  3. Test your home made controller with MockMySensors (w/ tutorial)
39 Posts 12 Posters 31.3k Views 14 Watching
  • ch3b7C
    ch3b7C
    ch3b7
    wrote on last edited by ch3b7
    all sensors present good but when finish i get a loop sended:
    send: 50-50-0-0 s=0,c=1,t=16,pt=7,l=5,sg=0,st=ok:0.0
    im use (lib 1.5) MockMySensors.ino
    barduinoB 1 Reply Last reply
    • ch3b7C ch3b7
      barduinoB
      barduinoB
      barduino
      @ch3b7
      Very interesting.
      I was not able to repruduce what you are describing above.
      According to your message we have:
      • Node 50 sending to node 0
      • Child sensor id 0
      • Message type 1 : SET
      • MessageSub Type 16: V_TRIPPED
      • Payload type 7: P_CUSTOM
      • Payload length 5
      Which is very strange.
      In MockMySensors there is no childid=0, the first sensor is #define ID_S_DOOR 1 and the node ID is set to 254 (but perhpas you have changed this)
      Also V_TRIPPED should be sending a bolean value...
      Could you upload your scetch?
      here is my log: SetUP
      send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
      send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
      read: 0-0-254 s=255,c=3,t=6,pt=0,l=1,sg=0:M
      sensor started, id=254, parent=0, distance=1
      GW Started
      Send Sketch Info: send: 254-254-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,st=ok:MockMySensors
      send: 254-254-0-0 s=255,c=3,t=12,pt=0,l=4,sg=0,st=ok:v0.3
      MockMySensors v0.3
      Get Config: Metric
      Presenting Nodes
      ________________
        S_DOOR
      send: 254-254-0-0 s=1,c=0,t=0,pt=0,l=0,sg=0,st=ok:
        S_MOTION
      send: 254-254-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,st=ok:
        S_SMOKE
      send: 254-254-0-0 s=3,c=0,t=2,pt=0,l=0,sg=0,st=ok:
        S_LIGHT
      send: 254-254-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
        S_DIMMER
      send: 254-254-0-0 s=5,c=0,t=4,pt=0,l=0,sg=0,st=ok:
        S_COVER
      send: 254-254-0-0 s=6,c=0,t=5,pt=0,l=0,sg=0,st=ok:
        S_TMEP
      send: 254-254-0-0 s=7,c=0,t=6,pt=0,l=0,sg=0,st=ok:
        S_HUM
      send: 254-254-0-0 s=8,c=0,t=7,pt=0,l=0,sg=0,st=ok:
        S_BARO
      send: 254-254-0-0 s=9,c=0,t=8,pt=0,l=0,sg=0,st=ok:
        S_WIND
      send: 254-254-0-0 s=10,c=0,t=9,pt=0,l=0,sg=0,st=ok:
        S_RAIN
      send: 254-254-0-0 s=11,c=0,t=10,pt=0,l=0,sg=0,st=ok:
        S_UV
      send: 254-254-0-0 s=12,c=0,t=11,pt=0,l=0,sg=0,st=ok:
        S_WEIGHT
      send: 254-254-0-0 s=13,c=0,t=12,pt=0,l=0,sg=0,st=ok:
        S_POWER
      send: 254-254-0-0 s=14,c=0,t=13,pt=0,l=0,sg=0,st=ok:
        S_DISTANCE
      send: 254-254-0-0 s=16,c=0,t=15,pt=0,l=0,sg=0,st=ok:
        S_LIGHT_LEVEL
      send: 254-254-0-0 s=17,c=0,t=16,pt=0,l=0,sg=0,st=ok:
        S_LOCK
      send: 254-254-0-0 s=18,c=0,t=19,pt=0,l=0,sg=0,st=ok:
        S_IR
      send: 254-254-0-0 s=19,c=0,t=20,pt=0,l=0,sg=0,st=ok:
        S_WATER
      send: 254-254-0-0 s=20,c=0,t=21,pt=0,l=0,sg=0,st=ok:
        S_AIR_QUALITY
      send: 254-254-0-0 s=21,c=0,t=22,pt=0,l=0,sg=0,st=ok:
        S_SCENE_CONTROLLER
      send: 254-254-0-0 s=23,c=0,t=25,pt=0,l=0,sg=0,st=ok:
        S_CUSTOM
      send: 254-254-0-0 s=24,c=0,t=23,pt=0,l=0,sg=0,st=ok:
