  3. Test your home made controller with MockMySensors (w/ tutorial)
39 Posts 12 Posters 31.3k Views 14 Watching
  • barduinoB barduino
    @ch3b7
    Very interesting.
    I was not able to repruduce what you are describing above.
    According to your message we have:
    • Node 50 sending to node 0
    • Child sensor id 0
    • Message type 1 : SET
    • MessageSub Type 16: V_TRIPPED
    • Payload type 7: P_CUSTOM
    • Payload length 5
    Which is very strange.
    In MockMySensors there is no childid=0, the first sensor is #define ID_S_DOOR 1 and the node ID is set to 254 (but perhpas you have changed this)
    Also V_TRIPPED should be sending a bolean value...
    Could you upload your scetch?
    here is my log: SetUP
    send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
    send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-254 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=254, parent=0, distance=1
    GW Started
    Send Sketch Info: send: 254-254-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,st=ok:MockMySensors
    send: 254-254-0-0 s=255,c=3,t=12,pt=0,l=4,sg=0,st=ok:v0.3
    MockMySensors v0.3
    Get Config: Metric
    Presenting Nodes
    ________________
      S_DOOR
    send: 254-254-0-0 s=1,c=0,t=0,pt=0,l=0,sg=0,st=ok:
      S_MOTION
    send: 254-254-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,st=ok:
      S_SMOKE
    send: 254-254-0-0 s=3,c=0,t=2,pt=0,l=0,sg=0,st=ok:
      S_LIGHT
    send: 254-254-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
      S_DIMMER
    send: 254-254-0-0 s=5,c=0,t=4,pt=0,l=0,sg=0,st=ok:
      S_COVER
    send: 254-254-0-0 s=6,c=0,t=5,pt=0,l=0,sg=0,st=ok:
      S_TMEP
    send: 254-254-0-0 s=7,c=0,t=6,pt=0,l=0,sg=0,st=ok:
      S_HUM
    send: 254-254-0-0 s=8,c=0,t=7,pt=0,l=0,sg=0,st=ok:
      S_BARO
    send: 254-254-0-0 s=9,c=0,t=8,pt=0,l=0,sg=0,st=ok:
      S_WIND
    send: 254-254-0-0 s=10,c=0,t=9,pt=0,l=0,sg=0,st=ok:
      S_RAIN
    send: 254-254-0-0 s=11,c=0,t=10,pt=0,l=0,sg=0,st=ok:
      S_UV
    send: 254-254-0-0 s=12,c=0,t=11,pt=0,l=0,sg=0,st=ok:
      S_WEIGHT
    send: 254-254-0-0 s=13,c=0,t=12,pt=0,l=0,sg=0,st=ok:
      S_POWER
    send: 254-254-0-0 s=14,c=0,t=13,pt=0,l=0,sg=0,st=ok:
      S_DISTANCE
    send: 254-254-0-0 s=16,c=0,t=15,pt=0,l=0,sg=0,st=ok:
      S_LIGHT_LEVEL
    send: 254-254-0-0 s=17,c=0,t=16,pt=0,l=0,sg=0,st=ok:
      S_LOCK
    send: 254-254-0-0 s=18,c=0,t=19,pt=0,l=0,sg=0,st=ok:
      S_IR
    send: 254-254-0-0 s=19,c=0,t=20,pt=0,l=0,sg=0,st=ok:
      S_WATER
    send: 254-254-0-0 s=20,c=0,t=21,pt=0,l=0,sg=0,st=ok:
      S_AIR_QUALITY
    send: 254-254-0-0 s=21,c=0,t=22,pt=0,l=0,sg=0,st=ok:
      S_SCENE_CONTROLLER
    send: 254-254-0-0 s=23,c=0,t=25,pt=0,l=0,sg=0,st=ok:
      S_CUSTOM
    send: 254-254-0-0 s=24,c=0,t=23,pt=0,l=0,sg=0,st=ok:
    ________________
    And the loop section
    RandomNumber:76
    Send Battery Level
    send: 254-254-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:76
