  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 404.4k Views 39 Watching
  • Andy PepA Andy Pep
    i have a few esp8266mod demo bords a node mcu 9.5 a few esp-01, when i get home i will throw a gateway together :) and test all you like ..i do not mind doing alpha or beta testing if needed ..great work btw ...
    also has anyone used this beta .. looks very cool aswell :) http://www.esp8266.com/viewtopic.php?f=29&t=4540
    kind regards
    andy
    Thanks! Please join me in testing this code!
    Nice, but as I stressed in my previous post this seems like overkill for a gateway to me.
    Of course we can cram a lot of extra code and functionality in the ESP. It has a lot of power and someone might even build a whole home automation suite directly in it (anybody? ;-) )
    Let's get this gateway usable, stable and tested. From there you can use it as a base for other applications.
    • Andy PepA
      Andy PepA
      Andy Pep
      ok i have used a esp8266mod dev board for my test hooked it up flashed the sketch and domoticz is seeing it ok and relaying my sensor data .. not a painfull process at all :) ..
      will update tomorrow to see if it fails or goes fubar ..but so far so good :P)
        @Andy-Pep Awesome! Good to hear its running without any troubles so far! :+1:
        Maybe I frightened people by writing a too elaborate description how to set things up :dizzy_face:
        DrJeffD 1 Reply Last reply
        • Andy PepA
          Andy PepA
          Andy Pep
          to me it was very easy to hook up and get working ..well done Yveaux you have given my collection of esp's a new life :) when my phone recharges ill take a pic and upload it ..i like the way it reboots when connection is lost .. handy feature :)
          well done kudos to you :)
          YveauxY 2 Replies Last reply
          • YveauxY Yveaux
            DrJeffD
            DrJeffD
            DrJeff
            @Yveaux No you did not scare me away but I'm in loss of time to do this. I look forward to setting my esp gateway up in a week or so. :)
              #23
              I wasn't aware of that. Most errors result in watchdog timeouts or access violations and cause a reboot. The Ethernet client has to be robust against this.
              We need extensive testing to catch these kinds of errors and assure they are handled in a defined way.
              • DrJeffD DrJeff
                A, damn ! Maybe next project then? :facepunch:
                The problem lies mainly in the vast amount of ESP variants and how to wire them to be able to download and to connect the radio.
                • Andy PepA
                  Andy PepA
                  Andy Pep
                  ok.
                  ill put a serial interface on to it and keep it running for debug data ..ill post up the next 3 hours of data later on this evening ..
                  • YveauxY Yveaux
                    DrJeffD
                    DrJeffD
                    DrJeff
                    wrote on last edited by DrJeff
                    #26
                    Sorry it was supposed to be "No you didn't scare", me auto correct!
                    I'm going to build this for sure!
                      I cannot replay this situation:
                      • Tried disabling my WiFI network on the router. Gateway keeps running and restores connection correctly when WiFI is enabled again. No reboot observed.
                      • Tried disconnecting telnet session. No reboot.
                      What did you do to cause a reboot?
                      • O
                        O
                        olof
                        Yes great work is right. thank you
                        • F
                          F
                          Fabien
                          Ok I will test it in few days.
                          Do you think is it possible to have an ESP gateway with RF24 and RF69 ? ESP have more memroy (ESP12E)
                          • F Fabien
                            @Fabien connecting two radios should work, although MySensors does not natively support it.
                            • G
                              G
                              gonzalonal
                              Hi, let me ask a silly question just to confirm if I understand how this would work.
                              This gateway would receive Nodes data throght NRF or RF69 and then send it to controller via wifi? The way back would be, receiving controller commands/data via wifi and get to the nodes through NRF or RF69.
                              Is this right?
                              • G gonzalonal
                                Is this right?
                                Is this right?
                                Correct!
