  3. 110v-230v AC to Mysensors PCB board
269 Posts 63 Posters 345.6k Views 68 Watching
  • AWIA AWI
    @shabba Right... if you look at the schematics upload-a10f80dc-0eda-4c4b-aa49-e0bbc6f827a8 you can see that the two capacitors can be swapped without consequences
    shabba
    @AWI Thanks! Very true!
    • m26872M m26872
      @bjornhallberg Maybe I've missed reading something, but why use a varistor for 5 Vdc and not a zener diode?
      bjornhallbergB
      bjornhallbergB
      bjornhallberg
      @m26872 You're probably right, I just followed the BOM. I'll see if I can stock up on some diodes from AliExpress for future use.
      • korttomaK
        korttomaK
        korttoma
        #116
        Whould a 5.1V zener work?
        edit: removed the link to the product so that no one would buy it the specs of it is to tight to be used with HLK.
        • Tomas
        m26872M 1 Reply Last reply
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          Just a stupid question, the "G3MB-202P DC-AC PCB SSR In 5VDC,Out 240V AC 2A " What happens if I forget and plug something more power-hungry like a toaster or a microwave-owen? does any of the fuses blow or does the relay break ?
          • korttomaK
            korttomaK
            korttoma
            there is no fuse on the relay switch so I guess either the PCB or the relay will fail.
            • Tomas
            • m26872M
              m26872M
              m26872
              I've seen commercial products with a thermal fuse glued to the switching side of the relay. Maybe that would help some in such situation.
              • korttomaK korttoma
                m26872M
                m26872M
                m26872
                wrote on last edited by m26872
                #120
                @korttoma A 5.1V zener is probably too tight. The HLK seems rated 5+/-0.2V.
                • m26872M m26872
                  bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  @m26872 Indeed, mine is 5.08V (with no load). I ordered some 5.1V and 5.6V 1206 SMD diodes from Ali for future use. Plus some 3.6V. And a set of DIP diodes.
                  rvendrameR 1 Reply Last reply
                    rvendrameR
                    rvendrameR
                    rvendrame
                    Just to remember, the typical zeners are 1W , which gives a max of 200mA of output capacity, pretty enough for Arduino+radio, but maybe not enough for many relays / Leds etc. And if they burn due overload, they will allow all voltage/current flowing from PSU into arduino.
                    That explains why we suggested the varistor, in order to short the PSU output and trigger its internal protection. Strange that your varistors didn't survive... Bad lot? Maybe they are not 5.5V as stated?
                    ESP8266 GW + mySensors 2.3.2
                    Alexa / Google Home
                    • rvendrameR rvendrame
                      m26872M
                      m26872M
                      m26872
                      @rvendrame
                      No.
                      The zener will only lead current during over voltage condition and only needs to dissapate enough energy till one of your (multiple?) over current protection trips. Just as your varistor setup is supposed to work.
                      • m26872M m26872
                        @rvendrame
                        No.
                        rvendrameR
                        rvendrameR
                        rvendrame
                        @m26872 , is it also true in case the PSU itself fail? And what happens if the circuit consumes more current than zener rating? I'm my (poor) knowledge, zeners are more relevant for stabilization, while varistor are effective 'protection' devices...
                        Alexa / Google Home
                        • M mvdarend
                          I spoke too soon... the unit seems to work well, but I hadn't tested if the relay actually switched or not. The status seems to change fine in the serial monitor, but it doesn't seem to be actually switching. I'll have to do some more troubleshooting.
                          shabba
                          @mvdarend You discover your issue with the relay?
                            m26872M
                            m26872M
                            m26872
                            @rvendrame
                            since we're discussing the PSU secondary side (output side), I think we already presume errors with the PSU. A fuse (over current protection) on the secondary is not just there as a back-up if the PSU internal over current protection fails. The fuse will also prevent your over voltage protection (zener, varistor, ...) from overload/burn/start a fire.
                            The current from PSU to load will not pass through the zener and hence the rating is irrelevant from that perspective. In other applications where a zener is used as voltage regulator, the full load current will pass through the zener when in idleing and then the rating is critical.
                            korttomaK 1 Reply Last reply
                            • m26872M m26872
                              @rvendrame
                              korttomaK
                              korttomaK
                              korttoma
                              @m26872 so how do we need to rate the zener? Should the zener be rated so that the fuse will blow before the zener brakes from the current it passes due to an over voltage situation? Or is it OK that the zener brakes to as long as it takes out the fuse first. Then an automatic fuse will no longer work.
                              • Tomas
                              • S shabba
                                mvdarend
                                Sorry, since that post I tried a few small things. But then I got caught up in other projects/work/family :) and haven't had time time to look into it further.
                                  m26872M
                                  m26872M
                                  m26872
                                  #129
                                  @korttoma Good questions. As always a trade-off of risk, cost, space, taste, etc. They should already be answered in the varistor case though. Personally I think it's overkill with additional overvoltage protection at the low volt secondary side of a good quality PSU and an inexpensive load - fuse, capacitors and regulators should be more than enough. Focus should be the primary side protections.
                                  Edit: Btw. Found some reading. See p.44
                                  • bjornhallbergB
                                    bjornhallbergB
                                    bjornhallberg
                                    Just a quick post to confirm I got the relays working as well (with Domoticz). I didn't read the schematic at first and just assumed how the mains and relay external wiring should be done. Still no idea about the smoking varistor.
                                    S 1 Reply Last reply
                                      shabba
                                      I thought all my relays were shot as I was not getting continuity on the load pins when I applied 5V. I checked resistance and there is just over 2K when 5V applied and infinite when none. I am going to put back together assuming the 240V A/C will pass through just fine.
                                        shabba
                                        What would cause no power to VCC when connected to mains (even though there is 5V at end of HLK-PM01) - if I bring that 5V with a jumper to VCC it works. Also works fine when connected to the serial port - Bad DC varistor?
                                        • korttomaK
                                          korttomaK
                                          korttoma
                                          #133
                                          @shabba
                                          The only thing between the HLK-PM01 and VCC is Fuse2. Check the Schematic. But yes a shorted varistor will in the combination with the fuse bring VCC to 0V. I experienced this also since the 5.5V varistors I bought from the link in the documentation (Ali seller Unionup Electronic Mall) did not work.
                                          Seems like there is quite many of us that are having problems with the 5.5V varistors. I measured a few from my batch and they all show 0.4ohm with a multimeter, should they not have something like infinite resistance unless they get more then the 5.5V? My multimeter gives 0.6V when it measures resistance.
                                          • Tomas
                                          RJ_MakeR 1 Reply Last reply
