  2. Announcements
  3. MySensors 1.5 Released
34 Posts 21 Posters 25.0k Views 9 Watching
  • D
    Dheeraj
    @hek and team. congratulation on new milestone.
    • JohnJ
      JohnJ
      John
      Congratulations to you and all contributors! I will try to update the plugin asap.
      • RJ_MakeR
        RJ_MakeR
        RJ_Make
        Yeeeeeee Haaaaaaaw :bowtie:
        RJ_Make
        • epierreE
          epierreE
          epierre
          @hek I have them all already:
          Water leak,Moisture : my leaf wetness
          Sound: I have stopped by waiting to have a real decibel algorithm... but I need FFT for that...
          Vibration: done it too ;-) help yourself !
          https://github.com/empierre/arduino/blob/master/FloodSensor.ino
          https://github.com/empierre/arduino/blob/master/LeafWetnessSensor.ino
          https://github.com/empierre/arduino/blob/master/SoundSensor2.ino
          https://github.com/empierre/arduino/blob/master/VibrationSensor.ino
          z-wave - Vera -> Domoticz
          hekH 1 Reply Last reply
          • epierreE epierre
            @epierre
            Thanks, I'll take a look at them and possibly lift them into the examples folder.
            For the flood sensor, what kind of conductivity probe are you using.
            • epierreE
              epierreE
              epierre
              @hek: two conductors ;-) well anything you want here it is binary logic, you don't need to mesure the resistance to know how wet it is ...
              • O
                O
                oded00
                What is the best practice to upgrade from 1.4?
                i'm using vera
                  As said above.. you don't need to update everything in one big bang unless you want to use the new features. Add new sensors with the updated library if you want.
                  • epierreE
                    epierreE
                    epierre
                    @hek seems there is something to correct http://forum.mysensors.org/topic/1729/updated-support-to-serial-version-1-5
                    • epierreE epierre
                      @epierre
                      Already talked to @John. Will update documentation more clearly that V_DIMMER and V_LIGHT has been deprecated for the more general wording V_PERCENTAGE and V_STATUS.
                      The old sketches will still work fine as I've introduced an alias.
                      • JohnJ
                        JohnJ
                        John
                        @hek, @epierre
                        I think i was too fast with committing my updates which creates new downloads automatically (sorry if it was too quick), so I had to do a post just in case of some "eager to update" user i have.
                          sebas
                          Very nice. How do I find out how the new sensor types work? Specifically the RGB and RGBW sensors.
                          I've browsed through the source code but haven't found it yet. What file should I be looking into?
                          • G
                            G
                            gbfromhb
                            Very cool. The timing was perfect. I was just about to jump into the deep end and start deploying the development branch. Thanks everyone for the hard work.
                            • S sebas
                              @sebas
                              Guess I'll have to toss an RGB example together some day. But basically the payload should be a ascii hex string describing the color components. I.e "FF0000" for red.
                              • SweebeeS
                                SweebeeS
                                Sweebee
                                I'm trying to burn the gateway but i get this:
                                /Users/Wiebe/Documents/Arduino/libraries/MySensors/MyGateway.cpp:13:30: fatal error: utility/MsTimer2.h: No such file or directory
                                 #include "utility/MsTimer2.h"
                                compilation terminated.
                                  @diggs
                                  I haven't made sketch-examples for all new sensor types yet. The community needs to help me with that. :)
                                  diggs
                                  @hek
                                  No worries, thanks for clarifying
                                  • BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @hek
                                    I have to say, the documentation for the update to 1.5 was done very well... thanks to you and whomever else assisted.
                                    nice work!
                                    :thumbsup:
                                      Thanks, but still room for improvements. :)
                                      @Anticimex is currently deploying a jenkins build-server to automate builds of the examples for different platforms when things get pushed to github. Makes it much easier to keep up the quality.
                                      This will also allow automatic doxygen documentation and perhaps a bit of a rearrangement of the repository layout which isn't optimal (except when downloading/installing).
                                        msebbe
                                        wrote on last edited by msebbe
                                        #31
                                        @hek I have updated my gateway but should the vera say plugin version 1.5? Or is the plugin version still 1.4? Im confused
                                        • rvendrameR
                                          rvendrameR
                                          rvendrame
                                          Mine says
                                          Plugin Version:1.4
                                          Lib Version: 1.5
                                          So I guess the 'plugin' refers to the lua/xml/json files in Vera.
                                          The oficial page points to Github. If dates are correct there, it seems nothing was changed recently (except by the HVAC device).
                                          ESP8266 GW + mySensors 2.3.2
                                          Alexa / Google Home