                                • F
                                  F
                                  Fabien
                                  Doesn't work here with stage version of ESP8266-Arduino (can't install stable version, I have checksum error). I use this module http://www.electrodragon.com/product/nodemcu-lua-amica-r2-esp8266-wifi-board/
                                  Can't load at 9600 bauds (how can you change uplaod baud rate ?)
                                  Crash on init and reboot :
                                  ESP8266 MySensors Gateway
                                  Connecting to Livebox-577E
                                  ...Connected!
                                  IP: 192.168.1.23
                                  Exception (3):
                                  epc1=0x40206955 epc2=0x00000000 epc3=0x00000000 excvaddr=0x40244cd2 depc=0x00000000
                                  ctx: cont
                                  sp: 3ffea540 end: 3ffea780 offset: 01a0
                                  >>>stack>>>
                                  3ffea6e0:  a8e1fcff 000000a8 3ffe9294 40206b7c
                                  3ffea6f0:  00000001 3ffe9290 3ffe9294 402036d0
                                  3ffea700:  00000000 00000000 3ffe91fc 40204910
                                  3ffea710:  0000007f 3ffea7ac 40201cac 3ffe9760
                                  3ffea720:  40202320 00000001 00000000 40201d4f
                                  3ffea730:  1701a8c0 00ffffff 0101a8c0 3ffea7ac
                                  3ffea740:  3ffe873d 3ffe9474 3ffe972c 4020266f
                                  3ffea750:  3ffe8c08 1701a8c0 00000000 00000000
                                  3ffea760:  3fffdc20 00000000 3ffea7a4 40201d1f
                                  3ffea770:  00000000 00000000 3ffe9760 40100374
                                  <<<stack<<<
                                   ets Jan  8 2013,rst cause:2, boot mode:(3,6)
                                  tail 0
                                  chksum 0x42
                                  csum 0x42
                                  ~ld
                                  • F Fabien
                                    ...Connected!
                                    IP: 192.168.1.23
                                    Exception (3):
                                    ctx: cont
                                    >>>stack>>>
                                    <<<stack<<<
                                    tail 0
                                    chksum 0x42
                                    csum 0x42
                                    ~ld
                                    What do you mean by stage version and checksum error exactly?
                                    Tonight @hek merged the gateway code for ESP to master 1.5. Could you try with that version?
                                    Seems identical to the one I ordered. Until I receive it I cannot replay your exact case. I did test & develop using separate ESP12 module, while your board has ESP12E, I guess. Can you confirm this?
                                    Don't bother about the download speed. I only suggest to start at low speed as it seems to download more reliably. Did download finish without errors?
                                    ...Connected!
                                    IP: 192.168.1.23
                                    Exception (3):
                                    ctx: cont
                                    >>>stack>>>
                                    <<<stack<<<
                                    tail 0
                                    chksum 0x42
                                    csum 0x42
                                    ~ld
                                    Apparently you did connect to WiFi correctly and got an IP address.
                                    Debugging this module is hard; I add serial print statements at strategic places to drill down to the cause of such access violations.
                                    It would really help if you can get some more info on where it crashes by adding these print statements.
                                    Otherwise you'll probably have to wait until we get to a common hardware setup.
                                    • F Fabien
                                      ...Connected!
                                      IP: 192.168.1.23
                                      Exception (3):
                                      ctx: cont
                                      >>>stack>>>
                                      <<<stack<<<
                                      tail 0
                                      chksum 0x42
                                      csum 0x42
                                      ~ld
                                      @Fabien My bad, mea culpa :facepunch:
                                      Have been so busy getting the stuff to compile for all different platforms that this bug sneaked in... That's why you should always verify if your code still works, after building it ;-)
                                      Anyway, see this pull request for the fix.
                                      Once it is merged to master, could you please try again?
                                      I'm also experiencing some random disconnects, so expect a new update soon...
                                        Opps :blush:
                                        Started Jenkins build of the PR.
                                          Opps :blush:
                                          @hek You probably got so accustomed to building it :tired_face:
