  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 333.4k Views 52 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    just for inspiration, here's another irrigation controller video (no, it's not mine.. but one of my friends that made it)
    https://www.youtube.com/watch?v=BRU0xrd8dn0
    petewillP DrJeffD 2 Replies Last reply
    • DidiD
      DidiD
      Didi
      Wow 48 channels thats awesome
      • tbowmoT tbowmo
        petewillP
        petewillP
        petewill
        @tbowmo WOW! What did he use that for??
        tbowmoT 1 Reply Last reply
        • tbowmoT tbowmo
          DrJeffD
          DrJeffD
          DrJeff
          @tbowmo Time for a Shower, Can you say body sprays! :)
          • petewillP petewill
            tbowmoT
            tbowmoT
            tbowmo
            @petewill
            He recently planted a lot of trees, so instead of walking around and watering each one manually he made this
            Its a arduino with a nrf24 module, but not using the mysensors library (yet...)
            petewillP 1 Reply Last reply
            • tbowmoT tbowmo
              @petewill
              petewillP
              petewillP
              petewill
              @tbowmo said:
              @petewill
              I guess so :)
              Cool!
              • BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @treb0r
                here is a stab at modification for no shift register... not much changes.
                Not tested but it compiles...
                Let me know if you see anything in testing.
                MySprinkler for MySensors
                Arduino Multi-Zone Sprinkler Control
                June 30, 2015
                *** Version 2.0nsr //MODIFIED FOR NO SHIFT REGISTER
                * LED status indicator
                PARTS LIST:
                * Relays (8 channel)
                * NRF24L01 Radio
                * Arduino (I used a Pro Mini)
                * Capacitors (10uf and .1uf)
                * 3.3v voltage regulator
                * Resistors (270 & 10K)
                * Female Dupont Cables
                * LED
                * Push button
                * Shift Register (SN74HC595)
                * 18 gauge wire (for relay)
                INSTRUCTIONS:
                  on the serial monitor.
                #include <Time.h>
                #include <LiquidCrystal.h>
                #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                #define SKETCH_VERSION "2.0nsr"
                #define CHILD_ID_SPRINKLER 0
                #define ACTIVE_LOW // comment out this line if your relays are active high
                #ifdef ACTIVE_LOW
                #define ALL_VALVES_OFF 0xFFFF
                #define ALL_VALVES_OFF 0U
                #ifdef DEBUG_ON
                typedef enum {
                SprinklerStates;
                SprinklerStates lastState;
                const int relayPin[NUMBER_OF_VALVES] = {5,6,7,8};//<<<<<<<<<<<<<<<<<<< YOUR DIGITAL PINS HERE
                byte menuState = 0;
                unsigned long menuTimer;
                byte countDownTime = 10;
                int allZoneTime [NUMBER_OF_VALVES + 1];
                int valveSoloTime [NUMBER_OF_VALVES + 1];
                int valveNumber;
                int lastValve;
                unsigned long startMillis;
                const int ledPin = 4;//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< CHANGED THIS TOO
                const int waterButtonPin = 3;
                boolean buttonPushed = false;
                boolean showTime = true;
                boolean clockUpdating = false;
                boolean recentUpdate = true;
                const char *dayOfWeek[] = {
                String valveNickName[17] = {
                time_t lastTimeRun = 0;
                /*Setup Shift Register...<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BIT
                const int latchPin = 8;
                const int clockPin = 4;
                const int dataPin  = 7;
                LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                  SERIAL_START(115200);
                  /*  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BLOCK
                  pinMode(latchPin, OUTPUT);
                  pinMode(clockPin, OUTPUT);
                  pinMode(dataPin, OUTPUT);
                  pinMode(ledPin, OUTPUT);
                  attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                  digitalWrite (ledPin, HIGH);
                  updateRelays(ALL_VALVES_OFF);
                  //delay(5000);
                  lcd.clear();
                  lcd.backlight();
                  lcd.createChar(0, clock);
                  lcd.createChar(1, raindrop);
                  delay(500);
                  if (gw.loadState(0) == 0xFF); // EEPROM flag
                    for (int i = 0; i < 4 ; i++)
                      lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                  gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                    gw.present(i, S_LIGHT);
                  digitalWrite (ledPin, LOW);
                  DEBUG_PRINTLN(F("Ready..."));
                  lcd.setCursor(0, 0);
                  lcd.setCursor(15, 0);
                  lcd.write(byte(0));
                  lcd.setCursor(0, 1);
                  int clockCounter = 0;
                    gw.requestTime(receiveTime);
                    delay(1000);
                    lcd.print(".");
                    clockCounter++;
                    if (clockCounter > 16)
                      lcd.clear();
                      delay(2000);
                  lcd.clear();
                    pinMode(relayPin[i], OUTPUT);//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< ADDED PINMODE HERE
                    lcd.print(F(" Updating  "));
                    lcd.print(i);
                    boolean flashIcon = false;
                    DEBUG_PRINT(i);
