  3. Battery Sensor v 1.0 PCB
56 Posts 9 Posters 44.4k Views 3 Watching
  • clippermiamiC clippermiami
    @Zeph it's just ordinary drywall. In the interest of complete disclosure, there is a floor-ceiling bookcase on the wall but if this stuff is THAT sensor then ... :-)
    The radios are all from an order about a month ago so they are probably the same batch. I have another batch of 10 coming but that's probably a week away yet.
    About the only thing left is to change radio channels but the numbers the scan don't tell me much, they don't vary but a few percent, so I am at a loss where to go.
    @clippermiami I hope to release a network sniffer for NRF24 in the near future which might probably help you to diagnose the problem. It captures all on-air packets and also shows which ones have CRC errors.
    The amount of packets with CRC errors is a good indication of the link quality.
    clippermiamiC 1 Reply Last reply
    • YveauxY Yveaux
      clippermiamiC
      clippermiamiC
      clippermiami
      @Yveaux thanks, I look forward to it :-)
      • daulagariD
        daulagariD
        daulagari
        @clippermiami: How about ACI, Adjacent Channel Interference?
        Having a WiFi background I know the 2.4 GHz band is also used by others, microwave oves, WiFi, Bluetooth etc.
        Been working on WiFi - Bluetooth coexistence and although they do not share channels, Bluetooth transmitting on 10 dBm can impact WiFi dramatically if the separation of the two devices is small.
        You could try moving both devices at least 5 meters away from other equipment and see if it makes a difference.
        • daulagariD daulagari
          clippermiamiC
          clippermiamiC
          clippermiami
          @daulagari A possibility. I have three separate Wifi Access Points running in the house two 2.4 GHz 802.11n and one 5 GHz 802.11a. The 11A and one of the 11N points are in a dual band device, the other 11N is part of my AT&T uVerse router. I have them forced to specific channels, but none of then adjacent to the MySensors default (CH 76 as I recall), the highest one is the 11A on Ch 36
          daulagariD 1 Reply Last reply
          • clippermiamiC
            clippermiamiC
            clippermiami
            I did have a chance for one more experiment. I had a SEEED "DevDuino" I bought to play with but haven't used yet. I swapped the radio from that module onto my sensor board and I was able to get reporting from another 10 feet away so there is definitely something related to the individual NRF24L01 modules --- different batch I guess. It still doesn't get me to even the other end of the house (perhaps 20 meters from the GW) let alone outside anywhere.or through outside walls.
              daulagariD
              daulagariD
              daulagari
              wrote on last edited by daulagari
              #51
              The NRF24 channels (Freq [MHz] = 2400 + channel) are not the same as WiFi channels. Ch 36 for WiFi is in the 5GHz band but can you share the 11n channels you forced the AP's to?
              See also https://en.wikipedia.org/wiki/List_of_WLAN_channels for a list of WiFi channels and their frequencies.
                clippermiamiC
                clippermiamiC
                clippermiami
                @daulagari Yes, my error, 36 is in the 5GHz band.
                The 2.4 GHz channels are 5 and 11. There are some neighbors' Wifi on Ch 1 and 2 but they are heavily attenuated.
                • clippermiamiC
                  clippermiamiC
                  clippermiami
                  It occurred to me that the one thing I had not changed was the GW radio. I had one spare NRF24L01+PA+SMA so I swapped it in the GW. That appears to be the fix --- I can now see the sensor module all the way out in the yard at the far end of the house, through outside walls and a half dozen interior walls. I doubt i'll get the 450+ meters reported elsewhere on the forum but its a LOT better than the 10 feet I was getting :)
                  hekH 1 Reply Last reply
                    @clippermiami
                    Sounds good!
                      @clippermiami
                      Sounds good!
                      clippermiamiC
                      clippermiamiC
                      clippermiami
                      @hek just my luck, the USB on my Vera Lite has packed up so now I can"t do any more testing until I sort that out. Maddening
                      • T
                        Tibus
                        I plan to use also a CR123 for my board. I bought some CR123a rechargeable on ebay but the battery give me 4V when it's charged... is it a problem to give 4V to a 3.3V step up converter? is the "a" after CR123 say that's a 3.7V instead of a 3V or is it just because of the rechargable function? is your CR123 give also 4V when it's charged?
                        Thank's so much
                        Julien
