  3. Mailbox/Postbox Alert
31 Posts 8 Posters 21.8k Views 7 Watching
  • N Offline
    N Offline
    n3ro
    wrote on last edited by n3ro
    Just finished my new project.
    I have added two magnetic switches to the front and the back of my postbox. Now i get a Mail if the postman was here :)
    You need:
    1x Arduino Mini Pro 3,3
    1x Battery Holder (2xaaa)
    1x NRF
    2x Reed switches (http://www.reichelt.de/KSK-1A663-2025/3/index.html?&ACTION=3&LA=446&ARTICLE=151700&artnr=KSK+1A663+2025&SEARCH=magnet+schlie�er)
    2x magnets (http://www.reichelt.de/MAGNET-M4/3/index.html?&ACTION=3&LA=446&ARTICLE=12483&artnr=MAGNET+M4&SEARCH=magnet)
    And this or a similar sketch: https://github.com/n3roGit/MySensors_n3ro/tree/master/Mailbox_Alert
    It works great =)
    pimatic + MySensors + Homeduino + z-way
    R DidiD Moshe LivneM 3 Replies Last reply
    • N n3ro
      You need:
      1x NRF
      It works great =)
      R Offline
      R Offline
      RJ_Make
      @n3ro No pictures, it didn't happen.. :eyes:
      RJ_Make
      • N Offline
        N Offline
        n3ro
        Okay :D But at the moment its fixed only freestyle ;)
        • N n3ro
          You need:
          1x NRF
          It works great =)
          DidiD Offline
          DidiD Offline
          Didi
          @n3ro said:
          2x Reedschalter (http://www.reichelt.de/KSK-1A663-2025/3/index.html?&ACTION=3&LA=446&ARTICLE=151700&artnr=KSK+1A663+2025&SEARCH=magnet+schlie�er)
          Hast du gut gemacht mit dem Reedschalter.:stuck_out_tongue_closed_eyes:
          I mean nice denglish :grin:
          N 1 Reply Last reply
          • DidiD Didi
            N Offline
            N Offline
            n3ro
            @Didi und wie heißt das verdammte teil auf englisch? :D
            DidiD 1 Reply Last reply
            • N n3ro
              DidiD Offline
              DidiD Offline
              Didi
              Reed switch :heart:
              • DidiD Didi
                Reed switch :heart:
                N Offline
                N Offline
                n3ro
                @Didi fixed ;)
                • N n3ro
                  @Didi fixed ;)
                  DidiD Offline
                  DidiD Offline
                  Didi
                  @n3ro said:
                  @Didi fixed ;)
                  :thumbsup:
                  • N n3ro
                    You need:
                    1x NRF
                    It works great =)
                    Moshe LivneM Offline
                    Moshe Livne
                    @n3ro I wish mine had a flap... still trying to figure out a way to do that
                    • N Offline
                      N Offline
                      n3ro
                      hmm after some days testing it works very fine, but:
                      the battery drains very fast and in dont know why. The Arduino sleeps the whole time and wakes up when the postman is coming (maybe 2 times a week).
                      The battery drains 11% in 7 Days :(
                      Any Ideas?
                      The power LED and regulator is cutted and the fuses are modified.
                      Regards
                      n3ro
                      R 1 Reply Last reply
                      • N n3ro
                        Any Ideas?
                        Regards
                        n3ro
                        R Offline
                        R Offline
                        RJ_Make
                        @n3ro Are you using an interrupt to wake everything up?
                        RJ_Make
                        • B Offline
                          B Offline
                          BulldogLowell
                          @n3ro
                          I'm guessing that your repeat() function is wearing out the battery.
