  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 406.4k Views 39 Watching
  • G
    G
    gmccarthy
    wrote on last edited by gmccarthy
    #74
    Do you need to the NodeMCU to implement this?
    I have an arduino uno and ESP-01. How do I wire these up?
    After doing some more reading looks like the esp-01 does not have enough pins. Dont think I can use it :(
    • K krajcl
      @Yveaux This is result with Domoticz as controller and new node (relay), same result:
      S 1 Reply Last reply
      • K
        K
        krajcl
        @Yveaux I tried function (clear routing table) in MYSConroller. This is result:
        Client 0: 0;0;3;0;10;C
        Client 0: 6;0;3;0;10;C
        ctx: cont
        sp: 3ffeabe0 end: 3ffeaf20 offset: 01b0
        When I try this function for gateway, evrything works fine, but for other nodes - gateway resets
        • K krajcl
          ctx: cont
          @krajcl When this message is addressed to the gateway (0;0;3;0;10;C) it does not get sent over the air by the radio.
          When you send it to node 6 (6;0;3;0;10;C), it will send the message to the node, using the radio.
          Can you please answer this: Will it crash with just any message sent to the nodes using the radio, or only when sending internal messages to nodes (internal messages to nodes have the first value unequal to 0 and the third value set to 3, like 6;x;3;x;x;x) ?
          • K
            K
            krajcl
            @Yveaux it doesn't matter, what I send, resets every time
            • K krajcl
              @krajcl Ah, ok! That helps!
              For me, and a lot of other people on this forum, sending messages just works with the ESP.
              Maybe @rvendrame is pointing in the right direction? How are you powering the ESP?
              • AndurilA
                AndurilA
                Anduril
                Is it possible to set a fixed IP adress and bypass DHCP? My router sometimes messes up his DHCP-table and reassigns all adresses. Then I would have to correct the IP in my controller which I want to avoid.
                • AndurilA Anduril
                  @Anduril The ESP8266 Arduino port uses the same API as the standard Arduino WiFi library.
                  This means you should be able to use WiFi.config() to set a fixed IP address.
                  Change the following line in Esp8266Gateway.ino
                    (void)WiFi.begin(ssid, pass);
                  into something like (untested!):
                    IPAddress ip(192, 168, 0, 123);  /* Set to whatever IP address you'd like the gateway to have */
                    WiFi.config(ip);
                  Please report back your experience!
                  • sowardS
                    sowardS
                    soward
                    I got this working on an 0.9 version of the nodeMCU ( the Yellow board ). It has some code upload issues, which are slightly worse on OS X than Linux, but usually a couple of tries with holding down the button as @hek mentioned usually does the trick. I do not have any TCP/IP clients pointed at it currently, but I also get lots of watch dog timer resets, which seem somewhat random, as it will run and log messages for somewhere between 15 mins and 10 hours.
                    It is just being powered by USB and I have not swapped NRF modules yet, so one of those may likely be the culprit, but just wanted to chime in with a (mostly) successful setup.
                    thanx
                    • K
                      K
                      kimnguu204
                      wrote on last edited by kimnguu204
                      #83
                      Hello all,
                      is there anybody setup MQTT gateway and it's working fine? how many node wifi gateway can handle?
                      Could you please share me Wifi MQTT Gateway code.
                      Thank you all and have a nice day
                      • K kimnguu204
                        Hello all,
                        Currently there is no MQTT WiFi gateway, but it shouldn't be very hard to create one by combining the WiFi Gateway with the MQTT gateway.
                        The same as any other MySensors gateway (around 250).
                        • R
                          R
                          ridge
                          I will report a successful first experience with MySensors using the esp8266 WiFi Gateway and a digital switch nRF24L01+ MySensors node.
                          Thank you Yveaux and hek! nRF24L01+ nodes are the only way to go for battery power!
                          I look forward to learning more about the MySensors architecture.
                          I am currently using openHAB as my controller.
                          For the MQTT library, I will vote for the https://github.com/Imroy/pubsubclient library if you decide to create a MQTT version of the WiFi Gateway. I have this library installed on 8 esp8266 nodes operating for over two months without any problems.
                          The knolleary version has had some recent updates since I installed the lmroy version, so it may work fine with Mosquitto MQTT 3.1.1 instead of MQTT 3.1 only.
