  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 398.0k Views 39 Watching
  • DrJeffD
    DrJeffD
    DrJeff
    @hek Yes I tried those but it's probably the driver install it was acting a little finicky so it was quicker to flip over to the VM. :)
    • F
      F
      fleinze
      @DrJeff
      I remember that there was an error in the boardmanager-package for MacOS. You need to change the file-permissions to executable:
      sudo chmod +x ~/Library/Arduino15/packages/esp8266/tools/esptool/0.4.4/esptool
      • rvendrameR
        rvendrameR
        rvendrame
        wrote on last edited by rvendrame
        #67
        I followed the steps above, and I'm even able to upload sketches, however I only get this in serial monitor:
        Bad module maybe?
        EDIT: After choosing the right board (v.1.0) and applying the fix above from @fleinze, it seems it is working now...
        ESP8266 GW + mySensors 2.3.2
        Alexa / Google Home
        • K
          K
          krajcl
          wrote on last edited by krajcl
          #68
          I'm having problems running ESP8266 gateway. When I reset my nodes or trying send command from controller to node (dimmer, realy etc.) my gateway reset itself. I try using different ESP-s (I'm using ESP-12), power supplys and radio modules.
          On serial monitor I get this error:
          • K krajcl
            #69
            @krajcl What catches my eye is the client command echoed by the gateway: "Client 0: 44;255;3;0;6;"
            The 0 at the end seems to be missing -- This could be a gateway issue (are you using the standard ESP gateway sketch, or did you make any modifications?) which causes e.g. the command parser to crash.
            Could you give a more detailed description of your setup? Which controller are you using, what does the network look like (nr. of sensors, repeaters etc.).
            • K
              K
              krajcl
              @Yveaux I'm using standard ESP gateway sketch (I reinstalled Arduino IDE, download latest mysensors library). At the moment I'm using MYSController as controler (for testing), I only have one node active (standard humidity sketch - only changed node id).
              • K krajcl
                @krajcl The last command from the controller seems to be a response to the sensor to indicate metric or imperial units are used (internal command 6). The payload should be either 'M' or 'I'.
                I'm not familiar with MYSController, but is there some setting influencing the unit system? Can you check if it has a valid value?
                I can't replay the situation right now, so anything you can do yourself to track the problem would really help.
                • K
                  K
                  krajcl
                  @Yveaux This is result with Domoticz as controller and new node (relay), same result:
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    I'm definitely not a expert at all on the topic, but could it be that a ftdi-usb adapter doesn't provide enough power to ESP, and it eventually hangs when wi-fi transmissions drawn too much power? (according to the specs, ~150mA when transmitting) .
                    Just trying to help with some (probably dumb) brainstorming. ;-)
                    Alexa / Google Home
                    • G
                      G
                      gmccarthy
                      wrote on last edited by gmccarthy
                      #74
                      Do you need to the NodeMCU to implement this?
                      I have an arduino uno and ESP-01. How do I wire these up?
                      After doing some more reading looks like the esp-01 does not have enough pins. Dont think I can use it :(
                      • K krajcl
                        S 1 Reply Last reply
                        • K
                          K
                          krajcl
                          @Yveaux I tried function (clear routing table) in MYSConroller. This is result:
                          Client 0: 0;0;3;0;10;C
                          Client 0: 6;0;3;0;10;C
                          ctx: cont
                          sp: 3ffeabe0 end: 3ffeaf20 offset: 01b0
                          When I try this function for gateway, evrything works fine, but for other nodes - gateway resets
                          • K krajcl
                            ctx: cont
                            @krajcl When this message is addressed to the gateway (0;0;3;0;10;C) it does not get sent over the air by the radio.
                            When you send it to node 6 (6;0;3;0;10;C), it will send the message to the node, using the radio.
                            Can you please answer this: Will it crash with just any message sent to the nodes using the radio, or only when sending internal messages to nodes (internal messages to nodes have the first value unequal to 0 and the third value set to 3, like 6;x;3;x;x;x) ?
                            • K
                              K
                              krajcl
                              @Yveaux it doesn't matter, what I send, resets every time
                              • K krajcl
                                @krajcl Ah, ok! That helps!
                                For me, and a lot of other people on this forum, sending messages just works with the ESP.
                                Maybe @rvendrame is pointing in the right direction? How are you powering the ESP?
                                • AndurilA
                                  AndurilA
                                  Anduril
                                  Is it possible to set a fixed IP adress and bypass DHCP? My router sometimes messes up his DHCP-table and reassigns all adresses. Then I would have to correct the IP in my controller which I want to avoid.
                                  • AndurilA Anduril
                                    @Anduril The ESP8266 Arduino port uses the same API as the standard Arduino WiFi library.
                                    This means you should be able to use WiFi.config() to set a fixed IP address.
                                    Change the following line in Esp8266Gateway.ino
                                      (void)WiFi.begin(ssid, pass);
                                    into something like (untested!):
                                      IPAddress ip(192, 168, 0, 123);  /* Set to whatever IP address you'd like the gateway to have */
                                      WiFi.config(ip);
                                    Please report back your experience!
                                    • sowardS
                                      sowardS
                                      soward
                                      I got this working on an 0.9 version of the nodeMCU ( the Yellow board ). It has some code upload issues, which are slightly worse on OS X than Linux, but usually a couple of tries with holding down the button as @hek mentioned usually does the trick. I do not have any TCP/IP clients pointed at it currently, but I also get lots of watch dog timer resets, which seem somewhat random, as it will run and log messages for somewhere between 15 mins and 10 hours.
                                      It is just being powered by USB and I have not swapped NRF modules yet, so one of those may likely be the culprit, but just wanted to chime in with a (mostly) successful setup.
                                      thanx
                                      • K
                                        K
                                        kimnguu204
                                        wrote on last edited by kimnguu204
                                        #83
                                        Hello all,
                                        is there anybody setup MQTT gateway and it's working fine? how many node wifi gateway can handle?
                                        Could you please share me Wifi MQTT Gateway code.
                                        Thank you all and have a nice day
                                        • K kimnguu204
                                          Hello all,
                                          Currently there is no MQTT WiFi gateway, but it shouldn't be very hard to create one by combining the WiFi Gateway with the MQTT gateway.
                                          The same as any other MySensors gateway (around 250).
