  3. Test your home made controller with MockMySensors (w/ tutorial)
39 Posts 12 Posters 31.2k Views 14 Watching
  • ch3b7C ch3b7
    all sensors present good but when finish i get a loop sended:
    send: 50-50-0-0 s=0,c=1,t=16,pt=7,l=5,sg=0,st=ok:0.0
    im use (lib 1.5) MockMySensors.ino
    barduinoB
    barduinoB
    barduino
    @ch3b7
    Very interesting.
    I was not able to repruduce what you are describing above.
    According to your message we have:
    • Node 50 sending to node 0
    • Child sensor id 0
    • Message type 1 : SET
    • MessageSub Type 16: V_TRIPPED
    • Payload type 7: P_CUSTOM
    • Payload length 5
    Which is very strange.
    In MockMySensors there is no childid=0, the first sensor is #define ID_S_DOOR 1 and the node ID is set to 254 (but perhpas you have changed this)
    Also V_TRIPPED should be sending a bolean value...
    Could you upload your scetch?
    here is my log: SetUP
    send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
    send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-254 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=254, parent=0, distance=1
    GW Started
    Send Sketch Info: send: 254-254-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,st=ok:MockMySensors
    send: 254-254-0-0 s=255,c=3,t=12,pt=0,l=4,sg=0,st=ok:v0.3
    MockMySensors v0.3
    Get Config: Metric
    Presenting Nodes
    ________________
      S_DOOR
    send: 254-254-0-0 s=1,c=0,t=0,pt=0,l=0,sg=0,st=ok:
      S_MOTION
    send: 254-254-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,st=ok:
      S_SMOKE
    send: 254-254-0-0 s=3,c=0,t=2,pt=0,l=0,sg=0,st=ok:
      S_LIGHT
    send: 254-254-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
      S_DIMMER
    send: 254-254-0-0 s=5,c=0,t=4,pt=0,l=0,sg=0,st=ok:
      S_COVER
    send: 254-254-0-0 s=6,c=0,t=5,pt=0,l=0,sg=0,st=ok:
      S_TMEP
    send: 254-254-0-0 s=7,c=0,t=6,pt=0,l=0,sg=0,st=ok:
      S_HUM
    send: 254-254-0-0 s=8,c=0,t=7,pt=0,l=0,sg=0,st=ok:
      S_BARO
    send: 254-254-0-0 s=9,c=0,t=8,pt=0,l=0,sg=0,st=ok:
      S_WIND
    send: 254-254-0-0 s=10,c=0,t=9,pt=0,l=0,sg=0,st=ok:
      S_RAIN
    send: 254-254-0-0 s=11,c=0,t=10,pt=0,l=0,sg=0,st=ok:
      S_UV
    send: 254-254-0-0 s=12,c=0,t=11,pt=0,l=0,sg=0,st=ok:
      S_WEIGHT
    send: 254-254-0-0 s=13,c=0,t=12,pt=0,l=0,sg=0,st=ok:
      S_POWER
    send: 254-254-0-0 s=14,c=0,t=13,pt=0,l=0,sg=0,st=ok:
      S_DISTANCE
    send: 254-254-0-0 s=16,c=0,t=15,pt=0,l=0,sg=0,st=ok:
      S_LIGHT_LEVEL
    send: 254-254-0-0 s=17,c=0,t=16,pt=0,l=0,sg=0,st=ok:
      S_LOCK
    send: 254-254-0-0 s=18,c=0,t=19,pt=0,l=0,sg=0,st=ok:
      S_IR
    send: 254-254-0-0 s=19,c=0,t=20,pt=0,l=0,sg=0,st=ok:
      S_WATER
    send: 254-254-0-0 s=20,c=0,t=21,pt=0,l=0,sg=0,st=ok:
      S_AIR_QUALITY
    send: 254-254-0-0 s=21,c=0,t=22,pt=0,l=0,sg=0,st=ok:
      S_SCENE_CONTROLLER
    send: 254-254-0-0 s=23,c=0,t=25,pt=0,l=0,sg=0,st=ok:
      S_CUSTOM
    send: 254-254-0-0 s=24,c=0,t=23,pt=0,l=0,sg=0,st=ok:
    ________________
    And the loop section