      ________________
      And the loop section
      RandomNumber:76
      Send Battery Level
      send: 254-254-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:76
      Request Time
      send: 254-254-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,st=ok:
      read: 0-0-254 s=255,c=3,t=1,pt=0,l=10,sg=0:1439720967
      Time value received: 1439720967
      Motion is: Quiet
      send: 254-254-0-0 s=2,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
      Smoke is: Quiet
      send: 254-254-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
      Light is: On
      send: 254-254-0-0 s=4,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
      Dimmer is set to: 255
      send: 254-254-0-0 s=5,c=1,t=3,pt=2,l=2,sg=0,st=ok:255
      Cover is : Idle
      send: 254-254-0-0 s=6,c=1,t=31,pt=2,l=2,sg=0,st=ok:31
      Temperature is: 34
      send: 254-254-0-0 s=7,c=1,t=0,pt=4,l=4,sg=0,st=ok:34
      Humitidty is: 76
      send: 254-254-0-0 s=8,c=1,t=1,pt=4,l=4,sg=0,st=ok:76
      Atmosferic Pressure is: 103363
      send: 254-254-0-0 s=9,c=1,t=4,pt=4,l=4,sg=0,st=ok:103363
      Weather forecast: unstable
      send: 254-254-0-0 s=9,c=1,t=5,pt=0,l=8,sg=0,st=ok:unstable
      Wind Speed is: 76
      send: 254-254-0-0 s=10,c=1,t=8,pt=4,l=4,sg=0,st=ok:76
      Wind Gust is: 86
      send: 254-254-0-0 s=10,c=1,t=9,pt=4,l=4,sg=0,st=ok:86
      Wind Direction is: 272
      send: 254-254-0-0 s=10,c=1,t=10,pt=4,l=4,sg=0,st=ok:272
      Rain ammount  is: 76
      send: 254-254-0-0 s=11,c=1,t=6,pt=4,l=4,sg=0,st=ok:76
      Rain rate  is: 1
      send: 254-254-0-0 s=11,c=1,t=7,pt=7,l=5,sg=0,st=ok:1.0
      Ultra Violet level is: 11
      send: 254-254-0-0 s=12,c=1,t=11,pt=4,l=4,sg=0,st=ok:11
      Weight is: 113
      send: 254-254-0-0 s=13,c=1,t=12,pt=4,l=4,sg=0,st=ok:113
      Impedance is: 113
      send: 254-254-0-0 s=14,c=1,t=14,pt=4,l=4,sg=0,st=ok:113
      Watt is: 113
      send: 254-254-0-0 s=14,c=1,t=17,pt=4,l=4,sg=0,st=ok:113
      KWH is: 113
      send: 254-254-0-0 s=14,c=1,t=18,pt=4,l=4,sg=0,st=ok:113
      Voltage is: 113
      send: 254-254-0-0 s=14,c=1,t=38,pt=4,l=4,sg=0,st=ok:113
      Current is: 113
      send: 254-254-0-0 s=14,c=1,t=39,pt=4,l=4,sg=0,st=ok:113
      Distance is: 113
      send: 254-254-0-0 s=16,c=1,t=13,pt=4,l=4,sg=0,st=ok:113
      Light is: 113
      send: 254-254-0-0 s=17,c=1,t=23,pt=4,l=4,sg=0,st=ok:113
      Lock is: On
      send: 254-254-0-0 s=18,c=1,t=36,pt=2,l=2,sg=0,st=ok:1
      Infrared is: 255
      send: 254-254-0-0 s=19,c=1,t=32,pt=2,l=2,sg=0,st=ok:255
      Water flow is: 113
      send: 254-254-0-0 s=20,c=1,t=34,pt=4,l=4,sg=0,st=ok:113
      Water volume is: 113
      send: 254-254-0-0 s=20,c=1,t=35,pt=4,l=4,sg=0,st=ok:113
      Air Quality is: 76
      send: 254-254-0-0 s=21,c=1,t=24,pt=4,l=4,sg=0,st=ok:76
      Scene is: On
      send: 254-254-0-0 s=23,c=1,t=19,pt=2,l=2,sg=0,st=ok:1
      Custom value is: 76
      send: 254-254-0-0 s=24,c=1,t=25,pt=4,l=4,sg=0,st=ok:76
      send: 254-254-0-0 s=24,c=1,t=26,pt=4,l=4,sg=0,st=ok:76
      send: 254-254-0-0 s=24,c=1,t=27,pt=4,l=4,sg=0,st=ok:76
      send: 254-254-0-0 s=24,c=1,t=28,pt=4,l=4,sg=0,st=ok:76
      ch3b7C 1 Reply Last reply
      • barduinoB barduino
        @ch3b7
        Very interesting.
