  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 330.8k Views 52 Watching
  • SparkmanS Sparkman
    @BulldogLowell Thanks for posting this. A sprinkler controller to replace my Rainbird controller is next on my list of projects.
    For those looking for a good and relatively cheap soil moisture sensor, these ones are pretty good and use a capacitive sensor: http://www.ebay.com/itm/261675851824. They transmit on 433 MHz. I currently use them with RFXCom and HomeSeer, but for those that don't have RFXCom, the protocol should be relatively easy to reverse engineer and then use directly with MySensors and a 433MHz receiver. I've also bought a few from here: https://www.plantcaretools.com/en/webshop/wireless-moisture-sensor-en-detail. Both sellers were good to deal with. The only drawback to them is that the antenna (and therefore range) is not very good, but there is an easy mod to improve that: http://www.domoticz.com/forum/viewtopic.php?f=13&t=2712
    Al
    DrJeffD
    DrJeffD
    DrJeff
    @Sparkman I like the sensors, I just built some and was dbating the way to make smaller, what kind of battery life do those moisture sensors have?
    @petewill Time to change my current 16 valve arduino sprinklers to a little smarter version like yours! I love this community.
    You have been coming on with some awesome videos and contributions!
    petewillP SparkmanS 2 Replies Last reply
    • DrJeffD DrJeff
      petewillP
      petewillP
      petewill
      @DrJeff I agree this is a great community! So much fun!
      Thanks for the kind words! All credit for this project goes to @BulldogLowell though. I just made the video :)
        Cool @hek!
        Well done @petewill So easy for folks to follow along your outstanding video!
        MySensors Community Rocks!
        DrJeffD
        DrJeffD
        DrJeff
        @BulldogLowell Sorry For not giving the credit where it is due! Major Props @BulldogLowell !
        • DrJeffD DrJeff
          SparkmanS
          SparkmanS
          Sparkman
          They've been running for about 9 months on the first set of batteries (2xAAA) so far and are still going strong.
          Al
          • DrJeffD DrJeff
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            Thanks @DrJeff
            I just made an irrigation controller... @petewill made it for everyone!
            • tbowmoT
              tbowmoT
              tbowmo
              just for inspiration, here's another irrigation controller video (no, it's not mine.. but one of my friends that made it)
              https://www.youtube.com/watch?v=BRU0xrd8dn0
              petewillP DrJeffD 2 Replies Last reply
              • DidiD
                DidiD
                Didi
                Wow 48 channels thats awesome
                • tbowmoT tbowmo
                  petewillP
                  petewillP
                  petewill
                  @tbowmo WOW! What did he use that for??
                  tbowmoT 1 Reply Last reply
                  • tbowmoT tbowmo
                    DrJeffD
                    DrJeffD
                    DrJeff
                    @tbowmo Time for a Shower, Can you say body sprays! :)
                    • petewillP petewill
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @petewill
                      He recently planted a lot of trees, so instead of walking around and watering each one manually he made this
                      Its a arduino with a nrf24 module, but not using the mysensors library (yet...)
                      petewillP 1 Reply Last reply
                      • tbowmoT tbowmo
                        @petewill
                        petewillP
                        petewillP
                        petewill
                        @tbowmo said:
                        @petewill
                        I guess so :)
                        Cool!
                        • BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @treb0r
                          here is a stab at modification for no shift register... not much changes.
                          Not tested but it compiles...
                          Let me know if you see anything in testing.
                          MySprinkler for MySensors
                          Arduino Multi-Zone Sprinkler Control
                          June 30, 2015
                          *** Version 2.0nsr //MODIFIED FOR NO SHIFT REGISTER
                          * LED status indicator
                          PARTS LIST:
                          * Relays (8 channel)
                          * NRF24L01 Radio
                          * Arduino (I used a Pro Mini)
                          * Capacitors (10uf and .1uf)
                          * 3.3v voltage regulator
                          * Resistors (270 & 10K)
                          * Female Dupont Cables
                          * LED
                          * Push button
                          * Shift Register (SN74HC595)
                          * 18 gauge wire (for relay)
                          INSTRUCTIONS:
                            on the serial monitor.