                    DEBUG_PRINTLN(F(" Data..."));
                    while (gw.process() == false)
                      flashIcon = !flashIcon;
                      gw.request(i, V_VAR1);
                      delay(100);
                      gw.request(i, V_VAR2);
                      delay(100);
                      gw.request(i, V_VAR3);
                      delay(100);
                  lcd.clear();
                  updateClock();
                  updateDisplay();
                  goGetValveTimes();
                  if (buttonPushed)
                    menuTimer = millis();
                      state = ZONE_SELECT_MENU;
                      menuState = 0;
                      menuState++;
                        menuState = 0;
                    slowToggleLED ();
                    if (state != lastState)
                        delay(50);
                        gw.send(msg1valve.setSensor(i).set(false), false);
                      lcd.clear();
                      lcd.setCursor(0,0);
                      lcd.setCursor(0,1);
                      delay(2000);
                      lastValve = -1;
                    if (lastValve != valveNumber)
                          gw.send(msg1valve.setSensor(i).set(true), false);
                    lastValve = valveNumber;
                    fastToggleLed();
                      valveNumber = 1;
                      startMillis = millis();
                      valveNumber++;
                        state = CYCLE_COMPLETE;
                        lastValve = -1;
                        lastTimeRun = now();
                        DEBUG_PRINT(F("State = "));
                        DEBUG_PRINTLN(state);
                    fastToggleLed();
                      DEBUG_PRINT(F("Zone: "));
                      DEBUG_PRINTLN(valveNumber);
                      fastToggleLed();
                  else if (state = ZONE_SELECT_MENU)
                    displayMenu();
                  lastState = state;
                void displayMenu(void)
                  static int lastSecond;
                    lcd.clear();
                    lcd.print(F("Starting"));
                    lcd.print(F("."));
                    Serial.print(".");
                  lastSecond = thisSecond;
                    if (menuState == 0)
                      valveNumber = 1;
                      state = RUN_ALL_ZONES;
                      valveNumber = menuState;
                      state = RUN_SINGLE_ZONE;
                  lastMenuState = menuState;
                void updateRelays(int value)
                  /*<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<  COMMENTED OUT THIS BLOCK BELOW
                  digitalWrite(latchPin, LOW);
                  digitalWrite(latchPin, HIGH);
                  //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<   ADDED THIS BLOCK BELOW
                  for (byte i = 0; i < NUMBER_OF_VALVES; i++)
                    digitalWrite(relayPin[i], bitRead(value, i));
                    buttonPushed = true;
                void fastToggleLed()
                    fastLedTimer = millis ();
                void slowToggleLED ()
                    slowLedTimer = millis ();
                  boolean zoneTimeUpdate = false;
                  if (message.isAck())
                    if (message.sensor == i)
                      if (message.type == V_LIGHT)
                        if (switchState == 0)
                          if (i == 0)
                            valveNumber = 1;
                            valveNumber = i;
                            DEBUG_PRINTLN(i);
                        DEBUG_PRINT(i);
                        DEBUG_PRINT(F(" = "));
                        DEBUG_PRINTLN(variable1);
                          allZoneTime[i] = variable1;
                          zoneTimeUpdate = true;
                        DEBUG_PRINT(i);
                        DEBUG_PRINTLN(variable2);
                          valveSoloTime[i] = variable2;
                        if (newMessage.length() == 0)
                          DEBUG_PRINTLN(i);
                        if (newMessage.length() > 16)
                          newMessage.substring(0, 16);
                        valveNickName[i] = "";
                        DEBUG_PRINT(F("Recieved new name for zone "));
                        DEBUG_PRINT(i);
                        DEBUG_PRINT(F(" and it is now called: "));
                  if (zoneTimeUpdate)
                      if (i != 0)
                        DEBUG_PRINT(F("Zone "));
                        DEBUG_PRINT(i);
                        DEBUG_PRINTLN(allZoneTime[i]);
                    recentUpdate = false;
                void updateDisplay()
                  static boolean displayToggle = false;
                    switch (state) {
                      case STAND_BY_ALL_OFF:
                        fastClear();
                        if (displayToggle)
                          if (clockUpdating)
                            lcd.write(byte(0));
                          lcd.print(hourFormat12());
                          lcd.print(minute());
                          lcd.print(month());
                          lcd.print(day());
                          lcd.print(F("/"));
                          lcd.print(year() % 100);
                          if (clockUpdating)
                            lcd.write(byte(0));
                          lcd.setCursor(11, 1);
                          lcd.print(day(lastTimeRun));
                      case RUN_SINGLE_ZONE:
                        fastClear();
                        if (displayToggle)
                          lcd.print(F(" Zone:"));
                          lcd.print(valveNumber);
                          lcd.print(F(" Active"));
                            lcd.print("min");
                            lcd.print("sec  ");
                      case RUN_ALL_ZONES:
                        fastClear();
                        if (displayToggle)
