  2. Enclosures / 3D Printing
  3. MySensors Sensebender Micro 3DP Case
22 Posts 8 Posters 17.0k Views 3 Watching
  • tbowmoT tbowmo
    Two things :)
    1. Why an extra cap on the radio? (Not using it myself in my micros from itead)
    2. If you place the boards at the end of the battery pack instead of the backside, wouldn't the casing be smaller then? (If I remember correctly, the sensebender is roughly the same dimensions as the end of the battery pack)
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @tbowmo
    Missed one part of your question. The reason I went with the backside; I wanted a "slide in" design for the battery holder.
    I'm not talented enough to create a solution that allowed that with the SBM (Sensebender Micro) on the bottom. :bowtie:
    RJ_Make
    • DrJeffD
      DrJeffD
      DrJeff
      Nice! What is your print time? What printer do you have?
      RJ_MakeR 1 Reply Last reply
      • DrJeffD DrJeff
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @DrJeff 3.25 Hours I believe.
        RJ_Make
        • P
          P
          Porky6666
          @ServiceXp
          Would you share the .stl file?
          Greets
          Stefan
          • P Porky6666
            @ServiceXp
            Greets
            Stefan
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @Porky6666
            Here ya go..
            http://www.thingiverse.com/thing:891486
            RJ_Make
            • RJ_MakeR
              RJ_MakeR
              RJ_Make
              V2. Case is smaller, and lighter (much thinner walls) and includes mounting tabs (instead of the rear mounting holes). I also added some side ventilation holes.
              RJ_Make
                mvader
                v2 looks good.. would you guess at how much each one of those cost you to make?
                • M mvader
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @mvader Cost In terms of what?
                  Printer cost, Electricity, Time, Filament??
                  RJ_Make
                    mvader
                    i would say filament cost.
                    more like if you look at how much it cost to print pictures vs have them printed. you don't take the cost of the printer into account.
                    I've been thinking about getting into 3d printing but outside of cases for my sensors i cant think of anything i would print lol
                    so i was just curious, how much it would cost you to print something like that.
                    thanks
                    • M mvader
                      thanks
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      @mvader Around $1.75 in filament for 1 top and body.
                      RJ_Make
                      • RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        Added a Motion Sensor Top
                        RJ_Make
                          got a few print to do when I get home...
                          • K
                            K
                            kalle
                            wrote on last edited by kalle
                            here is my first 3D print for the sensbender micro, printed with Arduino Materia 101 printer - STL files available if needed.
                            I think it is also possible to fit a motion sensor in the top - will try ;-)
                            • K
                              K
                              kalle
                              part 2:
                              • K kalle
                                RJ_MakeR
                                RJ_MakeR
                                RJ_Make
                                @kalle Nice.. What are you using for the battery contacts?
                                RJ_Make
                                • K
                                  K
                                  kalle
                                  Good catch ;-)
                                  Maybe I can build something with copper. There is a bit space to fit it in.
                                  • K
                                    K
                                    kalle
                                    Ok, now with connected batteries without any soldering :-)