                          • V
                            V
                            vickey
                            wrote on last edited by vickey
                            #86
                            Hi Friends
                            I am having an issue with my NRF24L01+. If I change gw.begin() to anything like below,
                            I get an error "radio init fail"
                            And I am now trying ESP-8266 12E module along with nrf24L01+ (genuine) transceiver to built wifi gateway, which I'll later use as gateway for openhab. I am having a similar issue, Here is the log I get through serial monitor.
                            **Connecting to Ahmed
                            ...........Connected!
                            IP: 192.168.0.31
                            0;0;3;0;9;radio init fail
                            ctx: cont
                            sp: 3ffebdf0 end: 3ffec010 offset: 01b0
                            stack>>>
                            3ffebfa0: 0000007f 3ffec03c 40201cac 3ffeaff0
                            3ffebfb0: 40202320 00000001 00000000 40201d4f
                            3ffebfc0: 1f00a8c0 00ffffff 0100a8c0 3ffec03c
                            3ffebfd0: 3ffe9328 3ffead34 3ffec070 402026ef
                            3ffebfe0: 3ffe98a8 1f00a8c0 00000000 00000000
                            3ffebff0: 3fffdc20 00000000 3ffec034 40201d1f
                            3ffec000: 00000000 00000000 3ffeaff0 40100398
                            <<<stack<<<
                            ets Jan 8 2013,rst cause:1, boot mode:(3,3)
                            tail 0
                            chksum 0x42
                            csum 0x42
                            ~ld**
                            This information runs in a loop again and again. I am using latest library from https://github.com/mysensors/Arduino/tree/master without editing the sample Esp8266Gateway sktech except user name and password. I have followed the connection instruction specified in sample sketch and sketch was successfully uploaded. I am using 101nf capacitors and 10K resistances as specified by https://www.youtube.com/watch?v=JA-0hs5rpMY.
                            Everything is working fine except that error. May anyone help me out?
                            • V vickey
                              Hi Friends
                              IP: 192.168.0.31
                              ctx: cont
                              stack>>>
                              <<<stack<<<
                              tail 0
                              chksum 0x42
                              csum 0x42
                              ~ld**
                              @vickey the resets you're experiencing are caused by the failure to init the radio. This will cause the MySensors library to enter an endless loop. This will cause the watchdog to trigger and reset the ESP.
                              Please try connecting the radio exactly as stated on the MySensors build page (when using NodeMcu hardware) or connect the same way as I did (see first post in this topic).
                              Double check your radio connections.
                              • V
                                V
                                vickey
                                #88
                                I have checked all the wires and every thing is according to as par advised. I am using 2 separate 3.3 v voltage regulator to power up ESP-8266 12E and nrf24L01+ having common ground, using ESP-8266 breakout board without voltage regulator and nrf24l01+ breakout board with 3.3 v regulator powered by 5v supply.
                                GPIO15 connected via 10K pulldown resistor to GND and also connected with CSN of nrf24l016, is this connection correct?
                                Moreover, I am using USB to TTL adapter in place of FTDI and TX of ESP-8266 is connected with RX of TTL serial adapter and vice versa, GND of TTL serial adapter is also connected common GND. It's all the difference from your mentioned procedure.
                                • V vickey
                                  @vickey could the nrf24 be defective?
                                  Did you obtain the gateway & MySensors code from my github repository or from MySensors repository?
                                  • V
                                    V
                                    vickey
                                    #90
                                    Sorry When I investigate the wiring throughly, MOSI and MISO was interchanged. Now it has started working but error has changed
                                    ESP8266 MySensors Gateway
                                    Connecting to Ahmed
                                    .......Connected!
                                    IP: 192.168.0.31
                                    0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                                    0;0;3;0;9;ver mismatch
                                    I obtained the code for gateway & MySensors from MySensors repository on github.
                                    what would be the problem now?
                                    • R
                                      R
                                      ridge
                                      wrote on last edited by ridge
                                      #91
                                      I would like to use this tutorial for MySensors in the openHAB program:
                                      http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
                                      I have the ESP8266 WiFi gateway working over a telnet session in Putty.
                                      Is there a way to have openHAB communicate over telnet like a hardwired serial interface?
                                      Has anyone used this yet?
                                      https://github.com/openhab/openhab/pull/2832
                                      • R ridge
                                        @ridge sorry, can't help with that. Everything's MQTT over here :-)
                                        • R
                                          R
                                          ridge
                                          Thanks! Are you using this gateway with a controller or is it a proof of concept?
                                          It is fun to watch the states respond in a telnet session. I am having trouble finding any mention on how to use this with a controller.
