  3. Binary Control Modules , Switches, or Outlets on a Vera Edge
sensor
33 Posts 4 Posters 17.7k Views 2 Watching
  • mntlvrM mntlvr
    @BulldogLowell I tried your sketch, had to put in the digitalwrite(i,HIGH), but even then it would only find 5 of the 7 nodes it needed, Switch 3-8 and the Arduino Node. I will see later what is going on because it should have worked .
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    @mntlvr,
    so this single line of code:
    pinMode(myPin, INPUT_PULLUP);
    is identical to these two lines of code:
    pinMode(myPin, INPUT);
    digitalWrite(myPin, HIGH);
    try adding some hold time to make sure your radio has enough power to transmit:
      gw.begin();
      gw.sendSketchInfo("RemoteControl", "1.05");
      for (int i = 0; i < NUMBER_OF_PINS; i++)
        msg[i] = MyMessage(i, V_TRIPPED);
        gw.present(i, S_DOOR);
        pinMode(buttonPin[i], INPUT_PULLUP);
        debouncer[buttonPin[i]].attach(buttonPin[i]);
        debouncer[buttonPin[i]].interval(5);
        gw.wait(75); //<<<<<<<<<<<<<<<<<<<<<< here
    mntlvrM 2 Replies Last reply
      @mntlvr,
        gw.begin();
      mntlvrM
      mntlvrM
      mntlvr
      @BulldogLowell , You are so correct the two lines of code mean exactly the same, thank you for pointing that out, so wo I will try this code again and I will try my modified code and see what happens. Now both should work but your code is more Nano or Pro-Mini friendly when it comes to memory.
        @mntlvr,
          gw.begin();
        mntlvrM
        mntlvrM
        mntlvr
        @BulldogLowell
        I tried the code again but it still only finds 0-4 delay made no difference. Also I don't follow your code for changing the msg so it shows 1,2,3,4,5,6 tripped could use a little visual help on this also. I am trying to trap the condition that is preventing it from running 0-5 instead of 0-4.
        • mntlvrM mntlvr
          @BulldogLowell
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @mntlvr
          use some serial debug messages like this to see what's what:
          #define NUMBER_OF_PINS 6
          int buttonPin[NUMBER_OF_PINS] = {3,4,5,6,7,8};
          Bounce debouncer[NUMBER_OF_PINS] = Bounce();
          int oldValue[NUMBER_OF_PINS];
          MyMessage msg[NUMBER_OF_PINS]; //= {MyMessage(0,V_TRIPPED),MyMessage(1,V_TRIPPED),MyMessage(2,V_TRIPPED),MyMessage(3,V_TRIPPED),MyMessage(4,V_TRIPPED),MyMessage(5,V_TRIPPED)};
            gw.begin();
              Serial.print(F("Setting up Pin"));
              Serial.println(i);
              msg[i] = MyMessage(i, V_TRIPPED); // instead of this
              gw.wait(100);
            Serial.println(F("Sensor presentation complete"));
              debouncer[i].update();
              if (value != oldValue[i])
                gw.send(msg[i].set(value));
                Serial.print(F("Pin "));
                Serial.print(i);
                Serial.print(F(" changed state...  New State: "));
                Serial.println(value? F("Tripped") : F("Not Tripped"));
                oldValue[i] = value;
            @mntlvr
              gw.begin();
                Serial.println(i);
                gw.wait(100);
                  Serial.print(i);
            mntlvrM
            mntlvrM
            mntlvr
            @BulldogLowell
            Bulldog I ran your debug code and here is the 6th irratition of the Serial Monitor on IDE ver 1.6.4
            • sensor started, id 32
              send: 32-32-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
              send: 32-32-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
              send: 32-32-0-0 s=255,c=3,t=11,pt=0,l=13,st=fail:RemoteControl
              send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=fail:1.05
              Setting up Pin0
              send: 32-32-0-0 s=0,c=0,t=0,pt=0,l=0,st=fail:
              Setting up Pin1
              send: 32-32-0-0 s=1,c=0,t=0,pt=0,l=0,st=fail:
              Setting up Pin2
              send: 32-32-0-0 s=2,c=0,t=0,pt=0,l=0,st=fail:
              send: 32-32-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
              Setting up Pin3
              send: 32-32-0-0 s=3,c=0,t=0,pt=0,l=0,st=fail:
              read: 32-32-0 s=3,c=0,t=0,pt=0,l=0:
              Setting up Pin4
              send: 32-32-0-0 s=4,c=0,t=0,pt=0,l=0,st=ok:
              read: 32-32-0 s=4,c=0,t=0,pt=0,l=0:
              Setting up Pin5
              send: 0-0-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
              read: 48-201-0 s=0,c=5,t=0,pt=0,l=0:
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              version mismatch
              send: 0-0-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:1
              Pin 3 changed state... New State: Tripped
              send: 0-0-0-0 s=4,c=1,t=16,pt=2,l=2,st=ok:1
              Pin 4 changed state... New State: Tripped
              send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:1
              Pin 5 changed state... New State: Tripped
              send: 0-0-0-0 s=0,c=1,t=16,pt=2,l=2,st=ok:1
              Pin 0 changed state... New State: Tripped
              send: 0-0-0-0 s=1,c=1,t=16,pt=2,l=2,st=ok:1
              Pin 1 changed state... New State: Tripped
              send: 0-0-0-0 s=2,c=1,t=16,pt=2,l=2,st=ok:1
              Pin 2 changed state... New State: Tripped
              @mntlvr
                gw.begin();
                  Serial.println(i);
                  gw.wait(100);
                    Serial.print(i);
              mntlvrM
              mntlvrM
              mntlvr
              @BulldogLowell
              Connected pin 5 to ground and reset Serial Monitor windows and this is the results
                send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=fail:1.08
                Setting up Pin0
                Setting up Pin1
                Setting up Pin2
                Setting up Pin3
                Setting up Pin4
                Setting up Pin5
                read: 50-219-0 s=0,c=5,t=0,pt=0,l=0:
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
                version mismatch
              This is as far as the code went..
