  3. How To - Doorbell Automation Hack
106 Posts 29 Posters 128.8k Views 26 Watching
  • D
    drock1985
    Well, I got it to work. Had to add a gw.send command to the code. The below is for the original 1 door chime that @petewill has created. I have added the code to make this compatible with Domoticz.
     * Version 1.0 - PeteWill
     * This sketch is used to control a doorbell ring with a relay as well as send an
     * alert when the buttons is pressed.  Connect the button to ground and digital
     * pin 3.  The relay controlling the doorbell is conntected to pin 4.
     * Watch the How To video here: https://youtu.be/nMIcalwpstc
     * Version 1.1 - ResentedPoet
     * Added gw.send command so that if doorbellDetect variable was active, it would send V_TRIPPED
     * to the motion sensor controlling the doorbell. Necessary for Domoticz compatibility
    #define NODE_ID AUTO // or set to AUTO if you want gw to assign a NODE_ID for you.
    #define DOORBELL_PIN  3      // Arduino Digital I/O pin number for the doorbell button
    #define RELAY_PIN  4         // Arduino Digital I/O pin number for the relay
    #define DOORBELL_CHILD_ID 0  //ID of the doorbell
    #define SWITCH_CHILD_ID 1    // Id of the switch that will control doorbell sound
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    MyMessage switchMsg(SWITCH_CHILD_ID, V_LIGHT);
    MyMessage doorbellMsg(DOORBELL_CHILD_ID, V_TRIPPED);
    unsigned int doorbellDelay = 1000; // interval at which to keep the doorbell button sensor triggered (milliseconds). This is used to stop people (kids) from pressing it too often
    unsigned int ringTime = 700; //How long the doorbell relay is on (in milliseconds)
    unsigned long doorbellMillis;  //Used to keep track of the last doorbell button press
    unsigned long doorbellTimer;  //Used to keep track of doorbell ring time
    byte doorbellPreviousVal;  //Used to keep track of doorbell button pressed state
    boolean ringDoorbell;  //Used to initiate the ring doorbell if statement
    boolean doorbellSound; //Used to keep track if the doorbell should sound or be silent.  Value recieved from doorbell on/off switch
    boolean doorbellOff = true;  //Used to keep track of doorbell ring state
      gw.begin(incomingMessage, NODE_ID);
      gw.sendSketchInfo("Doorbell Monitor", "1.0");
      // Setup the button and activate internal pull-up
      pinMode(DOORBELL_PIN, INPUT_PULLUP);
      debouncer.attach(DOORBELL_PIN);
      debouncer.interval(5);
      gw.present(SWITCH_CHILD_ID, S_LIGHT);
      gw.present(DOORBELL_CHILD_ID, S_MOTION);
      pinMode(RELAY_PIN, OUTPUT);
      // Set doorbellSound to last known state (using eeprom storage)
      doorbellSound = gw.loadState(SWITCH_CHILD_ID);
      //Check to see if doorbell button was pushed.
      if (currentMillis - doorbellMillis > doorbellDelay) //used to stop doorbell from being pressed too frequently
        debouncer.update();
        // Read doorbell button value
        byte doorbellDetect = !debouncer.read();//read, then reverse the value so it will send correct trigger state to controller
        if (doorbellDetect != doorbellPreviousVal)
          //Serial.print("doorbellDetect Value: ");
          //Serial.println(doorbellDetect);
          if (doorbellDetect == 1)
            ringDoorbell = true;
            doorbellTimer = currentMillis;
            gw.send(doorbellMsg.set(doorbellDetect?"1":"0"));  // Send tripped value to gw
          doorbellMillis = currentMillis;
          doorbellPreviousVal = doorbellDetect;
      if (ringDoorbell)
        if (doorbellSound)
          if (doorbellOff)
            digitalWrite(RELAY_PIN, RELAY_ON);
            //Serial.println("Doorbell sounded.");
            doorbellOff = false;
            if (currentMillis - doorbellTimer > ringTime)
              ringDoorbell = false;
              //Serial.println("Doorbell off.");
              doorbellOff = true;
      void incomingMessage(const MyMessage & message) {
        if (message.isAck()) {
          // Change relay state
          doorbellSound = message.getBool();
          // Store state in eeprom
          gw.saveState(SWITCH_CHILD_ID, doorbellSound);
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • D
      drock1985
      This is the output from Serial Monitor now on the doorchime controller.
