              korttomaK
              korttomaK
              korttoma
              yes
              • Tomas
              • F
                F
                fakeJake
                wrote on last edited by fakeJake
                The inclusion button is used to detect the connecting modules, yes?
                This is the output I get when I press the inclusion button on the serial gateway
                0;0;3;0;9;Inclusion started by button.
                0;0;3;0;5;1
                0;0;3;0;5;0
                I have another NRF module with ds18b20 connected. Can you help me on how I can get the temp sensor to connect to the serial gateway? I c
                I used the code here and changed the gw.begin() to gw.begin(NULL, 1)
                sensor started, id 1
                send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
                send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor
                send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
                send: 1-1-0-0 s=0,c=0,t=6,pt=0,l=5,st=fail:1.4.1
                send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:29.6
                send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:29.7
                send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
                send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:29.8
                • A
                  andriej
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    How are you powering your node? Your node's radio is constantly fail to transmit (st=fail).
                    Alexa / Google Home
                    hekH 1 Reply Last reply
                    • rvendrameR rvendrame
                      It's actually the gateway having problems transmitting acks back to node.
                        F
                        F
                        fakeJake
                        I'm powering the nrf modules from same 3.3V supply since I haven't bought a regulator yet. I'll test it again later. I'll be going out to buy them now.
                        Just to give me a heads up. What should the serial gateway get after i press the inclusion button?
                        • F
                          F
                          fakeJake
                          #23
                          Sorry for the late reply
                          Each modules are now supplied with 5V and 3.3V.
                          This is the serial gateway output:
                          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=0,pt=7,l=5:30.2
                          1;0;1;0;0;30.2
                          0;0;3;0;5;1
                          0;0;3;0;5;0
                          This is the temp output:
                          send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=fail:30.2
                          st keeps on failing. I checked the nrf supply and it ranges from 3.1v to 3.3 v. Is this bad? I'm using spx2815 since it's the only thing available to me. I placed 10uF capacitor in the 5v input and 3.3v output to ground
                            F
                            F
                            fakeJake
                            It only explains the "0;0;3;0;14;" but not the "s=255,c=3,t=11,pt=0,l=18,st=fail:Temperature Sensor" that it sends or reads
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              @fakeJake , are the node far from gateway, or any obstacle (such as a wall) in between? Another source of interference is for example a microwave.
                              Alexa / Google Home
                                F
                                F
                                fakeJake
                                They are just 6 inches apart :worried:
                                • rvendrameR
                                  rvendrameR
                                  rvendrame
                                  Some people reported trouble with cheap fake radios. If you have spares nRF try replacing one of them or both.
                                  You mentioned a flotation (3.1 to 3.3) in radio VCC, this can also be a reason, as these nRF are very sensible to power variations.
                                  Post your sketches too, just incase...
                                  Alexa / Google Home
                                  • F
                                    F
                                    fakeJake
                                    I'm using the DallasTemperatureSensor.ino on MySensors library. I just change the gw.begin(); to gw.begin(NULL, 1);
                                    // Example sketch showing how to send in OneWire temperature readings
                                    #include <OneWire.h>
                                    int numSensors=0;
                                    boolean receivedConfig = false;
                                    boolean metric = true;
                                    MyMessage msg(0,V_TEMP);
                                      // Startup OneWire
                                      sensors.begin();
                                      // Startup and initialize MySensors library. Set callback for incoming messages.
                                      gw.begin(NULL,1);
                                      gw.sendSketchInfo("Temperature Sensor", "1.0");
                                         gw.present(i, S_TEMP);
                                      // Process incoming messages (like config from server)
                                        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                        if (lastTemperature[i] != temperature && temperature != -127.00) {
                                          gw.send(msg.setSensor(i).set(temperature,1));
                                      gw.sleep(SLEEP_TIME);
                                    • F
                                      F
                                      fakeJake
                                      Good news! The gateway is now working :)
                                      I changed the dallas temperature to relay actuator and, yes, it's now working!
                                      Bad news is I still don't know what went wrong with my temperature sensor.
                                      I'll investigate on it soon.
                                      This is the gateway output:
                                      0;0;3;0;9;read: 2-2-0 s=255,c=0,t=18,pt=0,l=5:1.4.1
                                      2;255;0;0;18;1.4.1
                                      0;0;3;0;9;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:0
                                      2;255;3;0;6;0
                                      0;0;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=5:Relay
                                      2;255;3;0;11;Relay
                                      0;0;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3:1.0
                                      2;255;3;0;12;1.0
                                      0;0;3;0;9;read: 2-2-0 s=1,c=0,t=3,pt=0,l=5:1.4.1
                                      2;1;0;0;3;1.4.1
                                      This is the relay output:
                                      repeater started, id 2
                                      send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                                      send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                                      send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=5,st=ok:Relay
                                      send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                                      send: 2-2-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                                      I just need to test it.
                                      Since I'll be using a gsm to control the relay. Can you help me on what to send to the relay to turn it on/off?
                                      • rvendrameR
                                        rvendrameR
                                        rvendrame
                                        @fakeJake , I' m glad it worked with relay sketch.
                                        Regarding the temperature, try to move the sensor to other arduino pin. Pin 2 & 3 are used by interrupts and may not play nice with gw.sleep depending on the lib used.
                                        To send a message to the relay , you need a controller connected to the GW, either via USB or ethernet. You can also simulate it by entering the message on the Serial monitor.
                                        The protocol is described here http://www.mysensors.org/download/serial_api_14
                                        Alexa / Google Home
                                        • F
                                          F
                                          fakeJake
                                          #31
                                          I tried entering message on the serial monitor of the gateway but still no luck.
                                          This is the closest thing that I did to tell the relay to turn the light on.
                                          Gateway output after I enter "2;0;1;1;2;1;" to the Serial monitor:
                                          0;0;3;0;9;read: 2-2-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
                                          2;255;0;0;17;1.4.1
                                          2;255;3;0;6;0
                                          2;255;3;0;11;Relay
                                          2;255;3;0;12;1.0
                                          2;1;0;0;3;1.4.1
                                          0;0;3;0;9;send: 0-0-2-2 s=0,c=1,t=2,pt=0,l=1,st=ok:1
                                          0;0;3;0;9;read: 2-2-0 s=0,c=1,t=2,pt=0,l=1:1
                                          2;0;1;1;2;1
                                          Relay output after "2;0;1;1;2;1;" :
                                          sensor started, id 2
                                          send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                                          read: 0-0-2 s=0,c=1,t=2,pt=0,l=1:1
                                          send: 2-2-0-0 s=0,c=1,t=2,pt=0,l=1,st=ok:1
                                          Incoming change for sensor:0, New status: 1
                                          Still it doesn't turn on the light
