  3. My Ugly ESP GW Prototype
34 Posts 18 Posters 20.3k Views 8 Watching
  • tbowmoT tbowmo
    Is Photon compatible with Arduino? (the build eco system). That is one of the key elements of mysensors at the moment, and what makes it accessible for newcommers.
    If not then everything needs to be ported to another build system..
    @tbowmo said:
    Glad you brought this up.
    • rvendrameR
      rvendrameR
      rvendrame
      @tekka said:
      I'm running the GW sketch (and repeater node) natively on the ESP8266 - however, the porting needs some additional work on EEPROM handling and pointer addressing. Also, a stable power supply is important (>3.1V with ESP8266 and NRF24 attached, no peaks). Will post more as porting progresses.
      Would mind to share your sketch for the ESP8266 + WiFi+GW + nRF24 ? If I understood correctly --- the ESP can run the mySensors GW + regular Wi-fi, replacing the arduino? Any other downside than the EEPROM ?
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      tekkaT 1 Reply Last reply
      • rvendrameR rvendrame
        tekkaT
        tekkaT
        tekka
        @rvendrame yes, ESP8266 + nRF24L01 = GW. However, build is currently unstable and WIP.
        • rvendrameR
          rvendrameR
          rvendrame
          @tekka, ok got it. I just managed to run my serial GW on my media-player computer (using a serial to ethernet program), so I now I finally have my kind of ethernet GW. Thanks!
          Alexa / Google Home
          barduinoB 1 Reply Last reply
            barduinoB
            barduinoB
            barduino
            @rvendrame said:
            @tekka, ok got it. ... so I now I finally have my kind of ethernet GW. Thanks!
            NodeJS?
            • rvendrameR
              rvendrameR
              rvendrame
              @barduino , I have Vera as controller. And I have a old mac mini which is my media player / nas / voip / etc... I just installed the .99c TCP2Serial on it, and plugged my serial gateway. It is working like a charm.
              Alexa / Google Home
              • Daniel OliveiraD
                Daniel OliveiraD
                Daniel Oliveira
                Hi @hek and everyone,
                I'm starting to get really interested in knowing more about these ESP8266 litle things but after some "googling" I still didn't figured out one thing. I already saw some projects to use an ESP alone as a GW (with a RF24 module attached) but is it not possible to have a MySensor's network of only ESPs?
                One ESP as GE and multiple others as sensor nodes? Why?
                Thank you all in advance,
                Daniel
                MySensors rules my home :)
                  Most probably possible once someone get library running on it.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Daniel-Oliveira
                    If you were to make a sensor network only with ESP8266, you don't need mysensors (as I see it). It has network capabilities by itself (wifi), so you could actually just connect them to your existing wifi network (or create a new one with an old router).
                    One thing though, they probably will use more current, compared to nrf24 / rfm69. Unless you can power up/down the module. But then you'll have latency time when connecting to the wifi, before sending the actual sensor values.
                    But besides that, it should be possible to make some sort of sensor network with the ESP only..
                    • Lucas FiggL
                      Lucas FiggL
                      Lucas Figg
                      Does anyone have any working examples of Sensebender Micro working with a Photon? I have all the parts but finding it difficult to unravel all GW libs and so on. I just want to use my sensebender with a Onewire waterproof temp sensor and for it to report back to the Photon every 5 minutes or so.
                      12.5k
