  3. Binary Control Modules , Switches, or Outlets on a Vera Edge
sensor
33 Posts 4 Posters 17.7k Views 2 Watching
    @mntlvr,
    so this single line of code:
    pinMode(myPin, INPUT_PULLUP);
    is identical to these two lines of code:
    pinMode(myPin, INPUT);
    digitalWrite(myPin, HIGH);
    try adding some hold time to make sure your radio has enough power to transmit:
      gw.begin();
      gw.sendSketchInfo("RemoteControl", "1.05");
      for (int i = 0; i < NUMBER_OF_PINS; i++)
        msg[i] = MyMessage(i, V_TRIPPED);
        gw.present(i, S_DOOR);
        pinMode(buttonPin[i], INPUT_PULLUP);
        debouncer[buttonPin[i]].attach(buttonPin[i]);
        debouncer[buttonPin[i]].interval(5);
        gw.wait(75); //<<<<<<<<<<<<<<<<<<<<<< here
    mntlvrM
    mntlvrM
    mntlvr
    @BulldogLowell , You are so correct the two lines of code mean exactly the same, thank you for pointing that out, so wo I will try this code again and I will try my modified code and see what happens. Now both should work but your code is more Nano or Pro-Mini friendly when it comes to memory.
      @mntlvr,
        gw.begin();
      mntlvrM
      mntlvrM
      mntlvr
      @BulldogLowell
      I tried the code again but it still only finds 0-4 delay made no difference. Also I don't follow your code for changing the msg so it shows 1,2,3,4,5,6 tripped could use a little visual help on this also. I am trying to trap the condition that is preventing it from running 0-5 instead of 0-4.
      • mntlvrM mntlvr
        @BulldogLowell
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @mntlvr
        use some serial debug messages like this to see what's what:
        #define NUMBER_OF_PINS 6
        int buttonPin[NUMBER_OF_PINS] = {3,4,5,6,7,8};
        Bounce debouncer[NUMBER_OF_PINS] = Bounce();
        int oldValue[NUMBER_OF_PINS];
        MyMessage msg[NUMBER_OF_PINS]; //= {MyMessage(0,V_TRIPPED),MyMessage(1,V_TRIPPED),MyMessage(2,V_TRIPPED),MyMessage(3,V_TRIPPED),MyMessage(4,V_TRIPPED),MyMessage(5,V_TRIPPED)};
          gw.begin();
            Serial.print(F("Setting up Pin"));
            Serial.println(i);
            msg[i] = MyMessage(i, V_TRIPPED); // instead of this
            gw.wait(100);
          Serial.println(F("Sensor presentation complete"));
            debouncer[i].update();
            if (value != oldValue[i])
              gw.send(msg[i].set(value));
              Serial.print(F("Pin "));
              Serial.print(i);
              Serial.print(F(" changed state...  New State: "));
              Serial.println(value? F("Tripped") : F("Not Tripped"));
              oldValue[i] = value;
        mntlvrM 2 Replies Last reply
          @mntlvr
            gw.begin();
              Serial.println(i);
              gw.wait(100);
                Serial.print(i);
          mntlvrM
          mntlvrM
          mntlvr
          @BulldogLowell
          Bulldog I ran your debug code and here is the 6th irratition of the Serial Monitor on IDE ver 1.6.4
          • sensor started, id 32
            send: 32-32-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
            send: 32-32-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
            send: 32-32-0-0 s=255,c=3,t=11,pt=0,l=13,st=fail:RemoteControl
            send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=fail:1.05
            Setting up Pin0
            send: 32-32-0-0 s=0,c=0,t=0,pt=0,l=0,st=fail:
            Setting up Pin1
            send: 32-32-0-0 s=1,c=0,t=0,pt=0,l=0,st=fail:
            Setting up Pin2
            send: 32-32-0-0 s=2,c=0,t=0,pt=0,l=0,st=fail:
            send: 32-32-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
            Setting up Pin3
            send: 32-32-0-0 s=3,c=0,t=0,pt=0,l=0,st=fail:
            read: 32-32-0 s=3,c=0,t=0,pt=0,l=0:
            Setting up Pin4
            send: 32-32-0-0 s=4,c=0,t=0,pt=0,l=0,st=ok:
            read: 32-32-0 s=4,c=0,t=0,pt=0,l=0:
            Setting up Pin5
            send: 0-0-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
            read: 48-201-0 s=0,c=5,t=0,pt=0,l=0:
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            send: 0-0-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:1
            Pin 3 changed state... New State: Tripped
            send: 0-0-0-0 s=4,c=1,t=16,pt=2,l=2,st=ok:1
            Pin 4 changed state... New State: Tripped
            send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:1
            Pin 5 changed state... New State: Tripped
            send: 0-0-0-0 s=0,c=1,t=16,pt=2,l=2,st=ok:1
            Pin 0 changed state... New State: Tripped
            send: 0-0-0-0 s=1,c=1,t=16,pt=2,l=2,st=ok:1
            Pin 1 changed state... New State: Tripped
            send: 0-0-0-0 s=2,c=1,t=16,pt=2,l=2,st=ok:1
            Pin 2 changed state... New State: Tripped
            @mntlvr
              gw.begin();
                Serial.println(i);
                gw.wait(100);
                  Serial.print(i);
            mntlvrM
            mntlvrM
            mntlvr
            @BulldogLowell
            Connected pin 5 to ground and reset Serial Monitor windows and this is the results
              send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=fail:1.08
              Setting up Pin0
              Setting up Pin1
              Setting up Pin2
              Setting up Pin3
              Setting up Pin4
              Setting up Pin5
              read: 50-219-0 s=0,c=5,t=0,pt=0,l=0:
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
            This is as far as the code went..