    RandomNumber:76
    Send Battery Level
    send: 254-254-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:76
    Request Time
    send: 254-254-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,st=ok:
    read: 0-0-254 s=255,c=3,t=1,pt=0,l=10,sg=0:1439720967
    Time value received: 1439720967
    Motion is: Quiet
    send: 254-254-0-0 s=2,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
    Smoke is: Quiet
    send: 254-254-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
    Light is: On
    send: 254-254-0-0 s=4,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
    Dimmer is set to: 255
    send: 254-254-0-0 s=5,c=1,t=3,pt=2,l=2,sg=0,st=ok:255
    Cover is : Idle
    send: 254-254-0-0 s=6,c=1,t=31,pt=2,l=2,sg=0,st=ok:31
    Temperature is: 34
    send: 254-254-0-0 s=7,c=1,t=0,pt=4,l=4,sg=0,st=ok:34
    Humitidty is: 76
    send: 254-254-0-0 s=8,c=1,t=1,pt=4,l=4,sg=0,st=ok:76
    Atmosferic Pressure is: 103363
    send: 254-254-0-0 s=9,c=1,t=4,pt=4,l=4,sg=0,st=ok:103363
    Weather forecast: unstable
    send: 254-254-0-0 s=9,c=1,t=5,pt=0,l=8,sg=0,st=ok:unstable
    Wind Speed is: 76
    send: 254-254-0-0 s=10,c=1,t=8,pt=4,l=4,sg=0,st=ok:76
    Wind Gust is: 86
    send: 254-254-0-0 s=10,c=1,t=9,pt=4,l=4,sg=0,st=ok:86
    Wind Direction is: 272
    send: 254-254-0-0 s=10,c=1,t=10,pt=4,l=4,sg=0,st=ok:272
    Rain ammount  is: 76
    send: 254-254-0-0 s=11,c=1,t=6,pt=4,l=4,sg=0,st=ok:76
    Rain rate  is: 1
    send: 254-254-0-0 s=11,c=1,t=7,pt=7,l=5,sg=0,st=ok:1.0
    Ultra Violet level is: 11
    send: 254-254-0-0 s=12,c=1,t=11,pt=4,l=4,sg=0,st=ok:11
    Weight is: 113
    send: 254-254-0-0 s=13,c=1,t=12,pt=4,l=4,sg=0,st=ok:113
    Impedance is: 113
    send: 254-254-0-0 s=14,c=1,t=14,pt=4,l=4,sg=0,st=ok:113
    Watt is: 113
    send: 254-254-0-0 s=14,c=1,t=17,pt=4,l=4,sg=0,st=ok:113
    KWH is: 113
    send: 254-254-0-0 s=14,c=1,t=18,pt=4,l=4,sg=0,st=ok:113
    Voltage is: 113
    send: 254-254-0-0 s=14,c=1,t=38,pt=4,l=4,sg=0,st=ok:113
    Current is: 113
    send: 254-254-0-0 s=14,c=1,t=39,pt=4,l=4,sg=0,st=ok:113
    Distance is: 113
    send: 254-254-0-0 s=16,c=1,t=13,pt=4,l=4,sg=0,st=ok:113
    Light is: 113
    send: 254-254-0-0 s=17,c=1,t=23,pt=4,l=4,sg=0,st=ok:113
    Lock is: On
    send: 254-254-0-0 s=18,c=1,t=36,pt=2,l=2,sg=0,st=ok:1
    Infrared is: 255
    send: 254-254-0-0 s=19,c=1,t=32,pt=2,l=2,sg=0,st=ok:255
    Water flow is: 113
    send: 254-254-0-0 s=20,c=1,t=34,pt=4,l=4,sg=0,st=ok:113
    Water volume is: 113
    send: 254-254-0-0 s=20,c=1,t=35,pt=4,l=4,sg=0,st=ok:113
    Air Quality is: 76
    send: 254-254-0-0 s=21,c=1,t=24,pt=4,l=4,sg=0,st=ok:76
    Scene is: On
    send: 254-254-0-0 s=23,c=1,t=19,pt=2,l=2,sg=0,st=ok:1
    Custom value is: 76
    send: 254-254-0-0 s=24,c=1,t=25,pt=4,l=4,sg=0,st=ok:76
    send: 254-254-0-0 s=24,c=1,t=26,pt=4,l=4,sg=0,st=ok:76
    send: 254-254-0-0 s=24,c=1,t=27,pt=4,l=4,sg=0,st=ok:76
    send: 254-254-0-0 s=24,c=1,t=28,pt=4,l=4,sg=0,st=ok:76
    ch3b7C 1 Reply Last reply
    • barduinoB barduino
      @ch3b7
      Very interesting.