              • BulldogLowellB
                BulldogLowellB
                BulldogLowell
                you would need to flip the switches to see anything else :) so try that.
                this is a problem:
                Setting up Pin0
                Setting up Pin1
                Setting up Pin2
                Setting up Pin3
                let's slow down the startup... it looks like your initial radio messages are not making it to the gateway.
                #define RADIO_ID 32
                  delay(1000);
                  Serial.print(F("Sending device info..."));
                  gw.begin(NULL, RADIO_ID, false);
                  gw.wait(250);
                    Serial.println(i);
                    gw.wait(250);
                      Serial.print(i);
                mntlvrM 1 Reply Last reply
                • rvendrameR
                  rvendrameR
                  rvendrame
                  How are you powering the node? Is there any capacitor between radio VCC / GND? If you have an spare radio/power supply try replacing them. Make sure radio gets stable, 1.9-3.6V supply.
                  And check this thread. Many of us are experiencing random results from fake radios...
                  ESP8266 GW + mySensors 2.3.2
                  Alexa / Google Home
                    this is a problem:
                    Setting up Pin0
                    Setting up Pin1
                    Setting up Pin2
                    Setting up Pin3
                    #define RADIO_ID 32
                      delay(1000);
                      gw.wait(250);
                        Serial.println(i);
                        gw.wait(250);
                          Serial.print(i);
                    mntlvrM
                    mntlvrM
                    mntlvr
                    @BulldogLowell Ok Bulldog ran new code still getting Version Mismatch?and at the beginning fails.
                    My transceiver is about 4 feet away from the gateway.
                    • .sensor started, id 32
                      Setting up Pin0
                      Setting up Pin1
                      Setting up Pin2
                      Setting up Pin3
                      Setting up Pin4
                      0;0;3;0;9;send: 32-32-0-0 s=4,c=0,t=0,pt=0,l=0,st=ok:
                      Setting up Pin5
                      0;0;3;0;9;send: 0-0-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
                      read: 52-63-0 s=0,c=5,t=0,pt=0,l=0:
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      0;0;3;0;9;send: 0-0-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:1
                      0;0;3;0;9;send: 0-0-0-0 s=4,c=1,t=16,pt=2,l=2,st=ok:1
                      0;0;3;0;9;send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:1
                      0;0;3;0;9;send: 0-0-0-0 s=0,c=1,t=16,pt=2,l=2,st=ok:1
                      0;0;3;0;9;send: 0-0-0-0 s=1,c=1,t=16,pt=2,l=2,st=ok:1
                      0;0;3;0;9;send: 0-0-0-0 s=2,c=1,t=16,pt=2,l=2,st=ok:1
                    • BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      Setting up Pin5
                      version mismatch
                      version mismatch
                      version mismatch
                      version mismatch
                      yeah, this isn't what I would expect, but maybe hardware related... look here.
                      Power is my first instinct.
                      @hek any ideas here?
                      also, you didn't try flipping the switches!
                        Message seems corrupt... command-type=5!!
                        Underpowered or some strange mix of different radio-modules.