                          By the way you can take advantage of the return of sleep( ) here:
                          gw.sleep(MAILBOX_FRONT_PIN - 2, CHANGE, MAILBOX_BACK_PIN - 2, CHANGE, 0);
                          like this (untested):
                          #include <readVcc.h>
                          #define NODE_ID 21                      // ID of node
                          #define CHILD_ID 1                      // Id of the sensor child
                          #define MAILBOX_FRONT_PIN 2             // Arduino Digital I/O pin for button/reed switch
                          #define MAILBOX_BACK_PIN 3              // Arduino Digital I/O pin for button/reed switch
                          #define MIN_V 1900 // empty voltage (0%)
                          #define MAX_V 3200 // full voltage (100%)
                          boolean post = false;
                          boolean lastpost = false;
                          int oldBatteryPcnt;
                          int repeat = 20;
                          int trigger = -1;
                          unsigned long goToSleepTime;
                            gw.begin(NULL, NODE_ID, false);
                            pinMode(MAILBOX_FRONT_PIN, INPUT);
                            pinMode(MAILBOX_BACK_PIN, INPUT);
                            digitalWrite(MAILBOX_FRONT_PIN, HIGH);
                            digitalWrite(MAILBOX_BACK_PIN, HIGH);
                            gw.sendSketchInfo("Mailbox Alert", "1.0");
                            gw.present(CHILD_ID, S_MOTION);
                            Serial.println("---------- set Mailbox empty");
                            msg.set(0);
                            if (millis() - goToSleepTime > 10UL) //debounce
                              switch (trigger) {
                                case 0:
                                  post = true;
                                  Serial.println("---------- New Mail");
                                case 1:
                                  post = false;
                                  Serial.println("---------- Mailbox emptied");
                                default:
                                  Serial.println("---------- I just woke up");
                            trigger = -1;
                            if (post != lastpost)
                              Serial.print("---------- Send Mailboxstate ");
                              Serial.println(post ? "full" : "empty");
                              msg.set(post);
                              lastpost = post;
                              sendBattery();
                            goToSleepTime = millis();
                            trigger = gw.sleep(MAILBOX_FRONT_PIN - 2, CHANGE, MAILBOX_BACK_PIN - 2, CHANGE, 0);
                          void sendBattery() // Measure battery
                            int batteryPcnt = min(map(readVcc(), MIN_V, MAX_V, 0, 100), 100);
                            if (batteryPcnt != oldBatteryPcnt)
                              gw.sendBatteryLevel(batteryPcnt); // Send battery percentage
                              oldBatteryPcnt = batteryPcnt;
                            Serial.print("---------- Battery: ");
                            Serial.println(batteryPcnt);
                          • N Offline
                            N Offline
                            n3ro
                            Thx for the tips. I will try it.
                            I have just measured the current:
                            32uA in sleep and both opened
                            when one reen switch is closed: 171uA
                            when both closed: 309uA
                            i use a internal pullup and dont know why the current is so high when switch is closed :(
                            • N Offline
                              N Offline
                              n3ro
                              it is fixed :) changed internal pullup to an external with 680k. now its 32uA with both opened and 47uA with both closed :)
                              • N n3ro
                                Moshe Livne
                                @n3ro how do you do that?
                                • F Offline
                                  F Offline
                                  f1dev
                                  Hi!
                                  I+m trying to do a similar mailbox sensor, but I get different power consumptions hen I ground (pulling down) input pin 2 and 3.
                                  I´m using a pro mini, 3.3v standard boot loader with removed LED and 470k resistors as external pull-ups.
                                  In sleep mode with it draws about 65uA
                                  Roughly the same with input pin 3 -grounded (state 0)
                                  But when I ground pin 2 it draws 7mA
                                  Any ideas whats wrong?
                                  • Moshe LivneM Moshe Livne
                                    N Offline
                                    N Offline
                                    n3ro
                                    @Moshe-Livne just deactivate the this lines:
                                    //digitalWrite(MAILBOX_FRONT_PIN, HIGH);
                                    //digitalWrite(MAILBOX_BACK_PIN, HIGH);
                                    and solder two resistor from 3.3v to pin 2 and 3.
                                    F 1 Reply Last reply
                                    • N n3ro
                                      F Offline
                                      F Offline
                                      f1dev
                                      Ok, so I found that it is the radio that draws about 7mA when I ground input pin 2, it is connected to IRQ-pin on the radio.
                                      @n3ro Have you connected the radio as described on the build-page? [http://www.mysensors.org/build/connect_radio](link url)
                                      • F f1dev
                                        N Offline
                                        N Offline
                                        n3ro
                                        @f1dev yes. But you don't need irq on a node :)
                                        • B BulldogLowell
                                          @n3ro
                                          int oldBatteryPcnt;
                                          int repeat = 20;
                                          int trigger = -1;
                                            msg.set(0);
                                              switch (trigger) {
                                                case 0:
                                                  post = true;
                                                case 1:
                                                  post = false;
                                                default:
                                            trigger = -1;
                                              msg.set(post);
                                              lastpost = post;
                                              sendBattery();
                                          N Offline
                                          N Offline
                                          n3ro
                                          @BulldogLowell could you please explain your changes? I don't understand everything of this :sweat:
