  3. Binary Control Modules , Switches, or Outlets on a Vera Edge
sensor
33 Posts 4 Posters 17.7k Views 2 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    How are you powering the node? Is there any capacitor between radio VCC / GND? If you have an spare radio/power supply try replacing them. Make sure radio gets stable, 1.9-3.6V supply.
    And check this thread. Many of us are experiencing random results from fake radios...
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
      @mntlvr said:
      This is as far as the code went..
      you would need to flip the switches to see anything else :) so try that.
      this is a problem:
      Setting up Pin0
      send: 32-32-0-0 s=0,c=0,t=0,pt=0,l=0,st=fail:
      Setting up Pin1
      send: 32-32-0-0 s=1,c=0,t=0,pt=0,l=0,st=fail:
      Setting up Pin2
      send: 32-32-0-0 s=2,c=0,t=0,pt=0,l=0,st=fail:
      send: 32-32-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
      Setting up Pin3
      send: 32-32-0-0 s=3,c=0,t=0,pt=0,l=0,st=fail:
      let's slow down the startup... it looks like your initial radio messages are not making it to the gateway.
      #define NUMBER_OF_PINS 6
      #define RADIO_ID 32
      int buttonPin[NUMBER_OF_PINS] = {3,4,5,6,7,8};
      Bounce debouncer[NUMBER_OF_PINS] = Bounce();
      int oldValue[NUMBER_OF_PINS];
      MyMessage msg[NUMBER_OF_PINS]; //= {MyMessage(0,V_TRIPPED),MyMessage(1,V_TRIPPED),MyMessage(2,V_TRIPPED),MyMessage(3,V_TRIPPED),MyMessage(4,V_TRIPPED),MyMessage(5,V_TRIPPED)};
        delay(1000);
        Serial.print(F("Sending device info..."));
        gw.begin(NULL, RADIO_ID, false);
        gw.sendSketchInfo("RemoteControl", "1.05");
        gw.wait(250);
        for (int i = 0; i < NUMBER_OF_PINS; i++)
          Serial.print(F("Setting up Pin"));
          Serial.println(i);
          msg[i] = MyMessage(i, V_TRIPPED); // instead of this
          gw.present(i, S_DOOR);
          pinMode(buttonPin[i], INPUT_PULLUP);
          debouncer[buttonPin[i]].attach(buttonPin[i]);
          debouncer[buttonPin[i]].interval(5);
          gw.wait(250);
        Serial.println(F("Sensor presentation complete"));
          debouncer[i].update();
          if (value != oldValue[i])
            gw.send(msg[i].set(value));
            Serial.print(F("Pin "));
            Serial.print(i);
            Serial.print(F(" changed state...  New State: "));
            Serial.println(value? F("Tripped") : F("Not Tripped"));
            oldValue[i] = value;
      mntlvrM
      mntlvrM
      mntlvr
      @BulldogLowell Ok Bulldog ran new code still getting Version Mismatch?and at the beginning fails.
      My transceiver is about 4 feet away from the gateway.
      • .sensor started, id 32
        send: 32-32-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
        send: 32-32-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
        send: 32-32-0-0 s=255,c=3,t=11,pt=0,l=13,st=fail:RemoteControl
        send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=fail:1.05
        Setting up Pin0
        Setting up Pin1
        Setting up Pin2
        Setting up Pin3
        read: 32-32-0 s=3,c=0,t=0,pt=0,l=0:
        Setting up Pin4
        0;0;3;0;9;send: 32-32-0-0 s=4,c=0,t=0,pt=0,l=0,st=ok:
        read: 32-32-0 s=4,c=0,t=0,pt=0,l=0:
        Setting up Pin5
        0;0;3;0;9;send: 0-0-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
        read: 52-63-0 s=0,c=5,t=0,pt=0,l=0:
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        0;0;3;0;9;send: 0-0-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:1
        Pin 3 changed state... New State: Tripped
        0;0;3;0;9;send: 0-0-0-0 s=4,c=1,t=16,pt=2,l=2,st=ok:1
        Pin 4 changed state... New State: Tripped
        0;0;3;0;9;send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:1
        Pin 5 changed state... New State: Tripped
        0;0;3;0;9;send: 0-0-0-0 s=0,c=1,t=16,pt=2,l=2,st=ok:1
        Pin 0 changed state... New State: Tripped
        0;0;3;0;9;send: 0-0-0-0 s=1,c=1,t=16,pt=2,l=2,st=ok:1
        Pin 1 changed state... New State: Tripped
        0;0;3;0;9;send: 0-0-0-0 s=2,c=1,t=16,pt=2,l=2,st=ok:1
        Pin 2 changed state... New State: Tripped
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        Setting up Pin5
        version mismatch
        version mismatch
        version mismatch
        version mismatch
        yeah, this isn't what I would expect, but maybe hardware related... look here.