    Request Time
    send: 254-254-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,st=ok:
    read: 0-0-254 s=255,c=3,t=1,pt=0,l=10,sg=0:1439720967
    Time value received: 1439720967
    Motion is: Quiet
    send: 254-254-0-0 s=2,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
    Smoke is: Quiet
    send: 254-254-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
    Light is: On
    send: 254-254-0-0 s=4,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
    Dimmer is set to: 255
    send: 254-254-0-0 s=5,c=1,t=3,pt=2,l=2,sg=0,st=ok:255
    Cover is : Idle
    send: 254-254-0-0 s=6,c=1,t=31,pt=2,l=2,sg=0,st=ok:31
    Temperature is: 34
    send: 254-254-0-0 s=7,c=1,t=0,pt=4,l=4,sg=0,st=ok:34
    Humitidty is: 76
    send: 254-254-0-0 s=8,c=1,t=1,pt=4,l=4,sg=0,st=ok:76
    Atmosferic Pressure is: 103363
    send: 254-254-0-0 s=9,c=1,t=4,pt=4,l=4,sg=0,st=ok:103363
    Weather forecast: unstable
    send: 254-254-0-0 s=9,c=1,t=5,pt=0,l=8,sg=0,st=ok:unstable
    Wind Speed is: 76
    send: 254-254-0-0 s=10,c=1,t=8,pt=4,l=4,sg=0,st=ok:76
    Wind Gust is: 86
    send: 254-254-0-0 s=10,c=1,t=9,pt=4,l=4,sg=0,st=ok:86
    Wind Direction is: 272
    send: 254-254-0-0 s=10,c=1,t=10,pt=4,l=4,sg=0,st=ok:272
    Rain ammount  is: 76
    send: 254-254-0-0 s=11,c=1,t=6,pt=4,l=4,sg=0,st=ok:76
    Rain rate  is: 1
    send: 254-254-0-0 s=11,c=1,t=7,pt=7,l=5,sg=0,st=ok:1.0
    Ultra Violet level is: 11
    send: 254-254-0-0 s=12,c=1,t=11,pt=4,l=4,sg=0,st=ok:11
    Weight is: 113
    send: 254-254-0-0 s=13,c=1,t=12,pt=4,l=4,sg=0,st=ok:113
    Impedance is: 113
    send: 254-254-0-0 s=14,c=1,t=14,pt=4,l=4,sg=0,st=ok:113
    Watt is: 113
    send: 254-254-0-0 s=14,c=1,t=17,pt=4,l=4,sg=0,st=ok:113
    KWH is: 113
    send: 254-254-0-0 s=14,c=1,t=18,pt=4,l=4,sg=0,st=ok:113
    Voltage is: 113
    send: 254-254-0-0 s=14,c=1,t=38,pt=4,l=4,sg=0,st=ok:113
    Current is: 113
    send: 254-254-0-0 s=14,c=1,t=39,pt=4,l=4,sg=0,st=ok:113
    Distance is: 113
    send: 254-254-0-0 s=16,c=1,t=13,pt=4,l=4,sg=0,st=ok:113
    Light is: 113
    send: 254-254-0-0 s=17,c=1,t=23,pt=4,l=4,sg=0,st=ok:113
    Lock is: On
    send: 254-254-0-0 s=18,c=1,t=36,pt=2,l=2,sg=0,st=ok:1
    Infrared is: 255
    send: 254-254-0-0 s=19,c=1,t=32,pt=2,l=2,sg=0,st=ok:255
    Water flow is: 113
    send: 254-254-0-0 s=20,c=1,t=34,pt=4,l=4,sg=0,st=ok:113
    Water volume is: 113
    send: 254-254-0-0 s=20,c=1,t=35,pt=4,l=4,sg=0,st=ok:113
    Air Quality is: 76
    send: 254-254-0-0 s=21,c=1,t=24,pt=4,l=4,sg=0,st=ok:76
    Scene is: On
    send: 254-254-0-0 s=23,c=1,t=19,pt=2,l=2,sg=0,st=ok:1
    Custom value is: 76
    send: 254-254-0-0 s=24,c=1,t=25,pt=4,l=4,sg=0,st=ok:76
    send: 254-254-0-0 s=24,c=1,t=26,pt=4,l=4,sg=0,st=ok:76
    send: 254-254-0-0 s=24,c=1,t=27,pt=4,l=4,sg=0,st=ok:76
    send: 254-254-0-0 s=24,c=1,t=28,pt=4,l=4,sg=0,st=ok:76
    ch3b7C
    ch3b7C
    ch3b7
    @barduino
    sorry your sketch work good! the problem im have is with the @AWI example!
