  3. Air Conditioning state monitoring sensor
16 Posts 7 Posters 7.2k Views 5 Watching
  • C
    C
    Chester
    Great to see it working! Sometimes its definitely a case of going back to the simplest design idea to get the best result. Congratulations on getting the right solution :)
    • Moshe LivneM Moshe Livne
      First, special thanks to @Chester for thinking the way to do that and @Sparkman, my hero, for correcting my silly mistake.
      These sensors are for checking if the kids (or me, just hypothetically :-) ) left the air conditioning running in their rooms. What makes it work is that the flaps move in a particular way when you turn the air conditioning off in my wall unit and they "close down" to a position that is impossible while its running.
      This is the sensor (looks almost professional!):
      I have since added also battery monitoring although I have to tweak it a bit as it shows 66%.
      The reed sensor sense the presence of a magnet on the flap.
      This is the sensor in position. Couldn't find my kids blue tack so had to use blue tape.
      I have carefully measure everything to fit into one of the super cheap aliexpress project boxes. what I didn't take into account was that the battery adds extra 4mm to the height. Darn.
      Here you can see the magnet:upload_-1 (6).jpg
      and this is the sketch:
      #define REED_PIN 3
      #define INTERRUPT REED_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
      #define CHILD_ID 1
      #define SLEEP_TIME 28800000
        analogReference(INTERNAL);
        pinMode(REED_PIN, INPUT);
        digitalWrite(REED_PIN, HIGH); //internal pullup
      //  pinMode(A0, INPUT);
        gw.begin();
        gw.sendSketchInfo("AirCon Sensor", "1.0");
        gw.present(CHILD_ID, S_LIGHT);
      int old_value = -1;
      int oldBatteryPcnt = 0;
      	int value;
      	int bValue;
        // Listen for any knock at all.
      ///  gw.process(); // Process incomming messages
      //  	t = analogRead(A0);
        	value = digitalRead(REED_PIN);
      	Serial.println(value);
        	delay(500); //debounce
        	if (value != old_value){
        		old_value = value;
        		gw.send(msg.set(value));
      	//Battery
      	bValue = analogRead(BATTERY_SENSE_PIN);
          int batteryPcnt = bValue / 10;
          Serial.print("Battery : ");
      	Serial.print(batteryPcnt);
      	Serial.println("%");
          	oldBatteryPcnt = batteryPcnt;
      	gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @Moshe-Livne
      props for the use of blue tape!
      all kidding aside, this is a great project!
        @Moshe-Livne
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @BulldogLowell It does add a little 60`s look to the whole project, isn't it? I'll make these some pretty wood boxes. My problem is that temps here are now consistently under 10 degrees. white glue turns to cheese when its that cold. Have an idea for this as well... will post when it's ready.
        • C Chester
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @Chester That is why having a forum is so great! I don't think I would have thought about this myself - I tend to oversolve problems.
          • DidiD
            DidiD
            Didi
            you make yourself always down
            • DidiD
              DidiD
              Didi
              you gave me more solutions i think about before you here
              • DidiD Didi
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @Didi Thanks! Still, I tend to oversolve. I know that and try to fight it but whenever I see a problem my first instinct is an RPI with 1/2 TB storage, a few motors and sensors. Simple!
                • T
                  ThinkPad
                  Nice! Although i would probably have opened the unit and see if i could tap into the signal of one of those 'operation' LED's.
                  That way the whole MySensors node would be invisible ;)
                  • Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    And here they are, mounted properly:
                    SparkmanS 1 Reply Last reply
                    • T
                      ThinkPad
                      Looking neat!
                        SparkmanS
                        SparkmanS
                        Sparkman
                        @Moshe-Livne Looks great, but I kind of miss the blue tape :stuck_out_tongue:
                        Al
                        • SparkmanS Sparkman
                          Al
                          Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          @Sparkman I cater for the community members needs:
                            SparkmanS
                            SparkmanS
                            Sparkman
                            @Moshe-Livne :laughing: :satisfied:
                            • DidiD
                              DidiD
                              Didi
                              :laughing:
                              • Ivan ZI
                                Ivan ZI
                                Ivan Z
                                Good idea. Append IR control
