  3. Battery Sensor v 1.0 PCB
56 Posts 9 Posters 44.4k Views 3 Watching
  • clippermiamiC clippermiami
    I ran the scanner but got page after page of:
         RF24/examples/scanner/
         Scanning all available frequencies...Scan completed.
    My radio is configured exactly as described although I will admit i just loaded the sketch to the sensor board and ran it on there rather than set up a special build just for that.
    axillentA
    axillentA
    axillent
    wrote on last edited by hek
    #36
    @clippermiami do not knew why but there are a few versions of this example
    try this one
    sorry, do not knew how to insert a code here
     Copyright (C) 2011 James Coliz, Jr. <maniacbug@ymail.com>
     Copyright (c) 2012 Greg Copeland
     * Channel scanner
     * Example to detect interference on the various channels available.
     * This is a good diagnostic tool to check whether you're picking a
     * good channel for your application.
     * Inspired by cpixip.
     * See http://arduino.cc/forum/index.php/topic,54795.0.html
    #include "RF24.h"
    #include "printf.h"
    // Only display active frequencies
    static const bool activeOnly = true ;
    // Hardware configuration
    // Set up nRF24L01 radio on SPI bus plus pins 8 & 9
    RF24 radio(9,10);
    // Channel info
    const short num_channels = 128;
    short values[num_channels];
    uint8_t signalMeter[55] ;
    // Setup
    void setup(void)
      // Print preamble
      printf_begin();
      printf("\n\rRF24/examples/scanner/\n\r");
      // Setup and configure rf radio
      radio.begin();
      radio.powerUp() ;
      radio.setAutoAck(false);
      // Get into standby mode
      radio.openReadingPipe( 0, 0xFFFFFFFFFFULL ) ;
      //  radio.setDataRate( RF24_250KBPS ) ; // may fallback to 1Mbps
      radio.setDataRate( RF24_1MBPS ) ; // may fallback to 1Mbps
      radio.startListening() ;
      radio.stopListening() ;
    // Loop
    void loop(void)
      // Clear measurement values
      memset( values, 0x00, num_channels ) ;
      printf( "Scanning all available frequencies..." ) ;
      // Repeatedly scan multiple channels
      for( int channel=0 ; channel < num_channels; channel++ ) {
        radio.setChannel( channel ) ;
        // Amplify the signal based on carrier bandwidth
        int ampFactor ;
        for( int amp=0; amp <= 300; amp++ ) {
          // Alternate data rates
          ampFactor = amp%3 ;
          switch( ampFactor ) {
          case 0:
    	break ;
          case 1:
    	break ;
          default:
    	radio.setDataRate( RF24_2MBPS ) ;
    	break ;
          // Listen for carrier
          ampFactor++ ;
          delayMicroseconds( 6 - ampFactor ) ;
          // Was carrier detected? If so, signal level based on bandwidth
          if( radio.testRPD() ) {
    	values[channel] += ampFactor ;
      // Now display our results
      printf( "Scan completed.\r\n" ) ;
        if( !activeOnly || (activeOnly && values[channel] > 0) ) {
          memset( signalMeter, '*', min( values[channel], 54 ) ) ;
          signalMeter[min(values[channel], 54)] = 0x00 ;
          printf( "%03d (%4dMhz): %02d - %s\r\n",
    	      channel,
    	      2400+channel,
    	      values[channel],
    	      signalMeter ) ;
          // Reset the scanned value since its already beend displayed
          values[channel] = 0 ;
    // vim:ai:cin:sts=2 sw=2 ft=cpp
    sense and drive
    clippermiamiC 1 Reply Last reply
    • axillentA axillent
      try this one
       * Channel scanner
      #include "RF24.h"
      #include "printf.h"
      RF24 radio(9,10);
      // Channel info
      // Setup
      void setup(void)
        // Print preamble
        printf_begin();
        radio.begin();
        radio.powerUp() ;
      // Loop
      void loop(void)
          int ampFactor ;
            ampFactor = amp%3 ;
            case 0:
      	break ;
            case 1:
      	break ;
            default:
      	break ;
            ampFactor++ ;
      	      channel,
      	      2400+channel,
      	      values[channel],
      	      signalMeter ) ;
      clippermiamiC
      clippermiamiC
      clippermiami
      @axillent First thing I see is that this version has the radio on pins 8,9 whereas the version I used has it on pins 9,10 which is where it is in my hardware.
      axillentA 1 Reply Last reply
        axillentA
        axillentA
        axillent
        @clippermiami That is a good point. But something tells me that you do need an assistance to adjust this code to your hardware :)
        sense and drive
          clippermiamiC
          clippermiamiC
          clippermiami
          @axillent I won't deny that, but it seems simple enough. :)
          • clippermiamiC
            clippermiamiC
            clippermiami
            wrote on last edited by clippermiami
            #40
            So i breadboarded a Nano and a NRFL2401 with a PA and antenna, uploaded the scanner sketch and this is what I got: I'm using the default radio channel from the distribution library.