    @AWI
    all sensors present good but when finish i get a loop sended:
    send: 50-50-0-0 s=0,c=1,t=16,pt=7,l=5,sg=0,st=ok:0.0
    AWIA 1 Reply Last reply
    • ch3b7C ch3b7
      @barduino
      @AWI
      AWIA
      AWIA
      AWI
      @ch3b7 Sorry to have confused you but my sketch was meant for inspiration and as an alternative method to "stress test" the controller and network.
      The version I published is firing an enormous amount of messages at the controller for each sensor. The test data is in myTestData in the format {sensor, V_type, Dataformat, start_value, end_value, stepsize} You can fill the array with anything you want (also "not allowed" combinations).
      I suggest you remove the "ack" which is sent with each message at firtst {gw.send(Msg.set(i, false ))};
      • R
        R
        rene_2k2
        @AWI, @ch3b7
        The loop may be caused by a bug in the source code :
         for (int i = 0; i < NoTests ; i++) {
                for (byte j = myTestData[i][3]; i < myTestData[i][4] ; j += myTestData[i][5])
                  gw.send(Msg.set(i, true ));
        Isn't there a mix between 'i' and 'j' ? Shouldn't it be
                for (byte j = myTestData[i][3]; j < myTestData[i][4] ; j += myTestData[i][5])
                  gw.send(Msg.set(j, true ));
        Sorry, cannot test it right now...
        • R rene_2k2
          @AWI, @ch3b7
          AWIA
          AWIA
          AWI
          @rene_2k2 you're right, thanks
          • ch3b7C
            ch3b7C
            ch3b7
            wrote on last edited by ch3b7
            #24
            @awi can you upload the fixed SKETCH ?? pls! thank you!!
            • A
              akbooer
              I'm most grateful for your work on this sketch - I've used it to exercise my gateway as I developed and debugged my Vera emulation environment called 'openLuup'. I now have a controller for MySensors running on Vera, BeagleBone Black, and an Arduino Yun, all running the ALTUI interface, so it looks like the attached.
              Many thanks for the code and the initial explanations.
              barduinoB rvendrameR 2 Replies Last reply
              • A akbooer
                barduinoB
                barduinoB
                barduino
                @akbooer let me tell you...
                It looks fanastic!
                • A
                  akbooer
                  Well, thank you. But I have to say that the L&F is all down to the amazing ALTUI plugin produced by @amg0 on the Vera BB. I just do the behind-the-scenes bits which make it work on platforms other than Vera.
                  • AWIA
                    AWIA
                    AWI
                    wrote on last edited by AWI
                    #28
                    A "new" version of a stress test or "Fake sensor". As mentioned in a previous post it will never be complete. But I gave it an update to make it easier to work with.
                    This version (MySensors 1.5) will take an array of test values ; present them to the gateway/controller and spit out a range of values for each sensor in the testArray.
                    Version below is fixed node 50, 9 sensors and sends data every 0.1 sec.
                     PROJECT: MySensors
                     PROGRAMMER: AWI
                     DATE: 10 august 2015, update 4 september 2015
                     FILE: AWI_Universal_Test_50.ino
                     LICENSE: Public domain
                       -in conjunction with MySensors
                     STATUS: never finished, MySensors 1.5
                     KNOWN ISSUES: no text message yet
                     SUMMARY:
                    	multisensor for controller stress test
                    	1. Presents sensors to controller
                    	2. Sends (per sensor) values in defined range
                    	repeat
                     Setup: sends values for al sensor specified in setup array
                     Update: 20150904: Changed structure and type definitions (makes is easier to read)
                    const int NODE_ID = 50;  		  		// fixed MySensors node ID
                    const bool testAck = false ;			// set to true if you want all tests to be acknowledged
                    // reference: typedef enum {P_STRING, P_BYTE, P_INT16, P_UINT16, P_LONG32, P_ULONG32, P_CUSTOM, P_FLOAT32 } mysensor_payload ; // MySensor types
                    typedef	union {							// MySensor Payload types (only p_String used in this sketch)
                    	char p_String[10] ; 				// reduce characters to limit RAM size
