  2. Enclosures / 3D Printing
  3. MySensors Sensebender Micro 3DP Case
22 Posts 8 Posters 17.0k Views 3 Watching
  • tbowmoT tbowmo
    Two things :)
    1. Why an extra cap on the radio? (Not using it myself in my micros from itead)
    2. If you place the boards at the end of the battery pack instead of the backside, wouldn't the casing be smaller then? (If I remember correctly, the sensebender is roughly the same dimensions as the end of the battery pack)
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    wrote on last edited by RJ_Make
    1. The radio is from the original sensor (just transfered it to the Sensebender Micro.)
    2. There are small ridges, one on each side, that stop the battery housing. (can be seen in the first picture of the case)
    3. There are some vents in the bottom of the case, but wasn't sure if it would work. (can be seen in the first picture of the case on the bottom)
    4. It's a Flashforge Creator Pro.
    I've change the top; got rid of the screw holes, and went with a top that has longer side walls to create a friction fit.
    RJ_Make
    • tbowmoT tbowmo
      Two things :)
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @tbowmo
      Missed one part of your question. The reason I went with the backside; I wanted a "slide in" design for the battery holder.
      I'm not talented enough to create a solution that allowed that with the SBM (Sensebender Micro) on the bottom. :bowtie:
      RJ_Make
      • DrJeffD
        DrJeffD
        DrJeff
        Nice! What is your print time? What printer do you have?
        RJ_MakeR 1 Reply Last reply
        • DrJeffD DrJeff
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @DrJeff 3.25 Hours I believe.
          RJ_Make
          • P
            P
            Porky6666
            @ServiceXp
            Would you share the .stl file?
            Greets
            Stefan
            • P Porky6666
              @ServiceXp
              Greets
              Stefan
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @Porky6666
              Here ya go..
              http://www.thingiverse.com/thing:891486
              RJ_Make
              • RJ_MakeR
                RJ_MakeR
                RJ_Make
                V2. Case is smaller, and lighter (much thinner walls) and includes mounting tabs (instead of the rear mounting holes). I also added some side ventilation holes.
                RJ_Make
                  mvader
                  v2 looks good.. would you guess at how much each one of those cost you to make?
                  • M mvader
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @mvader Cost In terms of what?
                    Printer cost, Electricity, Time, Filament??
                    RJ_Make
                      mvader
                      i would say filament cost.
                      more like if you look at how much it cost to print pictures vs have them printed. you don't take the cost of the printer into account.
                      I've been thinking about getting into 3d printing but outside of cases for my sensors i cant think of anything i would print lol
                      so i was just curious, how much it would cost you to print something like that.
                      thanks
                      • M mvader
                        thanks
                        RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        @mvader Around $1.75 in filament for 1 top and body.
                        RJ_Make
                        • RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          Added a Motion Sensor Top
                          RJ_Make
                            got a few print to do when I get home...
                            • K
                              K
                              kalle
                              wrote on last edited by kalle
                              here is my first 3D print for the sensbender micro, printed with Arduino Materia 101 printer - STL files available if needed.
                              I think it is also possible to fit a motion sensor in the top - will try ;-)
                              • K
                                K
                                kalle
                                part 2:
                                • K kalle
                                  RJ_MakeR
                                  RJ_MakeR
                                  RJ_Make
                                  @kalle Nice.. What are you using for the battery contacts?
                                  RJ_Make
                                  • K
                                    K
                                    kalle
                                    Good catch ;-)
                                    Maybe I can build something with copper. There is a bit space to fit it in.
                                    • K
                                      K
                                      kalle
                                      Ok, now with connected batteries without any soldering :-)