                          Setting up Pin5
                          version mismatch
                          version mismatch
                          version mismatch
                          version mismatch
                          mntlvrM
                          mntlvrM
                          mntlvr
                          @BulldogLowell Bulldog
                          The power is coming from 2 LIPO 1500mAH batteries in series, so the boards input voltage is 8.4 volts which the on board regulator is handling on the 24l01 so the nRF24l01 is getting 3.3 volts one 22ufd caps on input right on nrf24l01 board. I am running the exact setup my first board is using when I built it on a Nano. On the Nano build when I would ground anyone of the input pin the Vera would show the state of change right away and so would the Serial Monitor on IDE. I will keep on it until I resolve it.
                            mntlvrM
                            mntlvrM
                            mntlvr
                            @hek All the radio modules are nRF24l01+ and I have 3 other sensors all working just fine with this gateway all using the same transceiver from the same company.
                              mntlvrM
                              mntlvrM
                              mntlvr
                              @hek this is the Serial Monitor output from the same board powered the same way except running my original code and no failures.
                              You can see when I gnd the input the output responds.
                              send: 32-32-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                              send: 32-32-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                              send: 32-32-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:RemoteControl
                              send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:1.05
                              send: 32-32-0-0 s=3,c=0,t=0,pt=0,l=0,st=ok:
                              send: 32-32-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
                              send: 32-32-0-0 s=6,c=0,t=0,pt=0,l=0,st=ok:
                              send: 32-32-0-0 s=7,c=0,t=0,pt=0,l=0,st=ok:
                              send: 32-32-0-0 s=8,c=0,t=0,pt=0,l=0,st=ok:
                              send: 32-32-0-0 s=3,c=1,t=16,pt=0,l=1,st=ok:1
                              send: 32-32-0-0 s=4,c=1,t=16,pt=0,l=1,st=ok:1
                              send: 32-32-0-0 s=5,c=1,t=16,pt=0,l=1,st=ok:1
                              send: 32-32-0-0 s=6,c=1,t=16,pt=0,l=1,st=ok:1
                              send: 32-32-0-0 s=7,c=1,t=16,pt=0,l=1,st=ok:1
                              send: 32-32-0-0 s=8,c=1,t=16,pt=0,l=1,st=ok:1
                              send: 32-32-0-0 s=5,c=1,t=16,pt=0,l=1,st=ok:0
                                I suspect the message array is doing some buffer overwrite.
                                Just define one msg and reuse it with
                                msg.setSensor(x)
                                • BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  msg.setSensor(x)
                                  agree...
                                  look here:
                                  not winding its way through the array like you wold expect.
                                  • mntlvrM mntlvr
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @mtnlvr
                                    like this perhaps:
                                    #define RADIO_ID 32
                                    MyMessage msg(0,V_TRIPPED);
                                      delay(1000);
                                      gw.wait(250);
                                        Serial.println(i);
                                        gw.wait(250);
                                          msg.setSensor(i);
                                          gw.send(msg.set(value));
                                          Serial.print(i);
                                      @mtnlvr
                                      like this perhaps:
                                      #define RADIO_ID 32
                                        delay(1000);
                                        gw.wait(250);
                                          Serial.println(i);
                                          gw.wait(250);
                                            msg.setSensor(i);
                                            Serial.print(i);
                                      mntlvrM
                                      mntlvrM
                                      mntlvr
                                      @BulldogLowell
                                      This seems to work much better but what is the "version mismatch"?
                                      You can see the change of pin 5 now immediately now when I connect it to gnd or leave it open.
                                      Sending device info...sensor started, id 32
                                      read: 0-0-32 s=255,c=3,t=6,pt=0,l=1:I
                                      send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:1.15
                                      Setting up Pin0
                                      send: 32-32-0-0 s=0,c=0,t=0,pt=0,l=0,st=ok:
                                      Setting up Pin1
                                      send: 32-32-0-0 s=1,c=0,t=0,pt=0,l=0,st=ok:
                                      Setting up Pin2
                                      send: 32-32-0-0 s=2,c=0,t=0,pt=0,l=0,st=ok:
                                      Setting up Pin3
                                      Setting up Pin4
                                      Setting up Pin5
                                      read: 39-155-0 s=0,c=5,t=0,pt=0,l=0:
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      version mismatch
                                      send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:0
                                      Pin 5 changed state... New State: Not Tripped
                                        You seem to have radio disturbance (or the nodes radio get wacky when gateway sends its ack...).
                                        I think I have similar things when underpowering my gateway and sending with full power on a amplified nrf-module.
                                          mntlvrM
                                          mntlvrM
                                          mntlvr
                                          wrote on last edited by mntlvr
                                          #24
                                          @hek I just re-ran my Serial Monitor and now pin 5 only shows "version mismatch" I don't know how else to power any of these units because I have a 9 vdc 1 amp power pack on the Gateway and my sensors all have 1 amp, 9 vdc power packs