      • Child sensor id 0
      • Payload length 5
      GW Started
      MockMySensors v0.3
      Get Config: Metric
      Presenting Nodes
      ________________
        S_DOOR
        S_MOTION
        S_SMOKE
        S_LIGHT
        S_DIMMER
        S_COVER
        S_TMEP
        S_HUM
        S_BARO
        S_WIND
        S_RAIN
        S_UV
        S_WEIGHT
        S_POWER
        S_DISTANCE
        S_LIGHT_LEVEL
        S_LOCK
        S_IR
        S_WATER
        S_AIR_QUALITY
        S_SCENE_CONTROLLER
        S_CUSTOM
      ________________
      RandomNumber:76
      Send Battery Level
      Request Time
      Motion is: Quiet
      Smoke is: Quiet
      Light is: On
      Cover is : Idle
      Temperature is: 34
      Humitidty is: 76
      Wind Speed is: 76
      Wind Gust is: 86
      Rain ammount  is: 76
      Rain rate  is: 1
      Weight is: 113
      Impedance is: 113
      Watt is: 113
      KWH is: 113
      Voltage is: 113
      Current is: 113
      Distance is: 113
      Light is: 113
      Lock is: On
      Infrared is: 255
      Water flow is: 113
      Air Quality is: 76
      Scene is: On
      Custom value is: 76
      ch3b7C
      ch3b7C
      ch3b7
      @barduino
      sorry your sketch work good! the problem im have is with the @AWI example!
      @AWI
      AWIA 1 Reply Last reply
      • ch3b7C ch3b7
        @barduino
        @AWI
        AWIA
        AWIA
        AWI
        @ch3b7 Sorry to have confused you but my sketch was meant for inspiration and as an alternative method to "stress test" the controller and network.
        The version I published is firing an enormous amount of messages at the controller for each sensor. The test data is in myTestData in the format {sensor, V_type, Dataformat, start_value, end_value, stepsize} You can fill the array with anything you want (also "not allowed" combinations).
        I suggest you remove the "ack" which is sent with each message at firtst {gw.send(Msg.set(i, false ))};
        • R
          R
          rene_2k2
          @AWI, @ch3b7
          The loop may be caused by a bug in the source code :
           for (int i = 0; i < NoTests ; i++) {
                  for (byte j = myTestData[i][3]; i < myTestData[i][4] ; j += myTestData[i][5])
                    gw.send(Msg.set(i, true ));
          Isn't there a mix between 'i' and 'j' ? Shouldn't it be
                  for (byte j = myTestData[i][3]; j < myTestData[i][4] ; j += myTestData[i][5])
                    gw.send(Msg.set(j, true ));
          Sorry, cannot test it right now...
          • R rene_2k2
            @AWI, @ch3b7
            AWIA
            AWIA
            AWI
            @rene_2k2 you're right, thanks
            • ch3b7C
              ch3b7C
              ch3b7
              wrote on last edited by ch3b7
              #24
              @awi can you upload the fixed SKETCH ?? pls! thank you!!
              • A
                akbooer
                I'm most grateful for your work on this sketch - I've used it to exercise my gateway as I developed and debugged my Vera emulation environment called 'openLuup'. I now have a controller for MySensors running on Vera, BeagleBone Black, and an Arduino Yun, all running the ALTUI interface, so it looks like the attached.