                          #include <Time.h>
                          #include <LiquidCrystal.h>
                          #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                          #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                          #define SKETCH_VERSION "2.0nsr"
                          #define CHILD_ID_SPRINKLER 0
                          #define ACTIVE_LOW // comment out this line if your relays are active high
                          #ifdef ACTIVE_LOW
                          #define ALL_VALVES_OFF 0xFFFF
                          #define ALL_VALVES_OFF 0U
                          #ifdef DEBUG_ON
                          typedef enum {
                          SprinklerStates;
                          SprinklerStates lastState;
                          const int relayPin[NUMBER_OF_VALVES] = {5,6,7,8};//<<<<<<<<<<<<<<<<<<< YOUR DIGITAL PINS HERE
                          byte menuState = 0;
                          unsigned long menuTimer;
                          byte countDownTime = 10;
                          int allZoneTime [NUMBER_OF_VALVES + 1];
                          int valveSoloTime [NUMBER_OF_VALVES + 1];
                          int valveNumber;
                          int lastValve;
                          unsigned long startMillis;
                          const int ledPin = 4;//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< CHANGED THIS TOO
                          const int waterButtonPin = 3;
                          boolean buttonPushed = false;
                          boolean showTime = true;
                          boolean clockUpdating = false;
                          boolean recentUpdate = true;
                          const char *dayOfWeek[] = {
                          String valveNickName[17] = {
                          time_t lastTimeRun = 0;
                          /*Setup Shift Register...<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BIT
                          const int latchPin = 8;
                          const int clockPin = 4;
                          const int dataPin  = 7;
                          LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                            SERIAL_START(115200);
                            /*  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BLOCK
                            pinMode(latchPin, OUTPUT);
                            pinMode(clockPin, OUTPUT);
                            pinMode(dataPin, OUTPUT);
                            pinMode(ledPin, OUTPUT);
                            attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                            digitalWrite (ledPin, HIGH);
                            updateRelays(ALL_VALVES_OFF);
                            //delay(5000);
                            lcd.clear();
                            lcd.backlight();
                            lcd.createChar(0, clock);
                            lcd.createChar(1, raindrop);
                            delay(500);
                            if (gw.loadState(0) == 0xFF); // EEPROM flag
                              for (int i = 0; i < 4 ; i++)
                                lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                            gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                              gw.present(i, S_LIGHT);
                            digitalWrite (ledPin, LOW);
                            DEBUG_PRINTLN(F("Ready..."));
                            lcd.setCursor(0, 0);
                            lcd.setCursor(15, 0);
                            lcd.write(byte(0));
                            lcd.setCursor(0, 1);
                            int clockCounter = 0;
                              gw.requestTime(receiveTime);
                              delay(1000);
                              lcd.print(".");
                              clockCounter++;
                              if (clockCounter > 16)
                                lcd.clear();
                                delay(2000);
                            lcd.clear();
                              pinMode(relayPin[i], OUTPUT);//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< ADDED PINMODE HERE
                              lcd.print(F(" Updating  "));
                              lcd.print(i);
                              boolean flashIcon = false;
                              DEBUG_PRINT(i);
                              DEBUG_PRINTLN(F(" Data..."));
                              while (gw.process() == false)
                                flashIcon = !flashIcon;
                                gw.request(i, V_VAR1);
                                delay(100);
                                gw.request(i, V_VAR2);
                                delay(100);
                                gw.request(i, V_VAR3);
                                delay(100);
                            lcd.clear();
                            updateClock();
                            updateDisplay();
                            goGetValveTimes();
                            if (buttonPushed)
                              menuTimer = millis();
                                state = ZONE_SELECT_MENU;
                                menuState = 0;
                                menuState++;
                                  menuState = 0;
                              slowToggleLED ();
                              if (state != lastState)
                                  delay(50);
                                  gw.send(msg1valve.setSensor(i).set(false), false);
                                lcd.clear();
                                lcd.setCursor(0,0);
                                lcd.setCursor(0,1);
                                delay(2000);
                                lastValve = -1;
                              if (lastValve != valveNumber)
                                    gw.send(msg1valve.setSensor(i).set(true), false);
                              lastValve = valveNumber;
                              fastToggleLed();
                                valveNumber = 1;
                                startMillis = millis();
                                valveNumber++;
                                  state = CYCLE_COMPLETE;
                                  lastValve = -1;
                                  lastTimeRun = now();
                                  DEBUG_PRINT(F("State = "));
                                  DEBUG_PRINTLN(state);
                              fastToggleLed();
                                DEBUG_PRINT(F("Zone: "));
                                DEBUG_PRINTLN(valveNumber);
                                fastToggleLed();
                            else if (state = ZONE_SELECT_MENU)
                              displayMenu();
                            lastState = state;
                          void displayMenu(void)
                            static int lastSecond;
                              lcd.clear();
                              lcd.print(F("Starting"));
                              lcd.print(F("."));
                              Serial.print(".");
                            lastSecond = thisSecond;
                              if (menuState == 0)
                                valveNumber = 1;