        • Child sensor id 0
        • Payload length 5
        GW Started
        MockMySensors v0.3
        Get Config: Metric
        Presenting Nodes
        ________________
          S_DOOR
          S_MOTION
          S_SMOKE
          S_LIGHT
          S_DIMMER
          S_COVER
          S_TMEP
          S_HUM
          S_BARO
          S_WIND
          S_RAIN
          S_UV
          S_WEIGHT
          S_POWER
          S_DISTANCE
          S_LIGHT_LEVEL
          S_LOCK
          S_IR
          S_WATER
          S_AIR_QUALITY
          S_SCENE_CONTROLLER
          S_CUSTOM
        ________________
        RandomNumber:76
        Send Battery Level
        Request Time
        Motion is: Quiet
        Smoke is: Quiet
        Light is: On
        Cover is : Idle
        Temperature is: 34
        Humitidty is: 76
        Wind Speed is: 76
        Wind Gust is: 86
        Rain ammount  is: 76
        Rain rate  is: 1
        Weight is: 113
        Impedance is: 113
        Watt is: 113
        KWH is: 113
        Voltage is: 113
        Current is: 113
        Distance is: 113
        Light is: 113
        Lock is: On
        Infrared is: 255
        Water flow is: 113
        Air Quality is: 76
        Scene is: On
        Custom value is: 76
        ch3b7C
        ch3b7C
        ch3b7
        @barduino
        sorry your sketch work good! the problem im have is with the @AWI example!
        @AWI
        AWIA 1 Reply Last reply
        • ch3b7C ch3b7
          @barduino
          @AWI
          AWIA
          AWIA
          AWI
          @ch3b7 Sorry to have confused you but my sketch was meant for inspiration and as an alternative method to "stress test" the controller and network.
          The version I published is firing an enormous amount of messages at the controller for each sensor. The test data is in myTestData in the format {sensor, V_type, Dataformat, start_value, end_value, stepsize} You can fill the array with anything you want (also "not allowed" combinations).
          I suggest you remove the "ack" which is sent with each message at firtst {gw.send(Msg.set(i, false ))};
          • R
            R
            rene_2k2
            @AWI, @ch3b7
            The loop may be caused by a bug in the source code :
             for (int i = 0; i < NoTests ; i++) {
                    for (byte j = myTestData[i][3]; i < myTestData[i][4] ; j += myTestData[i][5])
                      gw.send(Msg.set(i, true ));
            Isn't there a mix between 'i' and 'j' ? Shouldn't it be
                    for (byte j = myTestData[i][3]; j < myTestData[i][4] ; j += myTestData[i][5])
                      gw.send(Msg.set(j, true ));
            Sorry, cannot test it right now...
            • R rene_2k2
              @AWI, @ch3b7
              AWIA
              AWIA
              AWI
              @rene_2k2 you're right, thanks
              • ch3b7C
                ch3b7C
                ch3b7
                #24
                @awi can you upload the fixed SKETCH ?? pls! thank you!!
                • A
                  akbooer
                  I'm most grateful for your work on this sketch - I've used it to exercise my gateway as I developed and debugged my Vera emulation environment called 'openLuup'. I now have a controller for MySensors running on Vera, BeagleBone Black, and an Arduino Yun, all running the ALTUI interface, so it looks like the attached.