                          lcd.print(F(" Active "));
                          lcd.print("min");
                          lcd.print("sec  ");
                      case CYCLE_COMPLETE:
                        if (displayToggle)
                          int totalTimeRan = 0;
                          lcd.print(totalTimeRan);
                          lcd.print(" Minutes   ");
                    lastUpdateTime = millis();
                  lastDisplayState = state;
                  int lastSecond = second();
                  int lastMinute = minute();
                  int lastHour = hour();
                  setTime(newTime);
                    DEBUG_PRINT(hourFormat12());
                    DEBUG_PRINT(minute());
                    DEBUG_PRINT(month());
                    DEBUG_PRINT(F("/"));
                    DEBUG_PRINT(day());
                    DEBUG_PRINTLN(year());
                    showTime = false;
                void fastClear()
                void updateClock()
                    lcd.write(byte(0));
                    clockUpdating = true;
                    lastVeraGetTime = millis();
                  if (gw.loadState(0) != 0xFF)
                    gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                  for (int i = 1; i < 5; i++)
                    gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                void goGetValveTimes()
                  static byte valveIndex = 1;
                  if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                    DEBUG_PRINTLN(F("Calling for Valve Data..."));
                    lcd.write(byte(1)); //lcd.write(1);
                    gw.request(valveIndex, V_VAR1);
                    gw.request(valveIndex, V_VAR2);
                    gw.request(valveIndex, V_VAR3);
                    valveUpdateTime = millis();
                    valveIndex++;
                    if (valveIndex > NUMBER_OF_VALVES + 1)
                      valveIndex = 1;
                  @treb0r
                  June 30, 2015
                  PARTS LIST:
                  * NRF24L01 Radio
                  * LED
                  * Push button
                  INSTRUCTIONS:
                  #include <Time.h>
                  #ifdef ACTIVE_LOW
                  #ifdef DEBUG_ON
                  typedef enum {
                  SprinklerStates;
                  byte menuState = 0;
                  int valveNumber;
                  int lastValve;
                    //delay(5000);
                    lcd.clear();
                    lcd.backlight();
                    delay(500);
                    lcd.write(byte(0));
                      delay(1000);
                      lcd.print(".");
                      clockCounter++;
                        lcd.clear();
                        delay(2000);
                    lcd.clear();
                      lcd.print(i);
                      DEBUG_PRINT(i);
                        delay(100);
                        delay(100);
                        delay(100);
                    lcd.clear();
                    updateClock();
                    updateDisplay();
                    goGetValveTimes();
                    if (buttonPushed)
                        menuState = 0;
                        menuState++;
                          menuState = 0;
                      slowToggleLED ();
                          delay(50);
                        lcd.clear();
                        lcd.setCursor(0,0);
                        lcd.setCursor(0,1);
                        delay(2000);
                        lastValve = -1;
                      fastToggleLed();
                        valveNumber = 1;
                        valveNumber++;
                          lastValve = -1;
                      fastToggleLed();
                        fastToggleLed();
                      displayMenu();
                    lastState = state;
                      lcd.clear();
                      lcd.print(F("."));
                      Serial.print(".");
                      if (menuState == 0)
                        valveNumber = 1;
                            if (i == 0)
                              valveNumber = 1;
                              valveNumber = i;
                              DEBUG_PRINTLN(i);
                          DEBUG_PRINT(i);
                          DEBUG_PRINT(i);
                            DEBUG_PRINTLN(i);
                          DEBUG_PRINT(i);
                    if (zoneTimeUpdate)
                        if (i != 0)
                          DEBUG_PRINT(i);
                      switch (state) {
                          fastClear();
                          if (displayToggle)
                            if (clockUpdating)
                              lcd.write(byte(0));
                            lcd.print(month());
                            lcd.print(day());
                            lcd.print(F("/"));
                            if (clockUpdating)
                              lcd.write(byte(0));
                          fastClear();
                          if (displayToggle)
                              lcd.print("min");
                              lcd.print("sec  ");
                        case RUN_ALL_ZONES:
                          fastClear();
                          if (displayToggle)
                            lcd.print("min");
                            lcd.print("sec  ");
                          if (displayToggle)
                    setTime(newTime);
                      DEBUG_PRINT(day());
                      showTime = false;
                  void fastClear()
                  void updateClock()
                      lcd.write(byte(0));
                      valveIndex++;
                        valveIndex = 1;
                  treb0r
                  thank you for this modification. I will test it today. Shall it be working withou any problems with Domoticz on Raspberry Pi?
