  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.9k Views 36 Watching
    msantang
    wrote on last edited by msantang
    #31
    I got it working on my rb2 but i got 100% of cpu ussage.
    I read a lot of post about this but i cant found a solution.
    Some one know how to fix this?
    OitzuO 1 Reply Last reply
    • J jpbabou
      Hi
      something is missing..
      Is there a problem with the repository
      Tks a lot for your job!
      pi@domoticjp ~ $ sudo git clone https://github.com/mysensors/Raspberry.git
      Cloning into 'Raspberry'...
      remote: Counting objects: 273, done.
      remote: Compressing objects: 100% (3/3), done.
      remote: Total 273 (delta 0), reused 0 (delta 0), pack-reused 270
      Receiving objects: 100% (273/273), 215.00 KiB | 0 bytes/s, done.
      Resolving deltas: 100% (114/114), done.
      Checking connectivity... done.
      pi@domoticjp ~ $ cd Raspberry/librf24-bcm
      -bash: cd: Raspberry/librf24-bcm: No such file or directory
      alexsh1A
      alexsh1A
      alexsh1
      @jpbabou said:
      Hi
      Please go ahead and install the rf24 library from https://github.com/TMRh20/RF24
      The rest should be the same
      • M msantang
        OitzuO
        OitzuO
        Oitzu
        wrote on last edited by Oitzu
        #33
        The 100% cpu usage is probably due to the style of receiving new messages from rf24/serial port.
        The current state is that the PiSerialGateway tries to poll data in a endless loop from rf24/serial.
        This could maybe fixed with using the interrupt of the nrf24l01+ to signal new data and reading data from the serial in blocking mode.
        I want to solve this but using interrupts on the RPi isn't that trivial.
        • mfalkviddM
          http://forum.mysensors.org/topic/2367/pigatewayserial-using-interrupts/2 has information on how to use interrupts. I haven't tried it myself though.
            OitzuO
            OitzuO
            Oitzu
            Oh yeah, thanks for the hint @Bens got the exact same problem and seem to solved the rf24 part already. I hope he gets back online and shares his results. :)
            • D
              den2k
              Hi all,
              I'm following this thread and have upgraded to MySensors v1.5 and get the following error. Version mismatch.
              It looks like the Protocol version is 1.4.
              Does the Raspberry MySensors Gateway support v1.5 or only v1.4? Any ideas on how to fix?
              upload-27647566-60ff-4341-97aa-4d1186e5e670
              alexsh1A 1 Reply Last reply
              • D den2k
                Hi all,
                alexsh1A
                alexsh1A
                alexsh1
                @den2k said:
                Hi all,
                Up until now, MySensors v1.4 only for nrf24l01+ direct connection.
                Did you upgrade the GW or the sensors or both ?
                D 1 Reply Last reply
                  Protocol version hasn't changed since 1.4
                  https://github.com/mysensors/Raspberry/blob/master/MyMessage.h#L41
                  So you must have some other problem.. As you can see you only get zeroes in the log...
                  • GertSandersG
                    GertSandersG
                    GertSanders
                    #39
                    You can "fake" a later version (e.g, 1.5) on the Raspberry by changing the version code in the version.h file and recompiling the Gateway software.
                    As far as I understand, the gateway will still pass the messages to the controller, even is there is a version mismatch message on the console.
                    • alexsh1A alexsh1
                      @den2k said:
                      Hi all,
                      den2k
                      @alexsh1 I know the sensors are on v1.5. As for the Raspberry Gateway, it looks like based on the info here, that is running v1.4.
                        den2k
                        @hek I'm running a custom 1Mhz build bootloader on a Pro Mini for the Sensor side. This was paired with the standard Serial Gateway running on another Pro Mini with v1.5 on both gateway and sensor. That setup was working. But I moved over to using the Pi gatway+nRF24+ radio and have this issue. I don't believe the hookup is the problem. I've seen the 0 readings before, and that usually meant node side issue or uninitiated Gateway. I have not changed the Node, so it must be the Pi gateway that is the problem. Any thoughts on what to test?
                        • D
                          den2k
                          Noob question. Any one have an idea on solving the "Permission denied" error.
                          upload-a7ed9c85-5b6b-4198-af00-909e1861374e
                          • D
                            den2k
                            Solved my own problem. Using the following command did the trick.
                            sudo chown -h pi:pi ttyUSB20
                            • D
                              den2k
                              weird. Permission Denied problem again.
                              What is the USER : GROUP that is needed for this to work?
                              • mfalkviddM
                                @den2k I think your best chance is to post in the Home Assistant category. I don't have any experience with Home Assistant unfortunately.
