  3. Sketch for Lightning Sensor
58 Posts 14 Posters 41.7k Views 11 Watching
    Oh.. than sensor is more advanced than I thought.
    Send distance in "meter" for now. Stupid thing that the distance sensor example we're sending in cm in the first place.
    Energy intensity is harder. What unit that is that? Maybe you could send it in VAR_1 for now?
    SparkmanS
    SparkmanS
    Sparkman
    @hek The sensor has a number of registers that can be set and/or read, so depending what someone wants to do with it, additional parameters may be sent.
    Ok, will do regarding the units. The energy intensity is just a relative value with no units associated with it. I saw one sketch for a different breakout board for the same chip that converted the intensity to a value in the range of 1-10. The actual value returned can be as large as 16843008. I'll take a look at VAR_1, but don't believe the HomeSeer plugin supports that yet. As a test I used I used V_WATT/S_POWER for now.
    Al
    • jeylitesJ
      jeylitesJ
      jeylites
      @Sparkman
      If you can give me some time say around June or July, I'll be going to a tropical country with lots of lightning. I could test it out for you using Vera.
      SparkmanS 1 Reply Last reply
      • jeylitesJ jeylites
        @Sparkman
        SparkmanS
        SparkmanS
        Sparkman
        @jeylites Thanks, I appreciate the offer. July/August are prime thunderstorm season where I live and they are forecasting a possible thunderstorm for today, so I'm hoping to confirm that everything is working today :-)
        Al
        • sowardS
          sowardS
          soward
          I put one of these together a short while ago -- just missed a storm rolling though, but another round might come through later. There's a reference in the code to AS3935_CAPACITANCE and a comment suggesting it be set to "THE NUMBER LISTED ON YOUR BOARD", however I'm seeing no number listed on the board. Am I just over looking it or is it something you derive?
          thanx,
          JpS
          • sowardS soward
            thanx,
            JpS
            SparkmanS
            SparkmanS
            Sparkman
            wrote on last edited by Sparkman
            @soward So far the thunderstorms have skirted our area, but more to come tonight. Here's hoping ;-)
            The Capacitance value is written on the bag the sensor came in. If you don't have the bag anymore, send an email to TechnicalSupport@PlayingWithFusion.com and they should be able to cross reference your order and provide the value. How does your sketch compare to mine?
            Al
            sowardS 1 Reply Last reply
            • SparkmanS Sparkman
              Al
              sowardS
              sowardS
              soward
              @Sparkman great thanx, I do have the bag somewhere in the pile-of-parts-bags. So far I have only used the demo sketch from playingwithfusion, but once it appears to detect something I'll probably use yours as a base and branch out form there. I'm using a Vera so I can try to use VAR_1 as hek suggested.
                @hek The AS3935 Sensor also registers the energy intensity. What sensor type would be the best way to send that data to the controller? I'm using S_DISTANCE for the calculated distance, but would also like to capture the energy intensity. The energy intensity is returned as a 32 bit integer.
                Also, the AS3935 returns the distance in km, but I believe S_DISTANCE is in cm. Is there a way to specify different units or should I have the sketch convert it to cm and then have the controller convert back to km?
                Al
                H
                H
                hleidecker
                wrote on last edited by hleidecker
                #22
                Two mechanisms have been implemented in the HomeSeer controller plugin (1.0.5574.17274) to support custom unit strings in the controller UI:
                • V_UNIT_PREFIX (only available in the development branch of the MySensors library). The prefix provided in the V_UNIT_PREFIX message will precede the default metric unit (defined by the plugin e.g. m (meter) for the distance sensor). The sensor configuration (metric/imperial) can be set by the user as a property on S_ARDUINO_NODE device via the HomeSeer UI. Please note, the prefix will not take effect when the sensor configuration is set to imperial.
                • A user defined unit string. A unit string can be defined by the user. The metric/imperial configuration unit string and unit prefix will be ignored if a user defined unit string exists. The user defined unit string can be set by the user as a property on the device e..g. S_DISTANCE via the HomeSeer UI.
                The HomeSeer MySensors plugin is available here.
                Best regards,
                Henrik
                • H hleidecker
                  Best regards,
                  Henrik
                  SparkmanS
                  SparkmanS
                  Sparkman
                  @hleidecker Thanks Henrik!
                  • SparkmanS
                    SparkmanS
                    Sparkman
                    Hi all,
                    Well I was finally home when a thunderstorm rolled through and I was able to test the sensor and the sketch. Even though the sensor appeared to be working at 3.3V, I had to change it to 5V to get it to work properly with the USB powered Nano I have it connected to. I modified the sketch slightly (updated in my earlier post) to no longer send data when disturbers or unknown interrupt sources were detected. It's working great now and just need to put it into a case. I may use a different Arduino as well.
                    Al
                      Sweet. Would you want to create a pull request when you're ready with this example (including AS3935 library)?
                      SparkmanS
                      SparkmanS
                      Sparkman
                      #25
                      Hi Henrik,
                      Pull request submitted. Hopefully I did it correctly.
                      Al
                        Nice that you finally got some lightings to test your sketch.
                        Pull request looks all ok!
                        • Tore André RosanderT
                          Tore André Rosander
                          Is it possible to detect the distance to the lightningstrike?
                          I was thinking to get some sort of detector to notify me if there is ligning registered X km away from my home.
                          B SparkmanS 2 Replies Last reply
                          • Tore André RosanderT Tore André Rosander
                            B
                            B
                            boozz
                            @Tore-André-Rosander
                            You would need a sound detector for the thunder. Time (in milliseconds) between lightning and thunder times 0.34[m].