                Many thanks for the code and the initial explanations.
                barduinoB rvendrameR 2 Replies Last reply
                • A akbooer
                  barduinoB
                  barduinoB
                  barduino
                  @akbooer let me tell you...
                  It looks fanastic!
                  • A
                    akbooer
                    Well, thank you. But I have to say that the L&F is all down to the amazing ALTUI plugin produced by @amg0 on the Vera BB. I just do the behind-the-scenes bits which make it work on platforms other than Vera.
                    • AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      #28
                      A "new" version of a stress test or "Fake sensor". As mentioned in a previous post it will never be complete. But I gave it an update to make it easier to work with.
                      This version (MySensors 1.5) will take an array of test values ; present them to the gateway/controller and spit out a range of values for each sensor in the testArray.
                      Version below is fixed node 50, 9 sensors and sends data every 0.1 sec.
                       PROJECT: MySensors
                       PROGRAMMER: AWI
                       DATE: 10 august 2015, update 4 september 2015
                       FILE: AWI_Universal_Test_50.ino
                       LICENSE: Public domain
                         -in conjunction with MySensors
                       STATUS: never finished, MySensors 1.5
                       KNOWN ISSUES: no text message yet
                       SUMMARY:
                      	multisensor for controller stress test
                      	1. Presents sensors to controller
                      	2. Sends (per sensor) values in defined range
                      	repeat
                       Setup: sends values for al sensor specified in setup array
                       Update: 20150904: Changed structure and type definitions (makes is easier to read)
                      const int NODE_ID = 50;  		  		// fixed MySensors node ID
                      const bool testAck = false ;			// set to true if you want all tests to be acknowledged
                      // reference: typedef enum {P_STRING, P_BYTE, P_INT16, P_UINT16, P_LONG32, P_ULONG32, P_CUSTOM, P_FLOAT32 } mysensor_payload ; // MySensor types
                      typedef	union {							// MySensor Payload types (only p_String used in this sketch)
                      	char p_String[10] ; 				// reduce characters to limit RAM size
                      	int16_t p_Int16 ;
                      	uint16_t p_Uint16 ;
                      	int32_t p_Int32 ;
                      	uint32_t p_Uint32 ;
                      	byte p_Byte ;
                      	float p_Float32 ;
                      	} payLoadType ;
                      // data type for tests
                      typedef struct {
                      	int s_type ;						// S_ type of the sensor number (only for init)
                      	char s_name[10] ;					// sensor name (max 9 char)
                      	int v_type ;						// data V_ type to be sent
                      	mysensor_payload dataType ;			// data type identifier (uses MySensors MyTypes definition)
                      	payLoadType testStartValue ;		// start value for test
                      	payLoadType testEndValue ;			// end value for test
                      	float testIncrement;				// test increment (different behaviour for each datatype)
                      	} testDataType ;
                      // TESTDATA: testdata & initialization, change to adapt to your needs
                      const int noSensors = 9 ; 				// number of active sensors in node
                      const int noTests = noSensors ;			// noTests == noSensors for now
                      // testData index determines child_no
                      testDataType testData[noSensors] = { 									// size determined by noSensors constant
                      	{S_MOISTURE, "Moist1" , V_LEVEL, P_BYTE, "40", "50", 1 },			// start & end values in text for convenience, are converted later
                      	{S_MOISTURE, "Moist2" , V_LEVEL, P_BYTE, "60", "70", 1 },
                      	{S_MOISTURE, "Moist3" , V_LEVEL, P_BYTE, "80", "90", 1 },
                      	{S_MULTIMETER, "Multi1", V_VOLTAGE, P_FLOAT32, "30.2", "50.0", 2},  // MULTIMETER
                      	{S_MULTIMETER, "Multi2", V_CURRENT, P_FLOAT32, "1.3", "5.6", 1},
                      	{S_MULTIMETER, "Multi3", V_IMPEDANCE, P_FLOAT32, "300", "900", 50},
                      	{S_TEMP, "Temp1", V_TEMP, P_FLOAT32, "1.1", "20.3", 2},				// Temperature
                      	{S_TEMP, "Temp2", V_TEMP, P_FLOAT32, "10.3", "50.6", 3},
                      	{S_TEMP, "Temp3", V_TEMP, P_FLOAT32, "300", "900", 50}
                      // END TESTDATA
                      // initialize MySensors
                      MyTransportNRF24 transport(9, 10); // Ceech board, 3.3v (7,8)  (pin default 9,10)
                      MySensor gw(transport);
