  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 398.0k Views 39 Watching
  • Andy PepA
    Andy PepA
    Andy Pep
    ok.
    ill put a serial interface on to it and keep it running for debug data ..ill post up the next 3 hours of data later on this evening ..
    • YveauxY Yveaux
      @DrJeff said:
      @Yveaux No you did not scare me away
      A, damn ! Maybe next project then? :facepunch:
      The problem lies mainly in the vast amount of ESP variants and how to wire them to be able to download and to connect the radio.
      DrJeffD
      DrJeffD
      DrJeff
      wrote on last edited by DrJeff
      #26
      Sorry it was supposed to be "No you didn't scare", me auto correct!
      I'm going to build this for sure!
      • Andy PepA Andy Pep
        to me it was very easy to hook up and get working ..well done Yveaux you have given my collection of esp's a new life :) when my phone recharges ill take a pic and upload it ..i like the way it reboots when connection is lost .. handy feature :)
        well done kudos to you :)
        I cannot replay this situation:
        • Tried disabling my WiFI network on the router. Gateway keeps running and restores connection correctly when WiFI is enabled again. No reboot observed.
        • Tried disconnecting telnet session. No reboot.
        What did you do to cause a reboot?
        • O
          O
          olof
          Yes great work is right. thank you
          • F
            F
            Fabien
            Ok I will test it in few days.
            Do you think is it possible to have an ESP gateway with RF24 and RF69 ? ESP have more memroy (ESP12E)
            • F Fabien
              @Fabien connecting two radios should work, although MySensors does not natively support it.
              • G
                G
                gonzalonal
                Hi, let me ask a silly question just to confirm if I understand how this would work.
                This gateway would receive Nodes data throght NRF or RF69 and then send it to controller via wifi? The way back would be, receiving controller commands/data via wifi and get to the nodes through NRF or RF69.
                Is this right?
                • G gonzalonal
                  Is this right?
                  Is this right?
                  Correct!
                  • F
                    F
                    Fabien
                    Doesn't work here with stage version of ESP8266-Arduino (can't install stable version, I have checksum error). I use this module http://www.electrodragon.com/product/nodemcu-lua-amica-r2-esp8266-wifi-board/
                    Can't load at 9600 bauds (how can you change uplaod baud rate ?)
                    Crash on init and reboot :
                    ESP8266 MySensors Gateway
                    Connecting to Livebox-577E
                    ...Connected!
                    IP: 192.168.1.23
                    Exception (3):
                    epc1=0x40206955 epc2=0x00000000 epc3=0x00000000 excvaddr=0x40244cd2 depc=0x00000000
                    ctx: cont
                    sp: 3ffea540 end: 3ffea780 offset: 01a0
                    >>>stack>>>
                    3ffea6e0:  a8e1fcff 000000a8 3ffe9294 40206b7c
                    3ffea6f0:  00000001 3ffe9290 3ffe9294 402036d0
                    3ffea700:  00000000 00000000 3ffe91fc 40204910
                    3ffea710:  0000007f 3ffea7ac 40201cac 3ffe9760
                    3ffea720:  40202320 00000001 00000000 40201d4f
                    3ffea730:  1701a8c0 00ffffff 0101a8c0 3ffea7ac
                    3ffea740:  3ffe873d 3ffe9474 3ffe972c 4020266f
                    3ffea750:  3ffe8c08 1701a8c0 00000000 00000000
                    3ffea760:  3fffdc20 00000000 3ffea7a4 40201d1f
                    3ffea770:  00000000 00000000 3ffe9760 40100374
                    <<<stack<<<
                     ets Jan  8 2013,rst cause:2, boot mode:(3,6)
                    tail 0
                    chksum 0x42
                    csum 0x42
                    ~ld
                    YveauxY 2 Replies Last reply
                    • F Fabien
                      ...Connected!
                      IP: 192.168.1.23
                      Exception (3):
                      ctx: cont
                      >>>stack>>>
                      <<<stack<<<
                      tail 0
                      chksum 0x42
                      csum 0x42
                      ~ld
                      What do you mean by stage version and checksum error exactly?
                      Tonight @hek merged the gateway code for ESP to master 1.5. Could you try with that version?
                      Seems identical to the one I ordered. Until I receive it I cannot replay your exact case. I did test & develop using separate ESP12 module, while your board has ESP12E, I guess. Can you confirm this?
                      Don't bother about the download speed. I only suggest to start at low speed as it seems to download more reliably. Did download finish without errors?
                      ...Connected!
                      IP: 192.168.1.23
                      Exception (3):
                      ctx: cont
                      >>>stack>>>
                      <<<stack<<<
                      tail 0
                      chksum 0x42
                      csum 0x42
                      ~ld
                      Apparently you did connect to WiFi correctly and got an IP address.
                      Debugging this module is hard; I add serial print statements at strategic places to drill down to the cause of such access violations.
                      It would really help if you can get some more info on where it crashes by adding these print statements.
                      Otherwise you'll probably have to wait until we get to a common hardware setup.
                      • F Fabien
                        ...Connected!
                        IP: 192.168.1.23
                        Exception (3):
                        ctx: cont
                        >>>stack>>>
                        <<<stack<<<
                        tail 0
                        chksum 0x42
                        csum 0x42
                        ~ld
                        @Fabien My bad, mea culpa :facepunch:
                        Have been so busy getting the stuff to compile for all different platforms that this bug sneaked in... That's why you should always verify if your code still works, after building it ;-)
                        Anyway, see this pull request for the fix.
                        Once it is merged to master, could you please try again?
                        I'm also experiencing some random disconnects, so expect a new update soon...
                          Opps :blush:
                          Started Jenkins build of the PR.
                            Opps :blush:
                            @hek You probably got so accustomed to building it :tired_face:
                              The build server must earn its cost :)
                              • YveauxY
                                I prepared a new pull request which deals with some occasional watchdog timeouts (causing a reset) when clients connect or disconnect.
                                It also allows multiple clients to connect simultaneously to the ESP gateway.
                                Please update to this version once it's integrated in master.
                                • F
                                  F
                                  Fabien
                                  With pull #186, it works better ...
                                  Connection ok, can see messages form sensors on the serial line.
                                  Connecting with MYSController, got "Gateway startup complete." on the serial link but nothing on MYSController. Pinging works ...
                                  Perhaps somme problems with ESP and Livebox ... I have this problem before with some sketch and I must made an AP on my Odroid ... I will try later.
                                    MySensors/Arduino#186 Merged
                                    • DrJeffD
                                      DrJeffD
                                      DrJeff
                                      #42
                                      Can this be built with esp8266-03? I got a couple of those sitting here waiting to get used? It looks like I can swap Pin 4 for Pin 16 (or 18 in this picture) Is there something I'm missing?
                                      upload-84b2ef8e-b204-4e47-88a7-ddcd10405227
                                      • DrJeffD DrJeff
                                        #43
                                        @DrJeff GPIO16 is a strange IO pin on some modules as it might be triggering the nReset line. Should work for this ESP-03 though.
                                        Make sure to use the latest MySensors library and please post your experiences here so we can bundle them.
                                        • YveauxY
                                          NodeMcu boards are in!
                                          Fast shipment & very well packed:
                                          I can upload at 921600 baud (!) without manual reset/bootload from Arduino IDE and LED blink sketch is working.
                                          Next is connecting nRF24 and see if ESP gateway is running without problems.
                                          I'll keep you informed!