                  Many thanks for the code and the initial explanations.
                  barduinoB rvendrameR 2 Replies Last reply
                  • A akbooer
                    barduinoB
                    barduinoB
                    barduino
                    @akbooer let me tell you...
                    It looks fanastic!
                    • A
                      akbooer
                      Well, thank you. But I have to say that the L&F is all down to the amazing ALTUI plugin produced by @amg0 on the Vera BB. I just do the behind-the-scenes bits which make it work on platforms other than Vera.
                      • AWIA
                        AWIA
                        AWI
                        wrote on last edited by AWI
                        #28
                        A "new" version of a stress test or "Fake sensor". As mentioned in a previous post it will never be complete. But I gave it an update to make it easier to work with.
                        This version (MySensors 1.5) will take an array of test values ; present them to the gateway/controller and spit out a range of values for each sensor in the testArray.
                        Version below is fixed node 50, 9 sensors and sends data every 0.1 sec.
                         PROJECT: MySensors
                         PROGRAMMER: AWI
                         DATE: 10 august 2015, update 4 september 2015
                         FILE: AWI_Universal_Test_50.ino
                         LICENSE: Public domain
                           -in conjunction with MySensors
                         STATUS: never finished, MySensors 1.5
                         KNOWN ISSUES: no text message yet
                         SUMMARY:
                        	multisensor for controller stress test
                        	1. Presents sensors to controller
                        	2. Sends (per sensor) values in defined range
                        	repeat
                         Setup: sends values for al sensor specified in setup array
                         Update: 20150904: Changed structure and type definitions (makes is easier to read)
                        const int NODE_ID = 50;  		  		// fixed MySensors node ID
                        const bool testAck = false ;			// set to true if you want all tests to be acknowledged
                        // reference: typedef enum {P_STRING, P_BYTE, P_INT16, P_UINT16, P_LONG32, P_ULONG32, P_CUSTOM, P_FLOAT32 } mysensor_payload ; // MySensor types
                        typedef	union {							// MySensor Payload types (only p_String used in this sketch)
                        	char p_String[10] ; 				// reduce characters to limit RAM size
                        	int16_t p_Int16 ;
                        	uint16_t p_Uint16 ;
                        	int32_t p_Int32 ;
                        	uint32_t p_Uint32 ;
                        	byte p_Byte ;
                        	float p_Float32 ;
                        	} payLoadType ;
                        // data type for tests
                        typedef struct {
                        	int s_type ;						// S_ type of the sensor number (only for init)
                        	char s_name[10] ;					// sensor name (max 9 char)
                        	int v_type ;						// data V_ type to be sent
                        	mysensor_payload dataType ;			// data type identifier (uses MySensors MyTypes definition)
                        	payLoadType testStartValue ;		// start value for test
                        	payLoadType testEndValue ;			// end value for test
                        	float testIncrement;				// test increment (different behaviour for each datatype)
                        	} testDataType ;
                        // TESTDATA: testdata & initialization, change to adapt to your needs
                        const int noSensors = 9 ; 				// number of active sensors in node
                        const int noTests = noSensors ;			// noTests == noSensors for now
                        // testData index determines child_no
                        testDataType testData[noSensors] = { 									// size determined by noSensors constant
                        	{S_MOISTURE, "Moist1" , V_LEVEL, P_BYTE, "40", "50", 1 },			// start & end values in text for convenience, are converted later
                        	{S_MOISTURE, "Moist2" , V_LEVEL, P_BYTE, "60", "70", 1 },
                        	{S_MOISTURE, "Moist3" , V_LEVEL, P_BYTE, "80", "90", 1 },
                        	{S_MULTIMETER, "Multi1", V_VOLTAGE, P_FLOAT32, "30.2", "50.0", 2},  // MULTIMETER
                        	{S_MULTIMETER, "Multi2", V_CURRENT, P_FLOAT32, "1.3", "5.6", 1},
                        	{S_MULTIMETER, "Multi3", V_IMPEDANCE, P_FLOAT32, "300", "900", 50},
                        	{S_TEMP, "Temp1", V_TEMP, P_FLOAT32, "1.1", "20.3", 2},				// Temperature
                        	{S_TEMP, "Temp2", V_TEMP, P_FLOAT32, "10.3", "50.6", 3},
                        	{S_TEMP, "Temp3", V_TEMP, P_FLOAT32, "300", "900", 50}
                        // END TESTDATA
                        // initialize MySensors
                        MyTransportNRF24 transport(9, 10); // Ceech board, 3.3v (7,8)  (pin default 9,10)