      req id
      read: 0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0:8
      send: 8-8-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
      send: 8-8-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
      read: 0-0-8 s=255,c=3,t=6,pt=0,l=1,sg=0:M
      id=8
      sensor started, id=8, parent=0, distance=1
      send: 8-8-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:Doorbell Monitor
      send: 8-8-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
      send: 8-8-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
      send: 8-8-0-0 s=0,c=0,t=1,pt=0,l=0,sg=0,st=ok:
      send: 8-8-0-0 s=0,c=1,t=16,pt=0,l=1,sg=0,st=ok:1
      read: 0-0-8 s=1,c=1,t=2,pt=0,l=1,sg=0:1
      Incoming change for sensor:1, New status: 1
      read: 0-0-8 s=1,c=1,t=2,pt=0,l=1,sg=0:0
      Incoming change for sensor:1, New status: 0
      My Projects
      2 Door Chime Sensor
      • T
        timropp
        wrote on last edited by timropp
        #39
        So got my doorbell up and working. Here's the details: I used the mini RBoard and it's working out great.
        I soldered the cap directly onto the nrf board. Unfortunately, that board overhangs the A0 connections on the rboard (there's 2 pins there, one is the A0 pin and one is a ground). Thankfully, it only ACTUALLY covered the ground, so it was easy to work around. The brown wire in the photo is the wire I have connected to the A0 pin. The green wire is a temp wire I was connecting to the ground in the serial connections.
        In the doorbell, I cut away one of the panels over one of the resonant chambers since I saw that the module would fit in there perfectly. I then wired it up and tucked it away. I did lose a little volume since the chamber is filled rather than resonating, but it's worth it to have the doorbell notifying my Vera system. That can flash lights and so forth to notify us other ways - we couldn't usually hear the doorbell when downstairs anyway.
        Code wise, I used the original code above with just a couple minor changes. I set the doorbell_pin to A0, the relay_pin to 4, and the node_ID to auto. I also set it to act as a repeater since it's hardwired to power. Now that I have it working, I wish I'd changed the ringTime to a lower value since 7/10 of a second is way longer than the doorbell normally takes between the two notes, but it's not a big deal. Not worth pulling the board out, disconnecting it, reprogramming it, and reinstalling everything :-)
        VeraEdge UI7 with Mysensors ethernet gateway
        • T
          timropp
          My wiring:
          I discovered that they ran 4 conductor wire from the transformer in the basement to this location. So I plugged a phone charger in near the transformer, cut the end off a USB cable, and connected the 5V and gnd wires from that USB cable to the spare 2 wires in the cable. So then there's 6 wires coming into the doorbell as shown here: 2 for 16VAC from the transformer, 2 for 5VDC from the phone charger, and 2 from the doorbell button. I then connected the 5V pair to the top pair of screw terminals in the photo on the rboard. They're the blue and green wires. The white wire in the top terminal is one side of the button, connecting to ground there. The second side of the button is the red wire going into the grey wire nut. The brown wire coming out of the nut connects to the A0 pin on the board. Finally, the 2 16VAC wires are red and white. The red goes over to the right terminal on the plunger mechanism. The white goes to the common terminal on the rboard's relay connections. Finally, a black wire connects the NO from the relay to the other side of the plunger.
          Hopefully that was all clear for anyone wanting to wire up their own!
          • A
            arjen
            Hello all,
            I'm trying to hook this doorbell sensor up, what I've found is that when I connect it, I must connect it to NC. The downside is that when I reset the Arduino, the doorbell keeps ringing until pin4 is pulled up. How can I change that in the sketch?
            Also I can ring it once, it rings and then it stops working. Connection to the gateway is lost and it won't ring either.
            been trying to fix it for 3 days now, but I can't seem to figure out what I've done wrong.
            Hooked up pin 4 to the input pin of the relay. The relay is directly powered by 5v coming from a usb hub with 2A.
            The Arduino is powered using the same 5V, with a regulator to the radio to give it 3.3V. Connected a 4.7uF cap directly on the radio.