                      // Initialize messages (only generic message here)
                      MyMessage Msg;                    // instantiate message to fill "on the fly
                      unsigned long SLEEP_PERIOD = 100 ;   // Period between individual tests in ms
                      unsigned long loopDelay = 1000 ;      // Sleep period in ms)
                        Serial.println("\n  Stress test for Mysensors network (20150904).\n");
                        gw.begin(incomingMessage, NODE_ID); 								// start MySensors, fixed node ID
                        gw.sendSketchInfo("AWI Universal test 50", "1.1");
                        for (int i = 0; i < noSensors ; i++) {  							// Register al sensors (they will be created as child devices)
                          gw.present(i , testData[i].s_type, testData[i].s_name ); 		// present all sensors in list (sensor_no, sensor_type, sensor_name)
                          gw.wait(loopDelay);
                        gw.process();           											// check if message from controller
                        for (int i = 0; i < noTests ; i++) {
                          Msg.setSensor(i);				    							// set the sensor number, byte 0
                          Msg.setType(testData[i].v_type);      							// set the sensor type, byte 1
                          switch (testData[i].dataType) {         						// data type determines test format
                            case P_BYTE:
                              for (byte j = atoi(testData[i].testStartValue.p_String) ; j < atoi(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                                gw.send(Msg.set(j), testAck);
                                gw.wait(SLEEP_PERIOD);
                            case P_INT16:
                              for (int j = atoi(testData[i].testStartValue.p_String) ; j < atoi(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                            case P_UINT16:
                              for (unsigned int j = atoi(testData[i].testStartValue.p_String) ; j < atoi(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                            case P_ULONG32:
                              for (unsigned long j = atol(testData[i].testStartValue.p_String) ; j < atol(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                            case P_FLOAT32:
                              for (float j = atof(testData[i].testStartValue.p_String) ; j < atof(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                                gw.send(Msg.set(j,3), testAck );
                            default:
                              // do nothing
                          gw.wait(loopDelay);
                       Serial.print("Incoming Message");
                           Serial.print(" (type : ");
                           Serial.print(message.type);
                           Serial.print(")");
                           Serial.print(", status: ");
                      /*	IGNORE: For reference only
                      	S_DOOR, // Door sensor, V_TRIPPED, V_ARMED
                      	S_MOTION,  // Motion sensor, V_TRIPPED, V_ARMED
                      	S_SMOKE,  // Smoke sensor, V_TRIPPED, V_ARMED
                      	S_BINARY, // Binary light or relay, V_STATUS (or V_LIGHT), V_WATT (same as S_LIGHT)
                      	S_DIMMER, // Dimmable light or fan device, V_STATUS (on/off), V_DIMMER (dimmer level 0-100), V_WATT
                      	S_COVER, // Blinds or window cover, V_UP, V_DOWN, V_STOP, V_DIMMER (open/close to a percentage)
                      	S_TEMP, // Temperature sensor, V_TEMP
                      	S_HUM, // Humidity sensor, V_HUM
                      	S_BARO, // Barometer sensor, V_PRESSURE, V_FORECAST
                      	S_WIND, // Wind sensor, V_WIND, V_GUST
                      	S_RAIN, // Rain sensor, V_RAIN, V_RAINRATE
                      	S_UV, // Uv sensor, V_UV
                      	S_WEIGHT, // Personal scale sensor, V_WEIGHT, V_IMPEDANCE
                      	S_POWER, // Power meter, V_WATT, V_KWH
                      	S_HEATER, // Header device, V_HVAC_SETPOINT_HEAT, V_HVAC_FLOW_STATE
                      	S_DISTANCE, // Distance sensor, V_DISTANCE
                      	S_LIGHT_LEVEL, // Light level sensor, V_LIGHT_LEVEL (uncalibrated in percentage),  V_LEVEL (light level in lux)
                      	S_ARDUINO_NODE, // Used (internally) for presenting a non-repeating Arduino node
                      	S_ARDUINO_REPEATER_NODE, // Used (internally) for presenting a repeating Arduino node
                      	S_LOCK, // Lock device, V_LOCK_STATUS
                      	S_IR, // Ir device, V_IR_SEND, V_IR_RECEIVE
                      	S_WATER, // Water meter, V_FLOW, V_VOLUME
                      	S_AIR_QUALITY, // Air quality sensor, V_LEVEL
                      	S_CUSTOM, // Custom sensor
                      	S_DUST, // Dust sensor, V_LEVEL
                      	S_SCENE_CONTROLLER, // Scene controller device, V_SCENE_ON, V_SCENE_OFF.