                    	int16_t p_Int16 ;
                    	uint16_t p_Uint16 ;
                    	int32_t p_Int32 ;
                    	uint32_t p_Uint32 ;
                    	byte p_Byte ;
                    	float p_Float32 ;
                    	} payLoadType ;
                    // data type for tests
                    typedef struct {
                    	int s_type ;						// S_ type of the sensor number (only for init)
                    	char s_name[10] ;					// sensor name (max 9 char)
                    	int v_type ;						// data V_ type to be sent
                    	mysensor_payload dataType ;			// data type identifier (uses MySensors MyTypes definition)
                    	payLoadType testStartValue ;		// start value for test
                    	payLoadType testEndValue ;			// end value for test
                    	float testIncrement;				// test increment (different behaviour for each datatype)
                    	} testDataType ;
                    // TESTDATA: testdata & initialization, change to adapt to your needs
                    const int noSensors = 9 ; 				// number of active sensors in node
                    const int noTests = noSensors ;			// noTests == noSensors for now
                    // testData index determines child_no
                    testDataType testData[noSensors] = { 									// size determined by noSensors constant
                    	{S_MOISTURE, "Moist1" , V_LEVEL, P_BYTE, "40", "50", 1 },			// start & end values in text for convenience, are converted later
                    	{S_MOISTURE, "Moist2" , V_LEVEL, P_BYTE, "60", "70", 1 },
                    	{S_MOISTURE, "Moist3" , V_LEVEL, P_BYTE, "80", "90", 1 },
                    	{S_MULTIMETER, "Multi1", V_VOLTAGE, P_FLOAT32, "30.2", "50.0", 2},  // MULTIMETER
                    	{S_MULTIMETER, "Multi2", V_CURRENT, P_FLOAT32, "1.3", "5.6", 1},
                    	{S_MULTIMETER, "Multi3", V_IMPEDANCE, P_FLOAT32, "300", "900", 50},
                    	{S_TEMP, "Temp1", V_TEMP, P_FLOAT32, "1.1", "20.3", 2},				// Temperature
                    	{S_TEMP, "Temp2", V_TEMP, P_FLOAT32, "10.3", "50.6", 3},
                    	{S_TEMP, "Temp3", V_TEMP, P_FLOAT32, "300", "900", 50}
                    // END TESTDATA
                    // initialize MySensors
                    MyTransportNRF24 transport(9, 10); // Ceech board, 3.3v (7,8)  (pin default 9,10)
                    MySensor gw(transport);
                    // Initialize messages (only generic message here)
                    MyMessage Msg;                    // instantiate message to fill "on the fly
                    unsigned long SLEEP_PERIOD = 100 ;   // Period between individual tests in ms
                    unsigned long loopDelay = 1000 ;      // Sleep period in ms)
                      Serial.println("\n  Stress test for Mysensors network (20150904).\n");
                      gw.begin(incomingMessage, NODE_ID); 								// start MySensors, fixed node ID
                      gw.sendSketchInfo("AWI Universal test 50", "1.1");
                      for (int i = 0; i < noSensors ; i++) {  							// Register al sensors (they will be created as child devices)
                        gw.present(i , testData[i].s_type, testData[i].s_name ); 		// present all sensors in list (sensor_no, sensor_type, sensor_name)
                        gw.wait(loopDelay);
                      gw.process();           											// check if message from controller
                      for (int i = 0; i < noTests ; i++) {
                        Msg.setSensor(i);				    							// set the sensor number, byte 0
                        Msg.setType(testData[i].v_type);      							// set the sensor type, byte 1
                        switch (testData[i].dataType) {         						// data type determines test format
                          case P_BYTE:
                            for (byte j = atoi(testData[i].testStartValue.p_String) ; j < atoi(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                              gw.send(Msg.set(j), testAck);
                              gw.wait(SLEEP_PERIOD);
                          case P_INT16:
                            for (int j = atoi(testData[i].testStartValue.p_String) ; j < atoi(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                          case P_UINT16:
                            for (unsigned int j = atoi(testData[i].testStartValue.p_String) ; j < atoi(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                          case P_ULONG32:
                            for (unsigned long j = atol(testData[i].testStartValue.p_String) ; j < atol(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                          case P_FLOAT32:
                            for (float j = atof(testData[i].testStartValue.p_String) ; j < atof(testData[i].testEndValue.p_String) ; j += testData[i].testIncrement)
                              gw.send(Msg.set(j,3), testAck );
                          default:
                            // do nothing
                        gw.wait(loopDelay);
                     Serial.print("Incoming Message");
                         Serial.print(" (type : ");
                         Serial.print(message.type);
                         Serial.print(")");
                         Serial.print(", status: ");
                    /*	IGNORE: For reference only
                    	S_DOOR, // Door sensor, V_TRIPPED, V_ARMED
                    	S_MOTION,  // Motion sensor, V_TRIPPED, V_ARMED
                    	S_SMOKE,  // Smoke sensor, V_TRIPPED, V_ARMED
                    	S_BINARY, // Binary light or relay, V_STATUS (or V_LIGHT), V_WATT (same as S_LIGHT)
                    	S_DIMMER, // Dimmable light or fan device, V_STATUS (on/off), V_DIMMER (dimmer level 0-100), V_WATT
                    	S_COVER, // Blinds or window cover, V_UP, V_DOWN, V_STOP, V_DIMMER (open/close to a percentage)
                    	S_TEMP, // Temperature sensor, V_TEMP
                    	S_HUM, // Humidity sensor, V_HUM
                    	S_BARO, // Barometer sensor, V_PRESSURE, V_FORECAST
                    	S_WIND, // Wind sensor, V_WIND, V_GUST
                    	S_RAIN, // Rain sensor, V_RAIN, V_RAINRATE
                    	S_UV, // Uv sensor, V_UV
                    	S_WEIGHT, // Personal scale sensor, V_WEIGHT, V_IMPEDANCE
                    	S_POWER, // Power meter, V_WATT, V_KWH
                    	S_HEATER, // Header device, V_HVAC_SETPOINT_HEAT, V_HVAC_FLOW_STATE
                    	S_DISTANCE, // Distance sensor, V_DISTANCE
                    	S_LIGHT_LEVEL, // Light level sensor, V_LIGHT_LEVEL (uncalibrated in percentage),  V_LEVEL (light level in lux)
                    	S_ARDUINO_NODE, // Used (internally) for presenting a non-repeating Arduino node
                    	S_ARDUINO_REPEATER_NODE, // Used (internally) for presenting a repeating Arduino node
                    	S_LOCK, // Lock device, V_LOCK_STATUS
                    	S_IR, // Ir device, V_IR_SEND, V_IR_RECEIVE
                    	S_WATER, // Water meter, V_FLOW, V_VOLUME
                    	S_AIR_QUALITY, // Air quality sensor, V_LEVEL
                    	S_CUSTOM, // Custom sensor
                    	S_DUST, // Dust sensor, V_LEVEL
                    	S_SCENE_CONTROLLER, // Scene controller device, V_SCENE_ON, V_SCENE_OFF.
                    	S_RGB_LIGHT, // RGB light. Send color component data using V_RGB. Also supports V_WATT
                    	S_RGBW_LIGHT, // RGB light with an additional White component. Send data using V_RGBW. Also supports V_WATT
                    	S_COLOR_SENSOR,  // Color sensor, send color information using V_RGB
                    	S_HVAC, // Thermostat/HVAC device. V_HVAC_SETPOINT_HEAT, V_HVAC_SETPOINT_COLD, V_HVAC_FLOW_STATE, V_HVAC_FLOW_MODE
                    	S_MULTIMETER, // Multimeter device, V_VOLTAGE, V_CURRENT, V_IMPEDANCE
                    	S_SPRINKLER,  // Sprinkler, V_STATUS (turn on/off), V_TRIPPED (if fire detecting device)
                    	S_WATER_LEAK, // Water leak sensor, V_TRIPPED, V_ARMED
                    	S_SOUND, // Sound sensor, V_TRIPPED, V_ARMED, V_LEVEL (sound level in dB)
                    	S_VIBRATION, // Vibration sensor, V_TRIPPED, V_ARMED, V_LEVEL (vibration in Hz)
                    	S_MOISTURE, // Moisture sensor, V_TRIPPED, V_ARMED, V_LEVEL (water content or moisture in percentage?)
                    // sensor data types
                    // typedef enum {P_STRING, P_BYTE, P_INT16, P_UINT16, P_LONG32, P_ULONG32, P_CUSTOM, P_FLOAT32 } MyTypes ;
                    sTypes[V_TEMP] =  P_FLOAT32; // S_TEMP
                    sTypes[V_HUM] =P_FLOAT32; // S_HUM
                    sTypes[V_STATUS] = P_UINT16; //  S_LIGHT, S_DIMMER, S_SPRINKLER, S_HVAC, S_HEATER. Used for setting binary (on/off) status. 1=on, 0=off
                    sTypes[V_LIGHT] = P_UINT16; // Same as V_STATUS
                    sTypes[V_PERCENTAGE] = P_UINT16; // S_DIMMER. Used for sending a percentage value (0-100).