             000 (2400Mhz): 96 - ******************************************************
             001 (2401Mhz): 100 - ******************************************************
             002 (2402Mhz): 95 - ******************************************************
             003 (2403Mhz): 99 - ******************************************************
             004 (2404Mhz): 98 - ******************************************************
             005 (2405Mhz): 104 - ******************************************************
             006 (2406Mhz): 91 - ******************************************************
             007 (2407Mhz): 95 - ******************************************************
             008 (2408Mhz): 98 - ******************************************************
             009 (2409Mhz): 96 - ******************************************************
             010 (2410Mhz): 96 - ******************************************************
             011 (2411Mhz): 86 - ******************************************************
             012 (2412Mhz): 89 - ******************************************************
             013 (2413Mhz): 94 - ******************************************************
             014 (2414Mhz): 95 - ******************************************************
             015 (2415Mhz): 92 - ******************************************************
             016 (2416Mhz): 93 - ******************************************************
             017 (2417Mhz): 92 - ******************************************************
             018 (2418Mhz): 99 - ******************************************************
             019 (2419Mhz): 85 - ******************************************************
             020 (2420Mhz): 99 - ******************************************************
             021 (2421Mhz): 96 - ******************************************************
             022 (2422Mhz): 90 - ******************************************************
             023 (2423Mhz): 98 - ******************************************************
             024 (2424Mhz): 85 - ******************************************************
             025 (2425Mhz): 99 - ******************************************************
             026 (2426Mhz): 100 - ******************************************************
             027 (2427Mhz): 95 - ******************************************************
             028 (2428Mhz): 95 - ******************************************************
             029 (2429Mhz): 90 - ******************************************************
             030 (2430Mhz): 95 - ******************************************************
             031 (2431Mhz): 96 - ******************************************************
             032 (2432Mhz): 95 - ******************************************************
             033 (2433Mhz): 91 - ******************************************************
             034 (2434Mhz): 93 - ******************************************************
             035 (2435Mhz): 97 - ******************************************************
             036 (2436Mhz): 104 - ******************************************************
             037 (2437Mhz): 99 - ******************************************************
             038 (2438Mhz): 92 - ******************************************************
             039 (2439Mhz): 96 - ******************************************************
             040 (2440Mhz): 94 - ******************************************************
             041 (2441Mhz): 100 - ******************************************************
             042 (2442Mhz): 92 - ******************************************************
             043 (2443Mhz): 100 - ******************************************************
             044 (2444Mhz): 110 - ******************************************************
             045 (2445Mhz): 92 - ******************************************************
             046 (2446Mhz): 111 - ******************************************************
             047 (2447Mhz): 99 - ******************************************************
             048 (2448Mhz): 98 - ******************************************************
             049 (2449Mhz): 93 - ******************************************************
             050 (2450Mhz): 97 - ******************************************************
             051 (2451Mhz): 99 - ******************************************************
             052 (2452Mhz): 93 - ******************************************************
             053 (2453Mhz): 96 - ******************************************************
             054 (2454Mhz): 93 - ******************************************************
             055 (2455Mhz): 94 - ******************************************************
             056 (2456Mhz): 106 - ******************************************************
             057 (2457Mhz): 101 - ******************************************************
             058 (2458Mhz): 94 - ******************************************************
             059 (2459Mhz): 106 - ******************************************************
             060 (2460Mhz): 91 - ******************************************************
             061 (2461Mhz): 96 - ******************************************************
             062 (2462Mhz): 98 - ******************************************************
             063 (2463Mhz): 100 - ******************************************************
             064 (2464Mhz): 107 - ******************************************************
             065 (2465Mhz): 101 - ******************************************************
             066 (2466Mhz): 93 - ******************************************************
             067 (2467Mhz): 90 - ******************************************************
             068 (2468Mhz): 102 - ******************************************************
             069 (2469Mhz): 103 - ******************************************************
             070 (2470Mhz): 95 - ******************************************************
             071 (2471Mhz): 102 - ******************************************************
             072 (2472Mhz): 99 - ******************************************************
             073 (2473Mhz): 94 - ******************************************************