                                state = RUN_ALL_ZONES;
                                valveNumber = menuState;
                                state = RUN_SINGLE_ZONE;
                            lastMenuState = menuState;
                          void updateRelays(int value)
                            /*<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<  COMMENTED OUT THIS BLOCK BELOW
                            digitalWrite(latchPin, LOW);
                            digitalWrite(latchPin, HIGH);
                            //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<   ADDED THIS BLOCK BELOW
                            for (byte i = 0; i < NUMBER_OF_VALVES; i++)
                              digitalWrite(relayPin[i], bitRead(value, i));
                              buttonPushed = true;
                          void fastToggleLed()
                              fastLedTimer = millis ();
                          void slowToggleLED ()
                              slowLedTimer = millis ();
                            boolean zoneTimeUpdate = false;
                            if (message.isAck())
                              if (message.sensor == i)
                                if (message.type == V_LIGHT)
                                  if (switchState == 0)
                                    if (i == 0)
                                      valveNumber = 1;
                                      valveNumber = i;
                                      DEBUG_PRINTLN(i);
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(F(" = "));
                                  DEBUG_PRINTLN(variable1);
                                    allZoneTime[i] = variable1;
                                    zoneTimeUpdate = true;
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINTLN(variable2);
                                    valveSoloTime[i] = variable2;
                                  if (newMessage.length() == 0)
                                    DEBUG_PRINTLN(i);
                                  if (newMessage.length() > 16)
                                    newMessage.substring(0, 16);
                                  valveNickName[i] = "";
                                  DEBUG_PRINT(F("Recieved new name for zone "));
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(F(" and it is now called: "));
                            if (zoneTimeUpdate)
                                if (i != 0)
                                  DEBUG_PRINT(F("Zone "));
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINTLN(allZoneTime[i]);
                              recentUpdate = false;
                          void updateDisplay()
                            static boolean displayToggle = false;
                              switch (state) {
                                case STAND_BY_ALL_OFF:
                                  fastClear();
                                  if (displayToggle)
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.print(hourFormat12());
                                    lcd.print(minute());
                                    lcd.print(month());
                                    lcd.print(day());
                                    lcd.print(F("/"));
                                    lcd.print(year() % 100);
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.setCursor(11, 1);
                                    lcd.print(day(lastTimeRun));
                                case RUN_SINGLE_ZONE:
                                  fastClear();
                                  if (displayToggle)
                                    lcd.print(F(" Zone:"));
                                    lcd.print(valveNumber);
                                    lcd.print(F(" Active"));
                                      lcd.print("min");
                                      lcd.print("sec  ");
                                case RUN_ALL_ZONES:
                                  fastClear();
                                  if (displayToggle)
                                    lcd.print(F(" Active "));
                                    lcd.print("min");
                                    lcd.print("sec  ");
                                case CYCLE_COMPLETE:
                                  if (displayToggle)
                                    int totalTimeRan = 0;
                                    lcd.print(totalTimeRan);
                                    lcd.print(" Minutes   ");
                              lastUpdateTime = millis();
                            lastDisplayState = state;
                            int lastSecond = second();
                            int lastMinute = minute();
                            int lastHour = hour();
                            setTime(newTime);
                              DEBUG_PRINT(hourFormat12());
                              DEBUG_PRINT(minute());
                              DEBUG_PRINT(month());
                              DEBUG_PRINT(F("/"));
                              DEBUG_PRINT(day());
                              DEBUG_PRINTLN(year());
                              showTime = false;
                          void fastClear()
                          void updateClock()
                              lcd.write(byte(0));
                              clockUpdating = true;
                              lastVeraGetTime = millis();
                            if (gw.loadState(0) != 0xFF)
                              gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                            for (int i = 1; i < 5; i++)
                              gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                          void goGetValveTimes()
                            static byte valveIndex = 1;
                            if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                              DEBUG_PRINTLN(F("Calling for Valve Data..."));
                              lcd.write(byte(1)); //lcd.write(1);
                              gw.request(valveIndex, V_VAR1);
                              gw.request(valveIndex, V_VAR2);
                              gw.request(valveIndex, V_VAR3);
                              valveUpdateTime = millis();
                              valveIndex++;
                              if (valveIndex > NUMBER_OF_VALVES + 1)
                                valveIndex = 1;
                            @treb0r
                            June 30, 2015
                            PARTS LIST:
                            * NRF24L01 Radio
                            * LED
                            * Push button
                            INSTRUCTIONS:
                            #include <Time.h>
                            #ifdef ACTIVE_LOW
                            #ifdef DEBUG_ON
                            typedef enum {
                            SprinklerStates;
                            byte menuState = 0;
                            int valveNumber;
                            int lastValve;
                              //delay(5000);
                              lcd.clear();
                              lcd.backlight();
                              delay(500);
                              lcd.write(byte(0));
                                delay(1000);
                                lcd.print(".");