                    sTypes[V_DIMMER] = P_UINT16; // S_DIMMER. Same as V_PERCENTAGE.
                    sTypes[V_PRESSURE] = P_FLOAT32; // S_BARO
                    sTypes[V_FORECAST] = P_FLOAT32; // S_BARO
                    sTypes[V_RAIN] = P_FLOAT32; // S_RAIN
                    sTypes[V_RAINRATE] = P_FLOAT32;  // S_RAIN
                    sTypes[V_WIND] = P_FLOAT32; // S_WIND
                    sTypes[V_GUST] = P_FLOAT32; // S_WIND
                    sTypes[V_DIRECTION] = P_FLOAT32; // S_WIND
                    sTypes[V_UV] = P_FLOAT32; // S_UV
                    sTypes[V_WEIGHT] = P_FLOAT32; // S_WEIGHT
                    sTypes[V_DISTANCE] = P_FLOAT32; // S_DISTANCE
                    sTypes[V_IMPEDANCE] = P_FLOAT32; // S_MULTIMETER, S_WEIGHT
                    sTypes[V_ARMED]= P_FLOAT32; // S_DOOR, S_MOTION, S_SMOKE, S_SPRINKLER
                    sTypes[V_TRIPPED]= P_FLOAT32; // S_DOOR, S_MOTION, S_SMOKE, S_SPRINKLER (for sprinklers with fire detection)
                    sTypes[V_WATT]= P_FLOAT32; // S_POWER, S_LIGHT, S_DIMMER
                    sTypes[V_KWH]= P_FLOAT32; // S_POWER
                    sTypes[V_SCENE_ON]= P_FLOAT32; // S_SCENE_CONTROLLER
                    sTypes[V_SCENE_OFF]= P_FLOAT32; // S_SCENE_CONTROLLER
                    sTypes[V_HEATER]= P_FLOAT32; // Deprecated. Use V_HVAC_FLOW_STATE instead.
                    sTypes[V_HVAC_FLOW_STATE] = P_UINT16; // HVAC flow state ("Off", "HeatOn", "CoolOn", or "AutoChangeOver"). S_HEATER, S_HVAC
                    sTypes[V_HVAC_SPEED]= P_FLOAT32; // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto")
                    sTypes[V_LIGHT_LEVEL]= P_UINT16; // Used for sending light level in uncalibrated percentage. See also V_LEVEL (light level in lux). S_LIGHT_LEVEL
                    sTypes[V_VAR1] = P_FLOAT32;
                    sTypes[V_VAR2] = P_FLOAT32;
                    sTypes[V_VAR3] = P_FLOAT32;
                    sTypes[V_VAR4] = P_FLOAT32;
                    sTypes[V_VAR5] = P_FLOAT32;
                    sTypes[V_UP] = P_FLOAT32; // S_COVER
                    sTypes[V_DOWN] = P_FLOAT32; // S_COVER
                    sTypes[V_STOP] = P_FLOAT32; // S_COVER
                    sTypes[V_IR_SEND] = P_FLOAT32; // S_IR
                    sTypes[V_IR_RECEIVE] = P_FLOAT32; // S_IR
                    sTypes[V_FLOW] = P_FLOAT32; // S_WATER
                    sTypes[V_VOLUME] = P_FLOAT32; // S_WATER
                    sTypes[V_LOCK_STATUS] = P_FLOAT32; // S_LOCK
                    sTypes[V_LEVEL] = P_UINT16; // S_DUST, S_AIR_QUALITY, S_SOUND (dB), S_VIBRATION (hz), S_LIGHT_LEVEL (lux)
                    sTypes[V_VOLTAGE] = P_FLOAT32; // S_MULTIMETER
                    sTypes[V_CURRENT] = P_FLOAT32; // S_MULTIMETER
                    sTypes[V_RGB] = P_ULONG32; 	// S_RGB_LIGHT, S_COLOR_SENSOR.
                    					// Used for sending color information for multi color LED lighting or color sensors.
                    					// Sent as ASCII hex: RRGGBB (RR=red, GG=green, BB=blue component)
                    sTypes[V_RGBW] = P_ULONG32; // S_RGBW_LIGHT
                    					// Used for sending color information to multi color LED lighting.
                    					// Sent as ASCII hex: RRGGBBWW (WW=while component)
                    sTypes[V_ID] = P_FLOAT32; // S_TEMP
                    					// Used for sending in sensors hardware ids (i.e. OneWire DS1820b).
                    sTypes[V_UNIT_PREFIX] = P_STRING; // Allows sensors to send in a string representing the
                    								 // unit prefix to be displayed in GUI, not parsed by controller! E.g. cm, m, km, inch.