             074 (2474Mhz): 97 - ******************************************************
             075 (2475Mhz): 105 - ******************************************************
             076 (2476Mhz): 97 - ******************************************************
             077 (2477Mhz): 92 - ******************************************************
             078 (2478Mhz): 103 - ******************************************************
             079 (2479Mhz): 94 - ******************************************************
             080 (2480Mhz): 98 - ******************************************************
             081 (2481Mhz): 99 - ******************************************************
             082 (2482Mhz): 103 - ******************************************************
             083 (2483Mhz): 98 - ******************************************************
             084 (2484Mhz): 89 - ******************************************************
             085 (2485Mhz): 97 - ******************************************************
             086 (2486Mhz): 94 - ******************************************************
             087 (2487Mhz): 97 - ******************************************************
             088 (2488Mhz): 92 - ******************************************************
             089 (2489Mhz): 101 - ******************************************************
             090 (2490Mhz): 98 - ******************************************************
             091 (2491Mhz): 99 - ******************************************************
             092 (2492Mhz): 92 - ******************************************************
             093 (2493Mhz): 88 - ******************************************************
             094 (2494Mhz): 95 - ******************************************************
             095 (2495Mhz): 92 - ******************************************************
             096 (2496Mhz): 95 - ******************************************************
             097 (2497Mhz): 95 - ******************************************************
             098 (2498Mhz): 90 - ******************************************************
             099 (2499Mhz): 100 - ******************************************************
             100 (2500Mhz): 94 - ******************************************************
             101 (2501Mhz): 107 - ******************************************************
             102 (2502Mhz): 90 - ******************************************************
             103 (2503Mhz): 95 - ******************************************************
             104 (2504Mhz): 105 - ******************************************************
             105 (2505Mhz): 99 - ******************************************************
             106 (2506Mhz): 101 - ******************************************************
             107 (2507Mhz): 100 - ******************************************************
             108 (2508Mhz): 103 - ******************************************************
             109 (2509Mhz): 99 - ******************************************************
             110 (2510Mhz): 99 - ******************************************************
             111 (2511Mhz): 92 - ******************************************************
             112 (2512Mhz): 90 - ******************************************************
             113 (2513Mhz): 96 - ******************************************************
             114 (2514Mhz): 102 - ******************************************************
             115 (2515Mhz): 96 - ******************************************************
             116 (2516Mhz): 91 - ******************************************************
             117 (2517Mhz): 98 - ******************************************************
             118 (2518Mhz): 95 - ******************************************************
             119 (2519Mhz): 101 - ******************************************************
             120 (2520Mhz): 104 - ******************************************************
             121 (2521Mhz): 93 - ******************************************************
             122 (2522Mhz): 98 - ******************************************************
             123 (2523Mhz): 98 - ******************************************************
             124 (2524Mhz): 96 - ******************************************************
             125 (2525Mhz): 95 - ******************************************************
             126 (2526Mhz): 94 - ******************************************************
             127 (2527Mhz): 96 - ******************************************************
            Which does not look much like the display at the reference: http://arduino.cc/forum/index.php/topic,54795.0.html
            and i'm not sure what its telling me other than some relative signal level data. Perhaps someone could help me interpret this :)
            Updagte:
            As it continues to run it shows significantly different values over time, some reaching as high as
             063 (2463Mhz): 84 - ******************************************************
             064 (2464Mhz): 89 - ******************************************************
             065 (2465Mhz): 97 - ******************************************************
             066 (2466Mhz): 201 - ******************************************************
             067 (2467Mhz): 252 - ******************************************************
             068 (2468Mhz): 300 - ******************************************************
             069 (2469Mhz): 284 - ******************************************************
            • clippermiamiC
              clippermiamiC
              clippermiami
              I'm about idea'd out. I put a 200 uF electrolytic directly on the Vcc and Gnd terminals of the radio module and it made no difference whatsoever ... the sensor fails to report beyond about 10 meters and one interior wall. That doesn't leave much upside.
              I'm at a loss at this point, I've tried different radio modules to no avail. I've taken the radio off the board ground plane to no avail.Thus far the only thing I've found that allows decent distance is a radio with the PA/SMA antenna and that simply eats battery. I can't make hide nor hair out of the scanner output ... the channel variation doesn't appear to be more than a few percent for the most part so it doesn't look like that's much of a solution.