            • BulldogLowellB
              BulldogLowellB
              BulldogLowell
              you would need to flip the switches to see anything else :) so try that.
              this is a problem:
              Setting up Pin0
              Setting up Pin1
              Setting up Pin2
              Setting up Pin3
              let's slow down the startup... it looks like your initial radio messages are not making it to the gateway.
              #define RADIO_ID 32
                delay(1000);
                Serial.print(F("Sending device info..."));
                gw.begin(NULL, RADIO_ID, false);
                gw.wait(250);
                  Serial.println(i);
                  gw.wait(250);
                    Serial.print(i);
              mntlvrM 1 Reply Last reply
              • rvendrameR
                rvendrameR
                rvendrame
                How are you powering the node? Is there any capacitor between radio VCC / GND? If you have an spare radio/power supply try replacing them. Make sure radio gets stable, 1.9-3.6V supply.
                And check this thread. Many of us are experiencing random results from fake radios...
                ESP8266 GW + mySensors 2.3.2
                Alexa / Google Home
                  this is a problem:
                  Setting up Pin0
                  Setting up Pin1
                  Setting up Pin2
                  Setting up Pin3
                  #define RADIO_ID 32
                    delay(1000);
                    gw.wait(250);
                      Serial.println(i);
                      gw.wait(250);
                        Serial.print(i);
                  mntlvrM
                  mntlvrM
                  mntlvr
                  @BulldogLowell Ok Bulldog ran new code still getting Version Mismatch?and at the beginning fails.
                  My transceiver is about 4 feet away from the gateway.
                  • .sensor started, id 32
                    Setting up Pin0
                    Setting up Pin1
                    Setting up Pin2
                    Setting up Pin3
                    Setting up Pin4
                    0;0;3;0;9;send: 32-32-0-0 s=4,c=0,t=0,pt=0,l=0,st=ok:
                    Setting up Pin5
                    0;0;3;0;9;send: 0-0-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
                    read: 52-63-0 s=0,c=5,t=0,pt=0,l=0:
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    0;0;3;0;9;send: 0-0-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:1
                    0;0;3;0;9;send: 0-0-0-0 s=4,c=1,t=16,pt=2,l=2,st=ok:1
                    0;0;3;0;9;send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:1
                    0;0;3;0;9;send: 0-0-0-0 s=0,c=1,t=16,pt=2,l=2,st=ok:1
                    0;0;3;0;9;send: 0-0-0-0 s=1,c=1,t=16,pt=2,l=2,st=ok:1
                    0;0;3;0;9;send: 0-0-0-0 s=2,c=1,t=16,pt=2,l=2,st=ok:1
                  • BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    Setting up Pin5
                    version mismatch
                    version mismatch
                    version mismatch
                    version mismatch
                    yeah, this isn't what I would expect, but maybe hardware related... look here.
                    Power is my first instinct.
                    @hek any ideas here?
                    also, you didn't try flipping the switches!
                      Message seems corrupt... command-type=5!!
                      Underpowered or some strange mix of different radio-modules.
                        Setting up Pin5
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        mntlvrM
                        mntlvrM
                        mntlvr
                        @BulldogLowell Bulldog
                        The power is coming from 2 LIPO 1500mAH batteries in series, so the boards input voltage is 8.4 volts which the on board regulator is handling on the 24l01 so the nRF24l01 is getting 3.3 volts one 22ufd caps on input right on nrf24l01 board. I am running the exact setup my first board is using when I built it on a Nano. On the Nano build when I would ground anyone of the input pin the Vera would show the state of change right away and so would the Serial Monitor on IDE. I will keep on it until I resolve it.
                          mntlvrM
                          mntlvrM
                          mntlvr
                          @hek All the radio modules are nRF24l01+ and I have 3 other sensors all working just fine with this gateway all using the same transceiver from the same company.
                            mntlvrM
                            mntlvrM
                            mntlvr
                            @hek this is the Serial Monitor output from the same board powered the same way except running my original code and no failures.