                  • T treb0r
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    I assume so. It is using S_LIGHT, one of the most used device types. I am unsure however if Domoticz supports V_VAR1 & V_VAR2 for that device type, so you may have to check with other forum members who use Domoticz.
                    • epierreE
                      epierreE
                      epierre
                      Do you think I I could use that kind of design in parallel of a static watering controller, so I could have the basic program with the controller, and manage extras with the arduino/mysensors ?
                      z-wave - Vera -> Domoticz
                      SparkmanS 1 Reply Last reply
                      • epierreE epierre
                        SparkmanS
                        SparkmanS
                        Sparkman
                        wrote on last edited by Sparkman
                        #66
                        Inspired by @BulldogLowell's controller, I've been working on a MySensors irrigation controller that works in parallel with my RainBird Controller. I'm using a double set of relays (one 5VDC set that's controlled by the Arduino and a 24VAC set that's controlled by the 5VDC relays and the RainBird). This way I can also sense in my HA system when the valves have been opened by the RainBird controller. I have the base functionality finished and working on some additional bells and whistles. Will post some details in a separate thread later today.
                        Al
                        • SparkmanS Sparkman
                          Al
                          treb0r
                          Regarding the Video presenting this irrigation project: is the 15 min time, which is counting down after starting the valve via pressing the button, programed somewhere in the arduino code? Or it is taken from timer set in the Vera (or Domoticz) controller?
                            treb0r
                            Well, it is not working. Domoticz finds 5 switches, but on LCD there is Message: Failed Clock Synchronisation, and the Updating Valves but still 0 :/ Is the problems with V_VAR1 & V_VAR2 variables?
                            • BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              On my Vera controller (as demonstrated by @petewill ) you would edit the times under Variable1 and Variable2, which corresponds to V_VAR1 and V_VAR2 in the program.
                              The video shows how to modify the values in the arduino by changing the values. I am not sure if Domoticz supports such dataflow. Does Domoticz support V_VAR1 and V_VAR2?
                              does Domoticz support MySensors time function? That I do not know.
                                treb0r
                                @BulldogLowell
                                I am afraid that Domoticz doesn't have such advanced options of configuration of devices. Or maybe I am wrong? Is there any chance to bypass the V_VAR1 variables?
                                Moshe LivneM BulldogLowellB 2 Replies Last reply
                                • T treb0r
                                  @BulldogLowell
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @treb0r This thread seems to imply that V_VAR1 etc are supported. I guess @AWI can say more about that.
                                  • Moshe LivneM Moshe Livne
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    thanks for your help, @Moshe-Livne
                                    Do you know if Domoticz supports returning Unix timestamp using requestTime()?
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @BulldogLowell Sorry, I don't know.
                                      • T treb0r
                                        @BulldogLowell
                                        BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        thanks @Moshe-Livne
                                        @treb0r said:
                                        @BulldogLowell
                                        @treb0r,
                                        If you can find out if V_VAR1 & V_VAR2 can work you can try that. Otherwise we can hard code the watering times by zone into the programming.
                                        If requestTime() isn't supported, we can attach a Real Time Clock (RTC) device to gain back the clock functionality.
                                        You can then use the Domoticz devices to start the ALL_ZONE sequence or individual zones...
                                        Let me know what you would like to do and I can modify the program for you.
                                          thanks @Moshe-Livne
                                          @treb0r said:
                                          @BulldogLowell
                                          @treb0r,
                                          treb0r
                                          @BulldogLowell
                                          requestTime() seems not be supported. A have rtc ds3231 or ds1307. They can use the same commands and libraries. If you would change the code that would perfect :) As you proposed you would also include in the code the timers for zones, instead of requesting them from Domoticz. As I understand these timers are only for manuals starts (via button) right?