            When I reset the arduino this comes to the gateway:
            0;0;3;0;9;read: 16-16-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
            0;0;3;0;9;read: 16-16-0 s=255,c=3,t=11,pt=0,l=16,sg=0:Doorbell Monito
            0;0;3;0;9;read: 16-16-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
            0;0;3;0;9;read: 16-16-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
            0;0;3;0;9;read: 16-16-0 s=0,c=0,t=1,pt=0,l=0,sg=0:
            0;0;3;0;9;read: 16-16-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
            0;0;3;0;9;send: 0-0-16-16 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
            I can connect perfectly to the gateway using MyMQTT on Android so I think it is failing on the side of the doorbell any help would be greatly appreciated!
            petewillP 1 Reply Last reply
            • korttomaK
              korttomaK
              korttoma
              For the NC problem change:
              #define RELAY_ON 1
              #define RELAY_OFF 0
              to:
              #define RELAY_ON 0
              #define RELAY_OFF 1
              • Tomas
              korttomaK 1 Reply Last reply
              • A arjen
                Hello all,
                petewillP
                petewillP
                petewill
                @arjen That's strange. You shouldn't need to connect it to NC. That means you are normally sending power to your doorbell unless it is rung. Are you sure you have the wires from your doorbell correct? You may want to double check them with a multimeter.
                • A
                  arjen
                  Just to make sure I've took some photo's.
                  When I take a multimeter and place it on the bottom two wires of the trafo I get zero rating. doorbel.jpg
                  There is no difference between blue and red, neither does it make a difference if I change the wires in what ever way. Tried all possibilities I can think of.
                    You know that it is AC current coming out of that power supply right?
                    • A
                      arjen
                      Yeah i know. Does it matter? It's seperated by the relay from the rest right?
                      Or am I saying something stupid here.... :confused:
                      • A arjen
                        petewillP
                        petewillP
                        petewill
                        @arjen Can you post pictures of the rest of the wiring? It's still strange that you have to have it connected to normally closed. That is most likely why your doorbell is ringing when it's first powered on.
                        • A
                          arjen
                          Sure, no prob.
                          This is the relay, at the moment a 6 port, didn't had a one port available.
                          The green wire is connected to IN1 on the relay and pin4 on the arduino.
                          the backside of the print. The bottom row 'S' is pin 9 on the arduino, 'M' and 'K' is pin3 and Ground to doorbellbutton.
                          front side. The brown and blue on the left are 5V to the relay, on the right red and blue are input doorbellbutton.
                          • korttomaK korttoma
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            to:
                            #define RELAY_ON 0
                            #define RELAY_OFF 1
                            korttomaK
                            korttomaK
                            korttoma
                            Did you try my suggestion?
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            to:
                            #define RELAY_ON 0
                            #define RELAY_OFF 1
                            • Tomas
                            • petewillP
                              petewillP
                              petewill
                              Yeah, try @korttoma's suggestion. If that doesn't work, can you post a pic of the relay connections (all)?
                              • D
                                drock1985
                                Huh, I have the same problem as @arjen is describing too, the only difference is i'm using a 2x raly vs. his 4. I don't have an issue with the relay being on, since my node is always powered on, the pull always goes high. Might just change it in the code/wiring though when I get the Arduino IDE working again.
                                Quick question: do you have the relay board powered by the Arduino, or another 5V source?
                                My Projects
                                2 Door Chime Sensor
                                • A
                                  arjen
                                  Made the changes to the sketch as suggested, and now I can connect it to NO.
                                  Just to make sure I didn't made a mistake while soldering, used a fresh nano and made all connections again. In the sketch the changes still need to be made, however as far as i could test this morning all is working fine now!
                                  Thanks for all the tips!
                                  The relay is powered by the same powersource as the arduino (6 port powered usb hub 2A).
                                  • D drock1985
                                    petewillP
                                    petewillP
                                    petewill
                                    @drock1985 the relay should be powered by the same 5v power source as the Arduino but not from the arduino. It can draw too much power and cause issues when connected to the arduino.
                                    @arjen Great! I just noticed the selection pin (can't think of the correct name right now) on your relay. I wonder if switching that would allow you to use the original code as well as the NO connections?
                                    • N
                                      N
                                      Newzwaver
                                      Excellent project, great work.. So I need to pick your mind.... I have a doorbell that can change music and volume. I hope to be able to fully control it by zwave using this app with Vera...Any ideas.....
                                      • N Newzwaver
                                        petewillP
                                        petewillP
                                        petewill
                                        @Newzwaver Hmm. I doubt this would work for you to fully control it but you may still be able to trigger it. How do you control it now? Through an app or something?
                                        • Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          Hello all - sorry I have been away for so long...
                                          This bring back memories http://forum.mysensors.org/topic/1620/mysensored-doorbell
                                          I wish I found a way of triggering the notification from the ring and not the other way around, as this way when something happen to your arduino the doorbell will not ring. Didn't happen yet - it works perfectly for 6 months but I would feel more relaxed if it was the other way around. Oh well...