                      	S_RGB_LIGHT, // RGB light. Send color component data using V_RGB. Also supports V_WATT
                      	S_RGBW_LIGHT, // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT
                      	S_COLOR_SENSOR,  // Color sensor, send color information using V_RGB
                      	S_HVAC, // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT, V_HVAC_SETPOINT_COLD, V_HVAC_FLOW_STATE, V_HVAC_FLOW_MODE
                      	S_MULTIMETER, // Multimeter device, V_VOLTAGE, V_CURRENT, V_IMPEDANCE
                      	S_SPRINKLER,  // Sprinkler, V_STATUS (turn on/off), V_TRIPPED (if fire detecting device)
                      	S_WATER_LEAK, // Water leak sensor, V_TRIPPED, V_ARMED
                      	S_SOUND, // Sound sensor, V_TRIPPED, V_ARMED, V_LEVEL (sound level in dB)
                      	S_VIBRATION, // Vibration sensor, V_TRIPPED, V_ARMED, V_LEVEL (vibration in Hz)
                      	S_MOISTURE, // Moisture sensor, V_TRIPPED, V_ARMED, V_LEVEL (water content or moisture in percentage?)
                      // sensor data types
                      // typedef enum {P_STRING, P_BYTE, P_INT16, P_UINT16, P_LONG32, P_ULONG32, P_CUSTOM, P_FLOAT32 } MyTypes ;
                      sTypes[V_TEMP] =  P_FLOAT32; // S_TEMP
                      sTypes[V_HUM] =P_FLOAT32; // S_HUM
                      sTypes[V_STATUS] = P_UINT16; //  S_LIGHT, S_DIMMER, S_SPRINKLER, S_HVAC, S_HEATER. Used for setting binary (on/off) status. 1=on, 0=off
                      sTypes[V_LIGHT] = P_UINT16; // Same as V_STATUS
                      sTypes[V_PERCENTAGE] = P_UINT16; // S_DIMMER. Used for sending a percentage value (0-100).
                      sTypes[V_DIMMER] = P_UINT16; // S_DIMMER. Same as V_PERCENTAGE.
                      sTypes[V_PRESSURE] = P_FLOAT32; // S_BARO
                      sTypes[V_FORECAST] = P_FLOAT32; // S_BARO
                      sTypes[V_RAIN] = P_FLOAT32; // S_RAIN
                      sTypes[V_RAINRATE] = P_FLOAT32;  // S_RAIN
                      sTypes[V_WIND] = P_FLOAT32; // S_WIND
                      sTypes[V_GUST] = P_FLOAT32; // S_WIND
                      sTypes[V_DIRECTION] = P_FLOAT32; // S_WIND
                      sTypes[V_UV] = P_FLOAT32; // S_UV
                      sTypes[V_WEIGHT] = P_FLOAT32; // S_WEIGHT
                      sTypes[V_DISTANCE] = P_FLOAT32; // S_DISTANCE
                      sTypes[V_IMPEDANCE] = P_FLOAT32; // S_MULTIMETER, S_WEIGHT
                      sTypes[V_ARMED]= P_FLOAT32; // S_DOOR, S_MOTION, S_SMOKE, S_SPRINKLER
                      sTypes[V_TRIPPED]= P_FLOAT32; // S_DOOR, S_MOTION, S_SMOKE, S_SPRINKLER (for sprinklers with fire detection)
                      sTypes[V_WATT]= P_FLOAT32; // S_POWER, S_LIGHT, S_DIMMER
                      sTypes[V_KWH]= P_FLOAT32; // S_POWER
                      sTypes[V_SCENE_ON]= P_FLOAT32; // S_SCENE_CONTROLLER
                      sTypes[V_SCENE_OFF]= P_FLOAT32; // S_SCENE_CONTROLLER
                      sTypes[V_HEATER]= P_FLOAT32; // Deprecated. Use V_HVAC_FLOW_STATE instead.
