  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 406.4k Views 39 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    wrote on last edited by rvendrame
    #67
    I followed the steps above, and I'm even able to upload sketches, however I only get this in serial monitor:
    Bad module maybe?
    EDIT: After choosing the right board (v.1.0) and applying the fix above from @fleinze, it seems it is working now...
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    • K
      K
      krajcl
      wrote on last edited by krajcl
      #68
      I'm having problems running ESP8266 gateway. When I reset my nodes or trying send command from controller to node (dimmer, realy etc.) my gateway reset itself. I try using different ESP-s (I'm using ESP-12), power supplys and radio modules.
      On serial monitor I get this error:
      • K krajcl
        #69
        @krajcl What catches my eye is the client command echoed by the gateway: "Client 0: 44;255;3;0;6;"
        The 0 at the end seems to be missing -- This could be a gateway issue (are you using the standard ESP gateway sketch, or did you make any modifications?) which causes e.g. the command parser to crash.
        Could you give a more detailed description of your setup? Which controller are you using, what does the network look like (nr. of sensors, repeaters etc.).
        • K
          K
          krajcl
          @Yveaux I'm using standard ESP gateway sketch (I reinstalled Arduino IDE, download latest mysensors library). At the moment I'm using MYSController as controler (for testing), I only have one node active (standard humidity sketch - only changed node id).
          • K krajcl
            @krajcl The last command from the controller seems to be a response to the sensor to indicate metric or imperial units are used (internal command 6). The payload should be either 'M' or 'I'.
            I'm not familiar with MYSController, but is there some setting influencing the unit system? Can you check if it has a valid value?
            I can't replay the situation right now, so anything you can do yourself to track the problem would really help.
            • K
              K
              krajcl
              @Yveaux This is result with Domoticz as controller and new node (relay), same result:
              • rvendrameR
                rvendrameR
                rvendrame
                I'm definitely not a expert at all on the topic, but could it be that a ftdi-usb adapter doesn't provide enough power to ESP, and it eventually hangs when wi-fi transmissions drawn too much power? (according to the specs, ~150mA when transmitting) .
                Just trying to help with some (probably dumb) brainstorming. ;-)
                Alexa / Google Home
                • G
                  G
                  gmccarthy
                  wrote on last edited by gmccarthy
                  #74
                  Do you need to the NodeMCU to implement this?
                  I have an arduino uno and ESP-01. How do I wire these up?
                  After doing some more reading looks like the esp-01 does not have enough pins. Dont think I can use it :(
                  • K krajcl
                    S 1 Reply Last reply
                    • K
                      K
                      krajcl
                      @Yveaux I tried function (clear routing table) in MYSConroller. This is result:
                      Client 0: 0;0;3;0;10;C
                      Client 0: 6;0;3;0;10;C
                      ctx: cont
                      sp: 3ffeabe0 end: 3ffeaf20 offset: 01b0
                      When I try this function for gateway, evrything works fine, but for other nodes - gateway resets
                      • K krajcl
                        ctx: cont
                        @krajcl When this message is addressed to the gateway (0;0;3;0;10;C) it does not get sent over the air by the radio.
                        When you send it to node 6 (6;0;3;0;10;C), it will send the message to the node, using the radio.
                        Can you please answer this: Will it crash with just any message sent to the nodes using the radio, or only when sending internal messages to nodes (internal messages to nodes have the first value unequal to 0 and the third value set to 3, like 6;x;3;x;x;x) ?
                        • K
                          K
                          krajcl
                          @Yveaux it doesn't matter, what I send, resets every time
                          • K krajcl
                            @krajcl Ah, ok! That helps!
                            For me, and a lot of other people on this forum, sending messages just works with the ESP.
                            Maybe @rvendrame is pointing in the right direction? How are you powering the ESP?
                            • AndurilA
                              AndurilA
                              Anduril
                              Is it possible to set a fixed IP adress and bypass DHCP? My router sometimes messes up his DHCP-table and reassigns all adresses. Then I would have to correct the IP in my controller which I want to avoid.
                              • AndurilA Anduril
                                @Anduril The ESP8266 Arduino port uses the same API as the standard Arduino WiFi library.
                                This means you should be able to use WiFi.config() to set a fixed IP address.
