relay motion domoticz help
    i ḿ trying to make my own sketch. using a sketch form domoticz.com has a working relay. i'm trying to implement a motion sensor with no luck so far. can anybody help me?
    here s my sketch;
    // Example sketch showing how to control physical relays.
    // This example will remember relay state even after power failure.
    #define RELAY_1 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 0 // GPIO value to write to turn on attached relay
    #define CHILD_ID 1 // Id of the sensor child
    #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
    bool state;
    bool value;
    MyMessage msg(1,V_LIGHT);
    gw.sendSketchInfo("RelayDoMoticz", "1.0");
    // Fetch relay status
    gw.present(sensor, V_LIGHT);
    pinMode(pin, OUTPUT);
    digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
    gw.sendSketchInfo("Motion Sensor", "1.0");
    pinMode(DIGITAL_INPUT_SENSOR, INPUT); // sets the motion sensor digital pin as input
    gw.present(CHILD_ID, S_MOTION);
    if (message.type==V_LIGHT) {
    // Change relay state
    // Store state in eeprom
    // Read digital motion value
    Serial.println(tripped);
    gw.send(msg.set(tripped?"1":"0")); // Send tripped value to gw
  • @floris I have got it working!!!!!using a motion/relay sketch from the forum.
    Floris
  • it might be that this line
    should be changed to
    gw.present(sensor, S_LIGHT);
  • hello, I search for a code for 2 pir sensor and relay 2
      it exists?
  • @floris can you post the final sketch you used? I am having the same issue.
  • 11