        Power is my first instinct.
        @hek any ideas here?
        also, you didn't try flipping the switches!
        mntlvrM 1 Reply Last reply
          Message seems corrupt... command-type=5!!
          Underpowered or some strange mix of different radio-modules.
          mntlvrM 2 Replies Last reply
            Setting up Pin5
            version mismatch
            version mismatch
            version mismatch
            version mismatch
            mntlvrM
            mntlvrM
            mntlvr
            @BulldogLowell Bulldog
            The power is coming from 2 LIPO 1500mAH batteries in series, so the boards input voltage is 8.4 volts which the on board regulator is handling on the 24l01 so the nRF24l01 is getting 3.3 volts one 22ufd caps on input right on nrf24l01 board. I am running the exact setup my first board is using when I built it on a Nano. On the Nano build when I would ground anyone of the input pin the Vera would show the state of change right away and so would the Serial Monitor on IDE. I will keep on it until I resolve it.
              mntlvrM
              mntlvrM
              mntlvr
              @hek All the radio modules are nRF24l01+ and I have 3 other sensors all working just fine with this gateway all using the same transceiver from the same company.
                mntlvrM
                mntlvrM
                mntlvr
                @hek this is the Serial Monitor output from the same board powered the same way except running my original code and no failures.
                You can see when I gnd the input the output responds.
                send: 32-32-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                send: 32-32-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                send: 32-32-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:RemoteControl
                send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:1.05
                send: 32-32-0-0 s=3,c=0,t=0,pt=0,l=0,st=ok:
                send: 32-32-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
                send: 32-32-0-0 s=6,c=0,t=0,pt=0,l=0,st=ok:
                send: 32-32-0-0 s=7,c=0,t=0,pt=0,l=0,st=ok:
                send: 32-32-0-0 s=8,c=0,t=0,pt=0,l=0,st=ok:
                send: 32-32-0-0 s=3,c=1,t=16,pt=0,l=1,st=ok:1
                send: 32-32-0-0 s=4,c=1,t=16,pt=0,l=1,st=ok:1
                send: 32-32-0-0 s=5,c=1,t=16,pt=0,l=1,st=ok:1
                send: 32-32-0-0 s=6,c=1,t=16,pt=0,l=1,st=ok:1
                send: 32-32-0-0 s=7,c=1,t=16,pt=0,l=1,st=ok:1
                send: 32-32-0-0 s=8,c=1,t=16,pt=0,l=1,st=ok:1
                send: 32-32-0-0 s=5,c=1,t=16,pt=0,l=1,st=ok:0
                  I suspect the message array is doing some buffer overwrite.
                  Just define one msg and reuse it with
                  msg.setSensor(x)
                  • BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    msg.setSensor(x)
                    agree...
                    look here:
                    not winding its way through the array like you wold expect.
                    • mntlvrM mntlvr
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @mtnlvr
                      like this perhaps:
                      #define RADIO_ID 32
                      MyMessage msg(0,V_TRIPPED);
                        delay(1000);
                        gw.wait(250);
                          Serial.println(i);
                          gw.wait(250);
                            msg.setSensor(i);
                            gw.send(msg.set(value));
                            Serial.print(i);
                        @mtnlvr
                        like this perhaps:
                        #define RADIO_ID 32
                          delay(1000);
                          gw.wait(250);
                            Serial.println(i);
                            gw.wait(250);
                              msg.setSensor(i);
                              Serial.print(i);
                        mntlvrM
                        mntlvrM
                        mntlvr
                        @BulldogLowell
                        This seems to work much better but what is the "version mismatch"?
                        You can see the change of pin 5 now immediately now when I connect it to gnd or leave it open.