                                • J jpbabou
                                  Hi
                                  @jpbabou said:
                                  Hi
                                  The guide has been updated to reflect the updated in the MySensors Raspberry repository now. Thanks @jpbabou !
                                  • D den2k
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    #47
                                    @den2k
                                    Hi!
                                    Have you added the user that runs homeassistant to the dialout group? This group is usually owner of serial ports.
                                    Check default group of serial port (change for your port below) after connecting it:
                                    pi@martin-pi:~ $ ls -l /dev/ttyUSB0
                                    crw-rw---- 1 root dialout 188, 0 dec 18 03:21 /dev/ttyUSB0
                                    Check groups that user pi is in:
                                    pi@martin-pi:~ $ groups pi
                                    pi : pi adm dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio
                                    If pi runs homeassistant, which should be the case, and is not in dialout, add pi to dialout:
                                    sudo adduser pi dialout
                                    Changing owner of a port will only work until you disconnect it. Default owner will be restored upon reconnect, if you haven't written a special udev rule.
                                    Edit:
                                    According to the readme in the mysensors raspberry repo (https://github.com/mysensors/Raspberry), the group of the device is tty. So you should probably use that, and not dialout. But you will know, when you check with ls -l.
                                      Note: This guide is only applicable to MySensors 1.x. For MySensors 2, use this guide.
                                      I noticed that a step-by-step procedure to connect the NRF24L01 to the GPIO pins and use the Raspberry as a Serial Gateway was listed in the document for MySensors 1.6.
                                      Since I have three gateways configured this way, and I need to set up 3 more for covering different offices around the world, and I had already written the instructions in Swedish for Datormagazin, I thought I'd help out.
                                      This is the first draft. Any feedback is welcome.
                                      INTRODUCTION
                                      The radio module NRF24L01+ is cheap and power efficient, but it is unable to communicate with regular wifi. The bridge between NRF24L01+ nodes and the "computer world" is called a Gateway. You can use other types of gateways, but connecting the NRF24L01+ module directly to the Raspberry Pi is a simple and cheap alternative.
                                      Wiring Things Up
                                      Connect the NRF20L01+ radio module to the Raspberry Pi like this:
                                      Raspberry Pi NRF24L01+ Color
                                      6 / GND GND Black
                                      1 / 3.3V DC VCC Red
                                      22 / GPIO25 CE Orange
                                      24 / GPIO 8 CSN/CS Yellow
                                      23 / GPIO11 / SPI_CLK SCK Green
                                      19 / GPIO10 / SPI_MOSI MOSI Blue
                                      21 / GPIO9 / SPI_MISO MISO Violet
                                      The IRQ pin on NRF24L01 is not currently used.
                                      For a comprehensive view of the Raspberry Pi pins, see http://pinout.xyz/
                                      You should also connect a decoupling capacitor to the radio. See this guide.
                                      COMPILING THE GATEWAY
                                      Login to your Raspberry Pi (using SSH or open a terminal on the graphical console) and run these commands:
                                      git clone https://github.com/TMRh20/RF24.git
                                      cd RF24
                                      make all && sudo make install
                                      cd ..
                                      cd Raspberry
                                      If you get the following error:
                                      pi@raspberrypi ~/RF24 $ make all && sudo make install
                                      g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c RF24.cpp
                                      gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c bcm2835.c
                                      bcm2835.c: In function ‘bcm2835_init’:
                                      bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
                                      You've probably run into the problem discussed in this thread. People have had luck with different solutions. The simplest is to make the following change to ~/Raspberry/librf24-bcm/Makefile
                                      #IOBASE := $(shell cat /proc/iomem | grep bcm2708_vcio | cut -f 1 -d "-")
                                      IOBASE := 3F000000
                                      VERIFY THE GATEWAY
                                      Run sudo /usr/local/sbin/PiGatewaySerial. The output should look like this:
                                      pi@raspberrypi ~/Raspberry $ sudo /usr/local/sbin/PiGatewaySerial
                                      Starting PiGatewaySerial...