                    								 // Can be used for S_DISTANCE or gas concentration (S_DUST, S_AIR_QUALITY)
                    sTypes[V_HVAC_SETPOINT_COOL] = P_UINT16; // HVAC cool setpoint (Integer between 0-100). S_HVAC
                    sTypes[V_HVAC_SETPOINT_HEAT] = P_UINT16; // HVAC/Heater setpoint (Integer between 0-100). S_HEATER, S_HVAC
                    sTypes[V_HVAC_FLOW_MODE] = P_UINT16; // Flow mode for HVAC ("Auto", "ContinuousOn", "PeriodicOn"). S_HVAC
                    • A akbooer
                      rvendrameR
                      rvendrameR
                      rvendrame
                      @akbooer , just curious to know, what version of AltUI do you have? Did you adjust anything into the mySensors plugin json?
                      I'm asking that because, my plugin display a bit different:
                      ESP8266 GW + mySensors 2.3.2
                      Alexa / Google Home
                      • rvendrameR rvendrame
                        akbooer
                        @rvendrame
                        Yes, I made a mod to the Arduino plugin. The changes are on GitHub:
                        https://github.com/akbooer/Vera/blob/features-for-altui/L_Arduino.lua
                        I'm hoping to get this merged with the master branch in due course, but I've not finished.
                        rvendrameR 1 Reply Last reply
                        • A akbooer
                          @rvendrame
                          rvendrameR
                          rvendrameR
                          rvendrame
                          @akbooer , thanks a lot!
                          Alexa / Google Home
                          • barduinoB
                            barduinoB
                            barduino
                            wrote on last edited by barduino
                            #32
                            Hi Folks,
                            @GizMoCuz just commited a new version of MockMySensors and I'm about to commit another (MockMySensors.ino) (need to merge with his changes).
                            This will complete the 1.4 lib sensors and Giz has already started adding more.
                            In the mean time here is a picture of MockMySensors running on the MYSController
                            And here is how it look on the HAALL controller
                            If you have used this skecth in other controller would you mind posting screen shots of it here?
                            • D
                              dakipro
                              Hello, is it possible to MockMySensors without physical radio on the gateway?
                              I ordered/received wrong radios and I am now waiting (most likely a month) for the new ones, but I would like to setup the controller without actual sensors. How can I mock them, or somehow simulate sensors without the radio?
                              barduinoB 1 Reply Last reply
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @dakipro
                                Depending on what you want to run your controller on, and your own experience level with hacking stuff, you can use node-red to simulate sensors, and inject fake sensors into the controller of your choice. (Not all controllers support this though)
                                head over to http://forum.mysensors.org/topic/1965/nodered-injected-between-domoticz-and-mysensors for more info on setup..
                                • D dakipro
                                  barduinoB
                                  barduinoB
                                  barduino
                                  @dakipro
                                  I use nodeJS to read from the serial gatweay and send the information to my my controller HAALL, similar to what @tbowmo is suggesting.
                                  Now depending on how your controller accepts information you might pull this off with some hacking. (In HAALL case it accepts via REST service). I've attached my nodeJS example for convenience.
                                  • D
                                    dakipro
                                    Thank you. I installed MajorDoMo controller on a old laptop, just because it is written in php - which I do professionally so that I could optimize or debug it. And it looks decent too :)
                                    I just started with the MySensors and Arduino so I guess it will take me some time to get familiar with how everything works.
                                    My initial idea was to just use mockMySensors without radio and other sensors, but when I try initiate MySensors lib on the arduino I get "radio init fail" which is expected as I do not have the radio attached (it will arrive soon).
                                    I messed a bit inside MySensors library, trying to comment out the part that initializes the radio but then I get some other messages. I guess it is never needed in practice to turn off radio portion of MySensors.
                                    Maybe my question is more related to Network Stress test thread http://forum.mysensors.org/topic/2000/mysensors-network-stress-test on which I also get the same "radio init fail" message, as again radio is missing.
                                    If I find the time I will try to make some software emulation for sensors, based on your NodeJS example. That could be useful for prepping the Controller before even making new sensors, also for simulating scenarios and test how would controller react in certain situations (how different scenes work etc).