                      sTypes[V_HVAC_FLOW_STATE] = P_UINT16; // HVAC flow state ("Off", "HeatOn", "CoolOn", or "AutoChangeOver"). S_HEATER, S_HVAC
                      sTypes[V_HVAC_SPEED]= P_FLOAT32; // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto")
                      sTypes[V_LIGHT_LEVEL]= P_UINT16; // Used for sending light level in uncalibrated percentage. See also V_LEVEL (light level in lux). S_LIGHT_LEVEL
                      sTypes[V_VAR1] = P_FLOAT32;
                      sTypes[V_VAR2] = P_FLOAT32;
                      sTypes[V_VAR3] = P_FLOAT32;
                      sTypes[V_VAR4] = P_FLOAT32;
                      sTypes[V_VAR5] = P_FLOAT32;
                      sTypes[V_UP] = P_FLOAT32; // S_COVER
                      sTypes[V_DOWN] = P_FLOAT32; // S_COVER
                      sTypes[V_STOP] = P_FLOAT32; // S_COVER
                      sTypes[V_IR_SEND] = P_FLOAT32; // S_IR
                      sTypes[V_IR_RECEIVE] = P_FLOAT32; // S_IR
                      sTypes[V_FLOW] = P_FLOAT32; // S_WATER
                      sTypes[V_VOLUME] = P_FLOAT32; // S_WATER
                      sTypes[V_LOCK_STATUS] = P_FLOAT32; // S_LOCK
                      sTypes[V_LEVEL] = P_UINT16; // S_DUST, S_AIR_QUALITY, S_SOUND (dB), S_VIBRATION (hz), S_LIGHT_LEVEL (lux)
                      sTypes[V_VOLTAGE] = P_FLOAT32; // S_MULTIMETER
                      sTypes[V_CURRENT] = P_FLOAT32; // S_MULTIMETER
                      sTypes[V_RGB] = P_ULONG32; 	// S_RGB_LIGHT, S_COLOR_SENSOR.
                      					// Used for sending color information for multi color LED lighting or color sensors.
                      					// Sent as ASCII hex: RRGGBB (RR=red, GG=green, BB=blue component)
                      sTypes[V_RGBW] = P_ULONG32; // S_RGBW_LIGHT
                      					// Used for sending color information to multi color LED lighting.
                      					// Sent as ASCII hex: RRGGBBWW (WW=while component)
                      sTypes[V_ID] = P_FLOAT32; // S_TEMP
                      					// Used for sending in sensors hardware ids (i.e. OneWire DS1820b).
                      sTypes[V_UNIT_PREFIX] = P_STRING; // Allows sensors to send in a string representing the
                      								 // unit prefix to be displayed in GUI, not parsed by controller! E.g. cm, m, km, inch.
                      								 // Can be used for S_DISTANCE or gas concentration (S_DUST, S_AIR_QUALITY)
                      sTypes[V_HVAC_SETPOINT_COOL] = P_UINT16; // HVAC cool setpoint (Integer between 0-100). S_HVAC
                      sTypes[V_HVAC_SETPOINT_HEAT] = P_UINT16; // HVAC/Heater setpoint (Integer between 0-100). S_HEATER, S_HVAC
                      sTypes[V_HVAC_FLOW_MODE] = P_UINT16; // Flow mode for HVAC ("Auto", "ContinuousOn", "PeriodicOn"). S_HVAC
                      • A akbooer
                        rvendrameR
                        rvendrameR
                        rvendrame
                        @akbooer , just curious to know, what version of AltUI do you have? Did you adjust anything into the mySensors plugin json?