                        Sending device info...sensor started, id 32
                        read: 0-0-32 s=255,c=3,t=6,pt=0,l=1:I
                        send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:1.15
                        Setting up Pin0
                        send: 32-32-0-0 s=0,c=0,t=0,pt=0,l=0,st=ok:
                        Setting up Pin1
                        send: 32-32-0-0 s=1,c=0,t=0,pt=0,l=0,st=ok:
                        Setting up Pin2
                        send: 32-32-0-0 s=2,c=0,t=0,pt=0,l=0,st=ok:
                        Setting up Pin3
                        Setting up Pin4
                        Setting up Pin5
                        read: 39-155-0 s=0,c=5,t=0,pt=0,l=0:
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        version mismatch
                        send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:0
                        Pin 5 changed state... New State: Not Tripped
                          You seem to have radio disturbance (or the nodes radio get wacky when gateway sends its ack...).
                          I think I have similar things when underpowering my gateway and sending with full power on a amplified nrf-module.
                            mntlvrM
                            mntlvrM
                            mntlvr
                            wrote on last edited by mntlvr
                            #24
                            @hek I just re-ran my Serial Monitor and now pin 5 only shows "version mismatch" I don't know how else to power any of these units because I have a 9 vdc 1 amp power pack on the Gateway and my sensors all have 1 amp, 9 vdc power packs
                            • mntlvrM mntlvr
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @mntlvr
                              I really never use toggle switches like you are using here but it dawned on me that you are drawing current on all six pins simultaneously using the internal pull-ups. Perhaps you are overdrawing the power of the arduino a bit, causing the spurious results. We don't see the error until we power up that #5 pin.... but you are getting some crazy radio activity prior to that after we power up pin 3. That's where it occurred to me that we may be asking too much of your arduino, sinking all of the 6 pins to ground at once.
                              Can you try:
                              a: opening all of the switches before initialization and see if you still get the funky version mismatch error? Or,
                              b: just let the pins float by changing the initialization of the pin to:
                              pinMode(buttonPin[i], INPUT);
                              and see if it at least initializes correctly (your switches won't work correctly, that's fine to test this theory).
                              just spitballing here... but if that helps, there are solutions (at least one of which may require you to remove some of that lovely potting ;).
                                @mntlvr
                                Can you try:
                                mntlvrM
                                mntlvrM
                                mntlvr
                                @BulldogLowell said:
                                @mntlvr
                                Can you try:
                                Oh no Bulldog that is the one unit that is working just fine, all the version mismatches comes from your code I am trying out and we are making progress. For some reason when you are using arrays and for next loop this is where some of the issues are . If you look up a few replys when I replied to @hek I was using my code and there were no version mismatches.
                                • mntlvrM mntlvr
                                  @mntlvr
                                  Can you try:
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @mntlvr
                                  yes, I meant with my code!
                                    @mntlvr
                                    mntlvrM
                                    mntlvrM
                                    mntlvr
                                    @BulldogLowell
                                    O.k I will try your change when I can get some free time and see if I can prove out your theory.
                                      @mntlvr
                                      Can you try:
                                      mntlvrM
                                      mntlvrM
                                      mntlvr
                                      #29
                                      @mntlvr
                                      Can you try:
                                      Now when I sent my last set of results and most of the other including my code I leave all but 1 pin open and most of the time all pins open. And if all six switches are set to gnd the total current would only be 1.5 ma (5volts /20k)x6=.0015 amps I believe. the internal pullup resistors are 20k-50k according to arduino spec.
                                      • BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        yeah, I know, but if you are underpowered already (the radio....) the extra draw may create an issue... who the heck knows.
                                        I'll try on one of mine when I get the chance... your code works, and that's a treat, but now I need to understand why the simpler execution of the same code doesn't seem to cooperate with your rig.
                                        weird...
                                        mntlvrM 3 Replies Last reply
                                          weird...
                                          mntlvrM
                                          mntlvrM
                                          mntlvr
                                          weird...
                                          Bulldog same power pack is running nRF24l01+ in the fully working unit as in this test sensor I am using with your code I don't believe power is the issue my code probably runs much slower than yours and that might be the issue I will play with slowing down your code even further and see if it makes any difference. We shall overcome...
