  3. Open Source Home Automation (Raspberry)
automationopen sourceraspberrycontroller
111 Posts 30 Posters 185.5k Views 15 Watching
  • T toni
    @Yveaux openHAB has binding for MQTT and it has GUI (html5 and mobile app).
    https://github.com/openhab/openhab/wiki/MQTT-Binding
    https://github.com/cdjackson/HABmin
    https://www.youtube.com/watch?v=IlEa-R0VZ-c
    @toni Yeah, I also figured that out already, but I read some negative things here regarding openhab. Do you have some experience with it?
    • T
      toni
      I have a little experience with it. I have it installed and running on a virtual machine. So far only sonos and xbmc binding started. Which works fine. Will add ZWave and rfxcom as soon as I get the time.
      Learning threshold is a bit high at beginning but once you got the hang of it, it feels really smooth and you have full control. Im migrating from ver lite.
      • bjornhallbergB
        bjornhallbergB
        bjornhallberg
        wrote on last edited by bjornhallberg
        #33
        Those that did try openHAB (and felt it was slow), what version of java did you use? Did changing versions make any difference?
        I see that they recommend a very aggressive memory split also, leaving nothing for the GPU on the RPi. That is obviously impossible for those of us that also run the camera module.
        Edit: Perhaps someone would be daring enough to try openHAB 2.0 if and when it works:
        http://kaikreuzer.blogspot.com/2014/06/openhab-20-and-eclipse-smarthome.html
        Includes HABmin, and ...
        A second major design goal of openHAB 2.x is the optimization for embedded platforms. Although openHAB 1.x works on a Raspberry Pi, it sometimes feels a bit sluggish at startup or with huge installations - this is due to the fact that openHAB had never been specifically optimized for embedded systems and thus uses libraries such as Xtext, which are not meant to be used in constrained environments. In consequence, we will try to provide a minimal openHAB runtime that will work with alternatives or strategies such as pre-compilation etc.
        • DammeD
          DammeD
          Damme
          Code Contributor
          Maybe I'll leave the topic a bit, because I don't use raspberry myself but a linux server for my 'brain' so I don't have any problem with 'slowness'.
          I tried out openhab and actually likes it now, it is a bit ass to start up the configuration but then you learn it you'll easy put in new stuff. I might do a tutorial later on..
          But right now I'm looking at the communication between mysensors and openhab and yes I know there is one script written but I was thinking of making a new gateway software for the arduino.
          using mqtt protocol that is supported in openhab, and has a arduino library http://knolleary.net/arduino-client-for-mqtt/ ( https://github.com/knolleary/pubsubclient )
          an alternative to mqtt is to write something completely new using tcp binding or so, but I think its inventing the wheel all over again.
          • DammeD Damme
            @Damme I use a standard Ethernet gateway for mysensors and convert the mysensors messages using a quite simple Perl script running on my server (also not using RPI, so who cares about performance ;-) ).
            This script automatically publishes and subscribes to the mosquito MQTT broker, also running on the server. Works quite well!
            DammeD 1 Reply Last reply
            • YveauxY Yveaux
              DammeD
              DammeD
              Damme
              Code Contributor
              @Yveaux do you want to share? I am still waiting for my ethernet sheild so I cant do much programming there yet but would be fun to try out the mqtt protocol.. :)
              • DammeD Damme
                @Damme Ok, take a look at https://github.com/Yveaux/MySensors_MQTTGateway
                No documentation or getting started yet, no time :-1: Sorry...
                hekH epierreE 2 Replies Last reply
                • YveauxY Yveaux
                  @Yveaux
                  Nice. Forked it from MySensors-github so people will find it easier.
                    @Yveaux
                    #39
                    @hek Thanks! But I really need to start on my blog to document all the stuff I do... I'm afraid it isn't really self-documentary...
                    • YveauxY Yveaux
                      DammeD
                      DammeD
                      Damme
                      Code Contributor
                      @Yveaux I made it work but with lots of changes, first I use serial and not ethernet on the arduino, and then I didnt find the AnyEvent::MQTT, I use Net:MQTT instead. So basically its not much left of your original script, but it was just for testing MQTT a bit.
                      I think it would direcly in arduino..
                      • YveauxY Yveaux
                        epierreE
                        epierreE
                        epierre
                        @Yveaux I have the classic one : https://github.com/empierre/domoticz?files=1
                        but since you're perling I can contribute... and maybe add/create the imperihome rest intetface on top... but You'll have to overcome some isdues related to the absence of UI
                        z-wave - Vera -> Domoticz
                        • epierreE epierre
                          @epierre I'm afraid I don't get you...
                          So you're on domoticz, and you already have a gateway to mysensors?
                          Why do you want to switch to MQTT then?
                          epierreE 1 Reply Last reply
                          • YveauxY Yveaux
                            epierreE
                            epierreE
                            epierre
                            @Yveaux no I mean to make a mysensors gateway to imperihomr
                            • epierreE epierre
                              @epierre You could use my code as a start to connect to a mysensors Ethernet gateway and read/send messages, but it is really meant to bridge to MQTT protocol, and you don't need that, right?
                              • DammeD Damme
                                @Damme I did start with an arduino implementation buy as MQTT is text-based I needed quite some flash to store all the strings to convert the mysensors variable names and stuff.
                                This filled up my atmega328 almost completely and I got tired of all the trickery required to stay within the 32kb. I just wanted to prove and test the cooperation of my sensors and MQTT.
                                Then I realized the MQTT broker had to run on a 'heavier' platform anyway and decided that also my gateway could -- I see no use to stuff everything into an arduino.
                                If you're interested I can share the arduino implementation, but I no longer see the use for it.
                                If your changes improved my implementation then please share them with us :+1:
                                • YveauxY Yveaux
                                  DammeD
                                  DammeD
                                  Damme
                                  Code Contributor
                                  @Yveaux My script is not better than yours, I kind of broke it.. :)
                                  I had a thought that the atmega328 isn't enough, one option is to have external flash but no program code can be stoored there. The 32kb is still very limiting.
                                  I had a thought of atmega2560, there is one model with build in ethernet and some with external, total cost ~30USD. It has 256KB flash memory.
                                  So, yes I would be interessed in yout arduino code.. I might be able to slim the program down.. :)
                                  • F
                                    F
                                    filoucaenais
                                    Hello
                                    go Jeedom
                                    the project progresses faster
                                    and I motivated to make a plugin for MySensors
                                    there will be more people motivate
                                    faster plugin advance
                                    • DammeD Damme
                                      @Damme My code does only implement a MQTT client, not the broker. But if you still want it, chat me your email and I'll send it to you.
                                      • YveauxY Yveaux
                                        DammeD
                                        DammeD
                                        Damme
                                        Code Contributor
                                        @Yveaux Ah, I been writing a broker, just need a new Ethernet controller to continue, hope it will arrive tomorrow.
                                        • F filoucaenais
                                          Hello
                                          go Jeedom
                                          epierreE
                                          epierreE
                                          epierre
                                          @filoucaenais so bad all the core features in the market are to be bought... and that only zway which is now dying is supported, not openzwave...
                                          @bjornhallberg @Damme even domoticz guy are pushing people to use something better than raspberry... for a little more you have a cubieboard2 which has 1Go RAM and 2 cores @ 2011 bogomips... For z-wave OpenHab is still the best choice...
                                          bjornhallbergB hekH 2 Replies Last reply