                                Change the following line in Esp8266Gateway.ino
                                  (void)WiFi.begin(ssid, pass);
                                into something like (untested!):
                                  IPAddress ip(192, 168, 0, 123);  /* Set to whatever IP address you'd like the gateway to have */
                                  WiFi.config(ip);
                                Please report back your experience!
                                • sowardS
                                  sowardS
                                  soward
                                  I got this working on an 0.9 version of the nodeMCU ( the Yellow board ). It has some code upload issues, which are slightly worse on OS X than Linux, but usually a couple of tries with holding down the button as @hek mentioned usually does the trick. I do not have any TCP/IP clients pointed at it currently, but I also get lots of watch dog timer resets, which seem somewhat random, as it will run and log messages for somewhere between 15 mins and 10 hours.
                                  It is just being powered by USB and I have not swapped NRF modules yet, so one of those may likely be the culprit, but just wanted to chime in with a (mostly) successful setup.
                                  thanx
                                  • K
                                    K
                                    kimnguu204
                                    wrote on last edited by kimnguu204
                                    #83
                                    Hello all,
                                    is there anybody setup MQTT gateway and it's working fine? how many node wifi gateway can handle?
                                    Could you please share me Wifi MQTT Gateway code.
                                    Thank you all and have a nice day
                                    • K kimnguu204
                                      Hello all,
                                      Currently there is no MQTT WiFi gateway, but it shouldn't be very hard to create one by combining the WiFi Gateway with the MQTT gateway.
                                      The same as any other MySensors gateway (around 250).
                                      • R
                                        R
                                        ridge
                                        I will report a successful first experience with MySensors using the esp8266 WiFi Gateway and a digital switch nRF24L01+ MySensors node.
                                        Thank you Yveaux and hek! nRF24L01+ nodes are the only way to go for battery power!
                                        I look forward to learning more about the MySensors architecture.
                                        I am currently using openHAB as my controller.
                                        For the MQTT library, I will vote for the https://github.com/Imroy/pubsubclient library if you decide to create a MQTT version of the WiFi Gateway. I have this library installed on 8 esp8266 nodes operating for over two months without any problems.
                                        The knolleary version has had some recent updates since I installed the lmroy version, so it may work fine with Mosquitto MQTT 3.1.1 instead of MQTT 3.1 only.
                                        • V
                                          V
                                          vickey
                                          wrote on last edited by vickey
                                          #86
                                          Hi Friends
                                          I am having an issue with my NRF24L01+. If I change gw.begin() to anything like below,
                                          I get an error "radio init fail"
                                          And I am now trying ESP-8266 12E module along with nrf24L01+ (genuine) transceiver to built wifi gateway, which I'll later use as gateway for openhab. I am having a similar issue, Here is the log I get through serial monitor.
                                          **Connecting to Ahmed
                                          ...........Connected!
                                          IP: 192.168.0.31
                                          0;0;3;0;9;radio init fail
                                          ctx: cont
                                          sp: 3ffebdf0 end: 3ffec010 offset: 01b0
                                          stack>>>
                                          3ffebfa0: 0000007f 3ffec03c 40201cac 3ffeaff0
                                          3ffebfb0: 40202320 00000001 00000000 40201d4f
                                          3ffebfc0: 1f00a8c0 00ffffff 0100a8c0 3ffec03c
                                          3ffebfd0: 3ffe9328 3ffead34 3ffec070 402026ef
                                          3ffebfe0: 3ffe98a8 1f00a8c0 00000000 00000000
                                          3ffebff0: 3fffdc20 00000000 3ffec034 40201d1f
                                          3ffec000: 00000000 00000000 3ffeaff0 40100398
                                          <<<stack<<<
                                          ets Jan 8 2013,rst cause:1, boot mode:(3,3)
                                          tail 0
                                          chksum 0x42
                                          csum 0x42
                                          ~ld**
                                          This information runs in a loop again and again. I am using latest library from https://github.com/mysensors/Arduino/tree/master without editing the sample Esp8266Gateway sktech except user name and password. I have followed the connection instruction specified in sample sketch and sketch was successfully uploaded. I am using 101nf capacitors and 10K resistances as specified by https://www.youtube.com/watch?v=JA-0hs5rpMY.
                                          Everything is working fine except that error. May anyone help me out?
