  2. Announcements
  3. MySensors 1.5 Released
34 Posts 21 Posters 25.6k Views 9 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    Yeeeeeee Haaaaaaaw :bowtie:
    RJ_Make
    • epierreE
      epierreE
      epierre
      @hek I have them all already:
      Water leak,Moisture : my leaf wetness
      Sound: I have stopped by waiting to have a real decibel algorithm... but I need FFT for that...
      Vibration: done it too ;-) help yourself !
      https://github.com/empierre/arduino/blob/master/FloodSensor.ino
      https://github.com/empierre/arduino/blob/master/LeafWetnessSensor.ino
      https://github.com/empierre/arduino/blob/master/SoundSensor2.ino
      https://github.com/empierre/arduino/blob/master/VibrationSensor.ino
      z-wave - Vera -> Domoticz
      hekH 1 Reply Last reply
      • epierreE epierre
        @epierre
        Thanks, I'll take a look at them and possibly lift them into the examples folder.
        For the flood sensor, what kind of conductivity probe are you using.
        • epierreE
          epierreE
          epierre
          @hek: two conductors ;-) well anything you want here it is binary logic, you don't need to mesure the resistance to know how wet it is ...
          • O
            O
            oded00
            What is the best practice to upgrade from 1.4?
            i'm using vera
              As said above.. you don't need to update everything in one big bang unless you want to use the new features. Add new sensors with the updated library if you want.
              • epierreE
                epierreE
                epierre
                @hek seems there is something to correct http://forum.mysensors.org/topic/1729/updated-support-to-serial-version-1-5
                • epierreE epierre
                  @epierre
                  Already talked to @John. Will update documentation more clearly that V_DIMMER and V_LIGHT has been deprecated for the more general wording V_PERCENTAGE and V_STATUS.
                  The old sketches will still work fine as I've introduced an alias.
                  • JohnJ
                    JohnJ
                    John
                    @hek, @epierre
                    I think i was too fast with committing my updates which creates new downloads automatically (sorry if it was too quick), so I had to do a post just in case of some "eager to update" user i have.
                      sebas
                      Very nice. How do I find out how the new sensor types work? Specifically the RGB and RGBW sensors.
                      I've browsed through the source code but haven't found it yet. What file should I be looking into?
                      • G
                        G
                        gbfromhb
                        Very cool. The timing was perfect. I was just about to jump into the deep end and start deploying the development branch. Thanks everyone for the hard work.
                        • S sebas
                          @sebas
                          Guess I'll have to toss an RGB example together some day. But basically the payload should be a ascii hex string describing the color components. I.e "FF0000" for red.
                          • SweebeeS
                            SweebeeS
                            Sweebee
                            I'm trying to burn the gateway but i get this:
                            /Users/Wiebe/Documents/Arduino/libraries/MySensors/MyGateway.cpp:13:30: fatal error: utility/MsTimer2.h: No such file or directory
                             #include "utility/MsTimer2.h"
                            compilation terminated.
                              @diggs
                              I haven't made sketch-examples for all new sensor types yet. The community needs to help me with that. :)
                              diggs
                              @hek
                              No worries, thanks for clarifying
                              • BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @hek
                                I have to say, the documentation for the update to 1.5 was done very well... thanks to you and whomever else assisted.
                                nice work!
                                :thumbsup:
                                  Thanks, but still room for improvements. :)
                                  @Anticimex is currently deploying a jenkins build-server to automate builds of the examples for different platforms when things get pushed to github. Makes it much easier to keep up the quality.
                                  This will also allow automatic doxygen documentation and perhaps a bit of a rearrangement of the repository layout which isn't optimal (except when downloading/installing).
                                    msebbe
                                    wrote on last edited by msebbe
                                    #31
                                    @hek I have updated my gateway but should the vera say plugin version 1.5? Or is the plugin version still 1.4? Im confused
                                    • rvendrameR
                                      rvendrameR
                                      rvendrame
                                      Mine says
                                      Plugin Version:1.4
                                      Lib Version: 1.5
                                      So I guess the 'plugin' refers to the lua/xml/json files in Vera.
                                      The oficial page points to Github. If dates are correct there, it seems nothing was changed recently (except by the HVAC device).
                                      ESP8266 GW + mySensors 2.3.2
                                      Alexa / Google Home
                                      • rvendrameR rvendrame
                                        Mine says
                                        Plugin Version:1.4
                                        Lib Version: 1.5
                                        msebbe
                                        @rvendrame
                                        I got it working now, thank you
                                          Haven't bumped plugin version. No major things changed over there.
                                          12.5k
