  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.7k Views 73 Watching
  • rvendrameR rvendrame
    @tekka said:
    I meant to update the Gateway node with the most recent Serialgateway sketch...
    Yep, I'm already on latest version on GW. My GW runs on a pro-mini, with standard bootloader --- I guess this is not a issue?
    tekkaT
    tekkaT
    tekka
    and MYSController is connected via USB/FTDI to the GW...?
    • rvendrameR
      rvendrameR
      rvendrame
      It is connected via USB/FTDI into a mac-mini running a TCP-to-serial SW. (so both Vera and MYSController can reach it using IP address). Works like a charm, I can see all nodes and messages, no connection issues so far.
      Is it required the GW running on MYSBootloader? I hope not...
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @rvendrame Sensor nodes with MYSBootloader (unless they are Sensebender boards) and GW with original bootloader. Curious to see your logs.
        • tekkaT tekka
          @rvendrame said:
          Yes, I connect the radio and start the node, but nothing happens --- No serial monitor, nothing in MYSController. Just the pin 13 led flashing randomly.
          Just flashed MYSController.hex on my Arduino pro mini 3V3 and the fuses as mentioned in the boards.txt (L: 0xF7 E: 0x06 H: 0xDA), using USBasp and everything works smoothly...
          Please keep in mind: There is no serial monitor for MYSBootloader and the 13 led flashing is normal
          Can you try this (in the indicated order):
          0) Update Arduino IDE to 1.6.5
          1. burn the original bootloader and upload the clear eeprom sketch
          2. burn MYSController, disconnect flasher and connect nRF24L01+ module
          3. download the most recent MySensors 1.5 library and upload the GW sketch
          4. launch MYSController 0.1.2.282, activate AutoID, Logging and connect to the serial GW
          5. let it run for a few mins and upload the log-file here
          rvendrameR
          rvendrameR
          rvendrame
          wrote on last edited by rvendrame
          #185
          EDIT: @tekka, @scalz , after so many tries, I don't know why I decided to replace the nRF radio , and guess what?
          Funny thing is that the previous radio is working with regular bootloader. Dam fake chips! But I will sort it out later, now I want to play with my OTA ;-)
          Thanks a lot!
          Alexa / Google Home
            @rvendrame: so cool. I am happy for you!
            See you soon
            • FrancoisF
              FrancoisF
              Francois
              @tekka do MYSBootloader also work with the RFM69 radios?
                Thanks a lot!
                tekkaT
                tekkaT
                tekka
                @rvendrame excellent :)
                • FrancoisF Francois
                  tekkaT
                  tekkaT
                  tekka
                  @Francois No, in it's current stage only nRF24L01+, but porting to RFM69 should not be too difficult...
                  • 5546dug5
                    5546dug5
                    5546dug
                    @tekka silly ?
                    But still last night changed from serial to Ethernet gw using iboard wiz5100 and the h/w changes.
                    No issues but for later problems do I ---use myscontroller by way of FTDI connector>usb or
                    -- continue to plug the original serial gw into laptop leaving Ethernet still in use ( plugged in).
                    • 5546dug5 5546dug
                      @tekka silly ?
                      tekkaT
                      tekkaT
                      tekka
                      @5546dug said:
                      @tekka silly ?
                      I'm not quite sure I understand your question. Are you having issues with the EthernetGW?
                      • 5546dug5
                        5546dug5
                        5546dug
                        @tekka No everything is ok now but there will be problems in the future to sort out if history repeats itself.
                        So it is just a learning question for troubleshooting later.
                        To "see" Ethernet gw in your gui use FDTI>usb>laptop (with gw still connected to the router) or use the serial gw I had from before connected remotely to laptop via usb..
                        As of now I use only Ethernet gw plugged into router and the serial gw is no longer plugged into my vera.
                        • C cdr
                          @tekka I feel really, really, REALLY stupid;
                          I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
                          D'OH
                          Thanks for your patience and help, everything is working now and I'm really happy!
                          :+1:
                          N
                          N
                          NewFolk
                          D'OH
                          :+1:
                          @tekka is there a way to change the default channel in MYSbootloader ?
                          • P
                            P
                            Pendragon
                            What ware the designed values for "type" in the fimware_config.csv?
                            Can I use this variable for my sensor IDs?
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              @tekka, I've being playing with MYSController and MYSBootloader over last days, I'm totally amazed by them ;-) Thank you so much for developing such nice tool!
                              If you allow me, I have only one ask for the santa-claus list: Perhaps it is possible for MYSBootloader capture serial output from a node, allowing OTA Serial monitor via MYSController? I know you guys are doing a miracle within 2KB, but who knows...
                              Again, thanks a lot!
                              Alexa / Google Home
                              • N NewFolk
                                D'OH
                                :+1:
                                tekkaT
                                tekkaT
                                tekka
                                Yes, but for that you'll have to re-compile it.
                                N 1 Reply Last reply
                                • P Pendragon
                                  tekkaT
                                  tekkaT
                                  tekka
                                  Yes, but this is only an internal reference and not being used for AutoFW assignment
                                    #198
                                    This sounds like a great app! What is the current status? I clicked on the link in the OP expecting it would connect with GitHub (where there might be a ReadMe.txt which tells what the current status is), but instad of that it just downloaded the app right then and there! There are now 197 posts on this thread, which is a bit many to sort through to find the status....
                                    Move it to Github?
                                      tekkaT
                                      tekkaT
                                      tekka
                                      Thanks, I'm glad you like the tools. :)
                                      Unfortunately your suggestion is not possible: bootloader and sketch run sequentially, not in parallel, and thus, cannot communicate with each other.
                                        Move it to Github?
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @NeverDie said:
                                        This sounds like a great app! What is the current status? I clicked on the link in the OP expecting it would connect with GitHub (where there might be a ReadMe.txt which tells what the current status is), but instad of that it just downloaded the app right then and there! There are 197 posts on this thread, which is a bit many to sort through to find the status....
                                        Move it to Github?
                                        The first post is updated once a new version is released :)
                                        • tekkaT tekka
                                          Move it to Github?
                                          #201
                                          @tekka said:
                                          Move it to Github?
                                          So then, as far as status goes, based on the version number, I guess it's still an unstable alpha release? Am I reading between the lines correctly?
                                          I did download it, and I can see that the files are from 7/25/2015, but there's no readme or other indication as to its status.
                                          I imagine others probably have the same question....