                                clockCounter++;
                                  lcd.clear();
                                  delay(2000);
                              lcd.clear();
                                lcd.print(i);
                                DEBUG_PRINT(i);
                                  delay(100);
                                  delay(100);
                                  delay(100);
                              lcd.clear();
                              updateClock();
                              updateDisplay();
                              goGetValveTimes();
                              if (buttonPushed)
                                  menuState = 0;
                                  menuState++;
                                    menuState = 0;
                                slowToggleLED ();
                                    delay(50);
                                  lcd.clear();
                                  lcd.setCursor(0,0);
                                  lcd.setCursor(0,1);
                                  delay(2000);
                                  lastValve = -1;
                                fastToggleLed();
                                  valveNumber = 1;
                                  valveNumber++;
                                    lastValve = -1;
                                fastToggleLed();
                                  fastToggleLed();
                                displayMenu();
                              lastState = state;
                                lcd.clear();
                                lcd.print(F("."));
                                Serial.print(".");
                                if (menuState == 0)
                                  valveNumber = 1;
                                      if (i == 0)
                                        valveNumber = 1;
                                        valveNumber = i;
                                        DEBUG_PRINTLN(i);
                                    DEBUG_PRINT(i);
                                    DEBUG_PRINT(i);
                                      DEBUG_PRINTLN(i);
                                    DEBUG_PRINT(i);
                              if (zoneTimeUpdate)
                                  if (i != 0)
                                    DEBUG_PRINT(i);
                                switch (state) {
                                    fastClear();
                                    if (displayToggle)
                                      if (clockUpdating)
                                        lcd.write(byte(0));
                                      lcd.print(month());
                                      lcd.print(day());
                                      lcd.print(F("/"));
                                      if (clockUpdating)
                                        lcd.write(byte(0));
                                    fastClear();
                                    if (displayToggle)
                                        lcd.print("min");
                                        lcd.print("sec  ");
                                  case RUN_ALL_ZONES:
                                    fastClear();
                                    if (displayToggle)
                                      lcd.print("min");
                                      lcd.print("sec  ");
                                    if (displayToggle)
                              setTime(newTime);
                                DEBUG_PRINT(day());
                                showTime = false;
                            void fastClear()
                            void updateClock()
                                lcd.write(byte(0));
                                valveIndex++;
                                  valveIndex = 1;
                            treb0r
                            thank you for this modification. I will test it today. Shall it be working withou any problems with Domoticz on Raspberry Pi?
                            • T treb0r
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              I assume so. It is using S_LIGHT, one of the most used device types. I am unsure however if Domoticz supports V_VAR1 & V_VAR2 for that device type, so you may have to check with other forum members who use Domoticz.
                              • epierreE
                                epierreE
                                epierre
                                Do you think I I could use that kind of design in parallel of a static watering controller, so I could have the basic program with the controller, and manage extras with the arduino/mysensors ?
                                z-wave - Vera -> Domoticz
                                SparkmanS 1 Reply Last reply
                                • epierreE epierre
                                  SparkmanS
                                  SparkmanS
                                  Sparkman
                                  wrote on last edited by Sparkman
                                  #66
                                  Inspired by @BulldogLowell's controller, I've been working on a MySensors irrigation controller that works in parallel with my RainBird Controller. I'm using a double set of relays (one 5VDC set that's controlled by the Arduino and a 24VAC set that's controlled by the 5VDC relays and the RainBird). This way I can also sense in my HA system when the valves have been opened by the RainBird controller. I have the base functionality finished and working on some additional bells and whistles. Will post some details in a separate thread later today.
                                  Al
                                    Al
                                    treb0r
                                    Regarding the Video presenting this irrigation project: is the 15 min time, which is counting down after starting the valve via pressing the button, programed somewhere in the arduino code? Or it is taken from timer set in the Vera (or Domoticz) controller?
                                      treb0r
                                      Well, it is not working. Domoticz finds 5 switches, but on LCD there is Message: Failed Clock Synchronisation, and the Updating Valves but still 0 :/ Is the problems with V_VAR1 & V_VAR2 variables?
                                      • BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        On my Vera controller (as demonstrated by @petewill ) you would edit the times under Variable1 and Variable2, which corresponds to V_VAR1 and V_VAR2 in the program.
                                        The video shows how to modify the values in the arduino by changing the values. I am not sure if Domoticz supports such dataflow. Does Domoticz support V_VAR1 and V_VAR2?
                                        does Domoticz support MySensors time function? That I do not know.
                                          treb0r
                                          @BulldogLowell
                                          I am afraid that Domoticz doesn't have such advanced options of configuration of devices. Or maybe I am wrong? Is there any chance to bypass the V_VAR1 variables?
                                          Moshe LivneM BulldogLowellB 2 Replies Last reply