                            Same as you would do it with your own sensors (eyes and ears) :-)
                            BR,
                            Boozz
                              SparkmanS
                              SparkmanS
                              Sparkman
                              @Tore-André-Rosander Yes, the sensor can detect the distance. See the details of the sensor here: http://playingwithfusion.com/productview.php?pdid=22&catid=1001. Although I'm starting to believe that it's actually a lightning repeller rather than a lightning sensor as we've had very little lightning in our area after I installed it :laughing:
                              Al
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                I found a similar sensor in the UK and added this to the list of my to be sensors for the weatherstation. Can I use it inside or it has to be placed outside to have a direct vision?
                                http://www.embeddedadventures.com/as3935_lightning_sensor_module_mod-1016.html
                                Tore André RosanderT 1 Reply Last reply
                                • alexsh1A alexsh1
                                  Tore André Rosander
                                  @alexsh1 What i read when researching this chip it can be placed inside.
                                  @Sparkman Nice, i see that it has a detection range about 40km so thats already a pretty good distance to get a notification when lightning is detected.
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    #32
                                    @Sparkman I suppose your wiring diagram above is correct? I noted that the sensor is not working with 3.3V. Did you manage to find what the problem was? Looking at the datasheet http://www.embeddedadventures.com/datasheets/MOD-1016_hw_v8_doc_v4.pdf I can see what the module can operate down to 2.4V
                                    I am going to receive the sensor in a few days and test it.
                                    As I have a different module manufacturer, I may need to change the sketch as it uses a different library. This is unmodified example sketch:
                                    // AS3935 MOD-1016 Lightning Sensor Arduino test sketch
                                    // Written originally by Embedded Adventures
                                    #include <AS3935.h>
                                    #define IRQ_pin 2
                                    volatile bool detected = false;
                                      while (!Serial) {}
                                      Serial.println("Welcome to the MOD-1016 (AS3935) Lightning Sensor test sketch!");
                                      Serial.println("Embedded Adventures (www.embeddedadventures.com)\n");
                                      Wire.begin();
                                      mod1016.init(IRQ_pin);
                                      //Tune Caps, Set AFE, Set Noise Floor
                                      //autoTuneCaps(IRQ_pin);
                                      mod1016.setTuneCaps(7);
                                      mod1016.setOutdoors();
                                      mod1016.setNoiseFloor(5);
                                      Serial.println("TUNE\tIN/OUT\tNOISEFLOOR");
                                      Serial.print(mod1016.getTuneCaps(), HEX);
                                      Serial.print("\t");
                                      Serial.print(mod1016.getAFE(), BIN);
                                      Serial.print("\t");
                                      Serial.println(mod1016.getNoiseFloor(), HEX);
                                      Serial.print("\n");
                                      pinMode(IRQ_pin, INPUT);
                                      attachInterrupt(digitalPinToInterrupt(IRQ_pin), alert, RISING);
                                      Serial.println("after interrupt");
                                      if (detected) {
                                        translateIRQ(mod1016.getIRQ());
                                        detected = false;
                                    void alert() {
                                      detected = true;
                                    void translateIRQ(uns8 irq) {
                                      switch(irq) {
                                          case 1:
                                            Serial.println("NOISE DETECTED");
                                          case 4:
                                            Serial.println("DISTURBER DETECTED");
                                          case 8:
                                            Serial.println("LIGHTNING DETECTED");
                                            printDistance();
                                    void printDistance() {
                                      int distance = mod1016.calculateDistance();
                                      if (distance == -1)
                                        Serial.println("Lightning out of range");
                                      else if (distance == 1)
                                        Serial.println("Distance not in table");
                                      else if (distance == 0)
                                        Serial.println("Lightning overhead");
                                      else {
                                        Serial.print("Lightning ~");
                                        Serial.print(distance);
                                        Serial.println("km away\n");
                                    This is SPI sketch, I'd like to use I2C connection. Generally, the procedure is as follows:
                                    Wait a few milliseconds for the system to stabilise
                                     Set the tune capacitor to the value indicated on the packaging, by setting the
                                    TUNE_CAP bits of register 8
                                     Wait 2 milliseconds
                                     Callibrate RCO by:
                                    o Sending a calibrate RCO direct command (set memory location 0x3d to the
                                    value 0x96)
                                    o Set Register 0x08, bit 5 to 1
                                    o Wait 2 milliseconds
                                    o Set Register 0x08, bit 5 to 0
                                    The factory calibrating tuning cap value will be fine for general use. When you have a
                                    MOD-1016 in an enclosure or close to other electronics it is worth calibrating the tuning
                                    cap again.
                                      #33
                                      can't wait to test this one too ;) i have pcbs for a weather shield (with bme280, veml6070 etc. ) and i have this sensor on it too (https://forum.mysensors.org/uploads/files/1459631385870-stacked.jpg). But not assembled yet, was busy, i hope asap.. i plan to use it with 3v and i2c. @alexsh1 There are libs for i2c if you want :)
                                      Thx @Sparkman for your work on it ;)
                                      alexsh1A 1 Reply Last reply
                                      • scalzS scalz
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @scalz yes, please (for i2c lib). What is this red board you have?
                                        • SparkmanS
                                          SparkmanS
                                          Sparkman
                                          @alexsh1 @scalz
                                          I'm running my sketch with I2C now, rather than SPI. I found the sensor would lock up occassionally, so recently converted it and am still testing it. I have mine running at 5v now as well instead of 3.3v, but it works fine with either.
                                          I'll post an updated sketch (and wiring diagram) soon. I based both the spi and i2c sketches on the examples found here: http://playingwithfusion.com/productview.php?pdid=22&catid=1001.
                                          Al