                        MySensor gw(transport);
                        // Initialize messages (only generic message here)
                        MyMessage Msg;                    // instantiate message to fill "on the fly
                        unsigned long SLEEP_PERIOD = 100 ;   // Period between individual tests in ms
                        unsigned long loopDelay = 1000 ;      // Sleep period in ms)
                          Serial.println("\n  Stress test for Mysensors network (20150904).\n");
                          gw.begin(incomingMessage, NODE_ID); 								// start MySensors, fixed node ID
                          gw.sendSketchInfo("AWI Universal test 50", "1.1");
                          for (int i = 0; i < noSensors ; i++) {  							// Register al sensors (they will be created as child devices)
                            gw.present(i , testData[i].s_type, testData[i].s_name ); 		// present all sensors in list (sensor_no, sensor_type, sensor_name)
                            gw.wait(loopDelay);
                          gw.process();           											// check if message from controller
                          for (int i = 0; i < noTests ; i++) {
                            Msg.setSensor(i);				    							// set the sensor number, byte 0
                            Msg.setType(testData[i].v_type);      							// set the sensor type, byte 1
                            switch (testData[i].dataType) {         						// data type determines test format
                              case P_BYTE:
                                for (byte j = atoi(testData[i].testStartValue.p_String) ; j < atoi(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                                  gw.send(Msg.set(j), testAck);
                                  gw.wait(SLEEP_PERIOD);
                              case P_INT16:
                                for (int j = atoi(testData[i].testStartValue.p_String) ; j < atoi(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                              case P_UINT16:
                                for (unsigned int j = atoi(testData[i].testStartValue.p_String) ; j < atoi(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                              case P_ULONG32:
                                for (unsigned long j = atol(testData[i].testStartValue.p_String) ; j < atol(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                              case P_FLOAT32:
                                for (float j = atof(testData[i].testStartValue.p_String) ; j < atof(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                                  gw.send(Msg.set(j,3), testAck );
                              default:
                                // do nothing
                            gw.wait(loopDelay);
                         Serial.print("Incoming Message");
                             Serial.print(" (type : ");
                             Serial.print(message.type);
                             Serial.print(")");
                             Serial.print(", status: ");
                        /*	IGNORE: For reference only
                        	S_DOOR, // Door sensor, V_TRIPPED, V_ARMED
                        	S_MOTION,  // Motion sensor, V_TRIPPED, V_ARMED
                        	S_SMOKE,  // Smoke sensor, V_TRIPPED, V_ARMED
                        	S_BINARY, // Binary light or relay, V_STATUS (or V_LIGHT), V_WATT (same as S_LIGHT)
                        	S_DIMMER, // Dimmable light or fan device, V_STATUS (on/off), V_DIMMER (dimmer level 0-100), V_WATT
                        	S_COVER, // Blinds or window cover, V_UP, V_DOWN, V_STOP, V_DIMMER (open/close to a percentage)
                        	S_TEMP, // Temperature sensor, V_TEMP
                        	S_HUM, // Humidity sensor, V_HUM
                        	S_BARO, // Barometer sensor, V_PRESSURE, V_FORECAST
                        	S_WIND, // Wind sensor, V_WIND, V_GUST
                        	S_RAIN, // Rain sensor, V_RAIN, V_RAINRATE
                        	S_UV, // Uv sensor, V_UV
                        	S_WEIGHT, // Personal scale sensor, V_WEIGHT, V_IMPEDANCE
                        	S_POWER, // Power meter, V_WATT, V_KWH
                        	S_HEATER, // Header device, V_HVAC_SETPOINT_HEAT, V_HVAC_FLOW_STATE
                        	S_DISTANCE, // Distance sensor, V_DISTANCE
                        	S_LIGHT_LEVEL, // Light level sensor, V_LIGHT_LEVEL (uncalibrated in percentage),  V_LEVEL (light level in lux)
                        	S_ARDUINO_NODE, // Used (internally) for presenting a non-repeating Arduino node
                        	S_ARDUINO_REPEATER_NODE, // Used (internally) for presenting a repeating Arduino node
                        	S_LOCK, // Lock device, V_LOCK_STATUS
                        	S_IR, // Ir device, V_IR_SEND, V_IR_RECEIVE
                        	S_WATER, // Water meter, V_FLOW, V_VOLUME
                        	S_AIR_QUALITY, // Air quality sensor, V_LEVEL
                        	S_CUSTOM, // Custom sensor
                        	S_DUST, // Dust sensor, V_LEVEL
                        	S_SCENE_CONTROLLER, // Scene controller device, V_SCENE_ON, V_SCENE_OFF.