                            You can see when I gnd the input the output responds.
                            send: 32-32-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                            send: 32-32-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                            send: 32-32-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:RemoteControl
                            send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:1.05
                            send: 32-32-0-0 s=3,c=0,t=0,pt=0,l=0,st=ok:
                            send: 32-32-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
                            send: 32-32-0-0 s=6,c=0,t=0,pt=0,l=0,st=ok:
                            send: 32-32-0-0 s=7,c=0,t=0,pt=0,l=0,st=ok:
                            send: 32-32-0-0 s=8,c=0,t=0,pt=0,l=0,st=ok:
                            send: 32-32-0-0 s=3,c=1,t=16,pt=0,l=1,st=ok:1
                            send: 32-32-0-0 s=4,c=1,t=16,pt=0,l=1,st=ok:1
                            send: 32-32-0-0 s=5,c=1,t=16,pt=0,l=1,st=ok:1
                            send: 32-32-0-0 s=6,c=1,t=16,pt=0,l=1,st=ok:1
                            send: 32-32-0-0 s=7,c=1,t=16,pt=0,l=1,st=ok:1
                            send: 32-32-0-0 s=8,c=1,t=16,pt=0,l=1,st=ok:1
                            send: 32-32-0-0 s=5,c=1,t=16,pt=0,l=1,st=ok:0
                              I suspect the message array is doing some buffer overwrite.
                              Just define one msg and reuse it with
                              msg.setSensor(x)
                              • BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                msg.setSensor(x)
                                agree...
                                look here:
                                not winding its way through the array like you wold expect.
                                • mntlvrM mntlvr
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @mtnlvr
                                  like this perhaps:
                                  #define RADIO_ID 32
                                  MyMessage msg(0,V_TRIPPED);
                                    delay(1000);
                                    gw.wait(250);
                                      Serial.println(i);
                                      gw.wait(250);
                                        msg.setSensor(i);
                                        gw.send(msg.set(value));
                                        Serial.print(i);
                                    @mtnlvr
                                    like this perhaps:
                                    #define RADIO_ID 32
                                      delay(1000);
                                      gw.wait(250);
                                        Serial.println(i);
                                        gw.wait(250);
                                          msg.setSensor(i);
                                          Serial.print(i);
                                    mntlvrM
                                    mntlvrM
                                    mntlvr
                                    @BulldogLowell
                                    This seems to work much better but what is the "version mismatch"?
                                    You can see the change of pin 5 now immediately now when I connect it to gnd or leave it open.
                                    Sending device info...sensor started, id 32
                                    read: 0-0-32 s=255,c=3,t=6,pt=0,l=1:I
                                    send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:1.15
                                    Setting up Pin0
                                    send: 32-32-0-0 s=0,c=0,t=0,pt=0,l=0,st=ok:
                                    Setting up Pin1
                                    send: 32-32-0-0 s=1,c=0,t=0,pt=0,l=0,st=ok:
                                    Setting up Pin2
                                    send: 32-32-0-0 s=2,c=0,t=0,pt=0,l=0,st=ok:
                                    Setting up Pin3
                                    Setting up Pin4
                                    Setting up Pin5
                                    read: 39-155-0 s=0,c=5,t=0,pt=0,l=0:
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    version mismatch
                                    send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:0
                                    Pin 5 changed state... New State: Not Tripped
                                      You seem to have radio disturbance (or the nodes radio get wacky when gateway sends its ack...).
                                      I think I have similar things when underpowering my gateway and sending with full power on a amplified nrf-module.
                                        mntlvrM
                                        mntlvrM
                                        mntlvr
                                        wrote on last edited by mntlvr
                                        #24
                                        @hek I just re-ran my Serial Monitor and now pin 5 only shows "version mismatch" I don't know how else to power any of these units because I have a 9 vdc 1 amp power pack on the Gateway and my sensors all have 1 amp, 9 vdc power packs
                                        • mntlvrM mntlvr
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @mntlvr
                                          I really never use toggle switches like you are using here but it dawned on me that you are drawing current on all six pins simultaneously using the internal pull-ups. Perhaps you are overdrawing the power of the arduino a bit, causing the spurious results. We don't see the error until we power up that #5 pin.... but you are getting some crazy radio activity prior to that after we power up pin 3. That's where it occurred to me that we may be asking too much of your arduino, sinking all of the 6 pins to ground at once.
                                          Can you try:
                                          a: opening all of the switches before initialization and see if you still get the funky version mismatch error? Or,
                                          b: just let the pins float by changing the initialization of the pin to:
                                          pinMode(buttonPin[i], INPUT);
                                          and see if it at least initializes correctly (your switches won't work correctly, that's fine to test this theory).
                                          just spitballing here... but if that helps, there are solutions (at least one of which may require you to remove some of that lovely potting ;).