                        I'm asking that because, my plugin display a bit different:
                        ESP8266 GW + mySensors 2.3.2
                        Alexa / Google Home
                        • rvendrameR rvendrame
                          akbooer
                          @rvendrame
                          Yes, I made a mod to the Arduino plugin. The changes are on GitHub:
                          https://github.com/akbooer/Vera/blob/features-for-altui/L_Arduino.lua
                          I'm hoping to get this merged with the master branch in due course, but I've not finished.
                          rvendrameR 1 Reply Last reply
                          • A akbooer
                            @rvendrame
                            rvendrameR
                            rvendrameR
                            rvendrame
                            @akbooer , thanks a lot!
                            Alexa / Google Home
                            • barduinoB
                              barduinoB
                              barduino
                              wrote on last edited by barduino
                              #32
                              Hi Folks,
                              @GizMoCuz just commited a new version of MockMySensors and I'm about to commit another (MockMySensors.ino) (need to merge with his changes).
                              This will complete the 1.4 lib sensors and Giz has already started adding more.
                              In the mean time here is a picture of MockMySensors running on the MYSController
                              And here is how it look on the HAALL controller
                              If you have used this skecth in other controller would you mind posting screen shots of it here?
                              • D
                                dakipro
                                Hello, is it possible to MockMySensors without physical radio on the gateway?
                                I ordered/received wrong radios and I am now waiting (most likely a month) for the new ones, but I would like to setup the controller without actual sensors. How can I mock them, or somehow simulate sensors without the radio?
                                barduinoB 1 Reply Last reply
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @dakipro
                                  Depending on what you want to run your controller on, and your own experience level with hacking stuff, you can use node-red to simulate sensors, and inject fake sensors into the controller of your choice. (Not all controllers support this though)
                                  head over to http://forum.mysensors.org/topic/1965/nodered-injected-between-domoticz-and-mysensors for more info on setup..
                                  • D dakipro
                                    barduinoB
                                    barduinoB
                                    barduino
                                    @dakipro
                                    I use nodeJS to read from the serial gatweay and send the information to my my controller HAALL, similar to what @tbowmo is suggesting.
                                    Now depending on how your controller accepts information you might pull this off with some hacking. (In HAALL case it accepts via REST service). I've attached my nodeJS example for convenience.
                                    • D
                                      dakipro
                                      Thank you. I installed MajorDoMo controller on a old laptop, just because it is written in php - which I do professionally so that I could optimize or debug it. And it looks decent too :)
                                      I just started with the MySensors and Arduino so I guess it will take me some time to get familiar with how everything works.
                                      My initial idea was to just use mockMySensors without radio and other sensors, but when I try initiate MySensors lib on the arduino I get "radio init fail" which is expected as I do not have the radio attached (it will arrive soon).
                                      I messed a bit inside MySensors library, trying to comment out the part that initializes the radio but then I get some other messages. I guess it is never needed in practice to turn off radio portion of MySensors.
                                      Maybe my question is more related to Network Stress test thread http://forum.mysensors.org/topic/2000/mysensors-network-stress-test on which I also get the same "radio init fail" message, as again radio is missing.
                                      If I find the time I will try to make some software emulation for sensors, based on your NodeJS example. That could be useful for prepping the Controller before even making new sensors, also for simulating scenarios and test how would controller react in certain situations (how different scenes work etc).
                                        The mock example is written to use radio communications. Can be pretty hairy to fix it. Suggest you run the development branch which allows sensors to be attached to gateway. It should run twith the mock example if you configure it as a serial gateway (radio disabled).. See Serial Gateway example for how to activate gateway.
                                        Here is a couple of nodejs modules that might be helpful:
                                        http://forum.mysensors.org/topic/2208/node-js-modules-for-mysensors
                                        • barduinoB
                                          barduinoB
                                          barduino
                                          @dakipro
                                          arghhh of course, it will be very dificult geting pass the radio init fail...
                                          Sorry, I pointed you in the wrong direction.