                        	S_RGB_LIGHT, // RGB light. Send color component data using V_RGB. Also supports V_WATT
                        	S_RGBW_LIGHT, // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT
                        	S_COLOR_SENSOR,  // Color sensor, send color information using V_RGB
                        	S_HVAC, // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT, V_HVAC_SETPOINT_COLD, V_HVAC_FLOW_STATE, V_HVAC_FLOW_MODE
                        	S_MULTIMETER, // Multimeter device, V_VOLTAGE, V_CURRENT, V_IMPEDANCE
                        	S_SPRINKLER,  // Sprinkler, V_STATUS (turn on/off), V_TRIPPED (if fire detecting device)
                        	S_WATER_LEAK, // Water leak sensor, V_TRIPPED, V_ARMED
                        	S_SOUND, // Sound sensor, V_TRIPPED, V_ARMED, V_LEVEL (sound level in dB)
                        	S_VIBRATION, // Vibration sensor, V_TRIPPED, V_ARMED, V_LEVEL (vibration in Hz)
                        	S_MOISTURE, // Moisture sensor, V_TRIPPED, V_ARMED, V_LEVEL (water content or moisture in percentage?)
                        // sensor data types
                        // typedef enum {P_STRING, P_BYTE, P_INT16, P_UINT16, P_LONG32, P_ULONG32, P_CUSTOM, P_FLOAT32 } MyTypes ;
                        sTypes[V_TEMP] =  P_FLOAT32; // S_TEMP
                        sTypes[V_HUM] =P_FLOAT32; // S_HUM
                        sTypes[V_STATUS] = P_UINT16; //  S_LIGHT, S_DIMMER, S_SPRINKLER, S_HVAC, S_HEATER. Used for setting binary (on/off) status. 1=on, 0=off
                        sTypes[V_LIGHT] = P_UINT16; // Same as V_STATUS
                        sTypes[V_PERCENTAGE] = P_UINT16; // S_DIMMER. Used for sending a percentage value (0-100).
                        sTypes[V_DIMMER] = P_UINT16; // S_DIMMER. Same as V_PERCENTAGE.