                                      Protocol version - 1.4
                                      Created PTY '/dev/pts/1'
                                      Gateway tty: /dev/ttyMySensorsGateway
                                      ================ SPI Configuration ================
                                      CSN Pin          = CE0 (PI Hardware Driven)
                                      CE Pin           = Custom GPIO25
                                      Clock Speed      = 8 Mhz
                                      ================ NRF Configuration ================
                                      STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                                      RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
                                      RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                                      TX_ADDR          = 0xe7e7e7e7e7
                                      RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
                                      EN_AA            = 0x3b
                                      EN_RXADDR        = 0x07
                                      RF_CH            = 0x4c
                                      RF_SETUP         = 0x23
                                      CONFIG           = 0x0e
                                      DYNPD/FEATURE    = 0x3f 0x06
                                      Data Rate        = 250KBPS
                                      Model            = nRF24L01+
                                      CRC Length       = 16 bits
                                      PA Power         = PA_LOW
                                      If the NRF24L01+ isn't correctly wired, the following error will be shown
                                      pi@raspberrypi ~ $ sudo /usr/local/sbin/PiGatewaySerial
                                      Created PTY '/dev/pts/2'
                                      check wires
                                      If this happens, double-check your wiring and correct any problems. Press Ctrl+Z and type
                                      sudo killall PiGatewaySerial
                                      to get rid of the non-functioning Gateway. Then run sudo /usr/local/sbin/PiGatewaySerial again
                                      If all is well, exit PiGatewaySerial by pressing Ctrl+C. Then run
                                      sudo /etc/init.d/PiGatewaySerial start
                                      to start the gateway as a background process. Verify that it started correctly by running
                                      sudo cat /dev/ttyMySensorsGateway
                                      You should see the message "Gateway startup complete". Exit by typing Ctrl+C.
                                      MAKE THE GATEWAY AUTOSTART
                                      To make sure the Gateway is started when your Raspberry Pi boots up, run the following command:
                                      sudo make enable-gwserial
                                      Enable the gateway for use with Domoticz
                                      Domoticz (and maybe other home automation systems) has trouble reading from the default path created by PiGatewaySerial. You might need to run the following command:
                                      sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                                      And change /etc/rc.local from this
                                      exit 0
                                      to this
                                      exit 0
                                      OTHER NOTES
                                      • The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required. If you use an external power source gnd must be connected to the Raspberry Pi's gnd.
                                      • Connecting the NRF24L01+ directly to your Raspberry Pi will prevent you from using the Raspberry Pi's gpio ports for other things, like a Z-wave board.
                                      • A user experienced slow data transfer compared to USB-to-Serial(ttl)<-->MySensors Gateway connection, especially on OTA firmware update. If you think this will cause a problem for you, an ethernet gateway might be a better alternative.
                                      As always, I stand on the shoulders of giants. Related posts:
                                      • http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
                                      • http://forum.mysensors.org/topic/1974/domoticz-as-controller-and-a-gateway-for-mysensor-nodes-running-on-a-raspberry-pi-2
                                      TROUBLESHOOTING
                                      If you get this error
                                      pi@Domoticz3:~/Raspberry$ sudo /etc/init.d/PiGatewaySerial start
                                      [....] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.serviceFailed to start PiGatewaySerial.service: Unit PiGatewaySerial.service failed to load: No such file or directory.
                                       failed!
                                      or this error
                                      sudo: /usr/local/sbin/PiGatewaySerial: command not found
                                      you have probably forgotten to run sudo make install. Read the instructions again, and follow them this time :-) User @sineverba reported that a reboot of the Pi after running make install helped.
                                      Scala
                                      @mfalkvidd Hi there and thanks for a great and super detailed step-by-step tutorial.
                                      I've got mine running in no time with your instructions, but after a couple of minutes I've got the following error:
                                      2015-12-30 20:51:30.356 Error: MySensors: Unhandled sensor (sub-type=32), please report with log!
                                      2015-12-30 20:52:01.390 Error: Serial Port closed!... Error: End of file
                                      2015-12-30 20:52:02.315 MySensors: retrying in 30 seconds...
                                      2015-12-30 20:52:31.319 MySensors: Using serial port: /dev/ttyUSB20
                                      2015-12-30 20:52:31.320 Error: MySensors: Error opening serial port!
                                      2015-12-30 20:52:32.321 MySensors: retrying in 30 seconds...
                                      2015-12-30 20:53:01.324 MySensors: Using serial port: /dev/ttyUSB20
                                      I also attached a partial screen capture showing that it was working before 8-)
                                      Any idea on why is this happening and how to solve it?
                                      Southern regards and happy new year to all!
                                      ronnyandreR 1 Reply Last reply
                                      • mfalkviddM
                                        You are using a sensor type that your version of Domoticz doesn't support. What type os sensor is it? Which version of Domoticz are you using? Upgrading Domoticz might solve the problem (if the newer version supports this sub-type).
                                        • Sander TeunissenS
                                          Sander TeunissenS
                                          Sander Teunissen
                                          When I try to run the init.d script:
                                          I get the following error:
                                           failed!
                                          No such file or directory.... Obviously a missing folder or file, but I am not savvy enough to debug this.... Any help appreciated..