                                      The mock example is written to use radio communications. Can be pretty hairy to fix it. Suggest you run the development branch which allows sensors to be attached to gateway. It should run twith the mock example if you configure it as a serial gateway (radio disabled).. See Serial Gateway example for how to activate gateway.
                                      Here is a couple of nodejs modules that might be helpful:
                                      http://forum.mysensors.org/topic/2208/node-js-modules-for-mysensors
                                      • barduinoB
                                        barduinoB
                                        barduino
                                        @dakipro
                                        arghhh of course, it will be very dificult geting pass the radio init fail...
                                        Sorry, I pointed you in the wrong direction.
                                        • barduinoB
                                          barduinoB
                                          barduino
                                          #39
                                          Hi Folks,
                                          The guys at MySensors were kind to convert this to 1.6 lib.
                                          So being back in Europe for the holidays I decided to create a post with some explanations/tutorial about the code.
                                          This example MockMySensors from the MySensors examples actually combines 30 sensors in a single node.
                                          It may have a poor architecture but it will give you an idea of how to combine sensors and with some feedback we can always improve on the architecture.
                                          It has been designed for you to customize it for the sensor you want to test by uncomment the initial lines.
                                          This line defines your NODE ID, you can always change it to AUTO or to your specification
                                          #define MY_NODE_ID 254
                                          This part of the code defines the sensors you want to work with and their ids
                                          #define ID_S_ARMED             0  // dummy to controll armed stated for several sensors
                                          #define ID_S_DOOR              1
                                          //#define ID_S_TEMP              7
                                          //#define ID_S_BARO              9
                                          ... code lines snipped ...
                                          This part of the code defines the messages you want to instantiate to work with your sensors
                                          #ifdef ID_S_LIGHT
                                            bool isLightOn=0;
                                          #ifdef ID_S_MOISTURE
                                          // To be implemented
                                          On the presentation section, you have all the sensors being presented, along with some debugging
                                          void presentation()  {
                                          #ifdef ID_S_DOOR
                                              Serial.println("  S_DOOR");
                                              wait(SHORT_WAIT);
                                            #ifdef ID_S_MOTION
                                              Serial.println("  S_MOTION");
                                              wait(SHORT_WAIT);
                                            #ifdef ID_S_SMOKE
                                              Serial.println("  S_SMOKE");
                                              wait(SHORT_WAIT);
                                            #ifdef ID_S_CUSTOM
                                              Serial.println("  S_CUSTOM");
                                              wait(SHORT_WAIT);
                                          On the loop section you have methods which will trigger each sensor to report. This will happen periodically on the SLEEP_TIME, 15 minutes by default
                                          void loop()[
                                            //Read Sensors
                                            #ifdef ID_S_DOOR
                                              door();
                                            #ifdef ID_S_MOTION
                                              motion();
                                            #ifdef ID_S_SMOKE
                                              smoke();
                                            #ifdef ID_S_CUSTOM
                                              custom();
                                          Lets take a look at one of them, the dimmer. As you can see its just reporting the dimmerVal which was declared as a global variable.
                                          Sometimes these values are saved in the EPROM, for this example I wanted to avoid that.
                                             #ifdef ID_S_DIMMER
                                          	void dimmer(){
                                            	Serial.println(dimmerVal);
                                          Finally the incoming message section.
                                          	#ifdef ID_S_DIMMER
                                              case V_DIMMER:
                                                    dimmerVal= message.getInt();
                                                    dimmer();// temp ack
                                          The temp ack mean I'm just forcing the sensor to report back the new value to the controller.
                                          And this is basically what it takes to combine sensors in the MySensors library.
                                          One node can have many sensors and each sensor can receive any number or combinations of messages.
                                          So for the dimmer example
                                          #ifdef ID_S_DIMMER
                                            int dimmerVal=100;
                                          #ifdef ID_S_DIMMER
                                          	Serial.println("  S_DIMMER");
                                              wait(SHORT_WAIT);
                                          There is nothing stoping me to add another message type to the dimmer. So for example if the dimmer does have an on/off button I could add
                                          MyMessage msg_S_DIMMER_BUTTON(ID_S_DIMMER,V_STATUS)
                                          Note that your controller might not be expecting all this freedom of combinations of messages.
                                          So although I could report a temperature on a dimmer sensor using
                                          MyMessage msg_S_DIMMER_BUTTON(ID_S_DIMMER,V_TEMP)
                                          Your controller might not like it.
                                          As always feddback is welcome