                        sTypes[V_PRESSURE] = P_FLOAT32; // S_BARO
                        sTypes[V_FORECAST] = P_FLOAT32; // S_BARO
                        sTypes[V_RAIN] = P_FLOAT32; // S_RAIN
                        sTypes[V_RAINRATE] = P_FLOAT32;  // S_RAIN
                        sTypes[V_WIND] = P_FLOAT32; // S_WIND
                        sTypes[V_GUST] = P_FLOAT32; // S_WIND
                        sTypes[V_DIRECTION] = P_FLOAT32; // S_WIND
                        sTypes[V_UV] = P_FLOAT32; // S_UV
                        sTypes[V_WEIGHT] = P_FLOAT32; // S_WEIGHT
                        sTypes[V_DISTANCE] = P_FLOAT32; // S_DISTANCE
                        sTypes[V_IMPEDANCE] = P_FLOAT32; // S_MULTIMETER, S_WEIGHT
                        sTypes[V_ARMED]= P_FLOAT32; // S_DOOR, S_MOTION, S_SMOKE, S_SPRINKLER
                        sTypes[V_TRIPPED]= P_FLOAT32; // S_DOOR, S_MOTION, S_SMOKE, S_SPRINKLER (for sprinklers with fire detection)
                        sTypes[V_WATT]= P_FLOAT32; // S_POWER, S_LIGHT, S_DIMMER
                        sTypes[V_KWH]= P_FLOAT32; // S_POWER
                        sTypes[V_SCENE_ON]= P_FLOAT32; // S_SCENE_CONTROLLER
                        sTypes[V_SCENE_OFF]= P_FLOAT32; // S_SCENE_CONTROLLER
                        sTypes[V_HEATER]= P_FLOAT32; // Deprecated. Use V_HVAC_FLOW_STATE instead.
                        sTypes[V_HVAC_FLOW_STATE] = P_UINT16; // HVAC flow state ("Off", "HeatOn", "CoolOn", or "AutoChangeOver"). S_HEATER, S_HVAC
                        sTypes[V_HVAC_SPEED]= P_FLOAT32; // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto")
                        sTypes[V_LIGHT_LEVEL]= P_UINT16; // Used for sending light level in uncalibrated percentage. See also V_LEVEL (light level in lux). S_LIGHT_LEVEL
                        sTypes[V_VAR1] = P_FLOAT32;
                        sTypes[V_VAR2] = P_FLOAT32;
                        sTypes[V_VAR3] = P_FLOAT32;
                        sTypes[V_VAR4] = P_FLOAT32;
                        sTypes[V_VAR5] = P_FLOAT32;
                        sTypes[V_UP] = P_FLOAT32; // S_COVER
                        sTypes[V_DOWN] = P_FLOAT32; // S_COVER
                        sTypes[V_STOP] = P_FLOAT32; // S_COVER
                        sTypes[V_IR_SEND] = P_FLOAT32; // S_IR
                        sTypes[V_IR_RECEIVE] = P_FLOAT32; // S_IR
                        sTypes[V_FLOW] = P_FLOAT32; // S_WATER
                        sTypes[V_VOLUME] = P_FLOAT32; // S_WATER
                        sTypes[V_LOCK_STATUS] = P_FLOAT32; // S_LOCK
                        sTypes[V_LEVEL] = P_UINT16; // S_DUST, S_AIR_QUALITY, S_SOUND (dB), S_VIBRATION (hz), S_LIGHT_LEVEL (lux)
                        sTypes[V_VOLTAGE] = P_FLOAT32; // S_MULTIMETER
                        sTypes[V_CURRENT] = P_FLOAT32; // S_MULTIMETER
                        sTypes[V_RGB] = P_ULONG32; 	// S_RGB_LIGHT, S_COLOR_SENSOR.
                        					// Used for sending color information for multi color LED lighting or color sensors.
                        					// Sent as ASCII hex: RRGGBB (RR=red, GG=green, BB=blue component)
                        sTypes[V_RGBW] = P_ULONG32; // S_RGBW_LIGHT
                        					// Used for sending color information to multi color LED lighting.
                        					// Sent as ASCII hex: RRGGBBWW (WW=while component)
                        sTypes[V_ID] = P_FLOAT32; // S_TEMP
                        					// Used for sending in sensors hardware ids (i.e. OneWire DS1820b).
                        sTypes[V_UNIT_PREFIX] = P_STRING; // Allows sensors to send in a string representing the
                        								 // unit prefix to be displayed in GUI, not parsed by controller! E.g. cm, m, km, inch.
                        								 // Can be used for S_DISTANCE or gas concentration (S_DUST, S_AIR_QUALITY)
                        sTypes[V_HVAC_SETPOINT_COOL] = P_UINT16; // HVAC cool setpoint (Integer between 0-100). S_HVAC
                        sTypes[V_HVAC_SETPOINT_HEAT] = P_UINT16; // HVAC/Heater setpoint (Integer between 0-100). S_HEATER, S_HVAC
                        sTypes[V_HVAC_FLOW_MODE] = P_UINT16; // Flow mode for HVAC ("Auto", "ContinuousOn", "PeriodicOn"). S_HVAC
                        • A akbooer
                          rvendrameR
                          rvendrameR
                          rvendrame
                          @akbooer , just curious to know, what version of AltUI do you have? Did you adjust anything into the mySensors plugin json?