              I admit to being curious if anyone has actually had these things work beyond the workbench :)
              YveauxY Z 2 Replies Last reply
                #42
                Maybe your house is just a lot bigger than ours :office: :laughing:
                • YveauxY Yveaux
                  clippermiamiC
                  clippermiamiC
                  clippermiami
                  @Yveaux While I suppose that's possible 10-15 feet is still 10-15 feet :-)
                    Z
                    Z
                    Zeph
                    Do you know what's inside that one interior wall? Could it have anything which would interfere with RF (more than the typical wood 2x4's and two sheets of drywall do)?
                    Some people have definitely had better results.
                    I think you said that you had changed out the radio module, but did you try any from a different source or batch?
                    • Z Zeph
                      clippermiamiC
                      clippermiamiC
                      clippermiami
                      @Zeph it's just ordinary drywall. In the interest of complete disclosure, there is a floor-ceiling bookcase on the wall but if this stuff is THAT sensor then ... :-)
                      The radios are all from an order about a month ago so they are probably the same batch. I have another batch of 10 coming but that's probably a week away yet.
                      About the only thing left is to change radio channels but the numbers the scan don't tell me much, they don't vary but a few percent, so I am at a loss where to go.
                        @clippermiami I hope to release a network sniffer for NRF24 in the near future which might probably help you to diagnose the problem. It captures all on-air packets and also shows which ones have CRC errors.
                        The amount of packets with CRC errors is a good indication of the link quality.
                        • YveauxY Yveaux
                          clippermiamiC
                          clippermiamiC
                          clippermiami
                          @Yveaux thanks, I look forward to it :-)
                          • daulagariD
                            daulagariD
                            daulagari
                            @clippermiami: How about ACI, Adjacent Channel Interference?
                            Having a WiFi background I know the 2.4 GHz band is also used by others, microwave oves, WiFi, Bluetooth etc.
                            Been working on WiFi - Bluetooth coexistence and although they do not share channels, Bluetooth transmitting on 10 dBm can impact WiFi dramatically if the separation of the two devices is small.
                            You could try moving both devices at least 5 meters away from other equipment and see if it makes a difference.
                            • daulagariD daulagari
                              clippermiamiC
                              clippermiamiC
                              clippermiami
                              @daulagari A possibility. I have three separate Wifi Access Points running in the house two 2.4 GHz 802.11n and one 5 GHz 802.11a. The 11A and one of the 11N points are in a dual band device, the other 11N is part of my AT&T uVerse router. I have them forced to specific channels, but none of then adjacent to the MySensors default (CH 76 as I recall), the highest one is the 11A on Ch 36
                              daulagariD 1 Reply Last reply
                              • clippermiamiC
                                clippermiamiC
                                clippermiami
                                I did have a chance for one more experiment. I had a SEEED "DevDuino" I bought to play with but haven't used yet. I swapped the radio from that module onto my sensor board and I was able to get reporting from another 10 feet away so there is definitely something related to the individual NRF24L01 modules --- different batch I guess. It still doesn't get me to even the other end of the house (perhaps 20 meters from the GW) let alone outside anywhere.or through outside walls.
                                  daulagariD
                                  daulagariD
                                  daulagari
                                  wrote on last edited by daulagari
                                  #51
                                  The NRF24 channels (Freq [MHz] = 2400 + channel) are not the same as WiFi channels. Ch 36 for WiFi is in the 5GHz band but can you share the 11n channels you forced the AP's to?
                                  See also https://en.wikipedia.org/wiki/List_of_WLAN_channels for a list of WiFi channels and their frequencies.
                                    clippermiamiC
                                    clippermiamiC
                                    clippermiami
                                    @daulagari Yes, my error, 36 is in the 5GHz band.
                                    The 2.4 GHz channels are 5 and 11. There are some neighbors' Wifi on Ch 1 and 2 but they are heavily attenuated.
                                    • clippermiamiC
                                      clippermiamiC
                                      clippermiami
                                      It occurred to me that the one thing I had not changed was the GW radio. I had one spare NRF24L01+PA+SMA so I swapped it in the GW. That appears to be the fix --- I can now see the sensor module all the way out in the yard at the far end of the house, through outside walls and a half dozen interior walls. I doubt i'll get the 450+ meters reported elsewhere on the forum but its a LOT better than the 10 feet I was getting :)
                                      hekH 1 Reply Last reply
                                        @clippermiami
                                        Sounds good!
                                          @clippermiami
                                          Sounds good!
                                          clippermiamiC
                                          clippermiamiC
                                          clippermiami
                                          @hek just my luck, the USB on my Vera Lite has packed up so now I can"t do any more testing until I sort that out. Maddening