                          I'm asking that because, my plugin display a bit different:
                          ESP8266 GW + mySensors 2.3.2
                          Alexa / Google Home
                          • rvendrameR rvendrame
                            akbooer
                            @rvendrame
                            Yes, I made a mod to the Arduino plugin. The changes are on GitHub:
                            https://github.com/akbooer/Vera/blob/features-for-altui/L_Arduino.lua
                            I'm hoping to get this merged with the master branch in due course, but I've not finished.
                            rvendrameR 1 Reply Last reply
                            • A akbooer
                              @rvendrame
                              rvendrameR
                              rvendrameR
                              rvendrame
                              @akbooer , thanks a lot!
                              Alexa / Google Home
                              • barduinoB
                                barduinoB
                                barduino
                                wrote on last edited by barduino
                                #32
                                Hi Folks,
                                @GizMoCuz just commited a new version of MockMySensors and I'm about to commit another (MockMySensors.ino) (need to merge with his changes).
                                This will complete the 1.4 lib sensors and Giz has already started adding more.
                                In the mean time here is a picture of MockMySensors running on the MYSController
                                And here is how it look on the HAALL controller
                                If you have used this skecth in other controller would you mind posting screen shots of it here?
                                • D
                                  dakipro
                                  Hello, is it possible to MockMySensors without physical radio on the gateway?
                                  I ordered/received wrong radios and I am now waiting (most likely a month) for the new ones, but I would like to setup the controller without actual sensors. How can I mock them, or somehow simulate sensors without the radio?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @dakipro
                                    Depending on what you want to run your controller on, and your own experience level with hacking stuff, you can use node-red to simulate sensors, and inject fake sensors into the controller of your choice. (Not all controllers support this though)
                                    head over to http://forum.mysensors.org/topic/1965/nodered-injected-between-domoticz-and-mysensors for more info on setup..
                                    • D dakipro
                                      barduinoB
                                      barduinoB
                                      barduino
                                      @dakipro
                                      I use nodeJS to read from the serial gatweay and send the information to my my controller HAALL, similar to what @tbowmo is suggesting.
                                      Now depending on how your controller accepts information you might pull this off with some hacking. (In HAALL case it accepts via REST service). I've attached my nodeJS example for convenience.
                                      • D
                                        dakipro
                                        Thank you. I installed MajorDoMo controller on a old laptop, just because it is written in php - which I do professionally so that I could optimize or debug it. And it looks decent too :)
                                        I just started with the MySensors and Arduino so I guess it will take me some time to get familiar with how everything works.
                                        My initial idea was to just use mockMySensors without radio and other sensors, but when I try initiate MySensors lib on the arduino I get "radio init fail" which is expected as I do not have the radio attached (it will arrive soon).
                                        I messed a bit inside MySensors library, trying to comment out the part that initializes the radio but then I get some other messages. I guess it is never needed in practice to turn off radio portion of MySensors.
                                        Maybe my question is more related to Network Stress test thread http://forum.mysensors.org/topic/2000/mysensors-network-stress-test on which I also get the same "radio init fail" message, as again radio is missing.
                                        If I find the time I will try to make some software emulation for sensors, based on your NodeJS example. That could be useful for prepping the Controller before even making new sensors, also for simulating scenarios and test how would controller react in certain situations (how different scenes work etc).
                                          The mock example is written to use radio communications. Can be pretty hairy to fix it. Suggest you run the development branch which allows sensors to be attached to gateway. It should run twith the mock example if you configure it as a serial gateway (radio disabled).. See Serial Gateway example for how to activate gateway.
                                          Here is a couple of nodejs modules that might be helpful:
                                          http://forum.mysensors.org/topic/2208/node-js-modules-for-mysensors
